[U-Boot] pull request: u-boot-uniphier/master
Hi Tom,
Please pull some updates for v2017.01-rc2, thanks! - DT sync with Linux - Disable CONFIG_ARCH_FIXUP_FDT_MEMORY - Minor fixes
The following changes since commit 361a879902a3cbdb692149a1ac580e3199e771ba:
Revert "Merge branch 'master' of git://www.denx.de/git/u-boot-microblaze" (2016-12-09 07:56:54 -0500)
git://git.denx.de/u-boot-uniphier.git master
for you to fetch changes up to 6c498835af560ad850de4dad4ff8c60d26ef2898:
ARM: uniphier: remove BLK select (2016-12-11 17:55:13 +0900)
---------------------------------------------------------------- Masahiro Yamada (5): ARM: uniphier: remove unneeded initializer ARM: uniphier: remove unneeded parentheses ARM: uniphier: disable CONFIG_ARCH_FIXUP_FDT_MEMORY ARM: dts: uniphier: sync Device Tree with Linux ARM: uniphier: remove BLK select
arch/arm/Kconfig | 1 - arch/arm/dts/uniphier-common32.dtsi | 177 ------ arch/arm/dts/uniphier-ld11.dtsi | 111 +++- arch/arm/dts/uniphier-ld20.dtsi | 188 +++++-- arch/arm/dts/uniphier-ld4.dtsi | 651 +++++++++++++--------- arch/arm/dts/uniphier-pro4-ref.dts | 10 +- arch/arm/dts/uniphier-pro4.dtsi | 903 +++++++++++++++++------------- arch/arm/dts/uniphier-pro5.dtsi | 925 +++++++++++++++++++------------ arch/arm/dts/uniphier-pxs2-gentil.dts | 2 +- arch/arm/dts/uniphier-pxs2-vodka.dts | 2 +- arch/arm/dts/uniphier-pxs2.dtsi | 878 +++++++++++++++++------------ arch/arm/dts/uniphier-sld3.dtsi | 37 +- arch/arm/dts/uniphier-sld8.dtsi | 651 +++++++++++++--------- arch/arm/mach-uniphier/dram/umc-ld20.c | 6 +- arch/arm/mach-uniphier/memconf/memconf.c | 6 +- configs/uniphier_ld11_defconfig | 1 + configs/uniphier_ld20_defconfig | 1 + configs/uniphier_ld4_sld8_defconfig | 1 + configs/uniphier_pro4_defconfig | 1 + configs/uniphier_pxs2_ld6b_defconfig | 1 + configs/uniphier_sld3_defconfig | 1 + 21 files changed, 2697 insertions(+), 1857 deletions(-) delete mode 100644 arch/arm/dts/uniphier-common32.dtsi
On Sun, Dec 11, 2016 at 06:04:19PM +0900, Masahiro Yamada wrote:
Hi Tom,
- Minor fixes
Masahiro Yamada
