[PATCH] firmware: scmi: correct a validity check against power domain id
A power domain id on sandbox should be in the range from zero to ARRAY_SIZE(scmi_pwdom) - 1. Correct the validity check logic.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org Fixes: CID 467401 Fixes: CID 467405 --- drivers/firmware/scmi/sandbox-scmi_agent.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/firmware/scmi/sandbox-scmi_agent.c b/drivers/firmware/scmi/sandbox-scmi_agent.c index 9f5f497e0a6c..d13180962662 100644 --- a/drivers/firmware/scmi/sandbox-scmi_agent.c +++ b/drivers/firmware/scmi/sandbox-scmi_agent.c @@ -576,7 +576,7 @@ static int sandbox_scmi_pwd_attribs(struct udevice *dev, struct scmi_msg *msg) domain_id = *(u32 *)msg->in_msg; out = (struct scmi_pwd_attrs_out *)msg->out_msg;
- if (domain_id > ARRAY_SIZE(scmi_pwdom)) { + if (domain_id >= ARRAY_SIZE(scmi_pwdom)) { out->status = SCMI_NOT_FOUND;
return 0; @@ -613,7 +613,7 @@ static int sandbox_scmi_pwd_state_set(struct udevice *dev, struct scmi_msg *msg) in = (struct scmi_pwd_state_set_in *)msg->in_msg; status = (s32 *)msg->out_msg;
- if (in->domain_id > ARRAY_SIZE(scmi_pwdom)) { + if (in->domain_id >= ARRAY_SIZE(scmi_pwdom)) { *status = SCMI_NOT_FOUND;
return 0; @@ -653,7 +653,7 @@ static int sandbox_scmi_pwd_state_get(struct udevice *dev, struct scmi_msg *msg) domain_id = *(u32 *)msg->in_msg; out = (struct scmi_pwd_state_get_out *)msg->out_msg;
return 0; @@ -686,7 +686,7 @@ static int sandbox_scmi_pwd_name_get(struct udevice *dev, struct scmi_msg *msg) domain_id = *(u32 *)msg->in_msg; out = (struct scmi_pwd_name_get_out *)msg->out_msg;
AKASHI Takahiro
