[PATCH 00/12] dm: Expand of-platdata support to GPIOs and clean up
The of-platdata feature allows driver model to be used in SPL without the overhead of a devicetree. The relevant parts of the devicetree are converted to C by the dtoc tool.
So far of-platdata supports various drivers but not enough to support the am335x boards.
This series adds GPIO support to of-platdata, via a gpio_request_by_phandle() function which looks up GPIOs from the of-platdata information.
It also tidies up the existing clock support and finishes off irq support.
Finally it includes a new OF_REAL symbol to control whether a devicetree is actually available at runtime. This allows some simplification of the #ifdef logic.
For am335x, the cpsw driver uses several devicetree subnodes. For this to work with dtoc it needs to be converted to separate drivers for each subnode, each with a compatible string.
Simon Glass (12): treewide: fdt: Move fdt_get_config_... to ofnode_conf_read... fdt: Create a new OF_REAL Kconfig treewide: Simply conditions with the new OF_REAL treewide: Use OF_REAL instead of !OF_PLATDATA mmc: nds32: ftsdc010: Convert to livetree treewide: Try to avoid the preprocessor with OF_REAL fdt: Update Makefile rules with the new OF_REAL Kconfig dm: Add comments to dt-structs contents clk: Rename clk_get_by_driver_info() dm: doc: Add a note about of-platdata header files irq: Tidy up of-platdata irq support dm: gpio: Add of-platdata support
Makefile | 7 +- arch/arm/mach-rockchip/rk3188/rk3188.c | 4 +- arch/arm/mach-rockchip/rk3399/syscon_rk3399.c | 2 +- arch/arm/mach-rockchip/rk3568/syscon_rk3568.c | 2 +- arch/sandbox/dts/sandbox.dtsi | 21 +++++- arch/sandbox/dts/test.dts | 3 + arch/sandbox/include/asm/irq.h | 20 ++++++ arch/x86/cpu/apollolake/hostbridge.c | 4 +- arch/x86/cpu/apollolake/lpc.c | 2 +- arch/x86/cpu/apollolake/pch.c | 2 +- arch/x86/cpu/apollolake/pmc.c | 4 +- arch/x86/cpu/apollolake/uart.c | 2 +- arch/x86/cpu/coreboot/coreboot.c | 5 +- arch/x86/cpu/intel_common/itss.c | 2 +- arch/x86/cpu/intel_common/p2sb.c | 24 +++---- arch/x86/lib/lpc-uclass.c | 2 +- arch/x86/lib/tpl.c | 2 +- board/dhelectronics/dh_stm32mp1/board.c | 5 +- board/firefly/firefly-rk3288/firefly-rk3288.c | 4 +- board/google/chromebook_coral/coral.c | 2 +- board/sandbox/sandbox.c | 5 +- board/st/stm32mp1/stm32mp1.c | 5 +- common/autoboot.c | 8 +-- common/board_r.c | 4 +- common/cli.c | 7 +- common/spl/spl.c | 2 +- common/spl/spl_spi.c | 12 ++-- configs/sandbox_noinst_defconfig | 2 + configs/sandbox_spl_defconfig | 2 + disk/part_efi.c | 8 +-- doc/develop/driver-model/of-plat.rst | 32 +++++++-- doc/device-tree-bindings/config.txt | 4 +- drivers/clk/clk-uclass.c | 15 ++-- drivers/clk/clk_fixed_factor.c | 18 ++--- drivers/clk/clk_fixed_rate.c | 7 +- drivers/clk/rockchip/clk_px30.c | 4 +- drivers/clk/rockchip/clk_rk3188.c | 8 +-- drivers/clk/rockchip/clk_rk3288.c | 10 +-- drivers/clk/rockchip/clk_rk3308.c | 4 +- drivers/clk/rockchip/clk_rk3368.c | 10 +-- drivers/clk/rockchip/clk_rk3399.c | 20 +++--- drivers/core/device.c | 4 +- drivers/core/fdtaddr.c | 2 +- drivers/core/lists.c | 2 +- drivers/core/ofnode.c | 33 +++++++++ drivers/core/root.c | 4 +- drivers/core/simple-bus.c | 2 +- drivers/core/syscon-uclass.c | 2 +- drivers/core/uclass.c | 2 +- drivers/core/util.c | 2 +- drivers/firmware/firmware-uclass.c | 2 +- drivers/gpio/Makefile | 4 +- drivers/gpio/gpio-uclass.c | 28 +++++++- drivers/gpio/intel_gpio.c | 2 +- drivers/gpio/mxs_gpio.c | 4 +- drivers/gpio/omap_gpio.c | 4 +- drivers/gpio/sandbox.c | 14 ++-- drivers/gpio/sandbox_test.c | 21 ++++++ drivers/i2c/i2c-emul-uclass.c | 2 +- drivers/i2c/i2c-uclass.c | 10 +-- drivers/i2c/omap24xx_i2c.c | 4 +- drivers/misc/Makefile | 2 +- drivers/misc/cros_ec.c | 2 +- drivers/misc/irq-uclass.c | 10 ++- drivers/misc/irq_sandbox.c | 15 +--- drivers/misc/irq_sandbox_test.c | 22 ++++++ drivers/misc/misc-uclass.c | 2 +- drivers/misc/p2sb-uclass.c | 20 +++--- drivers/mmc/fsl_esdhc_imx.c | 17 ++--- drivers/mmc/ftsdc010_mci.c | 45 ++++++------ drivers/mmc/mxsmmc.c | 4 +- drivers/mmc/omap_hsmmc.c | 6 +- drivers/mmc/rockchip_dw_mmc.c | 8 ++- drivers/mmc/rockchip_sdhci.c | 14 ++-- drivers/pch/pch-uclass.c | 2 +- drivers/pinctrl/intel/pinctrl_apl.c | 4 +- drivers/pinctrl/nxp/pinctrl-mxs.c | 2 +- drivers/pinctrl/pinctrl-qe-io.c | 2 +- drivers/pinctrl/pinctrl-uclass.c | 2 +- drivers/pinctrl/rockchip/pinctrl-px30.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3036.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3128.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3188.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk322x.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3288.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3308.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3328.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3368.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3399.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rv1108.c | 2 +- drivers/power/domain/power-domain-uclass.c | 4 +- drivers/ram/rockchip/dmc-rk3368.c | 12 ++-- drivers/ram/rockchip/sdram_rk3188.c | 5 +- drivers/ram/rockchip/sdram_rk322x.c | 5 +- drivers/ram/rockchip/sdram_rk3288.c | 5 +- drivers/ram/rockchip/sdram_rk3328.c | 4 +- drivers/ram/rockchip/sdram_rk3399.c | 9 +-- drivers/rtc/rtc-uclass.c | 2 +- drivers/serial/ns16550.c | 8 +-- drivers/serial/sandbox.c | 2 +- drivers/serial/serial_mt7620.c | 4 +- drivers/serial/serial_omap.c | 6 +- drivers/spi/cf_spi.c | 4 +- drivers/spi/davinci_spi.c | 4 +- drivers/spi/fsl_espi.c | 4 +- drivers/spi/ich.c | 6 +- drivers/spi/mxs_spi.c | 4 +- drivers/spi/omap3_spi.c | 4 +- drivers/spi/pl022_spi.c | 4 +- drivers/spi/rk_spi.c | 38 +++++------ drivers/spi/spi-uclass.c | 14 ++-- drivers/sysreset/sysreset_sandbox.c | 2 +- drivers/timer/rockchip_timer.c | 16 ++--- drivers/timer/timer-uclass.c | 68 ++++++++++--------- drivers/timer/tsc_timer.c | 2 +- drivers/tpm/tpm-uclass.c | 2 +- drivers/video/cfb_console.c | 4 +- drivers/video/exynos/exynos_mipi_dsi.c | 4 +- drivers/watchdog/wdt-uclass.c | 2 +- dts/Kconfig | 29 +++++++- env/mmc.c | 5 +- include/asm-generic/gpio.h | 5 ++ include/clk.h | 35 ++++++++-- include/dm/device.h | 12 ++-- include/dm/ofnode.h | 37 ++++++++++ include/dt-structs.h | 27 ++++++++ include/fdtdec.h | 33 --------- include/irq.h | 29 ++++++++ include/power-domain.h | 6 +- lib/Makefile | 5 +- lib/fdtdec.c | 44 ------------ scripts/Makefile.spl | 9 +-- test/dm/of_platdata.c | 65 ++++++++++++++++-- test/dm/ofnode.c | 15 ++++ tools/dtoc/dtb_platdata.py | 1 + 135 files changed, 783 insertions(+), 477 deletions(-) create mode 100644 arch/sandbox/include/asm/irq.h create mode 100644 drivers/gpio/sandbox_test.c create mode 100644 drivers/misc/irq_sandbox_test.c
The current API is outdated as it requires a devicetree pointer.
Move these functions to use the ofnode API and update this globally. Add some tests while we are here.
Correct the call in exynos_dsim_config_parse_dt() which is obviously wrong.
arch/arm/mach-rockchip/rk3188/rk3188.c | 4 +- arch/sandbox/dts/test.dts | 3 ++ arch/x86/cpu/coreboot/coreboot.c | 5 +-- board/dhelectronics/dh_stm32mp1/board.c | 5 ++- board/firefly/firefly-rk3288/firefly-rk3288.c | 4 +- board/st/stm32mp1/stm32mp1.c | 5 ++- common/autoboot.c | 8 ++-- common/board_r.c | 4 +- common/cli.c | 7 ++- common/spl/spl_spi.c | 8 ++-- disk/part_efi.c | 8 ++-- doc/device-tree-bindings/config.txt | 4 +- drivers/core/ofnode.c | 33 ++++++++++++++ drivers/video/cfb_console.c | 4 +- drivers/video/exynos/exynos_mipi_dsi.c | 4 +- env/mmc.c | 5 ++- include/dm/ofnode.h | 37 ++++++++++++++++ include/fdtdec.h | 33 -------------- lib/fdtdec.c | 44 ------------------- test/dm/ofnode.c | 15 +++++++ 20 files changed, 124 insertions(+), 116 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3188/rk3188.c b/arch/arm/mach-rockchip/rk3188/rk3188.c index ad8c6cd1d79..5a02914e1b0 100644 --- a/arch/arm/mach-rockchip/rk3188/rk3188.c +++ b/arch/arm/mach-rockchip/rk3188/rk3188.c @@ -15,6 +15,7 @@ #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/grf_rk3188.h> #include <asm/arch-rockchip/hardware.h> +#include <dm/ofnode.h> #include <linux/err.h>
#define GRF_BASE 0x20008000 @@ -107,7 +108,6 @@ int rk_board_late_init(void) }
#ifdef CONFIG_SPL_BUILD -DECLARE_GLOBAL_DATA_PTR; static int setup_led(void) { #ifdef CONFIG_SPL_LED @@ -115,7 +115,7 @@ static int setup_led(void) char *led_name; int ret;
- led_name = fdtdec_get_config_string(gd->fdt_blob, "u-boot,boot-led"); + led_name = ofnode_conf_read_str("u-boot,boot-led"); if (!led_name) return 0; ret = led_get_by_label(led_name, &dev); diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index d5976318d1c..77d54e39d73 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -53,6 +53,9 @@ };
config { + testing-bool; + testing-int = <123>; + testing-str = "testing"; environment { from_fdt = "yes"; fdt_env_path = ""; diff --git a/arch/x86/cpu/coreboot/coreboot.c b/arch/x86/cpu/coreboot/coreboot.c index 69cf8f417c7..aaa5ae112e4 100644 --- a/arch/x86/cpu/coreboot/coreboot.c +++ b/arch/x86/cpu/coreboot/coreboot.c @@ -16,8 +16,7 @@ #include <asm/mtrr.h> #include <asm/cb_sysinfo.h> #include <asm/arch/timestamp.h> - -DECLARE_GLOBAL_DATA_PTR; +#include <dm/ofnode.h>
int arch_cpu_init(void) { @@ -65,7 +64,7 @@ static void board_final_init(void) mtrr_close(&state, true); }
- if (!fdtdec_get_config_bool(gd->fdt_blob, "u-boot,no-apm-finalize")) { + if (!ofnode_conf_read_bool("u-boot,no-apm-finalize")) { /* * Issue SMI to coreboot to lock down ME and registers * when allowed via device tree diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index d7c1857c168..4b3167f69d2 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -42,6 +42,7 @@ #include <usb.h> #include <usb/dwc2_udc.h> #include <watchdog.h> +#include <dm/ofnode.h> #include "../../st/common/stpmic1.h"
/* SYSCFG registers */ @@ -382,10 +383,10 @@ int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) #ifdef CONFIG_LED static int get_led(struct udevice **dev, char *led_string) { - char *led_name; + const char *led_name; int ret;
- led_name = fdtdec_get_config_string(gd->fdt_blob, led_string); + led_name = ofnode_conf_read_str(led_string); if (!led_name) { pr_debug("%s: could not find %s config string\n", __func__, led_string); diff --git a/board/firefly/firefly-rk3288/firefly-rk3288.c b/board/firefly/firefly-rk3288/firefly-rk3288.c index 41c49e5daa7..95d8b00924d 100644 --- a/board/firefly/firefly-rk3288/firefly-rk3288.c +++ b/board/firefly/firefly-rk3288/firefly-rk3288.c @@ -8,9 +8,9 @@ #include <led.h> #include <log.h> #include <asm/global_data.h> +#include <dm/ofnode.h>
#ifdef CONFIG_SPL_BUILD -DECLARE_GLOBAL_DATA_PTR; static int setup_led(void) { #ifdef CONFIG_SPL_LED @@ -18,7 +18,7 @@ static int setup_led(void) char *led_name; int ret;
- led_name = fdtdec_get_config_string(gd->fdt_blob, "u-boot,boot-led"); + led_name = ofnode_conf_read_str("u-boot,boot-led"); if (!led_name) return 0; ret = led_get_by_label(led_name, &dev); diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 59fb6e548c0..1a217c0e7e7 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -37,6 +37,7 @@ #include <asm/gpio.h> #include <asm/arch/stm32.h> #include <asm/arch/sys_proto.h> +#include <dm/ofnode.h> #include <jffs2/load_kernel.h> #include <linux/bitops.h> #include <linux/delay.h> @@ -231,10 +232,10 @@ int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name)
- led_name = fdtdec_get_config_string(gd->fdt_blob, led_string); + led_name = ofnode_conf_read_str(led_string); if (!led_name) { log_debug("could not find %s config string\n", led_string); return -ENOENT; diff --git a/common/autoboot.c b/common/autoboot.c index 5bb2e190895..6251c683108 100644 --- a/common/autoboot.c +++ b/common/autoboot.c @@ -24,6 +24,7 @@ #include <u-boot/sha256.h> #include <bootcount.h> #include <crypt.h> +#include <dm/ofnode.h>
@@ -424,12 +425,12 @@ static void process_fdt_options(const void *blob) ulong addr;
/* Add an env variable to point to a kernel payload, if available */ - addr = fdtdec_get_config_int(gd->fdt_blob, "kernel-offset", 0); + addr = ofnode_conf_read_int("kernel-offset", 0); if (addr) env_set_addr("kernaddr", (void *)(CONFIG_SYS_TEXT_BASE + addr));
/* Add an env variable to point to a root disk, if available */ - addr = fdtdec_get_config_int(gd->fdt_blob, "rootdisk-offset", 0); + addr = ofnode_conf_read_int("rootdisk-offset", 0); if (addr) env_set_addr("rootaddr", (void *)(CONFIG_SYS_TEXT_BASE + addr)); #endif /* CONFIG_SYS_TEXT_BASE */ @@ -446,8 +447,7 @@ const char *bootdelay_process(void) bootdelay = s ? (int)simple_strtol(s, NULL, 10) : CONFIG_BOOTDELAY;
if (IS_ENABLED(CONFIG_OF_CONTROL)) - bootdelay = fdtdec_get_config_int(gd->fdt_blob, "bootdelay", - bootdelay); + bootdelay = ofnode_conf_read_int("bootdelay", bootdelay);
debug("### main_loop entered: bootdelay=%d\n\n", bootdelay);
diff --git a/common/board_r.c b/common/board_r.c index e3e6248a1fd..68d3b1fb1ce 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -67,6 +67,7 @@ #endif #include <asm/sections.h> #include <dm/root.h> +#include <dm/ofnode.h> #include <linux/compiler.h> #include <linux/err.h> #include <efi_loader.h> @@ -448,8 +449,7 @@ static int initr_pvblock(void) static int should_load_env(void) { if (IS_ENABLED(CONFIG_OF_CONTROL)) - return fdtdec_get_config_int(gd->fdt_blob, - "load-environment", 1); + return ofnode_conf_read_int("load-environment", 1);
if (IS_ENABLED(CONFIG_DELAY_ENVIRONMENT)) return 0; diff --git a/common/cli.c b/common/cli.c index 048eacb9ef9..d86046a728b 100644 --- a/common/cli.c +++ b/common/cli.c @@ -19,8 +19,7 @@ #include <hang.h> #include <malloc.h> #include <asm/global_data.h> - -DECLARE_GLOBAL_DATA_PTR; +#include <dm/ofnode.h>
#ifdef CONFIG_CMDLINE /* @@ -157,7 +156,7 @@ int do_run(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) bool cli_process_fdt(const char **cmdp) { /* Allow the fdt to override the boot command */ - char *env = fdtdec_get_config_string(gd->fdt_blob, "bootcmd"); + const char *env = ofnode_conf_read_str("bootcmd"); if (env) *cmdp = env; /* @@ -165,7 +164,7 @@ bool cli_process_fdt(const char **cmdp) * Always use 'env' in this case, since bootsecure requres that the * bootcmd was specified in the FDT too. */ - return fdtdec_get_config_int(gd->fdt_blob, "bootsecure", 0) != 0; + return ofnode_conf_read_int("bootsecure", 0); }
/* diff --git a/common/spl/spl_spi.c b/common/spl/spl_spi.c index 9884e7c1850..f92ce37384c 100644 --- a/common/spl/spl_spi.c +++ b/common/spl/spl_spi.c @@ -16,8 +16,7 @@ #include <errno.h> #include <spl.h> #include <asm/global_data.h> - -DECLARE_GLOBAL_DATA_PTR; +#include <dm/ofnode.h>
#ifdef CONFIG_SPL_OS_BOOT /* @@ -104,9 +103,8 @@ static int spl_spi_load_image(struct spl_image_info *spl_image, header = spl_get_load_buffer(-sizeof(*header), sizeof(*header));
#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) - payload_offs = fdtdec_get_config_int(gd->fdt_blob, - "u-boot,spl-payload-offset", - payload_offs); + payload_offs = ofnode_conf_read_int("u-boot,spl-payload-offset", + payload_offs); #endif
#ifdef CONFIG_SPL_OS_BOOT diff --git a/disk/part_efi.c b/disk/part_efi.c index fdca91a6974..0ca7effc327 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -23,12 +23,11 @@ #include <malloc.h> #include <memalign.h> #include <part_efi.h> +#include <dm/ofnode.h> #include <linux/compiler.h> #include <linux/ctype.h> #include <u-boot/crc.h>
-DECLARE_GLOBAL_DATA_PTR; - #ifdef CONFIG_HAVE_BLOCK_DEVICE
/* GUID for basic data partitons */ @@ -563,9 +562,8 @@ static uint32_t partition_entries_offset(struct blk_desc *dev_desc) * from the start of the device) to be specified as a property * of the device tree '/config' node. */ - config_offset = fdtdec_get_config_int(gd->fdt_blob, - "u-boot,efi-partition-entries-offset", - -EINVAL); + config_offset = ofnode_conf_read_int( + "u-boot,efi-partition-entries-offset", -EINVAL); if (config_offset != -EINVAL) { offset_bytes = PAD_TO_BLOCKSIZE(config_offset, dev_desc); offset_blks = offset_bytes / dev_desc->blksz; diff --git a/doc/device-tree-bindings/config.txt b/doc/device-tree-bindings/config.txt index 6cdc16da5b5..d53b0aa3347 100644 --- a/doc/device-tree-bindings/config.txt +++ b/doc/device-tree-bindings/config.txt @@ -2,8 +2,8 @@ The /config node (Configuration Options) ----------------------------------------
A number of run-time configuration options are provided in the /config node -of the control device tree. You can access these using fdtdec_get_config_int(), -fdtdec_get_config_bool() and fdtdec_get_config_string(). +of the control device tree. You can access these using ofnode_conf_read_int(), +ofnode_conf_read_bool() and ofnode_conf_read_str().
Available options are:
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 701b23e2c91..08705ef8d99 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -1103,3 +1103,36 @@ int ofnode_set_enabled(ofnode node, bool value) else return ofnode_write_string(node, "status", "disabled"); } + +bool ofnode_conf_read_bool(const char *prop_name) +{ + ofnode node; + + node = ofnode_path("/config"); + if (!ofnode_valid(node)) + return false; + + return ofnode_read_bool(node, prop_name); +} + +int ofnode_conf_read_int(const char *prop_name, int default_val) +{ + ofnode node; + + node = ofnode_path("/config"); + if (!ofnode_valid(node)) + return default_val; + + return ofnode_read_u32_default(node, prop_name, default_val); +} + +const char *ofnode_conf_read_str(const char *prop_name) +{ + ofnode node; + + node = ofnode_path("/config"); + if (!ofnode_valid(node)) + return NULL; + + return ofnode_read_string(node, prop_name); +} diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 5e1ee061e8e..b24a511c4e1 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -75,6 +75,7 @@ #include <malloc.h> #include <video.h> #include <asm/global_data.h> +#include <dm/ofnode.h> #include <linux/compiler.h>
#if defined(CONFIG_VIDEO_MXS) @@ -2138,8 +2139,7 @@ int drv_video_init(void) #if defined(CONFIG_VGA_AS_SINGLE_DEVICE) have_keyboard = false; #elif defined(CONFIG_OF_CONTROL) - have_keyboard = !fdtdec_get_config_bool(gd->fdt_blob, - "u-boot,no-keyboard"); + have_keyboard = !ofnode_conf_read_bool("u-boot,no-keyboard"); #else have_keyboard = true; #endif diff --git a/drivers/video/exynos/exynos_mipi_dsi.c b/drivers/video/exynos/exynos_mipi_dsi.c index c56eadc8237..804fcd0b248 100644 --- a/drivers/video/exynos/exynos_mipi_dsi.c +++ b/drivers/video/exynos/exynos_mipi_dsi.c @@ -288,8 +288,8 @@ int exynos_dsim_config_parse_dt(const void *blob, struct mipi_dsim_config *dt, dt->rx_timeout = fdtdec_get_int(blob, node, "samsung,dsim-config-rx-timeout", 0);
- lcd_dt->name = fdtdec_get_config_string(blob, - "samsung,dsim-device-name"); + lcd_dt->name = fdt_getprop(blob, node, "samsung,dsim-device-name", + NULL);
lcd_dt->id = fdtdec_get_int(blob, node, "samsung,dsim-device-id", 0); diff --git a/env/mmc.c b/env/mmc.c index 09e94f0bd3b..c4cb1639914 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -19,6 +19,7 @@ #include <part.h> #include <search.h> #include <errno.h> +#include <dm/ofnode.h>
#define __STR(X) #X #define STR(X) __STR(X) @@ -73,7 +74,7 @@ static inline s64 mmc_offset(int copy) int err;
/* look for the partition in mmc CONFIG_SYS_MMC_ENV_DEV */ - str = fdtdec_get_config_string(gd->fdt_blob, dt_prop.partition); + str = ofnode_conf_read_str(dt_prop.partition); if (str) { /* try to place the environment at end of the partition */ err = mmc_offset_try_partition(str, copy, &val); @@ -90,7 +91,7 @@ static inline s64 mmc_offset(int copy) propname = dt_prop.offset_redund; } #endif - return fdtdec_get_config_int(gd->fdt_blob, propname, defvalue); + return ofnode_conf_read_int(propname, defvalue); } #else static inline s64 mmc_offset(int copy) diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 4e1a8447e65..6a714d0c7b5 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -1117,4 +1117,41 @@ int ofnode_write_string(ofnode node, const char *propname, const char *value); */ int ofnode_set_enabled(ofnode node, bool value);
+/** + * ofnode_conf_read_bool() - Read a boolean value from the U-Boot config + * + * This reads a property from the /config node of the devicetree. + * + * See doc/config.txt for bindings + * + * @prop_name property name to look up + * @return true, if it exists, false if not + */ +bool ofnode_conf_read_bool(const char *prop_name); + +/** + * ofnode_conf_read_int() - Read an integer value from the U-Boot config + * + * This reads a property from the /config node of the devicetree. + * + * See doc/config.txt for bindings + * + * @prop_name: property name to look up + * @default_val: default value to return if the property is not found + * @return integer value, if found, or @default_val if not + */ +int ofnode_conf_read_int(const char *prop_name, int default_val); + +/** + * ofnode_conf_read_str() - Read a string value from the U-Boot config + * + * This reads a property from the /config node of the devicetree. + * + * See doc/config.txt for bindings + * + * @prop_name: property name to look up + * @return string value, if found, or NULL if not + */ +const char *ofnode_conf_read_str(const char *prop_name); + #endif diff --git a/include/fdtdec.h b/include/fdtdec.h index 8ac20c9a64f..23efbe710cb 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -746,39 +746,6 @@ int fdtdec_get_bool(const void *blob, int node, const char *prop_name); */ int fdtdec_get_child_count(const void *blob, int node);
-/** - * Look in the FDT for a config item with the given name and return its value - * as a 32-bit integer. The property must have at least 4 bytes of data. The - * value of the first cell is returned. - * - * @param blob FDT blob to use - * @param prop_name Node property name - * @param default_val default value to return if the property is not found - * @return integer value, if found, or default_val if not - */ -int fdtdec_get_config_int(const void *blob, const char *prop_name, - int default_val); - -/** - * Look in the FDT for a config item with the given name - * and return whether it exists. - * - * @param blob FDT blob - * @param prop_name property name to look up - * @return 1, if it exists, or 0 if not - */ -int fdtdec_get_config_bool(const void *blob, const char *prop_name); - -/** - * Look in the FDT for a config item with the given name and return its value - * as a string. - * - * @param blob FDT blob - * @param prop_name property name to look up - * @returns property string, NULL on error. - */ -char *fdtdec_get_config_string(const void *blob, const char *prop_name); - /* * Look up a property in a node and return its contents in a byte * array of given length. The property must have at least enough data for diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 337c4443b03..1590eb5050e 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -864,50 +864,6 @@ const u8 *fdtdec_locate_byte_array(const void *blob, int node, return cell; }
-int fdtdec_get_config_int(const void *blob, const char *prop_name, - int default_val) -{ - int config_node; - - debug("%s: %s\n", __func__, prop_name); - config_node = fdt_path_offset(blob, "/config"); - if (config_node < 0) - return default_val; - return fdtdec_get_int(blob, config_node, prop_name, default_val); -} - -int fdtdec_get_config_bool(const void *blob, const char *prop_name) -{ - int config_node; - const void *prop; - - debug("%s: %s\n", __func__, prop_name); - config_node = fdt_path_offset(blob, "/config"); - if (config_node < 0) - return 0; - prop = fdt_get_property(blob, config_node, prop_name, NULL); - - return prop != NULL; -} - -char *fdtdec_get_config_string(const void *blob, const char *prop_name) -{ - const char *nodep; - int nodeoffset; - int len; - - debug("%s: %s\n", __func__, prop_name); - nodeoffset = fdt_path_offset(blob, "/config"); - if (nodeoffset < 0) - return NULL; - - nodep = fdt_getprop(blob, nodeoffset, prop_name, &len); - if (!nodep) - return NULL; - - return (char *)nodep; -} - u64 fdtdec_get_number(const fdt32_t *ptr, unsigned int cells) { u64 number = 0; diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c index 44e51de0854..49efabe871c 100644 --- a/test/dm/ofnode.c +++ b/test/dm/ofnode.c @@ -318,3 +318,18 @@ static int dm_test_ofnode_get_path(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_ofnode_get_path, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); + +static int dm_test_ofnode_conf(struct unit_test_state *uts) +{ + ut_assert(!ofnode_conf_read_bool("missing")); + ut_assert(ofnode_conf_read_bool("testing-bool")); + + ut_asserteq(123, ofnode_conf_read_int("testing-int", 0)); + ut_asserteq(6, ofnode_conf_read_int("missing", 6)); + + ut_assertnull(ofnode_conf_read_str("missing")); + ut_asserteq_str("testing", ofnode_conf_read_str("testing-str")); + + return 0; +} +DM_TEST(dm_test_ofnode_conf, 0);
Applied to u-boot-dm/next, thanks!
The condition to indicate whether there is a runtime devicetree available is OF_CONTROL && !OF_PLATDATA. This is a bit unweidly and is repeated in a lot of places.
Add a new OF_REAL Kconfig which provides this information directly.
Note: This is similar in effect to LIBFDT. We might consider dropping LIBFDT and using this instead, but this is left for now as we also have OF_LIBFDT_OVERLAY which it would not make sense to change.
dts/Kconfig | 28 +++++++++++++++++++++++++++- 1 file changed, 27 insertions(+), 1 deletion(-)
diff --git a/dts/Kconfig b/dts/Kconfig index dabe0080c1e..d853aaafbc1 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -48,6 +48,14 @@ config OF_CONTROL This feature provides for run-time configuration of U-Boot via a flattened device tree.
+config OF_REAL + def_bool y + help + Indicates that a real devicetree is available which can be accessed + at runtime. This means that dev_read_...() functions can be used to + read data from the devicetree for each device. This is true if + OF_CONTROL is enabled in U-Boot proper. + config OF_BOARD_FIXUP bool "Board-specific manipulation of Device Tree" help @@ -62,6 +70,7 @@ config SPL_OF_CONTROL bool "Enable run-time configuration via Device Tree in SPL" depends on SPL && OF_CONTROL select SPL_OF_LIBFDT if !SPL_OF_PLATDATA + select SPL_OF_REAL if !SPL_OF_PLATDATA help Some boards use device tree in U-Boot but only have 4KB of SRAM which is not enough to support device tree. Disable this option to @@ -71,6 +80,7 @@ config TPL_OF_CONTROL bool "Enable run-time configuration via Device Tree in TPL" depends on TPL && OF_CONTROL select TPL_OF_LIBFDT if !TPL_OF_PLATDATA + select TPL_OF_REAL if !TPL_OF_PLATDATA help Some boards use device tree in U-Boot but only have 4KB of SRAM which is not enough to support device tree. Enable this option to @@ -236,7 +246,7 @@ config MULTI_DTB_FIT
config SPL_MULTI_DTB_FIT - depends on SPL_LOAD_FIT && SPL_OF_CONTROL && !SPL_OF_PLATDATA + depends on SPL_LOAD_FIT && SPL_OF_REAL bool "Support embedding several DTBs in a FIT image for the SPL" help This option provides the SPL with the ability to select its own @@ -374,6 +384,14 @@ config SPL_OF_PLATDATA compatible string, then adding platform data and U_BOOT_DRVINFO declarations for each node. See of-plat.txt for more information.
+config SPL_OF_REAL + bool + help + Indicates that a real devicetree is available which can be accessed + at runtime. This means that dev_read_...() functions can be used to + read data from the devicetree for each device. This is true if + SPL_OF_CONTROL is enabled and not SPL_OF_PLATDATA + if SPL_OF_PLATDATA
config SPL_OF_PLATDATA_PARENT @@ -421,6 +439,14 @@ config SPL_OF_PLATDATA_DRIVER_RT
endif
+config TPL_OF_REAL + bool + help + Indicates that a real devicetree is available which can be accessed + at runtime. This means that dev_read_...() functions can be used to + read data from the devicetree for each device. This is true if + TPL_OF_CONTROL is enabled and not TPL_OF_PLATDATA + config TPL_OF_PLATDATA bool "Generate platform data for use in TPL" depends on TPL_OF_CONTROL
Use this new Kconfig to simplify the compilation conditions where appropriate.
arch/x86/lib/lpc-uclass.c | 2 +- common/spl/spl.c | 2 +- common/spl/spl_spi.c | 8 ++++---- drivers/clk/clk-uclass.c | 10 +++++----- drivers/clk/rockchip/clk_px30.c | 4 ++-- drivers/clk/rockchip/clk_rk3288.c | 2 +- drivers/clk/rockchip/clk_rk3308.c | 4 ++-- drivers/clk/rockchip/clk_rk3368.c | 2 +- drivers/clk/rockchip/clk_rk3399.c | 2 +- drivers/core/device.c | 4 ++-- drivers/core/fdtaddr.c | 2 +- drivers/core/lists.c | 2 +- drivers/core/root.c | 4 ++-- drivers/core/uclass.c | 2 +- drivers/firmware/firmware-uclass.c | 2 +- drivers/gpio/mxs_gpio.c | 4 ++-- drivers/gpio/omap_gpio.c | 2 +- drivers/i2c/i2c-uclass.c | 10 +++++----- drivers/i2c/omap24xx_i2c.c | 4 ++-- drivers/misc/misc-uclass.c | 2 +- drivers/mmc/mxsmmc.c | 4 ++-- drivers/mmc/omap_hsmmc.c | 6 +++--- drivers/pch/pch-uclass.c | 2 +- drivers/pinctrl/pinctrl-qe-io.c | 2 +- drivers/power/domain/power-domain-uclass.c | 4 ++-- drivers/serial/ns16550.c | 8 ++++---- drivers/serial/serial_omap.c | 6 +++--- drivers/spi/cf_spi.c | 4 ++-- drivers/spi/davinci_spi.c | 4 ++-- drivers/spi/fsl_espi.c | 4 ++-- drivers/spi/mxs_spi.c | 4 ++-- drivers/spi/omap3_spi.c | 4 ++-- drivers/spi/spi-uclass.c | 2 +- drivers/tpm/tpm-uclass.c | 2 +- drivers/watchdog/wdt-uclass.c | 2 +- dts/Kconfig | 3 ++- include/clk.h | 4 +--- include/dm/device.h | 2 +- include/power-domain.h | 6 ++---- 39 files changed, 72 insertions(+), 75 deletions(-)
diff --git a/arch/x86/lib/lpc-uclass.c b/arch/x86/lib/lpc-uclass.c index 1302a6e34a1..67b931d3b28 100644 --- a/arch/x86/lib/lpc-uclass.c +++ b/arch/x86/lib/lpc-uclass.c @@ -10,7 +10,7 @@ UCLASS_DRIVER(lpc) = { .id = UCLASS_LPC, .name = "lpc", -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .post_bind = dm_scan_fdt_dev, #endif }; diff --git a/common/spl/spl.c b/common/spl/spl.c index d55d3c28485..044a2dcf670 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -486,7 +486,7 @@ static int spl_common_init(bool setup_malloc) return ret; } #endif - if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) { + if (CONFIG_IS_ENABLED(OF_REAL)) { ret = fdtdec_setup(); if (ret) { debug("fdtdec_setup() returned error %d\n", ret); diff --git a/common/spl/spl_spi.c b/common/spl/spl_spi.c index f92ce37384c..46ee4058e76 100644 --- a/common/spl/spl_spi.c +++ b/common/spl/spl_spi.c @@ -102,10 +102,10 @@ static int spl_spi_load_image(struct spl_image_info *spl_image,
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) - payload_offs = ofnode_conf_read_int("u-boot,spl-payload-offset", - payload_offs); -#endif + if (CONFIG_IS_ENABLED(OF_REAL)) { + payload_offs = ofnode_conf_read_int("u-boot,spl-payload-offset", + payload_offs); + }
#ifdef CONFIG_SPL_OS_BOOT if (spl_start_uboot() || spi_load_image_os(spl_image, flash, header)) diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index cea38a4c6e5..7b1ea076afd 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -35,8 +35,7 @@ struct clk *dev_get_clk_ptr(struct udevice *dev) return (struct clk *)dev_get_uclass_priv(dev); }
-#if CONFIG_IS_ENABLED(OF_CONTROL) -# if CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_PLATDATA) int clk_get_by_driver_info(struct udevice *dev, struct phandle_1_arg *cells, struct clk *clk) { @@ -49,7 +48,9 @@ int clk_get_by_driver_info(struct udevice *dev, struct phandle_1_arg *cells,
return 0; } -# else +#endif + +#if CONFIG_IS_ENABLED(OF_REAL) static int clk_of_xlate_default(struct clk *clk, struct ofnode_phandle_args *args) { @@ -412,7 +413,6 @@ int clk_get_by_name(struct udevice *dev, const char *name, struct clk *clk)
return clk_get_by_index(dev, index, clk); } -# endif /* OF_PLATDATA */
int clk_get_by_name_nodev(ofnode node, const char *name, struct clk *clk) { @@ -465,7 +465,7 @@ int clk_release_all(struct clk *clk, int count) return 0; }
-#endif /* OF_CONTROL */ +#endif /* OF_REAL */
int clk_request(struct udevice *dev, struct clk *clk) { diff --git a/drivers/clk/rockchip/clk_px30.c b/drivers/clk/rockchip/clk_px30.c index 6b746f4c658..b4a7c8768ca 100644 --- a/drivers/clk/rockchip/clk_px30.c +++ b/drivers/clk/rockchip/clk_px30.c @@ -1335,7 +1335,7 @@ static ulong px30_clk_set_rate(struct clk *clk, ulong rate) return ret; }
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static int px30_gmac_set_parent(struct clk *clk, struct clk *parent) { struct px30_clk_priv *priv = dev_get_priv(clk->dev); @@ -1386,7 +1386,7 @@ static int px30_clk_enable(struct clk *clk) static struct clk_ops px30_clk_ops = { .get_rate = px30_clk_get_rate, .set_rate = px30_clk_set_rate, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .set_parent = px30_clk_set_parent, #endif .enable = px30_clk_enable, diff --git a/drivers/clk/rockchip/clk_rk3288.c b/drivers/clk/rockchip/clk_rk3288.c index 221a5bd400f..e61bd6f1bf6 100644 --- a/drivers/clk/rockchip/clk_rk3288.c +++ b/drivers/clk/rockchip/clk_rk3288.c @@ -950,7 +950,7 @@ static int __maybe_unused rk3288_clk_set_parent(struct clk *clk, struct clk *par static struct clk_ops rk3288_clk_ops = { .get_rate = rk3288_clk_get_rate, .set_rate = rk3288_clk_set_rate, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .set_parent = rk3288_clk_set_parent, #endif }; diff --git a/drivers/clk/rockchip/clk_rk3308.c b/drivers/clk/rockchip/clk_rk3308.c index 5248e596853..2876643e6be 100644 --- a/drivers/clk/rockchip/clk_rk3308.c +++ b/drivers/clk/rockchip/clk_rk3308.c @@ -939,7 +939,7 @@ static ulong rk3308_clk_set_rate(struct clk *clk, ulong rate) return ret; }
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static int __maybe_unused rk3308_mac_set_parent(struct clk *clk, struct clk *parent) { struct rk3308_clk_priv *priv = dev_get_priv(clk->dev); @@ -976,7 +976,7 @@ static int __maybe_unused rk3308_clk_set_parent(struct clk *clk, struct clk *par static struct clk_ops rk3308_clk_ops = { .get_rate = rk3308_clk_get_rate, .set_rate = rk3308_clk_set_rate, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .set_parent = rk3308_clk_set_parent, #endif }; diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index 780b49ccd89..ba9cf8915ea 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -574,7 +574,7 @@ static int __maybe_unused rk3368_clk_set_parent(struct clk *clk, struct clk *par static struct clk_ops rk3368_clk_ops = { .get_rate = rk3368_clk_get_rate, .set_rate = rk3368_clk_set_rate, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .set_parent = rk3368_clk_set_parent, #endif }; diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index f8cbda44551..75b6fbfc1b1 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -1289,7 +1289,7 @@ static int rk3399_clk_disable(struct clk *clk) static struct clk_ops rk3399_clk_ops = { .get_rate = rk3399_clk_get_rate, .set_rate = rk3399_clk_set_rate, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .set_parent = rk3399_clk_set_parent, #endif .enable = rk3399_clk_enable, diff --git a/drivers/core/device.c b/drivers/core/device.c index 29668f6fb30..42ba2dce465 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -670,7 +670,7 @@ static int device_get_device_tail(struct udevice *dev, int ret, return 0; }
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) /** * device_find_by_ofnode() - Return device associated with given ofnode * @@ -1074,7 +1074,7 @@ void dev_set_uclass_plat(struct udevice *dev, void *uclass_plat) dev->uclass_plat_ = uclass_plat; }
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) bool device_is_compatible(const struct udevice *dev, const char *compat) { return ofnode_device_is_compatible(dev_ofnode(dev), compat); diff --git a/drivers/core/fdtaddr.c b/drivers/core/fdtaddr.c index 4ffbd6b2ebc..6dfda207726 100644 --- a/drivers/core/fdtaddr.c +++ b/drivers/core/fdtaddr.c @@ -20,7 +20,7 @@ DECLARE_GLOBAL_DATA_PTR;
fdt_addr_t devfdt_get_addr_index(const struct udevice *dev, int index) { -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) fdt_addr_t addr;
if (CONFIG_IS_ENABLED(OF_TRANSLATE)) { diff --git a/drivers/core/lists.c b/drivers/core/lists.c index e214306b904..350b9d32687 100644 --- a/drivers/core/lists.c +++ b/drivers/core/lists.c @@ -154,7 +154,7 @@ int device_bind_driver_to_node(struct udevice *parent, const char *drv_name, return ret; }
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) /** * driver_check_compatible() - Check if a driver matches a compatible string * diff --git a/drivers/core/root.c b/drivers/core/root.c index 78eee082c95..fecdcb5b308 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -245,7 +245,7 @@ int dm_scan_plat(bool pre_reloc_only) return ret; }
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) /** * dm_scan_fdt_node() - Scan the device tree and bind drivers for a node * @@ -372,7 +372,7 @@ static int dm_scan(bool pre_reloc_only) return ret; }
- if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) { + if (CONFIG_IS_ENABLED(OF_REAL)) { ret = dm_extended_scan(pre_reloc_only); if (ret) { debug("dm_extended_scan() failed: %d\n", ret); diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index 117d35ac49c..c0ce1c1be56 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -394,7 +394,7 @@ done: return ret; }
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) int uclass_find_device_by_phandle(enum uclass_id id, struct udevice *parent, const char *name, struct udevice **devp) { diff --git a/drivers/firmware/firmware-uclass.c b/drivers/firmware/firmware-uclass.c index bfaf283eed5..e83a147a000 100644 --- a/drivers/firmware/firmware-uclass.c +++ b/drivers/firmware/firmware-uclass.c @@ -9,7 +9,7 @@ UCLASS_DRIVER(firmware) = { .id = UCLASS_FIRMWARE, .name = "firmware", -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .post_bind = dm_scan_fdt_dev, #endif }; diff --git a/drivers/gpio/mxs_gpio.c b/drivers/gpio/mxs_gpio.c index 7b9d88a8a75..1356f89ac2f 100644 --- a/drivers/gpio/mxs_gpio.c +++ b/drivers/gpio/mxs_gpio.c @@ -262,7 +262,7 @@ static int mxs_gpio_probe(struct udevice *dev) return 0; }
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static int mxs_of_to_plat(struct udevice *dev) { struct mxs_gpio_plat *plat = dev_get_plat(dev); @@ -301,7 +301,7 @@ U_BOOT_DRIVER(fsl_imx23_gpio) = { .probe = mxs_gpio_probe, .priv_auto = sizeof(struct mxs_gpio_priv), .plat_auto = sizeof(struct mxs_gpio_plat), -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .of_match = mxs_gpio_ids, .of_to_plat = mxs_of_to_plat, #endif diff --git a/drivers/gpio/omap_gpio.c b/drivers/gpio/omap_gpio.c index 316a28efa6b..eee36458d5a 100644 --- a/drivers/gpio/omap_gpio.c +++ b/drivers/gpio/omap_gpio.c @@ -336,7 +336,7 @@ static int omap_gpio_bind(struct udevice *dev) } #endif
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static const struct udevice_id omap_gpio_ids[] = { { .compatible = "ti,omap3-gpio" }, { .compatible = "ti,omap4-gpio" }, diff --git a/drivers/i2c/i2c-uclass.c b/drivers/i2c/i2c-uclass.c index 04c88503a2f..c4d17f69814 100644 --- a/drivers/i2c/i2c-uclass.c +++ b/drivers/i2c/i2c-uclass.c @@ -618,7 +618,7 @@ int i2c_deblock(struct udevice *bus) return ops->deblock(bus); }
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) int i2c_chip_of_to_plat(struct udevice *dev, struct dm_i2c_chip *chip) { int addr; @@ -640,7 +640,7 @@ int i2c_chip_of_to_plat(struct udevice *dev, struct dm_i2c_chip *chip)
static int i2c_pre_probe(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct dm_i2c_bus *i2c = dev_get_uclass_priv(dev); unsigned int max = 0; ofnode node; @@ -663,7 +663,7 @@ static int i2c_pre_probe(struct udevice *dev)
static int i2c_post_probe(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct dm_i2c_bus *i2c = dev_get_uclass_priv(dev);
i2c->speed_hz = dev_read_u32_default(dev, "clock-frequency", @@ -677,7 +677,7 @@ static int i2c_post_probe(struct udevice *dev)
static int i2c_child_post_bind(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct dm_i2c_chip *plat = dev_get_parent_plat(dev);
if (!dev_has_ofnode(dev)) @@ -694,7 +694,7 @@ static int i2c_post_bind(struct udevice *dev)
debug("%s: %s, seq=%d\n", __func__, dev->name, dev_seq(dev));
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) ret = dm_scan_fdt_dev(dev); #endif return ret; diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index 71f6f5f7ac8..0a408236e20 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -1062,7 +1062,7 @@ static int omap_i2c_probe(struct udevice *bus) return 0; }
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static int omap_i2c_of_to_plat(struct udevice *bus) { struct omap_i2c_plat *plat = dev_get_plat(bus); @@ -1091,7 +1091,7 @@ static const struct dm_i2c_ops omap_i2c_ops = { U_BOOT_DRIVER(i2c_omap) = { .name = "i2c_omap", .id = UCLASS_I2C, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .of_match = omap_i2c_ids, .of_to_plat = omap_i2c_of_to_plat, .plat_auto = sizeof(struct omap_i2c_plat), diff --git a/drivers/misc/misc-uclass.c b/drivers/misc/misc-uclass.c index 72720b0e590..cbfacc3801a 100644 --- a/drivers/misc/misc-uclass.c +++ b/drivers/misc/misc-uclass.c @@ -70,7 +70,7 @@ int misc_set_enabled(struct udevice *dev, bool val) UCLASS_DRIVER(misc) = { .id = UCLASS_MISC, .name = "misc", -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .post_bind = dm_scan_fdt_dev, #endif }; diff --git a/drivers/mmc/mxsmmc.c b/drivers/mmc/mxsmmc.c index 8fd41764152..35a8e21058e 100644 --- a/drivers/mmc/mxsmmc.c +++ b/drivers/mmc/mxsmmc.c @@ -665,7 +665,7 @@ static const struct dm_mmc_ops mxsmmc_ops = { .set_ios = mxsmmc_set_ios, };
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static int mxsmmc_of_to_plat(struct udevice *bus) { struct mxsmmc_plat *plat = dev_get_plat(bus); @@ -709,7 +709,7 @@ static const struct udevice_id mxsmmc_ids[] = { U_BOOT_DRIVER(fsl_imx23_mmc) = { .name = "fsl_imx23_mmc", .id = UCLASS_MMC, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .of_match = mxsmmc_ids, .of_to_plat = mxsmmc_of_to_plat, #endif diff --git a/drivers/mmc/omap_hsmmc.c b/drivers/mmc/omap_hsmmc.c index 306ce0fe1e2..d267dc64366 100644 --- a/drivers/mmc/omap_hsmmc.c +++ b/drivers/mmc/omap_hsmmc.c @@ -1891,7 +1891,7 @@ static int omap_hsmmc_get_pinctrl_state(struct mmc *mmc) } #endif
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) #ifdef CONFIG_OMAP54XX __weak const struct mmc_platform_fixups *platform_fixups_mmc(uint32_t addr) { @@ -2009,7 +2009,7 @@ static int omap_hsmmc_probe(struct udevice *dev) return omap_hsmmc_init_setup(mmc); }
static const struct omap_mmc_of_data dra7_mmc_of_data = { .controller_flags = OMAP_HSMMC_REQUIRE_IODELAY, @@ -2027,7 +2027,7 @@ static const struct udevice_id omap_hsmmc_ids[] = { U_BOOT_DRIVER(omap_hsmmc) = { .name = "omap_hsmmc", .id = UCLASS_MMC, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .of_match = omap_hsmmc_ids, .of_to_plat = omap_hsmmc_of_to_plat, .plat_auto = sizeof(struct omap_hsmmc_plat), diff --git a/drivers/pch/pch-uclass.c b/drivers/pch/pch-uclass.c index 7bc2372e96d..af028f9ceca 100644 --- a/drivers/pch/pch-uclass.c +++ b/drivers/pch/pch-uclass.c @@ -66,7 +66,7 @@ int pch_ioctl(struct udevice *dev, ulong req, void *data, int size) UCLASS_DRIVER(pch) = { .id = UCLASS_PCH, .name = "pch", -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .post_bind = dm_scan_fdt_dev, #endif }; diff --git a/drivers/pinctrl/pinctrl-qe-io.c b/drivers/pinctrl/pinctrl-qe-io.c index e129ab2f831..dc0be7ce3bd 100644 --- a/drivers/pinctrl/pinctrl-qe-io.c +++ b/drivers/pinctrl/pinctrl-qe-io.c @@ -248,7 +248,7 @@ U_BOOT_DRIVER(par_io_pinctrl) = { .of_to_plat = qe_io_of_to_plat, .plat_auto = sizeof(struct qe_io_plat), .ops = &par_io_pinctrl_ops, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .flags = DM_FLAG_PRE_RELOC, #endif }; diff --git a/drivers/power/domain/power-domain-uclass.c b/drivers/power/domain/power-domain-uclass.c index 00d1489ea20..33f9206bd09 100644 --- a/drivers/power/domain/power-domain-uclass.c +++ b/drivers/power/domain/power-domain-uclass.c @@ -112,7 +112,7 @@ int power_domain_off(struct power_domain *power_domain) return ops->off(power_domain); }
-#if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) +#if CONFIG_IS_ENABLED(OF_REAL) static int dev_power_domain_ctrl(struct udevice *dev, bool on) { struct power_domain pd; @@ -162,7 +162,7 @@ int dev_power_domain_off(struct udevice *dev) { return dev_power_domain_ctrl(dev, false); } -#endif +#endif /* OF_REAL */
UCLASS_DRIVER(power_domain) = { .id = UCLASS_POWER_DOMAIN, diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index cc121eee277..953c2fbe5c1 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -533,7 +533,7 @@ enum { }; #endif
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) int ns16550_serial_of_to_plat(struct udevice *dev) { struct ns16550_plat *plat = dev_get_plat(dev); @@ -588,7 +588,7 @@ const struct dm_serial_ops ns16550_serial_ops = { .getinfo = ns16550_serial_getinfo, };
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) /* * Please consider existing compatible strings before adding a new * one to keep this table compact. Or you may add a generic "ns16550" @@ -602,7 +602,7 @@ static const struct udevice_id ns16550_serial_ids[] = { { .compatible = "snps,dw-apb-uart", .data = PORT_NS16550 }, {} }; -#endif /* OF_CONTROL && !OF_PLATDATA */ +#endif /* OF_REAL */
#if CONFIG_IS_ENABLED(SERIAL_PRESENT)
@@ -611,7 +611,7 @@ static const struct udevice_id ns16550_serial_ids[] = { U_BOOT_DRIVER(ns16550_serial) = { .name = "ns16550_serial", .id = UCLASS_SERIAL, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .of_match = ns16550_serial_ids, .of_to_plat = ns16550_serial_of_to_plat, .plat_auto = sizeof(struct ns16550_plat), diff --git a/drivers/serial/serial_omap.c b/drivers/serial/serial_omap.c index 2b23ece442e..ee938f67632 100644 --- a/drivers/serial/serial_omap.c +++ b/drivers/serial/serial_omap.c @@ -98,7 +98,7 @@ DEBUG_UART_FUNCS
#if CONFIG_IS_ENABLED(DM_SERIAL)
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static int omap_serial_of_to_plat(struct udevice *dev) { struct ns16550_plat *plat = dev_get_plat(dev); @@ -149,13 +149,13 @@ static const struct udevice_id omap_serial_ids[] = { { .compatible = "ti,am654-uart", }, {} }; -#endif /* OF_CONTROL && !OF_PLATDATA */ +#endif /* OF_REAL */
#if CONFIG_IS_ENABLED(SERIAL_PRESENT) U_BOOT_DRIVER(omap_serial) = { .name = "omap_serial", .id = UCLASS_SERIAL, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .of_match = omap_serial_ids, .of_to_plat = omap_serial_of_to_plat, .plat_auto = sizeof(struct ns16550_plat), diff --git a/drivers/spi/cf_spi.c b/drivers/spi/cf_spi.c index 6511c0e0e54..ea23357090f 100644 --- a/drivers/spi/cf_spi.c +++ b/drivers/spi/cf_spi.c @@ -384,7 +384,7 @@ static int coldfire_spi_probe(struct udevice *bus) return 0; }
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static int coldfire_dspi_of_to_plat(struct udevice *bus) { fdt_addr_t addr; @@ -450,7 +450,7 @@ static const struct dm_spi_ops coldfire_spi_ops = { U_BOOT_DRIVER(coldfire_spi) = { .name = "spi_coldfire", .id = UCLASS_SPI, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .of_match = coldfire_spi_ids, .of_to_plat = coldfire_dspi_of_to_plat, .plat_auto = sizeof(struct coldfire_spi_plat), diff --git a/drivers/spi/davinci_spi.c b/drivers/spi/davinci_spi.c index 15557a62306..0ee6171108a 100644 --- a/drivers/spi/davinci_spi.c +++ b/drivers/spi/davinci_spi.c @@ -391,7 +391,7 @@ static int davinci_spi_probe(struct udevice *bus) return 0; }
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static int davinci_ofdata_to_platadata(struct udevice *bus) { struct davinci_spi_plat *plat = dev_get_plat(bus); @@ -418,7 +418,7 @@ static const struct udevice_id davinci_spi_ids[] = { U_BOOT_DRIVER(davinci_spi) = { .name = "davinci_spi", .id = UCLASS_SPI, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .of_match = davinci_spi_ids, .of_to_plat = davinci_ofdata_to_platadata, .plat_auto = sizeof(struct davinci_spi_plat), diff --git a/drivers/spi/fsl_espi.c b/drivers/spi/fsl_espi.c index 387b5471598..c7a692623fb 100644 --- a/drivers/spi/fsl_espi.c +++ b/drivers/spi/fsl_espi.c @@ -541,7 +541,7 @@ static const struct dm_spi_ops fsl_espi_ops = { .set_mode = fsl_espi_set_mode, };
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static int fsl_espi_of_to_plat(struct udevice *bus) { fdt_addr_t addr; @@ -572,7 +572,7 @@ static const struct udevice_id fsl_espi_ids[] = { U_BOOT_DRIVER(fsl_espi) = { .name = "fsl_espi", .id = UCLASS_SPI, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .of_match = fsl_espi_ids, .of_to_plat = fsl_espi_of_to_plat, #endif diff --git a/drivers/spi/mxs_spi.c b/drivers/spi/mxs_spi.c index d41352a0bb8..773e26bbed7 100644 --- a/drivers/spi/mxs_spi.c +++ b/drivers/spi/mxs_spi.c @@ -440,7 +440,7 @@ static const struct dm_spi_ops mxs_spi_ops = { */ };
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static int mxs_of_to_plat(struct udevice *bus) { struct mxs_spi_plat *plat = dev_get_plat(bus); @@ -483,7 +483,7 @@ static const struct udevice_id mxs_spi_ids[] = { U_BOOT_DRIVER(fsl_imx23_spi) = { .name = "fsl_imx23_spi", .id = UCLASS_SPI, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .of_match = mxs_spi_ids, .of_to_plat = mxs_of_to_plat, #endif diff --git a/drivers/spi/omap3_spi.c b/drivers/spi/omap3_spi.c index c69f8fee6e5..ea38a0ffbaf 100644 --- a/drivers/spi/omap3_spi.c +++ b/drivers/spi/omap3_spi.c @@ -481,7 +481,7 @@ static const struct dm_spi_ops omap3_spi_ops = { */ };
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static struct omap2_mcspi_platform_config omap2_pdata = { .regs_offset = 0, }; @@ -516,7 +516,7 @@ U_BOOT_DRIVER(omap3_spi) = { .name = "omap3_spi", .id = UCLASS_SPI, .flags = DM_FLAG_PRE_RELOC, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .of_match = omap3_spi_ids, .of_to_plat = omap3_spi_of_to_plat, .plat_auto = sizeof(struct omap3_spi_plat), diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index d867b278064..5a2a7436787 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -531,7 +531,7 @@ UCLASS_DRIVER(spi) = { .id = UCLASS_SPI, .name = "spi", .flags = DM_UC_FLAG_SEQ_ALIAS, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .post_bind = dm_scan_fdt_dev, #endif .post_probe = spi_post_probe, diff --git a/drivers/tpm/tpm-uclass.c b/drivers/tpm/tpm-uclass.c index 35774a6289e..f67fe1019b2 100644 --- a/drivers/tpm/tpm-uclass.c +++ b/drivers/tpm/tpm-uclass.c @@ -140,7 +140,7 @@ UCLASS_DRIVER(tpm) = { .id = UCLASS_TPM, .name = "tpm", .flags = DM_UC_FLAG_SEQ_ALIAS, -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .post_bind = dm_scan_fdt_dev, #endif .per_device_auto = sizeof(struct tpm_chip_priv), diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index 17334dbda6c..d111b146d7d 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -45,7 +45,7 @@ int initr_watchdog(void) } }
- if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) { + if (CONFIG_IS_ENABLED(OF_REAL)) { timeout = dev_read_u32_default(gd->watchdog_dev, "timeout-sec", WATCHDOG_TIMEOUT_SECS); reset_period = dev_read_u32_default(gd->watchdog_dev, diff --git a/dts/Kconfig b/dts/Kconfig index d853aaafbc1..0cc562c626e 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -44,12 +44,13 @@ config OF_CONTROL bool "Run-time configuration via Device Tree" select DTC select OF_LIBFDT if !OF_PLATDATA + select OF_REAL if !OF_PLATDATA help This feature provides for run-time configuration of U-Boot via a flattened device tree.
config OF_REAL - def_bool y + bool help Indicates that a real devicetree is available which can be accessed at runtime. This means that dev_read_...() functions can be used to diff --git a/include/clk.h b/include/clk.h index f3c88fe68aa..f34401f48ee 100644 --- a/include/clk.h +++ b/include/clk.h @@ -300,9 +300,7 @@ enum clk_defaults_stage { CLK_DEFAULTS_POST_FORCE, };
-#if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) && \ - CONFIG_IS_ENABLED(CLK) - +#if CONFIG_IS_ENABLED(OF_REAL) && CONFIG_IS_ENABLED(CLK) /** * clk_set_defaults - Process 'assigned-{clocks/clock-parents/clock-rates}' * properties to configure clocks diff --git a/include/dm/device.h b/include/dm/device.h index 0a9718a5b81..3c5c2f9417b 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -300,7 +300,7 @@ struct udevice_id { ulong data; };
-#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) #define of_match_ptr(_ptr) (_ptr) #else #define of_match_ptr(_ptr) NULL diff --git a/include/power-domain.h b/include/power-domain.h index 72ff2ff25ba..62ff19948f9 100644 --- a/include/power-domain.h +++ b/include/power-domain.h @@ -162,8 +162,7 @@ static inline int power_domain_off(struct power_domain *power_domain) * * @return 0 if OK, or a negative error code. */ -#if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) && \ - CONFIG_IS_ENABLED(POWER_DOMAIN) +#if CONFIG_IS_ENABLED(OF_REAL) && CONFIG_IS_ENABLED(POWER_DOMAIN) int dev_power_domain_on(struct udevice *dev); #else static inline int dev_power_domain_on(struct udevice *dev) @@ -179,8 +178,7 @@ static inline int dev_power_domain_on(struct udevice *dev) * * @return 0 if OK, or a negative error code. */ -#if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) && \ - CONFIG_IS_ENABLED(POWER_DOMAIN) +#if CONFIG_IS_ENABLED(OF_REAL) && CONFIG_IS_ENABLED(POWER_DOMAIN) int dev_power_domain_off(struct udevice *dev); #else static inline int dev_power_domain_off(struct udevice *dev)
Now that we have a 'positive' Kconfig option, use this instead of the negative one, which is harder to understand.
arch/arm/mach-rockchip/rk3399/syscon_rk3399.c | 2 +- arch/arm/mach-rockchip/rk3568/syscon_rk3568.c | 2 +- arch/x86/cpu/apollolake/hostbridge.c | 4 ++-- arch/x86/cpu/apollolake/lpc.c | 2 +- arch/x86/cpu/apollolake/pch.c | 2 +- arch/x86/cpu/apollolake/pmc.c | 4 ++-- arch/x86/cpu/apollolake/uart.c | 2 +- arch/x86/cpu/intel_common/itss.c | 2 +- arch/x86/cpu/intel_common/p2sb.c | 6 +++--- arch/x86/lib/tpl.c | 2 +- board/google/chromebook_coral/coral.c | 2 +- board/sandbox/sandbox.c | 5 ++++- doc/develop/driver-model/of-plat.rst | 2 +- drivers/clk/clk_fixed_factor.c | 2 +- drivers/clk/clk_fixed_rate.c | 2 +- drivers/clk/rockchip/clk_rk3188.c | 2 +- drivers/clk/rockchip/clk_rk3288.c | 2 +- drivers/clk/rockchip/clk_rk3368.c | 2 +- drivers/clk/rockchip/clk_rk3399.c | 4 ++-- drivers/core/simple-bus.c | 2 +- drivers/core/syscon-uclass.c | 2 +- drivers/core/util.c | 2 +- drivers/gpio/gpio-uclass.c | 2 +- drivers/gpio/intel_gpio.c | 2 +- drivers/gpio/omap_gpio.c | 2 +- drivers/i2c/i2c-emul-uclass.c | 2 +- drivers/misc/cros_ec.c | 2 +- drivers/misc/p2sb-uclass.c | 2 +- drivers/mmc/fsl_esdhc_imx.c | 4 ++-- drivers/mmc/ftsdc010_mci.c | 2 +- drivers/mmc/rockchip_dw_mmc.c | 2 +- drivers/mmc/rockchip_sdhci.c | 2 +- drivers/pinctrl/intel/pinctrl_apl.c | 4 ++-- drivers/pinctrl/nxp/pinctrl-mxs.c | 2 +- drivers/pinctrl/pinctrl-uclass.c | 2 +- drivers/pinctrl/rockchip/pinctrl-px30.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3036.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3128.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3188.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk322x.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3288.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3308.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3328.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3368.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rk3399.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rv1108.c | 2 +- drivers/ram/rockchip/dmc-rk3368.c | 2 +- drivers/ram/rockchip/sdram_rk3188.c | 2 +- drivers/ram/rockchip/sdram_rk322x.c | 2 +- drivers/ram/rockchip/sdram_rk3288.c | 2 +- drivers/ram/rockchip/sdram_rk3328.c | 4 ++-- drivers/ram/rockchip/sdram_rk3399.c | 4 ++-- drivers/rtc/rtc-uclass.c | 2 +- drivers/serial/sandbox.c | 2 +- drivers/serial/serial_mt7620.c | 4 ++-- drivers/spi/ich.c | 6 +++--- drivers/spi/pl022_spi.c | 4 ++-- drivers/spi/rk_spi.c | 2 +- drivers/spi/spi-uclass.c | 6 +++--- drivers/sysreset/sysreset_sandbox.c | 2 +- drivers/timer/rockchip_timer.c | 4 ++-- drivers/timer/timer-uclass.c | 4 ++-- drivers/timer/tsc_timer.c | 2 +- include/dm/device.h | 10 +++++----- 64 files changed, 88 insertions(+), 85 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3399/syscon_rk3399.c b/arch/arm/mach-rockchip/rk3399/syscon_rk3399.c index b360ca7ddef..2b5746cb31b 100644 --- a/arch/arm/mach-rockchip/rk3399/syscon_rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/syscon_rk3399.c @@ -21,7 +21,7 @@ static const struct udevice_id rk3399_syscon_ids[] = { U_BOOT_DRIVER(syscon_rk3399) = { .name = "rk3399_syscon", .id = UCLASS_SYSCON, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .bind = dm_scan_fdt_dev, #endif .of_match = rk3399_syscon_ids, diff --git a/arch/arm/mach-rockchip/rk3568/syscon_rk3568.c b/arch/arm/mach-rockchip/rk3568/syscon_rk3568.c index 20adfd11690..5407e7827f5 100644 --- a/arch/arm/mach-rockchip/rk3568/syscon_rk3568.c +++ b/arch/arm/mach-rockchip/rk3568/syscon_rk3568.c @@ -18,7 +18,7 @@ U_BOOT_DRIVER(syscon_rk3568) = { .name = "rk3568_syscon", .id = UCLASS_SYSCON, .of_match = rk3568_syscon_ids, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .bind = dm_scan_fdt_dev, #endif }; diff --git a/arch/x86/cpu/apollolake/hostbridge.c b/arch/x86/cpu/apollolake/hostbridge.c index 9decab7aa33..2405dec8525 100644 --- a/arch/x86/cpu/apollolake/hostbridge.c +++ b/arch/x86/cpu/apollolake/hostbridge.c @@ -220,7 +220,7 @@ static int apl_hostbridge_of_to_plat(struct udevice *dev) ret = uclass_first_device_err(UCLASS_PINCTRL, &pinctrl); if (ret) return log_msg_ret("no hostbridge PINCTRL", ret); -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) int root;
/* Get length of PCI Express Region */ @@ -375,7 +375,7 @@ struct acpi_ops apl_hostbridge_acpi_ops = { #endif };
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static const struct udevice_id apl_hostbridge_ids[] = { { .compatible = "intel,apl-hostbridge" }, { } diff --git a/arch/x86/cpu/apollolake/lpc.c b/arch/x86/cpu/apollolake/lpc.c index e085890d638..4be6366f043 100644 --- a/arch/x86/cpu/apollolake/lpc.c +++ b/arch/x86/cpu/apollolake/lpc.c @@ -128,7 +128,7 @@ struct acpi_ops apl_lpc_acpi_ops = { .inject_dsdt = southbridge_inject_dsdt, };
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static const struct udevice_id apl_lpc_ids[] = { { .compatible = "intel,apl-lpc" }, { } diff --git a/arch/x86/cpu/apollolake/pch.c b/arch/x86/cpu/apollolake/pch.c index 39d6ad5ed49..a0f9b031dea 100644 --- a/arch/x86/cpu/apollolake/pch.c +++ b/arch/x86/cpu/apollolake/pch.c @@ -23,7 +23,7 @@ static const struct pch_ops apl_pch_ops = { .set_spi_protect = apl_set_spi_protect, };
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static const struct udevice_id apl_pch_ids[] = { { .compatible = "intel,apl-pch" }, { } diff --git a/arch/x86/cpu/apollolake/pmc.c b/arch/x86/cpu/apollolake/pmc.c index 1d21187c96d..163119e2e9e 100644 --- a/arch/x86/cpu/apollolake/pmc.c +++ b/arch/x86/cpu/apollolake/pmc.c @@ -107,7 +107,7 @@ int apl_pmc_ofdata_to_uc_plat(struct udevice *dev) struct acpi_pmc_upriv *upriv = dev_get_uclass_priv(dev); struct apl_pmc_plat *plat = dev_get_plat(dev);
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) u32 base[6]; int size; int ret; @@ -206,7 +206,7 @@ static const struct acpi_pmc_ops apl_pmc_ops = { .global_reset_set_enable = apl_global_reset_set_enable, };
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static const struct udevice_id apl_pmc_ids[] = { { .compatible = "intel,apl-pmc" }, { } diff --git a/arch/x86/cpu/apollolake/uart.c b/arch/x86/cpu/apollolake/uart.c index 876fa592b8d..a9362436000 100644 --- a/arch/x86/cpu/apollolake/uart.c +++ b/arch/x86/cpu/apollolake/uart.c @@ -123,7 +123,7 @@ static int apl_ns16550_of_to_plat(struct udevice *dev) return 0; }
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static const struct udevice_id apl_ns16550_serial_ids[] = { { .compatible = "intel,apl-ns16550" }, { }, diff --git a/arch/x86/cpu/intel_common/itss.c b/arch/x86/cpu/intel_common/itss.c index 1eff0309831..ec73b3d8931 100644 --- a/arch/x86/cpu/intel_common/itss.c +++ b/arch/x86/cpu/intel_common/itss.c @@ -213,7 +213,7 @@ static const struct irq_ops itss_ops = { #endif };
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static const struct udevice_id itss_ids[] = { { .compatible = "intel,itss", .data = X86_IRQT_ITSS }, { } diff --git a/arch/x86/cpu/intel_common/p2sb.c b/arch/x86/cpu/intel_common/p2sb.c index d73ae438bbb..5dc816396e5 100644 --- a/arch/x86/cpu/intel_common/p2sb.c +++ b/arch/x86/cpu/intel_common/p2sb.c @@ -88,7 +88,7 @@ int p2sb_of_to_plat(struct udevice *dev) struct p2sb_uc_priv *upriv = dev_get_uclass_priv(dev); struct p2sb_plat *plat = dev_get_plat(dev);
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) int ret; u32 base[2];
@@ -159,7 +159,7 @@ static int p2sb_remove(struct udevice *dev)
static int p2sb_child_post_bind(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct p2sb_child_plat *pplat = dev_get_parent_plat(dev); int ret; u32 pid; @@ -177,7 +177,7 @@ static const struct p2sb_ops p2sb_ops = { .set_hide = intel_p2sb_set_hide, };
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static const struct udevice_id p2sb_ids[] = { { .compatible = "intel,p2sb" }, { } diff --git a/arch/x86/lib/tpl.c b/arch/x86/lib/tpl.c index b3e5f9c9138..5b57e53c2dd 100644 --- a/arch/x86/lib/tpl.c +++ b/arch/x86/lib/tpl.c @@ -139,7 +139,7 @@ void spl_board_init(void) * for devices, so the TPL BARs continue to be used. Once U-Boot starts it does * the auto allocation (after relocation). */ -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static const struct udevice_id tpl_fake_pci_ids[] = { { .compatible = "pci-x86" }, { } diff --git a/board/google/chromebook_coral/coral.c b/board/google/chromebook_coral/coral.c index 85cba50d4e5..53c5171d02b 100644 --- a/board/google/chromebook_coral/coral.c +++ b/board/google/chromebook_coral/coral.c @@ -300,7 +300,7 @@ struct sysinfo_ops coral_sysinfo_ops = { .get_str = coral_get_str, };
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static const struct udevice_id coral_ids[] = { { .compatible = "google,coral" }, { } diff --git a/board/sandbox/sandbox.c b/board/sandbox/sandbox.c index dcd73451a34..5d9a945d64c 100644 --- a/board/sandbox/sandbox.c +++ b/board/sandbox/sandbox.c @@ -26,7 +26,10 @@ gd_t *gd;
#if !CONFIG_IS_ENABLED(OF_PLATDATA) -/* Add a simple GPIO device */ +/* + * Add a simple GPIO device (don't use with of-platdata as it interferes with + * the auto-generated devices) + */ U_BOOT_DRVINFO(gpio_sandbox) = { .name = "sandbox_gpio", }; diff --git a/doc/develop/driver-model/of-plat.rst b/doc/develop/driver-model/of-plat.rst index 8a8eaed4c11..5f84f75d0fe 100644 --- a/doc/develop/driver-model/of-plat.rst +++ b/doc/develop/driver-model/of-plat.rst @@ -215,7 +215,7 @@ For example:
static int mmc_of_to_plat(struct udevice *dev) { - #if !CONFIG_IS_ENABLED(OF_PLATDATA) + #if CONFIG_IS_ENABLED(OF_REAL) /* Decode the devicetree data */ struct mmc_plat *plat = dev_get_plat(dev); const void *blob = gd->fdt_blob; diff --git a/drivers/clk/clk_fixed_factor.c b/drivers/clk/clk_fixed_factor.c index e51f94a9371..04871b4744d 100644 --- a/drivers/clk/clk_fixed_factor.c +++ b/drivers/clk/clk_fixed_factor.c @@ -40,7 +40,7 @@ const struct clk_ops clk_fixed_factor_ops = {
static int clk_fixed_factor_of_to_plat(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) int err; struct clk_fixed_factor *ff = to_clk_fixed_factor(dev);
diff --git a/drivers/clk/clk_fixed_rate.c b/drivers/clk/clk_fixed_rate.c index 325a9b2dcfb..d0f25941d0a 100644 --- a/drivers/clk/clk_fixed_rate.c +++ b/drivers/clk/clk_fixed_rate.c @@ -32,7 +32,7 @@ void clk_fixed_rate_ofdata_to_plat_(struct udevice *dev, struct clk_fixed_rate *plat) { struct clk *clk = &plat->clk; -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) plat->fixed_rate = dev_read_u32_default(dev, "clock-frequency", 0); #endif /* Make fixed rate clock accessible from higher level struct clk */ diff --git a/drivers/clk/rockchip/clk_rk3188.c b/drivers/clk/rockchip/clk_rk3188.c index 1b62d8d2898..1751672f640 100644 --- a/drivers/clk/rockchip/clk_rk3188.c +++ b/drivers/clk/rockchip/clk_rk3188.c @@ -540,7 +540,7 @@ static struct clk_ops rk3188_clk_ops = {
static int rk3188_clk_of_to_plat(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct rk3188_clk_priv *priv = dev_get_priv(dev);
priv->cru = dev_read_addr_ptr(dev); diff --git a/drivers/clk/rockchip/clk_rk3288.c b/drivers/clk/rockchip/clk_rk3288.c index e61bd6f1bf6..ee222217a53 100644 --- a/drivers/clk/rockchip/clk_rk3288.c +++ b/drivers/clk/rockchip/clk_rk3288.c @@ -957,7 +957,7 @@ static struct clk_ops rk3288_clk_ops = {
static int rk3288_clk_of_to_plat(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct rk3288_clk_priv *priv = dev_get_priv(dev);
priv->cru = dev_read_addr_ptr(dev); diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index ba9cf8915ea..92762f5a1b9 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -596,7 +596,7 @@ static int rk3368_clk_probe(struct udevice *dev)
static int rk3368_clk_of_to_plat(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct rk3368_clk_priv *priv = dev_get_priv(dev);
priv->cru = dev_read_addr_ptr(dev); diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 75b6fbfc1b1..209c726a4de 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -1402,7 +1402,7 @@ static int rk3399_clk_probe(struct udevice *dev)
static int rk3399_clk_of_to_plat(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct rk3399_clk_priv *priv = dev_get_priv(dev);
priv->cru = dev_read_addr_ptr(dev); @@ -1614,7 +1614,7 @@ static int rk3399_pmuclk_probe(struct udevice *dev)
static int rk3399_pmuclk_of_to_plat(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct rk3399_pmuclk_priv *priv = dev_get_priv(dev);
priv->pmucru = dev_read_addr_ptr(dev); diff --git a/drivers/core/simple-bus.c b/drivers/core/simple-bus.c index abc55c21719..6022e7514e0 100644 --- a/drivers/core/simple-bus.c +++ b/drivers/core/simple-bus.c @@ -65,7 +65,7 @@ UCLASS_DRIVER(simple_bus) = { .per_device_plat_auto = sizeof(struct simple_bus_plat), };
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static const struct udevice_id generic_simple_bus_ids[] = { { .compatible = "simple-bus" }, { .compatible = "simple-mfd" }, diff --git a/drivers/core/syscon-uclass.c b/drivers/core/syscon-uclass.c index cb33facc713..25fdb66eaa0 100644 --- a/drivers/core/syscon-uclass.c +++ b/drivers/core/syscon-uclass.c @@ -186,7 +186,7 @@ static const struct udevice_id generic_syscon_ids[] = { U_BOOT_DRIVER(generic_syscon) = { .name = "syscon", .id = UCLASS_SYSCON, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .bind = dm_scan_fdt_dev, #endif .of_match = generic_syscon_ids, diff --git a/drivers/core/util.c b/drivers/core/util.c index 91e93b0cf14..bea62a99fd9 100644 --- a/drivers/core/util.c +++ b/drivers/core/util.c @@ -33,7 +33,7 @@ int list_count_items(struct list_head *head) return count; }
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) int pci_get_devfn(struct udevice *dev) { struct fdt_pci_addr addr; diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index 8c77777dbe3..e0d3ae6f8cf 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -1137,7 +1137,7 @@ err: return ret; }
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static int _gpio_request_by_name_nodev(ofnode node, const char *list_name, int index, struct gpio_desc *desc, int flags, bool add_index) diff --git a/drivers/gpio/intel_gpio.c b/drivers/gpio/intel_gpio.c index f15ce7b59ee..4a3ec6d6350 100644 --- a/drivers/gpio/intel_gpio.c +++ b/drivers/gpio/intel_gpio.c @@ -204,7 +204,7 @@ static const struct dm_gpio_ops gpio_intel_ops = { #endif };
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static const struct udevice_id intel_intel_gpio_ids[] = { { .compatible = "intel,gpio" }, { } diff --git a/drivers/gpio/omap_gpio.c b/drivers/gpio/omap_gpio.c index eee36458d5a..50c4f75ddf5 100644 --- a/drivers/gpio/omap_gpio.c +++ b/drivers/gpio/omap_gpio.c @@ -362,7 +362,7 @@ U_BOOT_DRIVER(gpio_omap) = { .name = "gpio_omap", .id = UCLASS_GPIO, #if CONFIG_IS_ENABLED(OF_CONTROL) -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .of_match = omap_gpio_ids, .of_to_plat = of_match_ptr(omap_gpio_of_to_plat), .plat_auto = sizeof(struct omap_gpio_plat), diff --git a/drivers/i2c/i2c-emul-uclass.c b/drivers/i2c/i2c-emul-uclass.c index aeec6aa9fa6..1107cf309fc 100644 --- a/drivers/i2c/i2c-emul-uclass.c +++ b/drivers/i2c/i2c-emul-uclass.c @@ -79,7 +79,7 @@ UCLASS_DRIVER(i2c_emul) = { UCLASS_DRIVER(i2c_emul_parent) = { .id = UCLASS_I2C_EMUL_PARENT, .name = "i2c_emul_parent", -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .post_bind = dm_scan_fdt_dev, #endif }; diff --git a/drivers/misc/cros_ec.c b/drivers/misc/cros_ec.c index 2a15094d20a..1bbc0f98ae8 100644 --- a/drivers/misc/cros_ec.c +++ b/drivers/misc/cros_ec.c @@ -1671,7 +1671,7 @@ UCLASS_DRIVER(cros_ec) = { .id = UCLASS_CROS_EC, .name = "cros-ec", .per_device_auto = sizeof(struct cros_ec_dev), -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .post_bind = dm_scan_fdt_dev, #endif .flags = DM_UC_FLAG_ALLOC_PRIV_DMA, diff --git a/drivers/misc/p2sb-uclass.c b/drivers/misc/p2sb-uclass.c index 94d273de9b3..98d58b37c28 100644 --- a/drivers/misc/p2sb-uclass.c +++ b/drivers/misc/p2sb-uclass.c @@ -183,7 +183,7 @@ int p2sb_set_port_id(struct udevice *dev, int portid)
static int p2sb_child_post_bind(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct p2sb_child_plat *pplat = dev_get_parent_plat(dev); int ret; u32 pid; diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 465d935daf6..9aee6273540 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -1407,7 +1407,7 @@ __weak void init_clk_usdhc(u32 index)
static int fsl_esdhc_of_to_plat(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct fsl_esdhc_priv *priv = dev_get_priv(dev); #if CONFIG_IS_ENABLED(DM_REGULATOR) struct udevice *vqmmc_dev; @@ -1594,7 +1594,7 @@ static int fsl_esdhc_probe(struct udevice *dev) return ret; }
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) ret = mmc_of_parse(dev, &plat->cfg); if (ret) return ret; diff --git a/drivers/mmc/ftsdc010_mci.c b/drivers/mmc/ftsdc010_mci.c index 0fa037224fb..221fba313d3 100644 --- a/drivers/mmc/ftsdc010_mci.c +++ b/drivers/mmc/ftsdc010_mci.c @@ -392,7 +392,7 @@ static void ftsdc_setup_cfg(struct mmc_config *cfg, const char *name, int buswid
static int ftsdc010_mmc_of_to_plat(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct ftsdc_priv *priv = dev_get_priv(dev); struct ftsdc010_chip *chip = &priv->chip; chip->name = dev->name; diff --git a/drivers/mmc/rockchip_dw_mmc.c b/drivers/mmc/rockchip_dw_mmc.c index d7d5361fd50..fa297a0bc98 100644 --- a/drivers/mmc/rockchip_dw_mmc.c +++ b/drivers/mmc/rockchip_dw_mmc.c @@ -52,7 +52,7 @@ static uint rockchip_dwmmc_get_mmc_clk(struct dwmci_host *host, uint freq)
static int rockchip_dwmmc_of_to_plat(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct rockchip_dwmmc_priv *priv = dev_get_priv(dev); struct dwmci_host *host = &priv->host;
diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index d95f8b2a15b..abe59e65071 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -83,7 +83,7 @@ static int arasan_sdhci_probe(struct udevice *dev)
static int arasan_sdhci_of_to_plat(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct sdhci_host *host = dev_get_priv(dev);
host->name = dev->name; diff --git a/drivers/pinctrl/intel/pinctrl_apl.c b/drivers/pinctrl/intel/pinctrl_apl.c index acaa55d2e7f..181a6ff2702 100644 --- a/drivers/pinctrl/intel/pinctrl_apl.c +++ b/drivers/pinctrl/intel/pinctrl_apl.c @@ -155,7 +155,7 @@ static int apl_pinctrl_of_to_plat(struct udevice *dev) return intel_pinctrl_of_to_plat(dev, comm, 2); }
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static const struct udevice_id apl_gpio_ids[] = { { .compatible = "intel,apl-pinctrl"}, { } @@ -168,7 +168,7 @@ U_BOOT_DRIVER(intel_apl_pinctrl) = { .of_match = of_match_ptr(apl_gpio_ids), .probe = intel_pinctrl_probe, .ops = &intel_pinctrl_ops, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .bind = dm_scan_fdt_dev, #endif .of_to_plat = apl_pinctrl_of_to_plat, diff --git a/drivers/pinctrl/nxp/pinctrl-mxs.c b/drivers/pinctrl/nxp/pinctrl-mxs.c index e6b10a377b6..9a54b8bbe90 100644 --- a/drivers/pinctrl/nxp/pinctrl-mxs.c +++ b/drivers/pinctrl/nxp/pinctrl-mxs.c @@ -186,7 +186,7 @@ U_BOOT_DRIVER(fsl_imx23_pinctrl) = { .id = UCLASS_PINCTRL, .of_match = of_match_ptr(mxs_pinctrl_match), .probe = mxs_pinctrl_probe, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .bind = dm_scan_fdt_dev, #endif .priv_auto = sizeof(struct mxs_pinctrl_priv), diff --git a/drivers/pinctrl/pinctrl-uclass.c b/drivers/pinctrl/pinctrl-uclass.c index dfe60b6dadb..4462ed20e2d 100644 --- a/drivers/pinctrl/pinctrl-uclass.c +++ b/drivers/pinctrl/pinctrl-uclass.c @@ -421,7 +421,7 @@ static int __maybe_unused pinctrl_post_bind(struct udevice *dev)
UCLASS_DRIVER(pinctrl) = { .id = UCLASS_PINCTRL, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .post_bind = pinctrl_post_bind, #endif .flags = DM_UC_FLAG_SEQ_ALIAS, diff --git a/drivers/pinctrl/rockchip/pinctrl-px30.c b/drivers/pinctrl/rockchip/pinctrl-px30.c index 6058d0f4c13..9de29c0b8b4 100644 --- a/drivers/pinctrl/rockchip/pinctrl-px30.c +++ b/drivers/pinctrl/rockchip/pinctrl-px30.c @@ -363,7 +363,7 @@ U_BOOT_DRIVER(pinctrl_px30) = { .of_match = px30_pinctrl_ids, .priv_auto = sizeof(struct rockchip_pinctrl_priv), .ops = &rockchip_pinctrl_ops, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .bind = dm_scan_fdt_dev, #endif .probe = rockchip_pinctrl_probe, diff --git a/drivers/pinctrl/rockchip/pinctrl-rk3036.c b/drivers/pinctrl/rockchip/pinctrl-rk3036.c index 9ccee465b0f..afcd34396e2 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk3036.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk3036.c @@ -103,7 +103,7 @@ U_BOOT_DRIVER(pinctrl_rockchip) = { .of_match = rk3036_pinctrl_ids, .priv_auto = sizeof(struct rockchip_pinctrl_priv), .ops = &rockchip_pinctrl_ops, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .bind = dm_scan_fdt_dev, #endif .probe = rockchip_pinctrl_probe, diff --git a/drivers/pinctrl/rockchip/pinctrl-rk3128.c b/drivers/pinctrl/rockchip/pinctrl-rk3128.c index 85c2e611b6b..e6dc1af86e9 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk3128.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk3128.c @@ -205,7 +205,7 @@ U_BOOT_DRIVER(pinctrl_rk3128) = { .of_match = rk3128_pinctrl_ids, .priv_auto = sizeof(struct rockchip_pinctrl_priv), .ops = &rockchip_pinctrl_ops, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .bind = dm_scan_fdt_dev, #endif .probe = rockchip_pinctrl_probe, diff --git a/drivers/pinctrl/rockchip/pinctrl-rk3188.c b/drivers/pinctrl/rockchip/pinctrl-rk3188.c index 06d53e22d27..9a982cbfad9 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk3188.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk3188.c @@ -126,7 +126,7 @@ U_BOOT_DRIVER(rockchip_rk3188_pinctrl) = { .of_match = rk3188_pinctrl_ids, .priv_auto = sizeof(struct rockchip_pinctrl_priv), .ops = &rockchip_pinctrl_ops, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .bind = dm_scan_fdt_dev, #endif .probe = rockchip_pinctrl_probe, diff --git a/drivers/pinctrl/rockchip/pinctrl-rk322x.c b/drivers/pinctrl/rockchip/pinctrl-rk322x.c index fe386933c58..7c58f40d93d 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk322x.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk322x.c @@ -292,7 +292,7 @@ U_BOOT_DRIVER(pinctrl_rk3228) = { .of_match = rk3228_pinctrl_ids, .priv_auto = sizeof(struct rockchip_pinctrl_priv), .ops = &rockchip_pinctrl_ops, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .bind = dm_scan_fdt_dev, #endif .probe = rockchip_pinctrl_probe, diff --git a/drivers/pinctrl/rockchip/pinctrl-rk3288.c b/drivers/pinctrl/rockchip/pinctrl-rk3288.c index fc2810248ba..5894f47f534 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk3288.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk3288.c @@ -248,7 +248,7 @@ U_BOOT_DRIVER(rockchip_rk3288_pinctrl) = { .of_match = rk3288_pinctrl_ids, .priv_auto = sizeof(struct rockchip_pinctrl_priv), .ops = &rockchip_pinctrl_ops, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .bind = dm_scan_fdt_dev, #endif .probe = rockchip_pinctrl_probe, diff --git a/drivers/pinctrl/rockchip/pinctrl-rk3308.c b/drivers/pinctrl/rockchip/pinctrl-rk3308.c index a9b87b74571..83186f40f6f 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk3308.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk3308.c @@ -459,7 +459,7 @@ U_BOOT_DRIVER(pinctrl_rk3308) = { .of_match = rk3308_pinctrl_ids, .priv_auto = sizeof(struct rockchip_pinctrl_priv), .ops = &rockchip_pinctrl_ops, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .bind = dm_scan_fdt_dev, #endif .probe = rockchip_pinctrl_probe, diff --git a/drivers/pinctrl/rockchip/pinctrl-rk3328.c b/drivers/pinctrl/rockchip/pinctrl-rk3328.c index aa8bd76d6fb..1c3c5986a50 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk3328.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk3328.c @@ -323,7 +323,7 @@ U_BOOT_DRIVER(rockchip_rk3328_pinctrl) = { .of_match = rk3328_pinctrl_ids, .priv_auto = sizeof(struct rockchip_pinctrl_priv), .ops = &rockchip_pinctrl_ops, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .bind = dm_scan_fdt_dev, #endif .probe = rockchip_pinctrl_probe, diff --git a/drivers/pinctrl/rockchip/pinctrl-rk3368.c b/drivers/pinctrl/rockchip/pinctrl-rk3368.c index 18d3e3a9b5c..ba867a89174 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk3368.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk3368.c @@ -177,7 +177,7 @@ U_BOOT_DRIVER(rockchip_rk3368_pinctrl) = { .of_match = rk3368_pinctrl_ids, .priv_auto = sizeof(struct rockchip_pinctrl_priv), .ops = &rockchip_pinctrl_ops, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .bind = dm_scan_fdt_dev, #endif .probe = rockchip_pinctrl_probe, diff --git a/drivers/pinctrl/rockchip/pinctrl-rk3399.c b/drivers/pinctrl/rockchip/pinctrl-rk3399.c index 0c1adc37946..caa92200c6e 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk3399.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk3399.c @@ -317,7 +317,7 @@ U_BOOT_DRIVER(pinctrl_rk3399) = { .of_match = rk3399_pinctrl_ids, .priv_auto = sizeof(struct rockchip_pinctrl_priv), .ops = &rockchip_pinctrl_ops, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .bind = dm_scan_fdt_dev, #endif .probe = rockchip_pinctrl_probe, diff --git a/drivers/pinctrl/rockchip/pinctrl-rv1108.c b/drivers/pinctrl/rockchip/pinctrl-rv1108.c index d35425b5fa2..5b70b503d2b 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rv1108.c +++ b/drivers/pinctrl/rockchip/pinctrl-rv1108.c @@ -291,7 +291,7 @@ U_BOOT_DRIVER(pinctrl_rv1108) = { .of_match = rv1108_pinctrl_ids, .priv_auto = sizeof(struct rockchip_pinctrl_priv), .ops = &rockchip_pinctrl_ops, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .bind = dm_scan_fdt_dev, #endif .probe = rockchip_pinctrl_probe, diff --git a/drivers/ram/rockchip/dmc-rk3368.c b/drivers/ram/rockchip/dmc-rk3368.c index a9d051852a4..5a72283dac2 100644 --- a/drivers/ram/rockchip/dmc-rk3368.c +++ b/drivers/ram/rockchip/dmc-rk3368.c @@ -883,7 +883,7 @@ static int rk3368_dmc_of_to_plat(struct udevice *dev) { int ret = 0;
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct rk3368_sdram_params *plat = dev_get_plat(dev);
ret = regmap_init_mem(dev_ofnode(dev), &plat->map); diff --git a/drivers/ram/rockchip/sdram_rk3188.c b/drivers/ram/rockchip/sdram_rk3188.c index 25ae69e9acd..38d25c8b780 100644 --- a/drivers/ram/rockchip/sdram_rk3188.c +++ b/drivers/ram/rockchip/sdram_rk3188.c @@ -816,7 +816,7 @@ static int setup_sdram(struct udevice *dev)
static int rk3188_dmc_of_to_plat(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct rk3188_sdram_params *params = dev_get_plat(dev); int ret;
diff --git a/drivers/ram/rockchip/sdram_rk322x.c b/drivers/ram/rockchip/sdram_rk322x.c index 9057ccacd96..fd12008ed90 100644 --- a/drivers/ram/rockchip/sdram_rk322x.c +++ b/drivers/ram/rockchip/sdram_rk322x.c @@ -716,7 +716,7 @@ out:
static int rk322x_dmc_of_to_plat(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct rk322x_sdram_params *params = dev_get_plat(dev); const void *blob = gd->fdt_blob; int node = dev_of_offset(dev); diff --git a/drivers/ram/rockchip/sdram_rk3288.c b/drivers/ram/rockchip/sdram_rk3288.c index a933abf0d45..2cb034f263f 100644 --- a/drivers/ram/rockchip/sdram_rk3288.c +++ b/drivers/ram/rockchip/sdram_rk3288.c @@ -973,7 +973,7 @@ static int setup_sdram(struct udevice *dev)
static int rk3288_dmc_of_to_plat(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct rk3288_sdram_params *params = dev_get_plat(dev); int ret;
diff --git a/drivers/ram/rockchip/sdram_rk3328.c b/drivers/ram/rockchip/sdram_rk3328.c index 9af4c372d50..9c6798f816a 100644 --- a/drivers/ram/rockchip/sdram_rk3328.c +++ b/drivers/ram/rockchip/sdram_rk3328.c @@ -517,7 +517,7 @@ static int rk3328_dmc_init(struct udevice *dev) struct rockchip_dmc_plat *plat = dev_get_plat(dev); int ret;
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct rk3328_sdram_params *params = &plat->sdram_params; #else struct dtd_rockchip_rk3328_dmc *dtplat = &plat->dtplat; @@ -549,7 +549,7 @@ static int rk3328_dmc_init(struct udevice *dev)
static int rk3328_dmc_of_to_plat(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct rockchip_dmc_plat *plat = dev_get_plat(dev); int ret;
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index a83a670b322..c9631af2643 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -3013,7 +3013,7 @@ static int sdram_init(struct dram_info *dram,
static int rk3399_dmc_of_to_plat(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct rockchip_dmc_plat *plat = dev_get_plat(dev); int ret;
@@ -3068,7 +3068,7 @@ static int rk3399_dmc_init(struct udevice *dev) struct dram_info *priv = dev_get_priv(dev); struct rockchip_dmc_plat *plat = dev_get_plat(dev); int ret; -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct rk3399_sdram_params *params = &plat->sdram_params; #else struct dtd_rockchip_rk3399_dmc *dtplat = &plat->dtplat; diff --git a/drivers/rtc/rtc-uclass.c b/drivers/rtc/rtc-uclass.c index be6a2ddb667..2a9818243d9 100644 --- a/drivers/rtc/rtc-uclass.c +++ b/drivers/rtc/rtc-uclass.c @@ -176,7 +176,7 @@ int rtc_write32(struct udevice *dev, unsigned int reg, u32 value) UCLASS_DRIVER(rtc) = { .name = "rtc", .id = UCLASS_RTC, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .post_bind = dm_scan_fdt_dev, #endif }; diff --git a/drivers/serial/sandbox.c b/drivers/serial/sandbox.c index 5243c955fbf..dbbcea5bb4d 100644 --- a/drivers/serial/sandbox.c +++ b/drivers/serial/sandbox.c @@ -237,7 +237,7 @@ U_BOOT_DRIVER(sandbox_serial) = { .flags = DM_FLAG_PRE_RELOC, };
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static const struct sandbox_serial_plat platdata_non_fdt = { .colour = -1, }; diff --git a/drivers/serial/serial_mt7620.c b/drivers/serial/serial_mt7620.c index 826a14b49f8..76ecc2b38ce 100644 --- a/drivers/serial/serial_mt7620.c +++ b/drivers/serial/serial_mt7620.c @@ -145,7 +145,7 @@ static int mt7620_serial_probe(struct udevice *dev) return 0; }
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static int mt7620_serial_of_to_plat(struct udevice *dev) { struct mt7620_serial_plat *plat = dev_get_plat(dev); @@ -200,7 +200,7 @@ static const struct dm_serial_ops mt7620_serial_ops = { U_BOOT_DRIVER(serial_mt7620) = { .name = "serial_mt7620", .id = UCLASS_SERIAL, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .of_match = mt7620_serial_ids, .of_to_plat = mt7620_serial_of_to_plat, #endif diff --git a/drivers/spi/ich.c b/drivers/spi/ich.c index 08d54e86f45..42071bb70c4 100644 --- a/drivers/spi/ich.c +++ b/drivers/spi/ich.c @@ -604,7 +604,7 @@ static int ich_spi_exec_op(struct spi_slave *slave, const struct spi_mem_op *op) return ret; }
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) /** * ich_spi_get_basics() - Get basic information about the ICH device * @@ -672,7 +672,7 @@ static int ich_get_mmap_bus(struct udevice *bus, ulong *map_basep, uint *map_sizep, uint *offsetp) { pci_dev_t spi_bdf; -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) if (device_is_on_pci_bus(bus)) { struct pci_child_plat *pplat;
@@ -940,7 +940,7 @@ static int ich_spi_of_to_plat(struct udevice *dev) { struct ich_spi_plat *plat = dev_get_plat(dev);
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct ich_spi_priv *priv = dev_get_priv(dev); int ret;
diff --git a/drivers/spi/pl022_spi.c b/drivers/spi/pl022_spi.c index 9856a5669ca..ea1691438be 100644 --- a/drivers/spi/pl022_spi.c +++ b/drivers/spi/pl022_spi.c @@ -286,7 +286,7 @@ static const struct dm_spi_ops pl022_spi_ops = { .cs_info = pl022_cs_info, };
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static int pl022_spi_of_to_plat(struct udevice *bus) { struct pl022_spi_pdata *plat = dev_get_plat(bus); @@ -315,7 +315,7 @@ static const struct udevice_id pl022_spi_ids[] = { U_BOOT_DRIVER(pl022_spi) = { .name = "pl022_spi", .id = UCLASS_SPI, -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .of_match = pl022_spi_ids, .of_to_plat = pl022_spi_of_to_plat, #endif diff --git a/drivers/spi/rk_spi.c b/drivers/spi/rk_spi.c index 40bd8851b7c..e504e306fd7 100644 --- a/drivers/spi/rk_spi.c +++ b/drivers/spi/rk_spi.c @@ -193,7 +193,7 @@ static int conv_of_plat(struct udevice *dev)
static int rockchip_spi_of_to_plat(struct udevice *bus) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct rockchip_spi_plat *plat = dev_get_plat(bus); struct rockchip_spi_priv *priv = dev_get_priv(bus); int ret; diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index 5a2a7436787..655fb1407aa 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -162,7 +162,7 @@ int spi_write_then_read(struct spi_slave *slave, const u8 *opcode, return ret; }
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static int spi_child_post_bind(struct udevice *dev) { struct dm_spi_slave_plat *plat = dev_get_parent_plat(dev); @@ -176,7 +176,7 @@ static int spi_child_post_bind(struct udevice *dev)
static int spi_post_probe(struct udevice *bus) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct dm_spi_bus *spi = dev_get_uclass_priv(bus);
spi->max_hz = dev_read_u32_default(bus, "spi-max-frequency", 0); @@ -539,7 +539,7 @@ UCLASS_DRIVER(spi) = { .per_device_auto = sizeof(struct dm_spi_bus), .per_child_auto = sizeof(struct spi_slave), .per_child_plat_auto = sizeof(struct dm_spi_slave_plat), -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) .child_post_bind = spi_child_post_bind, #endif }; diff --git a/drivers/sysreset/sysreset_sandbox.c b/drivers/sysreset/sysreset_sandbox.c index 08685823e99..0ee286cbb34 100644 --- a/drivers/sysreset/sysreset_sandbox.c +++ b/drivers/sysreset/sysreset_sandbox.c @@ -133,7 +133,7 @@ U_BOOT_DRIVER(warm_sysreset_sandbox) = { .ops = &sandbox_warm_sysreset_ops, };
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) /* This is here in case we don't have a device tree */ U_BOOT_DRVINFO(sysreset_sandbox_non_fdt) = { .name = "sysreset_sandbox", diff --git a/drivers/timer/rockchip_timer.c b/drivers/timer/rockchip_timer.c index 18c61450aff..96621479105 100644 --- a/drivers/timer/rockchip_timer.c +++ b/drivers/timer/rockchip_timer.c @@ -55,7 +55,7 @@ ulong timer_get_boot_us(void) /* The timer is available */ rate = timer_get_rate(gd->timer); timer_get_count(gd->timer, &ticks); -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) } else if (ret == -EAGAIN) { /* We have been called so early that the DM is not ready,... */ ofnode node = offset_to_ofnode(-1); @@ -100,7 +100,7 @@ static u64 rockchip_timer_get_count(struct udevice *dev)
static int rockchip_clk_of_to_plat(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct rockchip_timer_priv *priv = dev_get_priv(dev);
priv->timer = dev_read_addr_ptr(dev); diff --git a/drivers/timer/timer-uclass.c b/drivers/timer/timer-uclass.c index c8e8419b22e..52bddb9654f 100644 --- a/drivers/timer/timer-uclass.c +++ b/drivers/timer/timer-uclass.c @@ -50,7 +50,7 @@ unsigned long notrace timer_get_rate(struct udevice *dev)
static int timer_pre_probe(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); struct clk timer_clk; int err; @@ -136,7 +136,7 @@ int notrace dm_timer_init(void) if (gd->dm_root == NULL) return -EAGAIN;
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) /* Check for a chosen timer to be used for tick */ node = ofnode_get_chosen_node("tick-timer");
diff --git a/drivers/timer/tsc_timer.c b/drivers/timer/tsc_timer.c index adef50c3744..192c7b71a5a 100644 --- a/drivers/timer/tsc_timer.c +++ b/drivers/timer/tsc_timer.c @@ -479,7 +479,7 @@ static const struct timer_ops tsc_timer_ops = { .get_count = tsc_timer_get_count, };
-#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) static const struct udevice_id tsc_timer_ids[] = { { .compatible = "x86,tsc-timer", }, { } diff --git a/include/dm/device.h b/include/dm/device.h index 3c5c2f9417b..b83e9f2da91 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -181,7 +181,7 @@ struct udevice { u32 flags_; #endif int seq_; -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) ofnode node_; #endif #ifdef CONFIG_DEVRES @@ -242,7 +242,7 @@ static inline void dev_bic_flags(struct udevice *dev, u32 bic) */ static inline ofnode dev_ofnode(const struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) return dev->node_; #else return ofnode_null(); @@ -262,7 +262,7 @@ static inline ofnode dev_ofnode(const struct udevice *dev)
static inline int dev_of_offset(const struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) return ofnode_to_offset(dev_ofnode(dev)); #else return -1; @@ -271,7 +271,7 @@ static inline int dev_of_offset(const struct udevice *dev)
static inline bool dev_has_ofnode(const struct udevice *dev) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) return ofnode_valid(dev_ofnode(dev)); #else return false; @@ -280,7 +280,7 @@ static inline bool dev_has_ofnode(const struct udevice *dev)
static inline void dev_set_ofnode(struct udevice *dev, ofnode node) { -#if !CONFIG_IS_ENABLED(OF_PLATDATA) +#if CONFIG_IS_ENABLED(OF_REAL) dev->node_ = node; #endif }
Applied to u-boot-dm/next, thanks!
Use the livetree API for this driver.
drivers/mmc/ftsdc010_mci.c | 22 +++++++--------------- 1 file changed, 7 insertions(+), 15 deletions(-)
diff --git a/drivers/mmc/ftsdc010_mci.c b/drivers/mmc/ftsdc010_mci.c index 221fba313d3..b30da5b72a4 100644 --- a/drivers/mmc/ftsdc010_mci.c +++ b/drivers/mmc/ftsdc010_mci.c @@ -30,8 +30,6 @@ #include <syscon.h> #include <linux/err.h>
-DECLARE_GLOBAL_DATA_PTR; - #define CFG_CMD_TIMEOUT (CONFIG_SYS_HZ >> 4) /* 250 ms */ #define CFG_RST_TIMEOUT CONFIG_SYS_HZ /* 1 sec reset timeout */
@@ -395,24 +393,18 @@ static int ftsdc010_mmc_of_to_plat(struct udevice *dev) #if CONFIG_IS_ENABLED(OF_REAL) struct ftsdc_priv *priv = dev_get_priv(dev); struct ftsdc010_chip *chip = &priv->chip; + chip->name = dev->name; chip->ioaddr = dev_read_addr_ptr(dev); - chip->buswidth = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), - "bus-width", 4); + chip->buswidth = dev_read_u32_default(dev, "bus-width", 4); chip->priv = dev; - priv->fifo_depth = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), - "fifo-depth", 0); - priv->fifo_mode = fdtdec_get_bool(gd->fdt_blob, dev_of_offset(dev), - "fifo-mode"); - if (fdtdec_get_int_array(gd->fdt_blob, dev_of_offset(dev), - "clock-freq-min-max", priv->minmax, 2)) { - int val = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), - "max-frequency", -EINVAL); - if (val < 0) - return val; + priv->fifo_depth = dev_read_u32_default(dev, "fifo-depth", 0); + priv->fifo_mode = dev_read_bool(dev, "fifo-mode"); + if (dev_read_u32_array(dev, "clock-freq-min-max", priv->minmax, 2)) { + if (dev_read_u32(dev, "max-frequency", &priv->minmax[1])) + return -EINVAL;
priv->minmax[0] = 400000; /* 400 kHz */ - priv->minmax[1] = val; } else { debug("%s: 'clock-freq-min-max' property was deprecated.\n", __func__);
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regars, Jaehoon Chung
- chip->name = dev->name; chip->ioaddr = dev_read_addr_ptr(dev);
"bus-width", 4);
- chip->buswidth = dev_read_u32_default(dev, "bus-width", 4); chip->priv = dev;
"fifo-depth", 0);
"fifo-mode");
if (val < 0)
return val;
return -EINVAL;
} else { debug("%s: 'clock-freq-min-max' property was deprecated.\n", __func__);priv->minmax[1] = val;
Convert some of these occurences to C code, where it is easy to do. This should help encourage this approach to be used in new code.
arch/x86/cpu/intel_common/p2sb.c | 20 ++++---- doc/develop/driver-model/of-plat.rst | 6 +-- drivers/clk/clk_fixed_factor.c | 18 ++++---- drivers/clk/clk_fixed_rate.c | 7 +-- drivers/clk/rockchip/clk_rk3188.c | 8 ++-- drivers/clk/rockchip/clk_rk3288.c | 8 ++-- drivers/clk/rockchip/clk_rk3368.c | 8 ++-- drivers/clk/rockchip/clk_rk3399.c | 18 ++++---- drivers/misc/p2sb-uclass.c | 20 ++++---- drivers/mmc/fsl_esdhc_imx.c | 17 +++---- drivers/mmc/ftsdc010_mci.c | 33 +++++++------- drivers/mmc/rockchip_dw_mmc.c | 6 ++- drivers/mmc/rockchip_sdhci.c | 12 ++--- drivers/ram/rockchip/dmc-rk3368.c | 12 ++--- drivers/ram/rockchip/sdram_rk3188.c | 5 +- drivers/ram/rockchip/sdram_rk322x.c | 5 +- drivers/ram/rockchip/sdram_rk3288.c | 5 +- drivers/ram/rockchip/sdram_rk3399.c | 5 +- drivers/spi/rk_spi.c | 36 +++++++-------- drivers/spi/spi-uclass.c | 8 ++-- drivers/timer/rockchip_timer.c | 16 +++---- drivers/timer/timer-uclass.c | 68 ++++++++++++++-------------- 22 files changed, 176 insertions(+), 165 deletions(-)
diff --git a/arch/x86/cpu/intel_common/p2sb.c b/arch/x86/cpu/intel_common/p2sb.c index 5dc816396e5..5a7b30d94a1 100644 --- a/arch/x86/cpu/intel_common/p2sb.c +++ b/arch/x86/cpu/intel_common/p2sb.c @@ -159,16 +159,16 @@ static int p2sb_remove(struct udevice *dev)
static int p2sb_child_post_bind(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_REAL) - struct p2sb_child_plat *pplat = dev_get_parent_plat(dev); - int ret; - u32 pid; - - ret = dev_read_u32(dev, "intel,p2sb-port-id", &pid); - if (ret) - return ret; - pplat->pid = pid; -#endif + if (CONFIG_IS_ENABLED(OF_REAL)) { + struct p2sb_child_plat *pplat = dev_get_parent_plat(dev); + int ret; + u32 pid; + + ret = dev_read_u32(dev, "intel,p2sb-port-id", &pid); + if (ret) + return ret; + pplat->pid = pid; + }
return 0; } diff --git a/doc/develop/driver-model/of-plat.rst b/doc/develop/driver-model/of-plat.rst index 5f84f75d0fe..61aa2bc3ed9 100644 --- a/doc/develop/driver-model/of-plat.rst +++ b/doc/develop/driver-model/of-plat.rst @@ -215,16 +215,16 @@ For example:
static int mmc_of_to_plat(struct udevice *dev) { - #if CONFIG_IS_ENABLED(OF_REAL) + if (CONFIG_IS_ENABLED(OF_REAL)) { /* Decode the devicetree data */ struct mmc_plat *plat = dev_get_plat(dev); const void *blob = gd->fdt_blob; int node = dev_of_offset(dev);
plat->fifo_depth = fdtdec_get_int(blob, node, "fifo-depth", 0); - #endif + }
- return 0; + return 0; }
static int mmc_probe(struct udevice *dev) diff --git a/drivers/clk/clk_fixed_factor.c b/drivers/clk/clk_fixed_factor.c index 04871b4744d..41b0d9c0603 100644 --- a/drivers/clk/clk_fixed_factor.c +++ b/drivers/clk/clk_fixed_factor.c @@ -40,17 +40,17 @@ const struct clk_ops clk_fixed_factor_ops = {
static int clk_fixed_factor_of_to_plat(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_REAL) - int err; - struct clk_fixed_factor *ff = to_clk_fixed_factor(dev); + if (CONFIG_IS_ENABLED(OF_REAL)) { + int err; + struct clk_fixed_factor *ff = to_clk_fixed_factor(dev);
- err = clk_get_by_index(dev, 0, &ff->parent); - if (err) - return err; + err = clk_get_by_index(dev, 0, &ff->parent); + if (err) + return err;
- ff->div = dev_read_u32_default(dev, "clock-div", 1); - ff->mult = dev_read_u32_default(dev, "clock-mult", 1); -#endif + ff->div = dev_read_u32_default(dev, "clock-div", 1); + ff->mult = dev_read_u32_default(dev, "clock-mult", 1); + }
return 0; } diff --git a/drivers/clk/clk_fixed_rate.c b/drivers/clk/clk_fixed_rate.c index d0f25941d0a..e0dc4ab85f8 100644 --- a/drivers/clk/clk_fixed_rate.c +++ b/drivers/clk/clk_fixed_rate.c @@ -32,9 +32,10 @@ void clk_fixed_rate_ofdata_to_plat_(struct udevice *dev, struct clk_fixed_rate *plat) { struct clk *clk = &plat->clk; -#if CONFIG_IS_ENABLED(OF_REAL) - plat->fixed_rate = dev_read_u32_default(dev, "clock-frequency", 0); -#endif + if (CONFIG_IS_ENABLED(OF_REAL)) + plat->fixed_rate = dev_read_u32_default(dev, "clock-frequency", + 0); + /* Make fixed rate clock accessible from higher level struct clk */ /* FIXME: This is not allowed */ dev_set_uclass_priv(dev, clk); diff --git a/drivers/clk/rockchip/clk_rk3188.c b/drivers/clk/rockchip/clk_rk3188.c index 1751672f640..038cb55965e 100644 --- a/drivers/clk/rockchip/clk_rk3188.c +++ b/drivers/clk/rockchip/clk_rk3188.c @@ -540,11 +540,11 @@ static struct clk_ops rk3188_clk_ops = {
static int rk3188_clk_of_to_plat(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_REAL) - struct rk3188_clk_priv *priv = dev_get_priv(dev); + if (CONFIG_IS_ENABLED(OF_REAL)) { + struct rk3188_clk_priv *priv = dev_get_priv(dev);
- priv->cru = dev_read_addr_ptr(dev); -#endif + priv->cru = dev_read_addr_ptr(dev); + }
return 0; } diff --git a/drivers/clk/rockchip/clk_rk3288.c b/drivers/clk/rockchip/clk_rk3288.c index ee222217a53..3b29992c3e5 100644 --- a/drivers/clk/rockchip/clk_rk3288.c +++ b/drivers/clk/rockchip/clk_rk3288.c @@ -957,11 +957,11 @@ static struct clk_ops rk3288_clk_ops = {
static int rk3288_clk_of_to_plat(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_REAL) - struct rk3288_clk_priv *priv = dev_get_priv(dev); + if (CONFIG_IS_ENABLED(OF_REAL)) { + struct rk3288_clk_priv *priv = dev_get_priv(dev);
return 0; } diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index 92762f5a1b9..79b9dfbaa46 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -596,11 +596,11 @@ static int rk3368_clk_probe(struct udevice *dev)
static int rk3368_clk_of_to_plat(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_REAL) - struct rk3368_clk_priv *priv = dev_get_priv(dev); + if (CONFIG_IS_ENABLED(OF_REAL)) { + struct rk3368_clk_priv *priv = dev_get_priv(dev);
return 0; } diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 209c726a4de..7d31a9f22a8 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -1402,11 +1402,12 @@ static int rk3399_clk_probe(struct udevice *dev)
static int rk3399_clk_of_to_plat(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_REAL) - struct rk3399_clk_priv *priv = dev_get_priv(dev); + if (CONFIG_IS_ENABLED(OF_REAL)) { + struct rk3399_clk_priv *priv = dev_get_priv(dev); + + priv->cru = dev_read_addr_ptr(dev); + }
- priv->cru = dev_read_addr_ptr(dev); -#endif return 0; }
@@ -1614,11 +1615,12 @@ static int rk3399_pmuclk_probe(struct udevice *dev)
static int rk3399_pmuclk_of_to_plat(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_REAL) - struct rk3399_pmuclk_priv *priv = dev_get_priv(dev); + if (CONFIG_IS_ENABLED(OF_REAL)) { + struct rk3399_pmuclk_priv *priv = dev_get_priv(dev); + + priv->pmucru = dev_read_addr_ptr(dev); + }
- priv->pmucru = dev_read_addr_ptr(dev); -#endif return 0; }
diff --git a/drivers/misc/p2sb-uclass.c b/drivers/misc/p2sb-uclass.c index 98d58b37c28..f24857a1515 100644 --- a/drivers/misc/p2sb-uclass.c +++ b/drivers/misc/p2sb-uclass.c @@ -183,16 +183,16 @@ int p2sb_set_port_id(struct udevice *dev, int portid)
return 0; } diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 9aee6273540..21b1f6ba004 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -1407,7 +1407,6 @@ __weak void init_clk_usdhc(u32 index)
static int fsl_esdhc_of_to_plat(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_REAL) struct fsl_esdhc_priv *priv = dev_get_priv(dev); #if CONFIG_IS_ENABLED(DM_REGULATOR) struct udevice *vqmmc_dev; @@ -1415,10 +1414,12 @@ static int fsl_esdhc_of_to_plat(struct udevice *dev) #endif const void *fdt = gd->fdt_blob; int node = dev_of_offset(dev); - fdt_addr_t addr; unsigned int val;
+ if (!CONFIG_IS_ENABLED(OF_REAL)) + return 0; + addr = dev_read_addr(dev); if (addr == FDT_ADDR_T_NONE) return -EINVAL; @@ -1490,7 +1491,7 @@ static int fsl_esdhc_of_to_plat(struct udevice *dev) priv->vs18_enable = 1; } #endif -#endif + return 0; }
@@ -1594,11 +1595,11 @@ static int fsl_esdhc_probe(struct udevice *dev) return ret; }
-#if CONFIG_IS_ENABLED(OF_REAL) - ret = mmc_of_parse(dev, &plat->cfg); - if (ret) - return ret; -#endif + if (CONFIG_IS_ENABLED(OF_REAL)) { + ret = mmc_of_parse(dev, &plat->cfg); + if (ret) + return ret; + }
mmc = &plat->mmc; mmc->cfg = &plat->cfg; diff --git a/drivers/mmc/ftsdc010_mci.c b/drivers/mmc/ftsdc010_mci.c index b30da5b72a4..b8cafeb0431 100644 --- a/drivers/mmc/ftsdc010_mci.c +++ b/drivers/mmc/ftsdc010_mci.c @@ -390,28 +390,29 @@ static void ftsdc_setup_cfg(struct mmc_config *cfg, const char *name, int buswid
static int ftsdc010_mmc_of_to_plat(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_REAL) struct ftsdc_priv *priv = dev_get_priv(dev); struct ftsdc010_chip *chip = &priv->chip;
- chip->name = dev->name; - chip->ioaddr = dev_read_addr_ptr(dev); - chip->buswidth = dev_read_u32_default(dev, "bus-width", 4); - chip->priv = dev; - priv->fifo_depth = dev_read_u32_default(dev, "fifo-depth", 0); - priv->fifo_mode = dev_read_bool(dev, "fifo-mode"); - if (dev_read_u32_array(dev, "clock-freq-min-max", priv->minmax, 2)) { - if (dev_read_u32(dev, "max-frequency", &priv->minmax[1])) - return -EINVAL; - - priv->minmax[0] = 400000; /* 400 kHz */ - } else { - debug("%s: 'clock-freq-min-max' property was deprecated.\n", - __func__); + if (CONFIG_IS_ENABLED(OF_REAL)) { + chip->name = dev->name; + chip->ioaddr = dev_read_addr_ptr(dev); + chip->buswidth = dev_read_u32_default(dev, "bus-width", 4); + chip->priv = dev; + priv->fifo_depth = dev_read_u32_default(dev, "fifo-depth", 0); + priv->fifo_mode = dev_read_bool(dev, "fifo-mode"); + if (dev_read_u32_array(dev, "clock-freq-min-max", priv->minmax, 2)) { + if (dev_read_u32(dev, "max-frequency", &priv->minmax[1])) + return -EINVAL; + + priv->minmax[0] = 400000; /* 400 kHz */ + } else { + debug("%s: 'clock-freq-min-max' property was deprecated.\n", + __func__); + } } -#endif chip->sclk = priv->minmax[1]; chip->regs = chip->ioaddr; + return 0; }
diff --git a/drivers/mmc/rockchip_dw_mmc.c b/drivers/mmc/rockchip_dw_mmc.c index fa297a0bc98..855c0e7af52 100644 --- a/drivers/mmc/rockchip_dw_mmc.c +++ b/drivers/mmc/rockchip_dw_mmc.c @@ -52,10 +52,12 @@ static uint rockchip_dwmmc_get_mmc_clk(struct dwmci_host *host, uint freq)
static int rockchip_dwmmc_of_to_plat(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_REAL) struct rockchip_dwmmc_priv *priv = dev_get_priv(dev); struct dwmci_host *host = &priv->host;
+ if (!CONFIG_IS_ENABLED(OF_REAL)) + return 0; + host->name = dev->name; host->ioaddr = dev_read_addr_ptr(dev); host->buswidth = dev_read_u32_default(dev, "bus-width", 4); @@ -95,7 +97,7 @@ static int rockchip_dwmmc_of_to_plat(struct udevice *dev) debug("%s: 'clock-freq-min-max' property was deprecated.\n", __func__); } -#endif + return 0; }
diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index abe59e65071..93e58c2d3f1 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -83,13 +83,13 @@ static int arasan_sdhci_probe(struct udevice *dev)
static int arasan_sdhci_of_to_plat(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_REAL) - struct sdhci_host *host = dev_get_priv(dev); + if (CONFIG_IS_ENABLED(OF_REAL)) { + struct sdhci_host *host = dev_get_priv(dev);
- host->name = dev->name; - host->ioaddr = dev_read_addr_ptr(dev); - host->bus_width = dev_read_u32_default(dev, "bus-width", 4); -#endif + host->name = dev->name; + host->ioaddr = dev_read_addr_ptr(dev); + host->bus_width = dev_read_u32_default(dev, "bus-width", 4); + }
return 0; } diff --git a/drivers/ram/rockchip/dmc-rk3368.c b/drivers/ram/rockchip/dmc-rk3368.c index 5a72283dac2..69c454a4ba8 100644 --- a/drivers/ram/rockchip/dmc-rk3368.c +++ b/drivers/ram/rockchip/dmc-rk3368.c @@ -883,13 +883,13 @@ static int rk3368_dmc_of_to_plat(struct udevice *dev) { int ret = 0;
-#if CONFIG_IS_ENABLED(OF_REAL) - struct rk3368_sdram_params *plat = dev_get_plat(dev); + if (CONFIG_IS_ENABLED(OF_REAL)) { + struct rk3368_sdram_params *plat = dev_get_plat(dev);
- ret = regmap_init_mem(dev_ofnode(dev), &plat->map); - if (ret) - return ret; -#endif + ret = regmap_init_mem(dev_ofnode(dev), &plat->map); + if (ret) + return ret; + }
return ret; } diff --git a/drivers/ram/rockchip/sdram_rk3188.c b/drivers/ram/rockchip/sdram_rk3188.c index 38d25c8b780..d9ed8adfcfd 100644 --- a/drivers/ram/rockchip/sdram_rk3188.c +++ b/drivers/ram/rockchip/sdram_rk3188.c @@ -816,10 +816,12 @@ static int setup_sdram(struct udevice *dev)
static int rk3188_dmc_of_to_plat(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_REAL) struct rk3188_sdram_params *params = dev_get_plat(dev); int ret;
+ if (!CONFIG_IS_ENABLED(OF_REAL)) + return 0; + /* rk3188 supports only one-channel */ params->num_channels = 1; ret = dev_read_u32_array(dev, "rockchip,pctl-timing", @@ -846,7 +848,6 @@ static int rk3188_dmc_of_to_plat(struct udevice *dev) ret = regmap_init_mem(dev_ofnode(dev), ¶ms->map); if (ret) return ret; -#endif
return 0; } diff --git a/drivers/ram/rockchip/sdram_rk322x.c b/drivers/ram/rockchip/sdram_rk322x.c index fd12008ed90..30e9c3ddc45 100644 --- a/drivers/ram/rockchip/sdram_rk322x.c +++ b/drivers/ram/rockchip/sdram_rk322x.c @@ -716,12 +716,14 @@ out:
static int rk322x_dmc_of_to_plat(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_REAL) struct rk322x_sdram_params *params = dev_get_plat(dev); const void *blob = gd->fdt_blob; int node = dev_of_offset(dev); int ret;
+ if (!CONFIG_IS_ENABLED(OF_REAL)) + return 0; + params->num_channels = 1;
ret = fdtdec_get_int_array(blob, node, "rockchip,pctl-timing", @@ -748,7 +750,6 @@ static int rk322x_dmc_of_to_plat(struct udevice *dev) ret = regmap_init_mem(dev_ofnode(dev), ¶ms->map); if (ret) return ret; -#endif
return 0; } diff --git a/drivers/ram/rockchip/sdram_rk3288.c b/drivers/ram/rockchip/sdram_rk3288.c index 2cb034f263f..f3e4a2808ab 100644 --- a/drivers/ram/rockchip/sdram_rk3288.c +++ b/drivers/ram/rockchip/sdram_rk3288.c @@ -973,10 +973,12 @@ static int setup_sdram(struct udevice *dev)
static int rk3288_dmc_of_to_plat(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_REAL) struct rk3288_sdram_params *params = dev_get_plat(dev); int ret;
+ if (!CONFIG_IS_ENABLED(OF_REAL)) + return 0; + /* Rk3288 supports dual-channel, set default channel num to 2 */ params->num_channels = 2; ret = dev_read_u32_array(dev, "rockchip,pctl-timing", @@ -1008,7 +1010,6 @@ static int rk3288_dmc_of_to_plat(struct udevice *dev) ret = regmap_init_mem(dev_ofnode(dev), ¶ms->map); if (ret) return ret; -#endif
return 0; } diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index c9631af2643..ce33fbbd7a6 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -3013,10 +3013,12 @@ static int sdram_init(struct dram_info *dram,
static int rk3399_dmc_of_to_plat(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_REAL) struct rockchip_dmc_plat *plat = dev_get_plat(dev); int ret;
+ if (!CONFIG_IS_ENABLED(OF_REAL)) + return 0; + ret = dev_read_u32_array(dev, "rockchip,sdram-params", (u32 *)&plat->sdram_params, sizeof(plat->sdram_params) / sizeof(u32)); @@ -3029,7 +3031,6 @@ static int rk3399_dmc_of_to_plat(struct udevice *dev) if (ret) printf("%s: regmap failed %d\n", __func__, ret);
-#endif return 0; }
diff --git a/drivers/spi/rk_spi.c b/drivers/spi/rk_spi.c index e504e306fd7..8309a5301f2 100644 --- a/drivers/spi/rk_spi.c +++ b/drivers/spi/rk_spi.c @@ -193,31 +193,31 @@ static int conv_of_plat(struct udevice *dev)
static int rockchip_spi_of_to_plat(struct udevice *bus) { -#if CONFIG_IS_ENABLED(OF_REAL) struct rockchip_spi_plat *plat = dev_get_plat(bus); struct rockchip_spi_priv *priv = dev_get_priv(bus); int ret;
- plat->base = dev_read_addr(bus); + if (CONFIG_IS_ENABLED(OF_REAL)) { + plat->base = dev_read_addr(bus);
- ret = clk_get_by_index(bus, 0, &priv->clk); - if (ret < 0) { - debug("%s: Could not get clock for %s: %d\n", __func__, - bus->name, ret); - return ret; - } + ret = clk_get_by_index(bus, 0, &priv->clk); + if (ret < 0) { + debug("%s: Could not get clock for %s: %d\n", __func__, + bus->name, ret); + return ret; + }
- plat->frequency = - dev_read_u32_default(bus, "spi-max-frequency", 50000000); - plat->deactivate_delay_us = - dev_read_u32_default(bus, "spi-deactivate-delay", 0); - plat->activate_delay_us = - dev_read_u32_default(bus, "spi-activate-delay", 0); + plat->frequency = dev_read_u32_default(bus, "spi-max-frequency", + 50000000); + plat->deactivate_delay_us = + dev_read_u32_default(bus, "spi-deactivate-delay", 0); + plat->activate_delay_us = + dev_read_u32_default(bus, "spi-activate-delay", 0);
- debug("%s: base=%x, max-frequency=%d, deactivate_delay=%d\n", - __func__, (uint)plat->base, plat->frequency, - plat->deactivate_delay_us); -#endif + debug("%s: base=%x, max-frequency=%d, deactivate_delay=%d\n", + __func__, (uint)plat->base, plat->frequency, + plat->deactivate_delay_us); + }
return 0; } diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index 655fb1407aa..f8ec312d715 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -176,11 +176,11 @@ static int spi_child_post_bind(struct udevice *dev)
static int spi_post_probe(struct udevice *bus) { -#if CONFIG_IS_ENABLED(OF_REAL) - struct dm_spi_bus *spi = dev_get_uclass_priv(bus); + if (CONFIG_IS_ENABLED(OF_REAL)) { + struct dm_spi_bus *spi = dev_get_uclass_priv(bus);
- spi->max_hz = dev_read_u32_default(bus, "spi-max-frequency", 0); -#endif + spi->max_hz = dev_read_u32_default(bus, "spi-max-frequency", 0); + } #if defined(CONFIG_NEEDS_MANUAL_RELOC) struct dm_spi_ops *ops = spi_get_ops(bus); static int reloc_done; diff --git a/drivers/timer/rockchip_timer.c b/drivers/timer/rockchip_timer.c index 96621479105..62eacb98689 100644 --- a/drivers/timer/rockchip_timer.c +++ b/drivers/timer/rockchip_timer.c @@ -55,8 +55,7 @@ ulong timer_get_boot_us(void) /* The timer is available */ rate = timer_get_rate(gd->timer); timer_get_count(gd->timer, &ticks); -#if CONFIG_IS_ENABLED(OF_REAL) - } else if (ret == -EAGAIN) { + } else if (CONFIG_IS_ENABLED(OF_REAL) && ret == -EAGAIN) { /* We have been called so early that the DM is not ready,... */ ofnode node = offset_to_ofnode(-1); struct rk_timer *timer = NULL; @@ -79,7 +78,6 @@ ulong timer_get_boot_us(void) debug("%s: could not read clock-frequency\n", __func__); return 0; } -#endif } else { return 0; } @@ -100,13 +98,13 @@ static u64 rockchip_timer_get_count(struct udevice *dev)
static int rockchip_clk_of_to_plat(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_REAL) - struct rockchip_timer_priv *priv = dev_get_priv(dev); + if (CONFIG_IS_ENABLED(OF_REAL)) { + struct rockchip_timer_priv *priv = dev_get_priv(dev);
- priv->timer = dev_read_addr_ptr(dev); - if (!priv->timer) - return -ENOENT; -#endif + priv->timer = dev_read_addr_ptr(dev); + if (!priv->timer) + return -ENOENT; + }
return 0; } diff --git a/drivers/timer/timer-uclass.c b/drivers/timer/timer-uclass.c index 52bddb9654f..6ea9e39e126 100644 --- a/drivers/timer/timer-uclass.c +++ b/drivers/timer/timer-uclass.c @@ -50,27 +50,29 @@ unsigned long notrace timer_get_rate(struct udevice *dev)
static int timer_pre_probe(struct udevice *dev) { -#if CONFIG_IS_ENABLED(OF_REAL) - struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); - struct clk timer_clk; - int err; - ulong ret; + if (CONFIG_IS_ENABLED(OF_REAL)) { + struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct clk timer_clk; + int err; + ulong ret;
- /* It is possible that a timer device has a null ofnode */ - if (!dev_has_ofnode(dev)) - return 0; + /* + * It is possible that a timer device has a null ofnode + */ + if (!dev_has_ofnode(dev)) + return 0;
- err = clk_get_by_index(dev, 0, &timer_clk); - if (!err) { - ret = clk_get_rate(&timer_clk); - if (IS_ERR_VALUE(ret)) - return ret; - uc_priv->clock_rate = ret; - } else { - uc_priv->clock_rate = - dev_read_u32_default(dev, "clock-frequency", 0); + err = clk_get_by_index(dev, 0, &timer_clk); + if (!err) { + ret = clk_get_rate(&timer_clk); + if (IS_ERR_VALUE(ret)) + return ret; + uc_priv->clock_rate = ret; + } else { + uc_priv->clock_rate = + dev_read_u32_default(dev, "clock-frequency", 0); + } } -#endif
return 0; } @@ -136,23 +138,23 @@ int notrace dm_timer_init(void) if (gd->dm_root == NULL) return -EAGAIN;
-#if CONFIG_IS_ENABLED(OF_REAL) - /* Check for a chosen timer to be used for tick */ - node = ofnode_get_chosen_node("tick-timer"); - - if (ofnode_valid(node) && - uclass_get_device_by_ofnode(UCLASS_TIMER, node, &dev)) { - /* - * If the timer is not marked to be bound before - * relocation, bind it anyway. - */ - if (!lists_bind_fdt(dm_root(), node, &dev, false)) { - ret = device_probe(dev); - if (ret) - return ret; + if (CONFIG_IS_ENABLED(OF_REAL)) { + /* Check for a chosen timer to be used for tick */ + node = ofnode_get_chosen_node("tick-timer"); + + if (ofnode_valid(node) && + uclass_get_device_by_ofnode(UCLASS_TIMER, node, &dev)) { + /* + * If the timer is not marked to be bound before + * relocation, bind it anyway. + */ + if (!lists_bind_fdt(dm_root(), node, &dev, false)) { + ret = device_probe(dev); + if (ret) + return ret; + } } } -#endif
if (!dev) { /* Fall back to the first available timer */
Simplify some of the Makefile rules using this Kconfig.
Makefile | 7 ++----- lib/Makefile | 5 +---- scripts/Makefile.spl | 9 +++------ 3 files changed, 6 insertions(+), 15 deletions(-)
diff --git a/Makefile b/Makefile index 269e353a28a..378eaccbc12 100644 --- a/Makefile +++ b/Makefile @@ -1304,10 +1304,6 @@ u-boot.ldr: u-boot # Use 'make BINMAN_VERBOSE=3' to set vebosity level default_dt := $(if $(DEVICE_TREE),$(DEVICE_TREE),$(CONFIG_DEFAULT_DEVICE_TREE))
-# Tell binman whether we have a devicetree for SPL and TPL -have_spl_dt := $(if $(CONFIG_SPL_OF_PLATDATA),,$(CONFIG_SPL_OF_CONTROL)) -have_tpl_dt := $(if $(CONFIG_TPL_OF_PLATDATA),,$(CONFIG_TPL_OF_CONTROL)) - quiet_cmd_binman = BINMAN $@ cmd_binman = $(srctree)/tools/binman/binman $(if $(BINMAN_DEBUG),-D) \ --toolpath $(objtree)/tools \ @@ -1321,7 +1317,8 @@ cmd_binman = $(srctree)/tools/binman/binman $(if $(BINMAN_DEBUG),-D) \ -a scp-path=$(SCP) \ -a spl-bss-pad=$(if $(CONFIG_SPL_SEPARATE_BSS),,1) \ -a tpl-bss-pad=$(if $(CONFIG_TPL_SEPARATE_BSS),,1) \ - -a spl-dtb=$(have_spl_dt) -a tpl-dtb=$(have_tpl_dt) \ + -a spl-dtb=$(CONFIG_SPL_OF_REAL) \ + -a tpl-dtb=$(CONFIG_SPL_OF_REAL) \ $(BINMAN_$(@F))
OBJCOPYFLAGS_u-boot.ldr.hex := -I binary -O ihex diff --git a/lib/Makefile b/lib/Makefile index 07c2ccd7cfd..ecb32ae1057 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -79,10 +79,7 @@ obj-$(CONFIG_$(SPL_)LIB_RATIONAL) += rational.o obj-$(CONFIG_LIBAVB) += libavb/
obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += libfdt/ -ifneq ($(CONFIG_$(SPL_TPL_)BUILD)$(CONFIG_$(SPL_TPL_)OF_PLATDATA),yy) -obj-$(CONFIG_$(SPL_TPL_)OF_CONTROL) += fdtdec_common.o -obj-$(CONFIG_$(SPL_TPL_)OF_CONTROL) += fdtdec.o -endif +obj-$(CONFIG_$(SPL_TPL_)OF_REAL) += fdtdec_common.o fdtdec.o
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_SPL_YMODEM_SUPPORT) += crc16.o diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 25a3e7fa52e..fb28b2b10f0 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -295,18 +295,15 @@ else FINAL_DTB_CONTAINER = $(obj)/$(SPL_BIN).multidtb.fit endif
-# Build the .dtb file if: -# - we are not using OF_PLATDATA -# - we are using OF_CONTROL +# Build the .dtb file if needed +# - OF_REAL is enabled # - we have either OF_SEPARATE or OF_HOSTFILE build_dtb := -ifeq ($(CONFIG_$(SPL_TPL_)OF_PLATDATA),) -ifneq ($(CONFIG_$(SPL_TPL_)OF_CONTROL),) +ifneq ($(CONFIG_$(SPL_TPL_)OF_REAL),) ifeq ($(CONFIG_OF_SEPARATE)$(CONFIG_OF_HOSTFILE),y) build_dtb := y endif endif -endif
ifneq ($(build_dtb),) $(obj)/$(SPL_BIN)-dtb.bin: $(obj)/$(SPL_BIN)-nodtb.bin \
These structs do not have comments at present. Add them.
include/dt-structs.h | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+)
diff --git a/include/dt-structs.h b/include/dt-structs.h index f9ccaf56a46..fa1622cb1dc 100644 --- a/include/dt-structs.h +++ b/include/dt-structs.h @@ -10,16 +10,43 @@ #if CONFIG_IS_ENABLED(OF_PLATDATA) struct driver_info;
+/** + * struct phandle_0_arg - hold a phandle record with no arguments + * + * This holds a phandle pointing to another device. See 'Indexes' in the + * of-plat-rst documentation. + * + * @idx: udevice index (or driver_info index if !OF_PLATDATA_INST) + * @arg: arguments + */ struct phandle_0_arg { uint idx; int arg[0]; };
+/** + * struct phandle_2_arg - hold a phandle record with up to one argument + * + * This holds a phandle pointing to another device. See 'Indexes' in the + * of-plat-rst documentation. + * + * @idx: udevice index (or driver_info index if !OF_PLATDATA_INST) + * @arg: arguments + */ struct phandle_1_arg { uint idx; int arg[1]; };
+/** + * struct phandle_2_arg - hold a phandle record with up to two arguments + * + * This holds a phandle pointing to another device. See 'Indexes' in the + * of-plat-rst documentation. + * + * @idx: udevice index (or driver_info index if !OF_PLATDATA_INST) + * @arg: arguments + */ struct phandle_2_arg { uint idx; int arg[2];
This is actually a misnomer now, since the phandle info may contain a driver_info index or a udevice index. Rename it to use the word 'phandle', which seems more accurate. Add a comment while we are here.
Also add a test for this function.
drivers/clk/clk-uclass.c | 7 +++---- drivers/mmc/ftsdc010_mci.c | 2 +- drivers/mmc/rockchip_dw_mmc.c | 2 +- drivers/mmc/rockchip_sdhci.c | 2 +- drivers/ram/rockchip/sdram_rk3399.c | 2 +- drivers/spi/rk_spi.c | 2 +- include/clk.h | 31 ++++++++++++++++++++++++++--- test/dm/of_platdata.c | 19 ++++++++++++++++++ 8 files changed, 55 insertions(+), 12 deletions(-)
diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index 7b1ea076afd..493018b33eb 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -36,8 +36,8 @@ struct clk *dev_get_clk_ptr(struct udevice *dev) }
#if CONFIG_IS_ENABLED(OF_PLATDATA) -int clk_get_by_driver_info(struct udevice *dev, struct phandle_1_arg *cells, - struct clk *clk) +int clk_get_by_phandle(struct udevice *dev, const struct phandle_1_arg *cells, + struct clk *clk) { int ret;
@@ -413,6 +413,7 @@ int clk_get_by_name(struct udevice *dev, const char *name, struct clk *clk)
return clk_get_by_index(dev, index, clk); } +#endif /* OF_REAL */
int clk_get_by_name_nodev(ofnode node, const char *name, struct clk *clk) { @@ -465,8 +466,6 @@ int clk_release_all(struct clk *clk, int count) return 0; }
-#endif /* OF_REAL */ - int clk_request(struct udevice *dev, struct clk *clk) { const struct clk_ops *ops; diff --git a/drivers/mmc/ftsdc010_mci.c b/drivers/mmc/ftsdc010_mci.c index b8cafeb0431..570d54cf9d8 100644 --- a/drivers/mmc/ftsdc010_mci.c +++ b/drivers/mmc/ftsdc010_mci.c @@ -433,7 +433,7 @@ static int ftsdc010_mmc_probe(struct udevice *dev) chip->priv = dev; chip->dev_index = 1; memcpy(priv->minmax, dtplat->clock_freq_min_max, sizeof(priv->minmax)); - ret = clk_get_by_driver_info(dev, dtplat->clocks, &priv->clk); + ret = clk_get_by_phandle(dev, dtplat->clocks, &priv->clk); if (ret < 0) return ret; #endif diff --git a/drivers/mmc/rockchip_dw_mmc.c b/drivers/mmc/rockchip_dw_mmc.c index 855c0e7af52..7f8dea1e343 100644 --- a/drivers/mmc/rockchip_dw_mmc.c +++ b/drivers/mmc/rockchip_dw_mmc.c @@ -123,7 +123,7 @@ static int rockchip_dwmmc_probe(struct udevice *dev) priv->minmax[0] = 400000; /* 400 kHz */ priv->minmax[1] = dtplat->max_frequency;
- ret = clk_get_by_driver_info(dev, dtplat->clocks, &priv->clk); + ret = clk_get_by_phandle(dev, dtplat->clocks, &priv->clk); if (ret < 0) return ret; #else diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index 93e58c2d3f1..a6ee7143953 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -46,7 +46,7 @@ static int arasan_sdhci_probe(struct udevice *dev) host->name = dev->name; host->ioaddr = map_sysmem(dtplat->reg[0], dtplat->reg[1]); max_frequency = dtplat->max_frequency; - ret = clk_get_by_driver_info(dev, dtplat->clocks, &clk); + ret = clk_get_by_phandle(dev, dtplat->clocks, &clk); #else max_frequency = dev_read_u32_default(dev, "max-frequency", 0); ret = clk_get_by_index(dev, 0, &clk); diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index ce33fbbd7a6..c0a06dcaed0 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -3107,7 +3107,7 @@ static int rk3399_dmc_init(struct udevice *dev) priv->cic, priv->pmugrf, priv->pmusgrf, priv->pmucru, priv->pmu);
#if CONFIG_IS_ENABLED(OF_PLATDATA) - ret = clk_get_by_driver_info(dev, dtplat->clocks, &priv->ddr_clk); + ret = clk_get_by_phandle(dev, dtplat->clocks, &priv->ddr_clk); #else ret = clk_get_by_index(dev, 0, &priv->ddr_clk); #endif diff --git a/drivers/spi/rk_spi.c b/drivers/spi/rk_spi.c index 8309a5301f2..cb80be77ae9 100644 --- a/drivers/spi/rk_spi.c +++ b/drivers/spi/rk_spi.c @@ -183,7 +183,7 @@ static int conv_of_plat(struct udevice *dev)
plat->base = dtplat->reg[0]; plat->frequency = 20000000; - ret = clk_get_by_driver_info(dev, dtplat->clocks, &priv->clk); + ret = clk_get_by_phandle(dev, dtplat->clocks, &priv->clk); if (ret < 0) return ret;
diff --git a/include/clk.h b/include/clk.h index f34401f48ee..a928879b122 100644 --- a/include/clk.h +++ b/include/clk.h @@ -89,11 +89,36 @@ struct clk_bulk {
#if CONFIG_IS_ENABLED(OF_CONTROL) && CONFIG_IS_ENABLED(CLK) struct phandle_1_arg; -int clk_get_by_driver_info(struct udevice *dev, - struct phandle_1_arg *cells, struct clk *clk); +/** + * clk_get_by_phandle() - Get a clock by its phandle information (of-platadata) + * + * This function is used when of-platdata is enabled. + * + * This looks up a clock using the phandle info. With dtoc, each phandle in the + * 'clocks' property is transformed into an idx representing the device. For + * example: + * + * clocks = <&dpll_mpu_ck 23>; + * + * might result in: + * + * .clocks = {1, {23}},}, + * + * indicating that the clock is udevice idx 1 in dt-plat.c with an argument of + * 23. This function can return a valid clock given the above information. In + * this example it would return a clock containing the 'dpll_mpu_ck' device and + * the clock ID 23. + * + * @dev: Device containing the phandle + * @cells: Phandle info + * @clock: A pointer to a clock struct to initialise + * @return 0 if OK, or a negative error code. + */ +int clk_get_by_phandle(struct udevice *dev, const struct phandle_1_arg *cells, + struct clk *clk);
/** - * clk_get_by_index - Get/request a clock by integer index. + * clk_get_by_index() - Get/request a clock by integer index. * * This looks up and requests a clock. The index is relative to the client * device; each device is assumed to have n clocks associated with it somehow, diff --git a/test/dm/of_platdata.c b/test/dm/of_platdata.c index 0463cf0b433..c4a2d114104 100644 --- a/test/dm/of_platdata.c +++ b/test/dm/of_platdata.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+
#include <common.h> +#include <clk.h> #include <dm.h> #include <dt-structs.h> #include <dm/test.h> @@ -222,3 +223,21 @@ static int dm_test_of_plat_parent(struct unit_test_state *uts) } DM_TEST(dm_test_of_plat_parent, UT_TESTF_SCAN_PDATA); #endif + +/* Test clocks with of-platdata */ +static int dm_test_of_plat_clk(struct unit_test_state *uts) +{ + struct dtd_sandbox_clk_test *plat; + struct udevice *dev; + struct clk clk; + + ut_assertok(uclass_first_device_err(UCLASS_MISC, &dev)); + ut_asserteq_str("sandbox_clk_test", dev->name); + plat = dev_get_plat(dev); + + ut_assertok(clk_get_by_phandle(dev, &plat->clocks[0], &clk)); + ut_asserteq_str("sandbox_fixed_clock", clk.dev->name); + + return 0; +} +DM_TEST(dm_test_of_plat_clk, UT_TESTF_SCAN_PDATA);
struct clk *clk)
{ int ret;struct clk *clk)
- ret = clk_get_by_phandle(dev, dtplat->clocks, &priv->clk); if (ret < 0) return ret; #endif
- ret = clk_get_by_phandle(dev, dtplat->clocks, &priv->clk); if (ret < 0) return ret; #else
- ret = clk_get_by_phandle(dev, dtplat->clocks, &clk); #else max_frequency = dev_read_u32_default(dev, "max-frequency", 0); ret = clk_get_by_index(dev, 0, &clk);
- ret = clk_get_by_phandle(dev, dtplat->clocks, &priv->ddr_clk); #else ret = clk_get_by_index(dev, 0, &priv->ddr_clk); #endif
- clk_get_by_phandle() - Get a clock by its phandle information (of-platadata)
- This function is used when of-platdata is enabled.
- This looks up a clock using the phandle info. With dtoc, each phandle in the
- 'clocks' property is transformed into an idx representing the device. For
- example:
- clocks = <&dpll_mpu_ck 23>;
- might result in:
- .clocks = {1, {23}},},
One too many closing braces?
- indicating that the clock is udevice idx 1 in dt-plat.c with an argument of
- This function can return a valid clock given the above information. In
- this example it would return a clock containing the 'dpll_mpu_ck' device and
- the clock ID 23.
- @dev: Device containing the phandle
- @cells: Phandle info
- @clock: A pointer to a clock struct to initialise
- @return 0 if OK, or a negative error code.
struct clk *clk);
- clk_get_by_index - Get/request a clock by integer index.
- clk_get_by_index() - Get/request a clock by integer index.
- This looks up and requests a clock. The index is relative to the client
- device; each device is assumed to have n clocks associated with it somehow,
- struct dtd_sandbox_clk_test *plat;
- struct udevice *dev;
- struct clk clk;
- ut_assertok(uclass_first_device_err(UCLASS_MISC, &dev));
- ut_asserteq_str("sandbox_clk_test", dev->name);
- plat = dev_get_plat(dev);
- ut_assertok(clk_get_by_phandle(dev, &plat->clocks[0], &clk));
- ut_asserteq_str("sandbox_fixed_clock", clk.dev->name);
This error can be confusing so mention it specifically in the documentation.
doc/develop/driver-model/of-plat.rst | 26 +++++++++++++++++++++++++- 1 file changed, 25 insertions(+), 1 deletion(-)
diff --git a/doc/develop/driver-model/of-plat.rst b/doc/develop/driver-model/of-plat.rst index 61aa2bc3ed9..921178cd4aa 100644 --- a/doc/develop/driver-model/of-plat.rst +++ b/doc/develop/driver-model/of-plat.rst @@ -634,7 +634,7 @@ then dtoc looks at the first compatible string ("rockchip,rk3188-grf"), converts that to a C identifier (rockchip_rk3188_grf) and then looks for that.
Various things can cause dtoc to fail to find the driver and it tries to -warn about these. For example: +warn about these. For example::
rockchip_rk3188_uart: Missing .compatible in drivers/serial/serial_rockchip.c : WARNING: the driver rockchip_rk3188_uart was not found in the driver list @@ -649,6 +649,30 @@ Checks are also made to confirm that the referenced driver has a .compatible member and a .id member. The first provides the array of compatible strings and the second provides the uclass ID.
+Another error that can crop up is something like:: + + spl/dts/dt-device.c:257:38: error: invalid application of ‘sizeof’ to + incomplete type ‘struct sandbox_irq_priv’ + 257 | u8 _sandbox_irq_priv_irq_sbox[sizeof(struct sandbox_irq_priv)] + | ^~~~~~ + +This indicates that `struct sandbox_irq_priv` is not defined anywhere. The +solution is to add a DM_HEADER() line, as below, so this is included in the +dt-device.c file:: + + U_BOOT_DRIVER(sandbox_irq) = { + .name = "sandbox_irq", + .id = UCLASS_IRQ, + .of_match = sandbox_irq_ids, + .ops = &sandbox_irq_ops, + .priv_auto = sizeof(struct sandbox_irq_priv), + DM_HEADER(<asm/irq.h>) + }; + +Note that there is no dependency checking on the above, so U-Boot will not +regenerate the dt-device.c file when you update the source file (here, +`irq_sandbox.c`). You need to run `make mrproper` first to get a fresh build. +
Caveats -------
This function is available but not exported. More generally it does not really work as intended.
Reimplement it and add a sandbox test too.
arch/sandbox/dts/sandbox.dtsi | 13 +++++++++++++ arch/sandbox/include/asm/irq.h | 20 ++++++++++++++++++++ drivers/misc/Makefile | 2 +- drivers/misc/irq-uclass.c | 10 ++++++++-- drivers/misc/irq_sandbox.c | 15 +++------------ drivers/misc/irq_sandbox_test.c | 22 ++++++++++++++++++++++ include/irq.h | 29 +++++++++++++++++++++++++++++ test/dm/of_platdata.c | 26 ++++++++++++++++++++++---- tools/dtoc/dtb_platdata.py | 1 + 9 files changed, 119 insertions(+), 19 deletions(-) create mode 100644 arch/sandbox/include/asm/irq.h create mode 100644 drivers/misc/irq_sandbox_test.c
diff --git a/arch/sandbox/dts/sandbox.dtsi b/arch/sandbox/dts/sandbox.dtsi index 200fcab6a41..819e81464af 100644 --- a/arch/sandbox/dts/sandbox.dtsi +++ b/arch/sandbox/dts/sandbox.dtsi @@ -123,6 +123,19 @@ #sound-dai-cells = <1>; };
+ irq_sandbox: irq-sbox { + u-boot,dm-spl; + compatible = "sandbox,irq"; + interrupt-controller; + #interrupt-cells = <2>; + }; + + irq-test { + u-boot,dm-spl; + compatible = "sandbox,irq-test"; + interrupts-extended = <&irq_sandbox 3 0>; + }; + lcd { u-boot,dm-pre-proper; compatible = "sandbox,lcd-sdl"; diff --git a/arch/sandbox/include/asm/irq.h b/arch/sandbox/include/asm/irq.h new file mode 100644 index 00000000000..f73fec74f5c --- /dev/null +++ b/arch/sandbox/include/asm/irq.h @@ -0,0 +1,20 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2021 Google LLC + */ + +#ifndef __SANDBOX_IRQ_H +#define __SANDBOX_IRQ_H + +/** + * struct sandbox_irq_priv - private data for this driver + * + * @count: Counts the number calls to the read_and_clear() method + * @pending: true if an interrupt is pending, else false + */ +struct sandbox_irq_priv { + int count; + bool pending; +}; + +#endif /* __SANDBOX_IRQ_H */ diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 0c67d43a5d4..844a46f9311 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -42,7 +42,7 @@ obj-$(CONFIG_GDSYS_IOEP) += gdsys_ioep.o obj-$(CONFIG_GDSYS_RXAUI_CTRL) += gdsys_rxaui_ctrl.o obj-$(CONFIG_GDSYS_SOC) += gdsys_soc.o obj-$(CONFIG_IRQ) += irq-uclass.o -obj-$(CONFIG_SANDBOX) += irq_sandbox.o +obj-$(CONFIG_SANDBOX) += irq_sandbox.o irq_sandbox_test.o obj-$(CONFIG_$(SPL_)I2C_EEPROM) += i2c_eeprom.o obj-$(CONFIG_IHS_FPGA) += ihs_fpga.o obj-$(CONFIG_IMX8) += imx8/ diff --git a/drivers/misc/irq-uclass.c b/drivers/misc/irq-uclass.c index 3aa26f61d9e..eb9f3b902f4 100644 --- a/drivers/misc/irq-uclass.c +++ b/drivers/misc/irq-uclass.c @@ -64,8 +64,8 @@ int irq_read_and_clear(struct irq *irq) }
#if CONFIG_IS_ENABLED(OF_PLATDATA) -int irq_get_by_driver_info(struct udevice *dev, - struct phandle_1_arg *cells, struct irq *irq) +int irq_get_by_phandle(struct udevice *dev, const struct phandle_2_arg *cells, + struct irq *irq) { int ret;
@@ -74,6 +74,12 @@ int irq_get_by_driver_info(struct udevice *dev, return ret; irq->id = cells->arg[0];
+ /* + * Note: we could call irq_of_xlate_default() here to do this properly. + * For now, this is good enough for existing cases. + */ + irq->flags = cells->arg[1]; + return 0; } #else diff --git a/drivers/misc/irq_sandbox.c b/drivers/misc/irq_sandbox.c index 1f7e62e6614..8b5573fcadd 100644 --- a/drivers/misc/irq_sandbox.c +++ b/drivers/misc/irq_sandbox.c @@ -9,19 +9,9 @@ #include <dm.h> #include <irq.h> #include <acpi/acpi_device.h> +#include <asm/irq.h> #include <asm/test.h>
-/** - * struct sandbox_irq_priv - private data for this driver - * - * @count: Counts the number calls to the read_and_clear() method - * @pending: true if an interrupt is pending, else false - */ -struct sandbox_irq_priv { - int count; - bool pending; -}; - static int sandbox_set_polarity(struct udevice *dev, uint irq, bool active_low) { if (irq > 10) @@ -103,10 +93,11 @@ static const struct udevice_id sandbox_irq_ids[] = { { } };
-U_BOOT_DRIVER(sandbox_irq_drv) = { +U_BOOT_DRIVER(sandbox_irq) = { .name = "sandbox_irq", .id = UCLASS_IRQ, .of_match = sandbox_irq_ids, .ops = &sandbox_irq_ops, .priv_auto = sizeof(struct sandbox_irq_priv), + DM_HEADER(<asm/irq.h>) }; diff --git a/drivers/misc/irq_sandbox_test.c b/drivers/misc/irq_sandbox_test.c new file mode 100644 index 00000000000..95c45c24edb --- /dev/null +++ b/drivers/misc/irq_sandbox_test.c @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Sandbox driver for testing interrupts with of-platdata + * + * Copyright 2021 Google LLC + */ + +#include <common.h> +#include <dm.h> +#include <irq.h> +#include <asm/irq.h> + +static const struct udevice_id sandbox_irq_test_ids[] = { + { .compatible = "sandbox,irq-test" }, + { } +}; + +U_BOOT_DRIVER(sandbox_irq_test) = { + .name = "sandbox_irq_test", + .id = UCLASS_MISC, + .of_match = sandbox_irq_test_ids, +}; diff --git a/include/irq.h b/include/irq.h index 8527e4dd797..a0965e44209 100644 --- a/include/irq.h +++ b/include/irq.h @@ -200,6 +200,35 @@ int irq_restore_polarities(struct udevice *dev); */ int irq_read_and_clear(struct irq *irq);
+struct phandle_2_arg; +/** + * irq_get_by_phandle() - Get an irq by its phandle information (of-platadata) + * + * This function is used when of-platdata is enabled. + * + * This looks up an irq using the phandle info. With dtoc, each phandle in the + * 'interrupts-extended ' property is transformed into an idx representing the + * device. For example: + * + * interrupts-extended = <&acpi_gpe 0x3c 0>; + * + * might result in: + * + * .interrupts_extended = {6, {0x3c, 0}},}, + * + * indicating that the irq is udevice idx 6 in dt-plat.c with a arguments of + * 0x3c and 0.This function can return a valid irq given the above + * information. In this example it would return an irq containing the + * 'acpi_gpe' device and the irq ID 0x3c. + * + * @dev: Device containing the phandle + * @cells: Phandle info + * @irq: A pointer to a irq struct to initialise + * @return 0 if OK, or a negative error code + */ +int irq_get_by_phandle(struct udevice *dev, const struct phandle_2_arg *cells, + struct irq *irq); + /** * irq_get_by_index - Get/request an irq by integer index. * diff --git a/test/dm/of_platdata.c b/test/dm/of_platdata.c index c4a2d114104..082989021d9 100644 --- a/test/dm/of_platdata.c +++ b/test/dm/of_platdata.c @@ -4,6 +4,7 @@ #include <clk.h> #include <dm.h> #include <dt-structs.h> +#include <irq.h> #include <dm/test.h> #include <test/test.h> #include <test/ut.h> @@ -28,11 +29,9 @@ static int dm_test_of_plat_props(struct unit_test_state *uts) struct udevice *dev; int i;
- /* Skip the clock */ - ut_assertok(uclass_first_device_err(UCLASS_MISC, &dev)); - ut_asserteq_str("sandbox_clk_test", dev->name); + ut_assertok(uclass_get_device_by_name(UCLASS_MISC, "sandbox_spl_test", + &dev));
- ut_assertok(uclass_next_device_err(&dev)); plat = dev_get_plat(dev); ut_assert(plat->boolval); ut_asserteq(1, plat->intval); @@ -241,3 +240,22 @@ static int dm_test_of_plat_clk(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_of_plat_clk, UT_TESTF_SCAN_PDATA); + +/* Test irqs with of-platdata */ +static int dm_test_of_plat_irq(struct unit_test_state *uts) +{ + struct dtd_sandbox_irq_test *plat; + struct udevice *dev; + struct irq irq; + + ut_assertok(uclass_get_device_by_name(UCLASS_MISC, "sandbox_irq_test", + &dev)); + plat = dev_get_plat(dev); + + ut_assertok(irq_get_by_phandle(dev, &plat->interrupts_extended[0], + &irq)); + ut_asserteq_str("sandbox_irq", irq.dev->name); + + return 0; +} +DM_TEST(dm_test_of_plat_irq, UT_TESTF_SCAN_PDATA); diff --git a/tools/dtoc/dtb_platdata.py b/tools/dtoc/dtb_platdata.py index 869c92b49bf..3bb5c680f2e 100644 --- a/tools/dtoc/dtb_platdata.py +++ b/tools/dtoc/dtb_platdata.py @@ -62,6 +62,7 @@ VAL_PREFIX = 'dtv_' # a phandle property. PHANDLE_PROPS = { 'clocks': '#clock-cells', + 'interrupts-extended': '#interrupt-cells', 'gpios': '#gpio-cells', 'sandbox,emul': '#emul-cells', }
Add support for accessing GPIOs using of-plata. This uses the same mechanism as for clocks, but allows use of the xlate() method so that the driver can interpret the parameters.
Update the condition for GPIO_HOG so that it is not built into SPL, since it needs SPL_OF_REAL which is not enabled in sandbox_spl.
arch/sandbox/dts/sandbox.dtsi | 8 +++++++- configs/sandbox_noinst_defconfig | 2 ++ configs/sandbox_spl_defconfig | 2 ++ drivers/gpio/Makefile | 4 ++-- drivers/gpio/gpio-uclass.c | 26 ++++++++++++++++++++++++-- drivers/gpio/sandbox.c | 14 ++++++++++---- drivers/gpio/sandbox_test.c | 21 +++++++++++++++++++++ include/asm-generic/gpio.h | 5 +++++ test/dm/of_platdata.c | 20 ++++++++++++++++++++ 9 files changed, 93 insertions(+), 9 deletions(-) create mode 100644 drivers/gpio/sandbox_test.c
diff --git a/arch/sandbox/dts/sandbox.dtsi b/arch/sandbox/dts/sandbox.dtsi index 819e81464af..2d42cda6ebb 100644 --- a/arch/sandbox/dts/sandbox.dtsi +++ b/arch/sandbox/dts/sandbox.dtsi @@ -65,7 +65,7 @@ };
gpio_b: gpios@1 { - u-boot,dm-pre-proper; + u-boot,dm-spl; gpio-controller; compatible = "sandbox,gpio"; #gpio-cells = <2>; @@ -73,6 +73,12 @@ sandbox,gpio-count = <10>; };
+ gpio-test { + u-boot,dm-spl; + compatible = "sandbox,gpio-test"; + test-gpios = <&gpio_b 3 0>; + }; + hexagon { compatible = "demo-simple"; colour = "white"; diff --git a/configs/sandbox_noinst_defconfig b/configs/sandbox_noinst_defconfig index 88443f5ab27..4a6f0ee8b87 100644 --- a/configs/sandbox_noinst_defconfig +++ b/configs/sandbox_noinst_defconfig @@ -1,4 +1,5 @@ CONFIG_SYS_TEXT_BASE=0x200000 +CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 @@ -120,6 +121,7 @@ CONFIG_SANDBOX_GPIO=y CONFIG_I2C_CROS_EC_TUNNEL=y CONFIG_I2C_CROS_EC_LDO=y CONFIG_DM_I2C_GPIO=y +# CONFIG_SPL_DM_I2C_GPIO is not set CONFIG_SYS_I2C_SANDBOX=y CONFIG_I2C_MUX=y CONFIG_I2C_ARB_GPIO_CHALLENGE=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 77dd83cf6fd..0e8098e2f40 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -1,4 +1,5 @@ CONFIG_SYS_TEXT_BASE=0x200000 +CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 @@ -122,6 +123,7 @@ CONFIG_SANDBOX_GPIO=y CONFIG_I2C_CROS_EC_TUNNEL=y CONFIG_I2C_CROS_EC_LDO=y CONFIG_DM_I2C_GPIO=y +# CONFIG_SPL_DM_I2C_GPIO is not set CONFIG_SYS_I2C_SANDBOX=y CONFIG_I2C_MUX=y CONFIG_I2C_ARB_GPIO_CHALLENGE=y diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 16b09fb1b5b..662ed5050b5 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -32,7 +32,7 @@ obj-$(CONFIG_ROCKCHIP_GPIO) += rk_gpio.o obj-$(CONFIG_RCAR_GPIO) += gpio-rcar.o obj-$(CONFIG_RZA1_GPIO) += gpio-rza1.o obj-$(CONFIG_S5P) += s5p_gpio.o -obj-$(CONFIG_SANDBOX_GPIO) += sandbox.o +obj-$(CONFIG_SANDBOX_GPIO) += sandbox.o sandbox_test.o obj-$(CONFIG_TEGRA_GPIO) += tegra_gpio.o obj-$(CONFIG_TEGRA186_GPIO) += tegra186_gpio.o obj-$(CONFIG_DA8XX_GPIO) += da8xx_gpio.o @@ -61,7 +61,7 @@ obj-$(CONFIG_OCTEON_GPIO) += octeon_gpio.o obj-$(CONFIG_MVEBU_GPIO) += mvebu_gpio.o obj-$(CONFIG_MSM_GPIO) += msm_gpio.o obj-$(CONFIG_$(SPL_)PCF8575_GPIO) += pcf8575_gpio.o -obj-$(CONFIG_PM8916_GPIO) += pm8916_gpio.o +obj-$(CONFIG_$(SPL_TPL_)PM8916_GPIO) += pm8916_gpio.o obj-$(CONFIG_MT7620_GPIO) += mt7620_gpio.o obj-$(CONFIG_MT7621_GPIO) += mt7621_gpio.o obj-$(CONFIG_MSCC_SGPIO) += mscc_sgpio.o diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index e0d3ae6f8cf..bb2f23241ed 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -7,6 +7,7 @@
#include <common.h> #include <dm.h> +#include <dt-structs.h> #include <log.h> #include <dm/devres.h> #include <dm/device_compat.h> @@ -231,7 +232,7 @@ static int gpio_find_and_xlate(struct gpio_desc *desc, return gpio_xlate_offs_flags(desc->dev, desc, args); }
-#if defined(CONFIG_GPIO_HOG) +#if CONFIG_IS_ENABLED(GPIO_HOG)
struct gpio_hog_priv { struct gpio_desc gpiod; @@ -1226,6 +1227,27 @@ int gpio_get_list_count(struct udevice *dev, const char *list_name) } #endif /* OF_PLATDATA */
+#if CONFIG_IS_ENABLED(OF_PLATDATA) +int gpio_request_by_phandle(struct udevice *dev, + const struct phandle_2_arg *cells, + struct gpio_desc *desc, int flags) +{ + struct ofnode_phandle_args args; + struct udevice *gpio_dev; + const int index = 0; + int ret; + + ret = device_get_by_ofplat_idx(cells->idx, &gpio_dev); + if (ret) + return ret; + args.args[0] = cells->arg[0]; + args.args[1] = cells->arg[1]; + + return gpio_request_tail(ret, NULL, &args, NULL, index, desc, flags, + index > 0, gpio_dev); +} +#endif + int dm_gpio_free(struct udevice *dev, struct gpio_desc *desc) { /* For now, we don't do any checking of dev */ @@ -1430,7 +1452,7 @@ static int gpio_post_bind(struct udevice *dev) } #endif
- if (IS_ENABLED(CONFIG_GPIO_HOG)) { + if (CONFIG_IS_ENABLED(OF_REAL) && IS_ENABLED(CONFIG_GPIO_HOG)) { dev_for_each_subnode(node, dev) { if (ofnode_read_bool(node, "gpio-hog")) { const char *name = ofnode_get_name(node); diff --git a/drivers/gpio/sandbox.c b/drivers/gpio/sandbox.c index d008fdd2224..106b2a7b27c 100644 --- a/drivers/gpio/sandbox.c +++ b/drivers/gpio/sandbox.c @@ -323,11 +323,13 @@ static const struct dm_gpio_ops gpio_sandbox_ops = {
static int sandbox_gpio_of_to_plat(struct udevice *dev) { - struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + if (CONFIG_IS_ENABLED(OF_REAL)) { + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev);
- uc_priv->gpio_count = dev_read_u32_default(dev, "sandbox,gpio-count", - 0); - uc_priv->bank_name = dev_read_string(dev, "gpio-bank-name"); + uc_priv->gpio_count = + dev_read_u32_default(dev, "sandbox,gpio-count", 0); + uc_priv->bank_name = dev_read_string(dev, "gpio-bank-name"); + }
return 0; } @@ -371,6 +373,8 @@ U_BOOT_DRIVER(sandbox_gpio) = {
DM_DRIVER_ALIAS(sandbox_gpio, sandbox_gpio_alias)
+#if CONFIG_IS_ENABLED(PINCTRL) + /* pincontrol: used only to check GPIO pin configuration (pinmux command) */
struct sb_pinctrl_priv { @@ -579,3 +583,5 @@ U_BOOT_DRIVER(sandbox_pinctrl_gpio) = { .priv_auto = sizeof(struct sb_pinctrl_priv), ACPI_OPS_PTR(&pinctrl_sandbox_acpi_ops) }; + +#endif /* PINCTRL */ diff --git a/drivers/gpio/sandbox_test.c b/drivers/gpio/sandbox_test.c new file mode 100644 index 00000000000..c76e1997419 --- /dev/null +++ b/drivers/gpio/sandbox_test.c @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Sandbox driver for testing GPIOs with of-platdata + * + * Copyright 2021 Google LLC + */ + +#include <common.h> +#include <dm.h> +#include <asm-generic/gpio.h> + +static const struct udevice_id sandbox_gpio_test_ids[] = { + { .compatible = "sandbox,gpio-test" }, + { } +}; + +U_BOOT_DRIVER(sandbox_gpio_test) = { + .name = "sandbox_gpio_test", + .id = UCLASS_MISC, + .of_match = sandbox_gpio_test_ids, +}; diff --git a/include/asm-generic/gpio.h b/include/asm-generic/gpio.h index e33cde7abdd..6de13d925eb 100644 --- a/include/asm-generic/gpio.h +++ b/include/asm-generic/gpio.h @@ -608,6 +608,11 @@ int gpio_request_list_by_name(struct udevice *dev, const char *list_name, */ int dm_gpio_request(struct gpio_desc *desc, const char *label);
+struct phandle_2_arg; +int gpio_request_by_phandle(struct udevice *dev, + const struct phandle_2_arg *cells, + struct gpio_desc *desc, int flags); + /** * gpio_get_list_count() - Returns the number of GPIOs in a list * diff --git a/test/dm/of_platdata.c b/test/dm/of_platdata.c index 082989021d9..ec41087a558 100644 --- a/test/dm/of_platdata.c +++ b/test/dm/of_platdata.c @@ -8,6 +8,7 @@ #include <dm/test.h> #include <test/test.h> #include <test/ut.h> +#include <asm-generic/gpio.h> #include <asm/global_data.h>
/* Test that we can find a device using of-platdata */ @@ -259,3 +260,22 @@ static int dm_test_of_plat_irq(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_of_plat_irq, UT_TESTF_SCAN_PDATA); + +/* Test GPIOs with of-platdata */ +static int dm_test_of_plat_gpio(struct unit_test_state *uts) +{ + struct dtd_sandbox_gpio_test *plat; + struct udevice *dev; + struct gpio_desc desc; + + ut_assertok(uclass_get_device_by_name(UCLASS_MISC, "sandbox_gpio_test", + &dev)); + plat = dev_get_plat(dev); + + ut_assertok(gpio_request_by_phandle(dev, &plat->test_gpios[0], &desc, + GPIOD_IS_OUT)); + ut_asserteq_str("sandbox_gpio", desc.dev->name); + + return 0; +} +DM_TEST(dm_test_of_plat_gpio, UT_TESTF_SCAN_PDATA);
Jaehoon Chung
Sean Anderson
