[U-Boot] [PATCH] armv7m: Add SysTick timer driver
The SysTick is a 24-bit down counter that is found on all ARM Cortex M3, M4, M7 devices and is always located at a fixed address.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com --- arch/arm/cpu/armv7m/Makefile | 2 + arch/arm/cpu/armv7m/systick-timer.c | 91 +++++++++++++++++++++++++++++++++++++ 2 files changed, 93 insertions(+) create mode 100644 arch/arm/cpu/armv7m/systick-timer.c
diff --git a/arch/arm/cpu/armv7m/Makefile b/arch/arm/cpu/armv7m/Makefile index aff60e8..e1a6c40 100644 --- a/arch/arm/cpu/armv7m/Makefile +++ b/arch/arm/cpu/armv7m/Makefile @@ -7,3 +7,5 @@
extra-y := start.o obj-y += cpu.o + +obj-$(CONFIG_SYS_ARCH_TIMER) += systick-timer.o diff --git a/arch/arm/cpu/armv7m/systick-timer.c b/arch/arm/cpu/armv7m/systick-timer.c new file mode 100644 index 0000000..6ccc2fb --- /dev/null +++ b/arch/arm/cpu/armv7m/systick-timer.c @@ -0,0 +1,91 @@ +/* + * ARM Cortex M3/M4/M7 SysTick timer driver + * (C) Copyright 2017 Renesas Electronics Europe Ltd + * + * Based on arch/arm/mach-stm32/stm32f1/timer.c + * (C) Copyright 2015 + * Kamil Lulko, kamil.lulko@gmail.com + * + * Copyright 2015 ATS Advanced Telematics Systems GmbH + * Copyright 2015 Konsulko Group, Matt Porter mporter@konsulko.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* SysTick Base Address - fixed for all Cortex M3, M4 and M7 devices */ +#define SYSTICK_BASE 0xE000E010 + +struct cm3_systick { + uint32_t ctrl; + uint32_t reload; + uint32_t val; + uint32_t calibration; +}; + +#define TIMER_LOAD_VAL 0x00FFFFFF +#define SYSTICK_CTRL_EN BIT(0) +/* Clock source: 0 = Ref clock, 1 = CPU clock */ +#define SYSTICK_CTRL_CPU_CLK BIT(2) + +/* read the 24-bit timer */ +static ulong read_timer(void) +{ + struct cm3_systick *systick = (struct cm3_systick *)SYSTICK_BASE; + + /* The timer counts down, therefore convert to an incrementing timer */ + return TIMER_LOAD_VAL - readl(&systick->val); +} + +int timer_init(void) +{ + struct cm3_systick *systick = (struct cm3_systick *)SYSTICK_BASE; + + writel(TIMER_LOAD_VAL, &systick->reload); + writel(TIMER_LOAD_VAL, &systick->val); + +#ifdef CONFIG_ARMCORTEXM3_SYSTICK_CPU + /* Use CPU clock, no interrupts */ + writel(SYSTICK_CTRL_EN | SYSTICK_CTRL_CPU_CLK, &systick->ctrl); +#else + /* Use external clock, no interrupts */ + writel(SYSTICK_CTRL_EN, &systick->ctrl); +#endif + + gd->arch.tbl = 0; + gd->arch.tbu = 0; + gd->arch.lastinc = read_timer(); + + return 0; +} + +/* return milli-seconds timer value */ +ulong get_timer(ulong base) +{ + unsigned long long t = get_ticks() * 1000; + + return (ulong)((t / CONFIG_SYS_HZ_CLOCK)) - base; +} + +unsigned long long get_ticks(void) +{ + u32 now = read_timer(); + + if (now >= gd->arch.lastinc) + gd->arch.tbl += (now - gd->arch.lastinc); + else + gd->arch.tbl += (TIMER_LOAD_VAL - gd->arch.lastinc) + now; + + gd->arch.lastinc = now; + + return gd->arch.tbl; +} + +ulong get_tbclk(void) +{ + return CONFIG_SYS_HZ_CLOCK; +}
- ARM Cortex M3/M4/M7 SysTick timer driver
- (C) Copyright 2017 Renesas Electronics Europe Ltd
- Based on arch/arm/mach-stm32/stm32f1/timer.c
- (C) Copyright 2015
- Kamil Lulko, kamil.lulko@gmail.com
- Copyright 2015 ATS Advanced Telematics Systems GmbH
- Copyright 2015 Konsulko Group, Matt Porter mporter@konsulko.com
- uint32_t ctrl;
- uint32_t reload;
- uint32_t val;
- uint32_t calibration;
- struct cm3_systick *systick = (struct cm3_systick *)SYSTICK_BASE;
- /* The timer counts down, therefore convert to an incrementing timer */
- return TIMER_LOAD_VAL - readl(&systick->val);
- writel(TIMER_LOAD_VAL, &systick->reload);
- writel(TIMER_LOAD_VAL, &systick->val);
- /* Use CPU clock, no interrupts */
- writel(SYSTICK_CTRL_EN | SYSTICK_CTRL_CPU_CLK, &systick->ctrl);
+#else
- /* Use external clock, no interrupts */
- writel(SYSTICK_CTRL_EN, &systick->ctrl);
- gd->arch.tbl = 0;
- gd->arch.tbu = 0;
- gd->arch.lastinc = read_timer();
- unsigned long long t = get_ticks() * 1000;
- return (ulong)((t / CONFIG_SYS_HZ_CLOCK)) - base;
- u32 now = read_timer();
- if (now >= gd->arch.lastinc)
- else
- gd->arch.lastinc = now;
- return gd->arch.tbl;
- return CONFIG_SYS_HZ_CLOCK;
And (cc'ing maintainers) we could use this in place of arch/arm/mach-stm32/*/timer.c I assume, yes? Thanks!
uint32_t ctrl;
uint32_t reload;
uint32_t val;
+#else
gd->arch.tbl = 0;
gd->arch.tbu = 0;
else
-- Tom
Yes, however as far as I remember the systick is only 24-bit and usually runs on CPU clock so it will roll over too fast to be useful without using interrupts. Maybe I have missed something?
/Kamil
Hi Kamil,
uint32_t ctrl;
uint32_t reload;
uint32_t val;
+#else
gd->arch.tbl = 0;
gd->arch.tbu = 0;
else
-- Tom
Yes, it is only a 24-bit counter. On the device I am using, the clock is not the cpu clock, but a low speed clock at 6.25MHz. Even at that low clock it will still wrap every ~2.6 seconds.
/Kamil
Thanks Phil
On Tue, Feb 07, 2017 at 02:19:39PM +0000, Phil Edworthy wrote:
Hi Kamil,
uint32_t ctrl;
uint32_t reload;
uint32_t val;
+#else
gd->arch.tbl = 0;
gd->arch.tbu = 0;
else
-- Tom
So are you able to use the timer then, given the quick overflow?
Hi Tom,
Hi Kamil,
uint32_t ctrl;
uint32_t reload;
uint32_t val;
+#else
gd->arch.tbl = 0;
gd->arch.tbu = 0;
else
-- Tom
Yes, I didn't see any problems. All of the udelay/mdelay calls should work because they resolve to constantly calling get_ticks.
I guess it will not work if you attempt to time something that is longer than 2.6 seconds though.
Thanks Phil
Hi Phil,
-----Original Message----- From: Phil Edworthy [mailto:phil.edworthy@renesas.com] Sent: Tuesday, February 07, 2017 6:34 AM To: Tom Rini trini@konsulko.com Cc: Kamil Lulko kamil.lulko@gmail.com; Vikas MANOCHA vikas.manocha@st.com; Michael Kurz michi.kurz@gmail.com; Albert Aribaud albert.u.boot@aribaud.net; U-Boot Mailing List u-boot@lists.denx.de Subject: RE: [U-Boot] [PATCH] armv7m: Add SysTick timer driver
Hi Tom,
Hi Kamil,
uint32_t ctrl;
uint32_t reload;
uint32_t val;
+#define TIMER_LOAD_VAL 0x00FFFFFF +#define SYSTICK_CTRL_EN BIT(0) +/* Clock source: 0 = Ref clock, 1 = CPU clock */ #define +SYSTICK_CTRL_CPU_CLK BIT(2)
+/* read the 24-bit timer */ +static ulong read_timer(void) {
+*)SYSTICK_BASE;
- incrementing timer
return TIMER_LOAD_VAL - readl(&systick->val); }
+*)SYSTICK_BASE;
+&systick->ctrl); #else
writel(SYSTICK_CTRL_EN, &systick->ctrl); #endif
gd->arch.tbl = 0;
gd->arch.tbu = 0;
+/* return milli-seconds timer value */ ulong get_timer(ulong +base) {
return (ulong)((t / CONFIG_SYS_HZ_CLOCK)) - base; }
+unsigned long long get_ticks(void) {
else
return CONFIG_SYS_HZ_CLOCK; }
-- Tom
Hmm, I wish it had some way to increase overflow time...it doesn't have the pre-scalar to divide the clock..
As this timer is same for all cortex-Mx, It makes sense to use this timer for stm32 and other cortexMx. I didn't check calibration register : could it be useful here ?
Cheers, Vikas
Thanks Phil
Hi Vikas,
On 12 February 2017 21:10, Vikas MANOCHA wrote:
Hi Phil,
Albert Aribaud albert.u.boot@aribaud.net; U-Boot Mailing List <u-
boot@lists.denx.de>
Hi Tom,
Hi Kamil,
> The SysTick is a 24-bit down counter that is found on all ARM > Cortex M3, M4, M7 devices and is always located at a fixed address. > > Signed-off-by: Phil Edworthy phil.edworthy@renesas.com > --- > arch/arm/cpu/armv7m/Makefile | 2 + > arch/arm/cpu/armv7m/systick-timer.c | 91
> 2 files changed, 93 insertions(+) create mode 100644 > arch/arm/cpu/armv7m/systick-timer.c > > diff --git a/arch/arm/cpu/armv7m/Makefile
> index aff60e8..e1a6c40 100644 > --- a/arch/arm/cpu/armv7m/Makefile > +++ b/arch/arm/cpu/armv7m/Makefile > @@ -7,3 +7,5 @@ > > extra-y := start.o > obj-y += cpu.o > + > +obj-$(CONFIG_SYS_ARCH_TIMER) += systick-timer.o > diff --git a/arch/arm/cpu/armv7m/systick-timer.c
> new file mode 100644 > index 0000000..6ccc2fb > --- /dev/null > +++ b/arch/arm/cpu/armv7m/systick-timer.c > @@ -0,0 +1,91 @@ > +/* > + * ARM Cortex M3/M4/M7 SysTick timer driver > + * (C) Copyright 2017 Renesas Electronics Europe Ltd > + * > + * Based on arch/arm/mach-stm32/stm32f1/timer.c > + * (C) Copyright 2015 > + * Kamil Lulko, kamil.lulko@gmail.com > + * > + * Copyright 2015 ATS Advanced Telematics Systems GmbH > + * Copyright 2015 Konsulko Group, Matt Porter
> + * > + * SPDX-License-Identifier: GPL-2.0+ > + */ > + > +#include <common.h> > +#include <asm/io.h> > + > +DECLARE_GLOBAL_DATA_PTR; > + > +/* SysTick Base Address - fixed for all Cortex M3, M4 and M7 devices
> +#define SYSTICK_BASE 0xE000E010 > + > +struct cm3_systick { > + uint32_t ctrl; > + uint32_t reload; > + uint32_t val; > + uint32_t calibration; > +}; > + > +#define TIMER_LOAD_VAL 0x00FFFFFF > +#define SYSTICK_CTRL_EN BIT(0) > +/* Clock source: 0 = Ref clock, 1 = CPU clock */ #define > +SYSTICK_CTRL_CPU_CLK BIT(2) > + > +/* read the 24-bit timer */ > +static ulong read_timer(void) { > + struct cm3_systick *systick = (struct cm3_systick > +*)SYSTICK_BASE; > + > + /* The timer counts down, therefore convert to an > + incrementing timer
> + return TIMER_LOAD_VAL - readl(&systick->val); } > + > +int timer_init(void) > +{ > + struct cm3_systick *systick = (struct cm3_systick > +*)SYSTICK_BASE; > + > + writel(TIMER_LOAD_VAL, &systick->reload); > + writel(TIMER_LOAD_VAL, &systick->val); > + > +#ifdef CONFIG_ARMCORTEXM3_SYSTICK_CPU > + /* Use CPU clock, no interrupts */ > + writel(SYSTICK_CTRL_EN | SYSTICK_CTRL_CPU_CLK, > +&systick->ctrl); #else > + /* Use external clock, no interrupts */ > + writel(SYSTICK_CTRL_EN, &systick->ctrl); #endif > + > + gd->arch.tbl = 0; > + gd->arch.tbu = 0; > + gd->arch.lastinc = read_timer(); > + > + return 0; > +} > + > +/* return milli-seconds timer value */ ulong get_timer(ulong > +base) { > + unsigned long long t = get_ticks() * 1000; > + > + return (ulong)((t / CONFIG_SYS_HZ_CLOCK)) - base; } > + > +unsigned long long get_ticks(void) { > + u32 now = read_timer(); > + > + if (now >= gd->arch.lastinc) > + gd->arch.tbl += (now - gd->arch.lastinc); > + else > + gd->arch.tbl += (TIMER_LOAD_VAL - > + gd->arch.lastinc) + now; > + > + gd->arch.lastinc = now; > + > + return gd->arch.tbl; > +} > + > +ulong get_tbclk(void) > +{ > + return CONFIG_SYS_HZ_CLOCK; }
-- Tom
seconds though.
Hmm, I wish it had some way to increase overflow time...it doesn't have the pre- scalar to divide the clock..
None that I could find.
It could be used to get the clock rate, though you would need a fall back in case the calibration reg is wrong or indicates an inexact 10ms value.
Thanks Phil
Cheers, Vikas
Thanks Phil
Hi Phil,
-----Original Message----- From: Tom Rini [mailto:trini@konsulko.com] Sent: Sunday, February 05, 2017 3:17 PM To: Phil Edworthy phil.edworthy@renesas.com; Vikas MANOCHA vikas.manocha@st.com; Michael Kurz michi.kurz@gmail.com Cc: Albert Aribaud albert.u.boot@aribaud.net; u-boot@lists.denx.de; Kamil Lulko kamil.lulko@gmail.com Subject: Re: [U-Boot] [PATCH] armv7m: Add SysTick timer driver
- uint32_t ctrl;
- uint32_t reload;
- uint32_t val;
This register is current timer value, write of any value clears it. Rename to cur_val would avoid any confusion.
- return TIMER_LOAD_VAL - readl(&systick->val); }
use mask to be sure of 24bit timer counter value.
Writing load value gives the impression that it is load register, in fact it is only clearing countflag.
Cortex M3 systick has only cpu clock source ?
Cheers, Vikas
+#else
- writel(SYSTICK_CTRL_EN, &systick->ctrl); #endif
- gd->arch.tbl = 0;
- gd->arch.tbu = 0;
+/* return milli-seconds timer value */ ulong get_timer(ulong base) {
- return (ulong)((t / CONFIG_SYS_HZ_CLOCK)) - base; }
- else
-- Tom
Hi Vikas,
- uint32_t ctrl;
- uint32_t reload;
- uint32_t val;
Ok, though I'm not sure that cur_val is any clearer :)
Why? It's a 24-bit timer, the other bits are always zero.
Ok
No, it can have cpu clock or another clock external to the M3 core. In our case we use the external clock because it is much slower than the cpu clock, making the timer usable without interrupts. I can't imagine anyone using the cpu clock unless they add code to handle the interrupt. I'll add a comment to that effect.
Thanks Phil
Cheers, Vikas
+#else
- gd->arch.tbl = 0;
- gd->arch.tbu = 0;
- else
-- Tom
Kamil Lulko
Phil Edworthy
Vikas MANOCHA
