[v2, 00/11] mmc: fsl_esdhc: support eMMC HS200/HS400 modes
This patch-set is to support eMMC HS200 and HS400 speed modes for eSDHC, and enable them on LX2160ARDB board.
CI build link https://travis-ci.org/github/yangbolu1991/u-boot-test/builds/709088861
Changes for v2: - Added two patches to fix stability issue.
Yangbo Lu (11): mmc: add a reinit() API mmc: fsl_esdhc: add a reinit() callback mmc: fsl_esdhc: support tuning for eMMC HS200 mmc: fsl_esdhc: clean TBCTL[TB_EN] manually during init mmc: add a hs400_tuning flag mmc: add a mmc_hs400_prepare_ddr() interface mmc: fsl_esdhc: support eMMC HS400 mode mmc: fsl_esdhc: fix mmc->clock with actual clock mmc: fsl_esdhc: fix eMMC HS400 stability issue arm: dts: lx2160ardb: support eMMC HS400 mode configs: lx2160ardb: enable eMMC HS400 mode support
arch/arm/dts/fsl-lx2160a-rdb.dts | 2 + configs/lx2160ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2160ardb_tfa_defconfig | 1 + configs/lx2160ardb_tfa_stmm_defconfig | 1 + drivers/mmc/fsl_esdhc.c | 154 ++++++++++++++++++++++++++- drivers/mmc/mmc-uclass.c | 30 ++++++ drivers/mmc/mmc.c | 12 ++- include/fsl_esdhc.h | 29 ++++- include/mmc.h | 26 ++++- 9 files changed, 246 insertions(+), 10 deletions(-)
For DM_MMC, the controller re-initialization is needed to clear old configuration for mmc rescan.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. --- drivers/mmc/mmc-uclass.c | 15 +++++++++++++++ drivers/mmc/mmc.c | 8 ++++++-- include/mmc.h | 10 ++++++++++ 3 files changed, 31 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/mmc-uclass.c b/drivers/mmc/mmc-uclass.c index c5b7872..b9f0880 100644 --- a/drivers/mmc/mmc-uclass.c +++ b/drivers/mmc/mmc-uclass.c @@ -170,6 +170,21 @@ int mmc_deferred_probe(struct mmc *mmc) return dm_mmc_deferred_probe(mmc->dev); }
+int dm_mmc_reinit(struct udevice *dev) +{ + struct dm_mmc_ops *ops = mmc_get_ops(dev); + + if (ops->reinit) + return ops->reinit(dev); + + return 0; +} + +int mmc_reinit(struct mmc *mmc) +{ + return dm_mmc_reinit(mmc->dev); +} + int mmc_of_parse(struct udevice *dev, struct mmc_config *cfg) { int val; diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 50f47d4..a53f93a 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -2813,13 +2813,17 @@ int mmc_get_op_cond(struct mmc *mmc) return err;
#if CONFIG_IS_ENABLED(DM_MMC) - /* The device has already been probed ready for use */ + /* + * Re-initialization is needed to clear old configuration for + * mmc rescan. + */ + err = mmc_reinit(mmc); #else /* made sure it's not NULL earlier */ err = mmc->cfg->ops->init(mmc); +#endif if (err) return err; -#endif mmc->ddr_mode = 0;
retry: diff --git a/include/mmc.h b/include/mmc.h index 8256219..161b8bc 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -422,6 +422,14 @@ struct dm_mmc_ops { */ int (*deferred_probe)(struct udevice *dev); /** + * reinit() - Re-initialization to clear old configuration for + * mmc rescan. + * + * @dev: Device to reinit + * @return 0 if Ok, -ve if error + */ + int (*reinit)(struct udevice *dev); + /** * send_cmd() - Send a command to the MMC device * * @dev: Device to receive the command @@ -518,6 +526,7 @@ int dm_mmc_execute_tuning(struct udevice *dev, uint opcode); int dm_mmc_wait_dat0(struct udevice *dev, int state, int timeout_us); int dm_mmc_host_power_cycle(struct udevice *dev); int dm_mmc_deferred_probe(struct udevice *dev); +int dm_mmc_reinit(struct udevice *dev); int dm_mmc_get_b_max(struct udevice *dev, void *dst, lbaint_t blkcnt);
/* Transition functions for compatibility */ @@ -529,6 +538,7 @@ int mmc_wait_dat0(struct mmc *mmc, int state, int timeout_us); int mmc_set_enhanced_strobe(struct mmc *mmc); int mmc_host_power_cycle(struct mmc *mmc); int mmc_deferred_probe(struct mmc *mmc); +int mmc_reinit(struct mmc *mmc); int mmc_get_b_max(struct mmc *mmc, void *dst, lbaint_t blkcnt);
#else
Subject: [v2, 01/11] mmc: add a reinit() API
Changes for v2:
- None.
- struct dm_mmc_ops *ops = mmc_get_ops(dev);
- if (ops->reinit)
- return dm_mmc_reinit(mmc->dev);
* mmc rescan.
You mean cmd "mmc rescan" ?
- err = mmc_reinit(mmc);
Probe could not provide what you need? You need a different settings?
Regards, Peng.
* mmc rescan.
- int (*reinit)(struct udevice *dev);
- send_cmd() - Send a command to the MMC device
- @dev: Device to receive the command
#else
2.7.4
Hi Peng,
-----Original Message----- From: Peng Fan peng.fan@nxp.com Sent: Monday, July 20, 2020 9:33 AM To: Y.b. Lu yangbo.lu@nxp.com; u-boot@lists.denx.de; Priyanka Jain priyanka.jain@nxp.com; 'Jaehoon Chung' jh80.chung@samsung.com Cc: Y.b. Lu yangbo.lu@nxp.com Subject: RE: [v2, 01/11] mmc: add a reinit() API
Changes for v2:
- None.
- if (ops->reinit)
* mmc rescan.
Yes. The flag has_init is being used to skip the reinitialization if the card has been initialized once. Going through the mmc driver, the only place where we want to actually and completely reinitialize the SD card is "mmc rescan". For "mmc rescan", before sending CMD0 to reset card, the controller is still needed to be reset/re-initialized. Otherwise the controller may be still in previous status (registers setting) communicating with the card.
Probe is called only once. The controller still needs to be reset/re-initialized to clean all previous registers setting, before sending CMD0 for mmc rescan. For example, the eSDHC controller is now in 8-bit 200MHz eMMC HS400 mode (in tuning mode). When we want mmc rescan to completely reinitialize the card starting from CMD0, we needs to reset/re-initialize the controller to clean previous HS400 mode setting.
Regards, Peng.
100644
* mmc rescan.
#else
2.7.4
Add a reinit() callback for mmc rescan.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. --- drivers/mmc/fsl_esdhc.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index a4b923a..d1f2e4a 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -946,6 +946,14 @@ static int fsl_esdhc_set_ios(struct udevice *dev) return esdhc_set_ios_common(priv, &plat->mmc); }
+static int fsl_esdhc_reinit(struct udevice *dev) +{ + struct fsl_esdhc_plat *plat = dev_get_platdata(dev); + struct fsl_esdhc_priv *priv = dev_get_priv(dev); + + return esdhc_init_common(priv, &plat->mmc); +} + static const struct dm_mmc_ops fsl_esdhc_ops = { .get_cd = fsl_esdhc_get_cd, .send_cmd = fsl_esdhc_send_cmd, @@ -953,6 +961,7 @@ static const struct dm_mmc_ops fsl_esdhc_ops = { #ifdef MMC_SUPPORTS_TUNING .execute_tuning = fsl_esdhc_execute_tuning, #endif + .reinit = fsl_esdhc_reinit, };
static const struct udevice_id fsl_esdhc_ids[] = {
Support tuning process for eMMC HS200 for eSDHC.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. --- drivers/mmc/fsl_esdhc.c | 106 ++++++++++++++++++++++++++++++++++++++++++++++-- include/fsl_esdhc.h | 17 ++++++-- 2 files changed, 116 insertions(+), 7 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index d1f2e4a..5ad01ac 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -60,7 +60,9 @@ struct fsl_esdhc { uint dmaerrattr; /* DMA error attribute register */ char reserved5[4]; /* reserved */ uint hostcapblt2; /* Host controller capabilities register 2 */ - char reserved6[756]; /* reserved */ + char reserved6[8]; /* reserved */ + uint tbctl; /* Tuning block control register */ + char reserved7[744]; /* reserved */ uint esdhcctl; /* eSDHC control register */ };
@@ -101,7 +103,9 @@ static uint esdhc_xfertyp(struct mmc_cmd *cmd, struct mmc_data *data) if (data) { xfertyp |= XFERTYP_DPSEL; #ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO - xfertyp |= XFERTYP_DMAEN; + if (cmd->cmdidx != MMC_CMD_SEND_TUNING_BLOCK && + cmd->cmdidx != MMC_CMD_SEND_TUNING_BLOCK_HS200) + xfertyp |= XFERTYP_DMAEN; #endif if (data->blocks > 1) { xfertyp |= XFERTYP_MSBSEL; @@ -380,6 +384,10 @@ static int esdhc_send_cmd_common(struct fsl_esdhc_priv *priv, struct mmc *mmc, esdhc_write32(®s->cmdarg, cmd->cmdarg); esdhc_write32(®s->xfertyp, xfertyp);
+ if (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK || + cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK_HS200) + flags = IRQSTAT_BRR; + /* Wait for the command to complete */ start = get_timer(0); while (!(esdhc_read32(®s->irqstat) & flags)) { @@ -439,6 +447,11 @@ static int esdhc_send_cmd_common(struct fsl_esdhc_priv *priv, struct mmc *mmc, #ifdef CONFIG_SYS_FSL_ESDHC_USE_PIO esdhc_pio_read_write(priv, data); #else + flags = DATA_COMPLETE; + if (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK || + cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK_HS200) + flags = IRQSTAT_BRR; + do { irqstat = esdhc_read32(®s->irqstat);
@@ -451,7 +464,7 @@ static int esdhc_send_cmd_common(struct fsl_esdhc_priv *priv, struct mmc *mmc, err = -ECOMM; goto out; } - } while ((irqstat & DATA_COMPLETE) != DATA_COMPLETE); + } while ((irqstat & flags) != flags);
/* * Need invalidate the dcache here again to avoid any @@ -555,6 +568,19 @@ static void esdhc_clock_control(struct fsl_esdhc_priv *priv, bool enable) } }
+static void esdhc_set_timing(struct fsl_esdhc_priv *priv, enum bus_mode mode) +{ + struct fsl_esdhc *regs = priv->esdhc_regs; + + esdhc_clock_control(priv, false); + + if (mode == MMC_HS_200) + esdhc_clrsetbits32(®s->autoc12err, UHSM_MASK, + UHSM_SDR104_HS200); + + esdhc_clock_control(priv, true); +} + static int esdhc_set_ios_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) { struct fsl_esdhc *regs = priv->esdhc_regs; @@ -570,6 +596,9 @@ static int esdhc_set_ios_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) if (priv->clock != mmc->clock) set_sysctl(priv, mmc, mmc->clock);
+ /* Set timing */ + esdhc_set_timing(priv, mmc->selected_mode); + /* Set the bus width */ esdhc_clrbits32(®s->proctl, PROCTL_DTW_4 | PROCTL_DTW_8);
@@ -954,6 +983,77 @@ static int fsl_esdhc_reinit(struct udevice *dev) return esdhc_init_common(priv, &plat->mmc); }
+#ifdef MMC_SUPPORTS_TUNING +static void esdhc_flush_async_fifo(struct fsl_esdhc_priv *priv) +{ + struct fsl_esdhc *regs = priv->esdhc_regs; + u32 time_out; + + esdhc_setbits32(®s->esdhcctl, ESDHCCTL_FAF); + + time_out = 20; + while (esdhc_read32(®s->esdhcctl) & ESDHCCTL_FAF) { + if (time_out == 0) { + printf("fsl_esdhc: Flush asynchronous FIFO timeout.\n"); + break; + } + time_out--; + mdelay(1); + } +} + +static void esdhc_tuning_block_enable(struct fsl_esdhc_priv *priv, + bool en) +{ + struct fsl_esdhc *regs = priv->esdhc_regs; + + esdhc_clock_control(priv, false); + esdhc_flush_async_fifo(priv); + if (en) + esdhc_setbits32(®s->tbctl, TBCTL_TB_EN); + else + esdhc_clrbits32(®s->tbctl, TBCTL_TB_EN); + esdhc_clock_control(priv, true); +} + +static int fsl_esdhc_execute_tuning(struct udevice *dev, uint32_t opcode) +{ + struct fsl_esdhc_plat *plat = dev_get_platdata(dev); + struct fsl_esdhc_priv *priv = dev_get_priv(dev); + struct fsl_esdhc *regs = priv->esdhc_regs; + u32 val, irqstaten; + int i; + + esdhc_tuning_block_enable(priv, true); + esdhc_setbits32(®s->autoc12err, EXECUTE_TUNING); + + irqstaten = esdhc_read32(®s->irqstaten); + esdhc_write32(®s->irqstaten, IRQSTATEN_BRR); + + for (i = 0; i < MAX_TUNING_LOOP; i++) { + mmc_send_tuning(&plat->mmc, opcode, NULL); + mdelay(1); + + val = esdhc_read32(®s->autoc12err); + if (!(val & EXECUTE_TUNING)) { + if (val & SMPCLKSEL) + break; + } + } + + esdhc_write32(®s->irqstaten, irqstaten); + + if (i != MAX_TUNING_LOOP) + return 0; + + printf("fsl_esdhc: tuning failed!\n"); + esdhc_clrbits32(®s->autoc12err, SMPCLKSEL); + esdhc_clrbits32(®s->autoc12err, EXECUTE_TUNING); + esdhc_tuning_block_enable(priv, false); + return -ETIMEDOUT; +} +#endif + static const struct dm_mmc_ops fsl_esdhc_ops = { .get_cd = fsl_esdhc_get_cd, .send_cmd = fsl_esdhc_send_cmd, diff --git a/include/fsl_esdhc.h b/include/fsl_esdhc.h index e148eaa..ada95bc 100644 --- a/include/fsl_esdhc.h +++ b/include/fsl_esdhc.h @@ -78,8 +78,10 @@ #define IRQSTATEN_TC (0x00000002) #define IRQSTATEN_CC (0x00000001)
+/* eSDHC control register */ #define ESDHCCTL 0x0002e40c #define ESDHCCTL_PCS (0x00080000) +#define ESDHCCTL_FAF (0x00040000)
#define PRSSTAT 0x0002e024 #define PRSSTAT_DAT0 (0x01000000) @@ -158,6 +160,12 @@ #define BLKATTR_SIZE(x) (x & 0x1fff) #define MAX_BLK_CNT 0x7fff /* so malloc will have enough room with 32M */
+/* Auto CMD error status register / system control 2 register */ +#define EXECUTE_TUNING 0x00400000 +#define SMPCLKSEL 0x00800000 +#define UHSM_MASK 0x00070000 +#define UHSM_SDR104_HS200 0x00030000 + /* Host controller capabilities register */ #define HOSTCAPBLT_VS18 0x04000000 #define HOSTCAPBLT_VS30 0x02000000 @@ -166,6 +174,11 @@ #define HOSTCAPBLT_DMAS 0x00400000 #define HOSTCAPBLT_HSS 0x00200000
+/* Tuning block control register */ +#define TBCTL_TB_EN 0x00000004 + +#define MAX_TUNING_LOOP 40 + struct fsl_esdhc_cfg { phys_addr_t esdhc_base; u32 sdhc_clk; @@ -207,10 +220,6 @@ struct fsl_esdhc_cfg { int fsl_esdhc_mmc_init(bd_t *bis); int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg); void fdt_fixup_esdhc(void *blob, bd_t *bd); -#ifdef MMC_SUPPORTS_TUNING -static inline int fsl_esdhc_execute_tuning(struct udevice *dev, - uint32_t opcode) {return 0; } -#endif #else static inline int fsl_esdhc_mmc_init(bd_t *bis) { return -ENOSYS; } static inline void fdt_fixup_esdhc(void *blob, bd_t *bd) {}
Clean TBCTL[TB_EN] manually during init since it is not able to be reset by reset all operation.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. --- drivers/mmc/fsl_esdhc.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 5ad01ac..607b420 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -637,6 +637,9 @@ static int esdhc_init_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) return -ETIMEDOUT; }
+ /* Clean TBCTL[TB_EN] which is not able to be reset by reset all */ + esdhc_clrbits32(®s->tbctl, TBCTL_TB_EN); + esdhc_enable_cache_snooping(regs);
esdhc_setbits32(®s->sysctl, SYSCTL_HCKEN | SYSCTL_IPGEN);
Add a hs400_tuning flag to identify the tuning for HS400 mode.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. --- drivers/mmc/mmc.c | 2 ++ include/mmc.h | 1 + 2 files changed, 3 insertions(+)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index a53f93a..a18e75d 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -1976,7 +1976,9 @@ static int mmc_select_hs400(struct mmc *mmc) mmc_set_clock(mmc, mmc->tran_speed, false);
/* execute tuning if needed */ + mmc->hs400_tuning = 1; err = mmc_execute_tuning(mmc, MMC_CMD_SEND_TUNING_BLOCK_HS200); + mmc->hs400_tuning = 0; if (err) { debug("tuning failed\n"); return err; diff --git a/include/mmc.h b/include/mmc.h index 161b8bc..2399cc2 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -707,6 +707,7 @@ struct mmc { * accessing the boot partitions */ u32 quirks; + u8 hs400_tuning; };
struct mmc_hwpart_conf {
Subject: [v2, 05/11] mmc: add a hs400_tuning flag
Why? Please explain a bit more.
Thanks, Peng.
Changes for v2:
- None.
- mmc->hs400_tuning = 1; err = mmc_execute_tuning(mmc,
- mmc->hs400_tuning = 0; if (err) { debug("tuning failed\n"); return err;
- u8 hs400_tuning;
2.7.4
Hi Peng,
-----Original Message----- From: Peng Fan peng.fan@nxp.com Sent: Monday, July 20, 2020 9:37 AM To: Y.b. Lu yangbo.lu@nxp.com; u-boot@lists.denx.de; Priyanka Jain priyanka.jain@nxp.com; 'Jaehoon Chung' jh80.chung@samsung.com Cc: Y.b. Lu yangbo.lu@nxp.com Subject: RE: [v2, 05/11] mmc: add a hs400_tuning flag
Some specific controllers may have difference between HS400 tuning and HS200 tuning. For eSDHC, as you saw in my patch #7, and there are also some eSDHC errata related to HS400 tuning which I will upstream patches in the future. In kernel drivers/mmc/host/sdhci.c, there is a flag SDHCI_HS400_TUNING used by sdhci-msm.c and sdhci-of-esdhc.c for specific handling. I will explain more in commit message.
Thanks, Peng.
Changes for v2:
- None.
- u8 hs400_tuning;
2.7.4
Add a mmc_hs400_prepare_ddr() interface for controllers which needs preparation before switching to DDR mode for HS400 mode.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. --- drivers/mmc/mmc-uclass.c | 15 +++++++++++++++ drivers/mmc/mmc.c | 2 ++ include/mmc.h | 15 ++++++++++++++- 3 files changed, 31 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/mmc-uclass.c b/drivers/mmc/mmc-uclass.c index b9f0880..240b205 100644 --- a/drivers/mmc/mmc-uclass.c +++ b/drivers/mmc/mmc-uclass.c @@ -141,6 +141,21 @@ int mmc_set_enhanced_strobe(struct mmc *mmc) } #endif
+int dm_mmc_hs400_prepare_ddr(struct udevice *dev) +{ + struct dm_mmc_ops *ops = mmc_get_ops(dev); + + if (ops->hs400_prepare_ddr) + return ops->hs400_prepare_ddr(dev); + + return 0; +} + +int mmc_hs400_prepare_ddr(struct mmc *mmc) +{ + return dm_mmc_hs400_prepare_ddr(mmc->dev); +} + int dm_mmc_host_power_cycle(struct udevice *dev) { struct dm_mmc_ops *ops = mmc_get_ops(dev); diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index a18e75d..e396207 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -1987,6 +1987,8 @@ static int mmc_select_hs400(struct mmc *mmc) /* Set back to HS */ mmc_set_card_speed(mmc, MMC_HS, true);
+ mmc_hs400_prepare_ddr(mmc); + err = mmc_switch(mmc, EXT_CSD_CMD_SET_NORMAL, EXT_CSD_BUS_WIDTH, EXT_CSD_BUS_WIDTH_8 | EXT_CSD_DDR_FLAG); if (err) diff --git a/include/mmc.h b/include/mmc.h index 2399cc2..659df75 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -513,6 +513,14 @@ struct dm_mmc_ops { * @return maximum number of blocks for this transfer */ int (*get_b_max)(struct udevice *dev, void *dst, lbaint_t blkcnt); + + /** + * hs400_prepare_ddr - prepare to switch to DDR mode + * + * @dev: Device to check + * @return 0 if success, -ve on error + */ + int (*hs400_prepare_ddr)(struct udevice *dev); };
#define mmc_get_ops(dev) ((struct dm_mmc_ops *)(dev)->driver->ops) @@ -540,7 +548,7 @@ int mmc_host_power_cycle(struct mmc *mmc); int mmc_deferred_probe(struct mmc *mmc); int mmc_reinit(struct mmc *mmc); int mmc_get_b_max(struct mmc *mmc, void *dst, lbaint_t blkcnt); - +int mmc_hs400_prepare_ddr(struct mmc *mmc); #else struct mmc_ops { int (*send_cmd)(struct mmc *mmc, @@ -552,6 +560,11 @@ struct mmc_ops { int (*host_power_cycle)(struct mmc *mmc); int (*get_b_max)(struct mmc *mmc, void *dst, lbaint_t blkcnt); }; + +static inline int mmc_hs400_prepare_ddr(struct mmc *mmc) +{ + return 0; +} #endif
struct mmc_config {
Subject: [v2, 06/11] mmc: add a mmc_hs400_prepare_ddr() interface
This is LSx specific? If yes, could this be done in fsl_esdhc.c?
Thanks, Peng.
Changes for v2:
- None.
+int dm_mmc_hs400_prepare_ddr(struct udevice *dev) {
- if (ops->hs400_prepare_ddr)
+int mmc_hs400_prepare_ddr(struct mmc *mmc) {
- return dm_mmc_hs400_prepare_ddr(mmc->dev);
- mmc_hs400_prepare_ddr(mmc);
- err = mmc_switch(mmc, EXT_CSD_CMD_SET_NORMAL,
- int (*hs400_prepare_ddr)(struct udevice *dev);
+static inline int mmc_hs400_prepare_ddr(struct mmc *mmc) {
+} #endif
struct mmc_config {
2.7.4
Hi Peng,
-----Original Message----- From: Peng Fan peng.fan@nxp.com Sent: Monday, July 20, 2020 9:40 AM To: Y.b. Lu yangbo.lu@nxp.com; u-boot@lists.denx.de; Priyanka Jain priyanka.jain@nxp.com; 'Jaehoon Chung' jh80.chung@samsung.com Cc: Y.b. Lu yangbo.lu@nxp.com Subject: RE: [v2, 06/11] mmc: add a mmc_hs400_prepare_ddr() interface
Yes. Actually I desire to put these esdhc specific setting in its own driver too. However the HS400 procedure of esdhc indeed break the standard process. As you see in my patch #7 commit message, the tuning block has to be disabled after switching to HS and before switching to DDR.
- Switch to High Speed mode and then set the card clock frequency to a value not greater than 52Mhz
- Clear TBCTL[TB_EN],tuning block enable bit.
- Change to 8 bit DDR Mode
I have to make code changed as below expecting some controllers drivers may utilize mmc_hs400_prepare_ddr() too. We had done same thing in linux too. (cc14eec mmc: core: Add ->hs400_prepare_ddr() callback) Do you have any suggestion?
Thanks.
Thanks, Peng.
Changes for v2:
- None.
int
+} #endif
struct mmc_config {
2.7.4
The process for eMMC HS400 mode for eSDHC is,
1. Perform the Tuning Process at the HS400 target operating frequency. Latched the clock division value. 2. if read transaction, then set the SDTIMNGCTL[FLW_CTL_BG]. 3. Switch to High Speed mode and then set the card clock frequency to a value not greater than 52Mhz 4. Clear TBCTL[TB_EN],tuning block enable bit. 5. Change to 8 bit DDR Mode 6. Switch the card to HS400 mode. 7. Set TBCTL[TB_EN], tuning block enable bit. 8. Clear SYSCTL[SDCLKEN] 9. Wait for PRSSTAT[SDSTB] to be set 10. Change the clock division to latched value.Set TBCTL[HS 400 mode] and Set SDCLKCTL[CMD_CLK_CTRL] 11. Set SYSCTL[SDCLKEN] 12. Wait for PRSSTAT[SDSTB] to be set 13. Set DLLCFG0[DLL_ENABLE] and DLLCFG0[DLL_FREQ_SEL]. 14. Wait for delay chain to lock. 15. Set TBCTL[HS400_WNDW_ADJUST] 16. Again clear SYSCTL[SDCLKEN] 17. Wait for PRSSTAT[SDSTB] to be set 18. Set ESDHCCTL[FAF] 19. Wait for ESDHCCTL[FAF] to be cleared 20. Set SYSCTL[SDCLKEN] 21. Wait for PRSSTAT[SDSTB] to be set.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. --- drivers/mmc/fsl_esdhc.c | 98 ++++++++++++++++++++++++++++++++----------------- include/fsl_esdhc.h | 12 ++++++ 2 files changed, 76 insertions(+), 34 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 607b420..c1a127c 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -62,7 +62,12 @@ struct fsl_esdhc { uint hostcapblt2; /* Host controller capabilities register 2 */ char reserved6[8]; /* reserved */ uint tbctl; /* Tuning block control register */ - char reserved7[744]; /* reserved */ + char reserved7[32]; /* reserved */ + uint sdclkctl; /* SD clock control register */ + uint sdtimingctl; /* SD timing control register */ + char reserved8[20]; /* reserved */ + uint dllcfg0; /* DLL config 0 register */ + char reserved9[680]; /* reserved */ uint esdhcctl; /* eSDHC control register */ };
@@ -568,6 +573,38 @@ static void esdhc_clock_control(struct fsl_esdhc_priv *priv, bool enable) } }
+static void esdhc_flush_async_fifo(struct fsl_esdhc_priv *priv) +{ + struct fsl_esdhc *regs = priv->esdhc_regs; + u32 time_out; + + esdhc_setbits32(®s->esdhcctl, ESDHCCTL_FAF); + + time_out = 20; + while (esdhc_read32(®s->esdhcctl) & ESDHCCTL_FAF) { + if (time_out == 0) { + printf("fsl_esdhc: Flush asynchronous FIFO timeout.\n"); + break; + } + time_out--; + mdelay(1); + } +} + +static void esdhc_tuning_block_enable(struct fsl_esdhc_priv *priv, + bool en) +{ + struct fsl_esdhc *regs = priv->esdhc_regs; + + esdhc_clock_control(priv, false); + esdhc_flush_async_fifo(priv); + if (en) + esdhc_setbits32(®s->tbctl, TBCTL_TB_EN); + else + esdhc_clrbits32(®s->tbctl, TBCTL_TB_EN); + esdhc_clock_control(priv, true); +} + static void esdhc_set_timing(struct fsl_esdhc_priv *priv, enum bus_mode mode) { struct fsl_esdhc *regs = priv->esdhc_regs; @@ -577,7 +614,17 @@ static void esdhc_set_timing(struct fsl_esdhc_priv *priv, enum bus_mode mode) if (mode == MMC_HS_200) esdhc_clrsetbits32(®s->autoc12err, UHSM_MASK, UHSM_SDR104_HS200); + if (mode == MMC_HS_400) { + esdhc_setbits32(®s->tbctl, HS400_MODE); + esdhc_setbits32(®s->sdclkctl, CMD_CLK_CTL); + esdhc_clock_control(priv, true);
+ esdhc_setbits32(®s->dllcfg0, DLL_ENABLE | DLL_FREQ_SEL); + esdhc_setbits32(®s->tbctl, HS400_WNDW_ADJUST); + + esdhc_clock_control(priv, false); + esdhc_flush_async_fifo(priv); + } esdhc_clock_control(priv, true); }
@@ -592,6 +639,9 @@ static int esdhc_set_ios_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) esdhc_clock_control(priv, true); }
+ if (mmc->selected_mode == MMC_HS_400) + esdhc_tuning_block_enable(priv, true); + /* Set the clock speed */ if (priv->clock != mmc->clock) set_sysctl(priv, mmc, mmc->clock); @@ -987,38 +1037,6 @@ static int fsl_esdhc_reinit(struct udevice *dev) }
#ifdef MMC_SUPPORTS_TUNING -static void esdhc_flush_async_fifo(struct fsl_esdhc_priv *priv) -{ - struct fsl_esdhc *regs = priv->esdhc_regs; - u32 time_out; - - esdhc_setbits32(®s->esdhcctl, ESDHCCTL_FAF); - - time_out = 20; - while (esdhc_read32(®s->esdhcctl) & ESDHCCTL_FAF) { - if (time_out == 0) { - printf("fsl_esdhc: Flush asynchronous FIFO timeout.\n"); - break; - } - time_out--; - mdelay(1); - } -} - -static void esdhc_tuning_block_enable(struct fsl_esdhc_priv *priv, - bool en) -{ - struct fsl_esdhc *regs = priv->esdhc_regs; - - esdhc_clock_control(priv, false); - esdhc_flush_async_fifo(priv); - if (en) - esdhc_setbits32(®s->tbctl, TBCTL_TB_EN); - else - esdhc_clrbits32(®s->tbctl, TBCTL_TB_EN); - esdhc_clock_control(priv, true); -} - static int fsl_esdhc_execute_tuning(struct udevice *dev, uint32_t opcode) { struct fsl_esdhc_plat *plat = dev_get_platdata(dev); @@ -1046,8 +1064,11 @@ static int fsl_esdhc_execute_tuning(struct udevice *dev, uint32_t opcode)
- if (i != MAX_TUNING_LOOP) + if (i != MAX_TUNING_LOOP) { + if (plat->mmc.hs400_tuning) + esdhc_setbits32(®s->sdtimingctl, FLW_CTL_BG); return 0; + }
printf("fsl_esdhc: tuning failed!\n"); esdhc_clrbits32(®s->autoc12err, SMPCLKSEL); @@ -1057,6 +1078,14 @@ static int fsl_esdhc_execute_tuning(struct udevice *dev, uint32_t opcode) } #endif
+int fsl_esdhc_hs400_prepare_ddr(struct udevice *dev) +{ + struct fsl_esdhc_priv *priv = dev_get_priv(dev); + + esdhc_tuning_block_enable(priv, false); + return 0; +} + static const struct dm_mmc_ops fsl_esdhc_ops = { .get_cd = fsl_esdhc_get_cd, .send_cmd = fsl_esdhc_send_cmd, @@ -1065,6 +1094,7 @@ static const struct dm_mmc_ops fsl_esdhc_ops = { .execute_tuning = fsl_esdhc_execute_tuning, #endif .reinit = fsl_esdhc_reinit, + .hs400_prepare_ddr = fsl_esdhc_hs400_prepare_ddr, };
static const struct udevice_id fsl_esdhc_ids[] = { diff --git a/include/fsl_esdhc.h b/include/fsl_esdhc.h index ada95bc..cbb2c34 100644 --- a/include/fsl_esdhc.h +++ b/include/fsl_esdhc.h @@ -176,6 +176,18 @@
/* Tuning block control register */ #define TBCTL_TB_EN 0x00000004 +#define HS400_MODE 0x00000010 +#define HS400_WNDW_ADJUST 0x00000040 + +/* SD clock control register */ +#define CMD_CLK_CTL 0x00008000 + +/* SD timing control register */ +#define FLW_CTL_BG 0x00008000 + +/* DLL config 0 register */ +#define DLL_ENABLE 0x80000000 +#define DLL_FREQ_SEL 0x08000000
Subject: [v2, 07/11] mmc: fsl_esdhc: support eMMC HS400 mode
- Perform the Tuning Process at the HS400 target operating frequency. Latched the clock division value.
- if read transaction, then set the SDTIMNGCTL[FLW_CTL_BG].
- Switch the card to HS400 mode.
- Set TBCTL[TB_EN], tuning block enable bit.
- Clear SYSCTL[SDCLKEN]
- Wait for PRSSTAT[SDSTB] to be set
- Change the clock division to latched value.Set TBCTL[HS 400 mode] and Set SDCLKCTL[CMD_CLK_CTRL]
- Set SYSCTL[SDCLKEN]
- Set DLLCFG0[DLL_ENABLE] and DLLCFG0[DLL_FREQ_SEL].
- Wait for delay chain to lock.
- Set TBCTL[HS400_WNDW_ADJUST]
- Again clear SYSCTL[SDCLKEN]
- Set ESDHCCTL[FAF]
- Wait for ESDHCCTL[FAF] to be cleared 20. Set SYSCTL[SDCLKEN] 21. Wait
Changes for v2:
- None.
- char reserved7[32]; /* reserved */
- uint sdclkctl; /* SD clock control register */
- uint sdtimingctl; /* SD timing control register */
- char reserved8[20]; /* reserved */
- uint dllcfg0; /* DLL config 0 register */
- char reserved9[680]; /* reserved */ uint esdhcctl; /* eSDHC control register */
+static void esdhc_flush_async_fifo(struct fsl_esdhc_priv *priv) {
- u32 time_out;
- time_out = 20;
break;
time_out--;
mdelay(1);
bool en)
- if (en)
- else
- if (mmc->selected_mode == MMC_HS_400)
- /* Set the clock speed */ if (priv->clock != mmc->clock) set_sysctl(priv, mmc, mmc->clock);
- u32 time_out;
- time_out = 20;
break;
time_out--;
mdelay(1);
bool en)
- if (en)
- else
- if (i != MAX_TUNING_LOOP) {
Ok, it is used here, but I not see the benefit putting hs400_tunning into common mmc structure.
Regards, Peng.
+int fsl_esdhc_hs400_prepare_ddr(struct udevice *dev) {
- struct fsl_esdhc_priv *priv = dev_get_priv(dev);
- esdhc_tuning_block_enable(priv, false);
- .hs400_prepare_ddr = fsl_esdhc_hs400_prepare_ddr,
-- 2.7.4
Hi Peng,
-----Original Message----- From: Peng Fan peng.fan@nxp.com Sent: Monday, July 20, 2020 9:42 AM To: Y.b. Lu yangbo.lu@nxp.com; u-boot@lists.denx.de; Priyanka Jain priyanka.jain@nxp.com; 'Jaehoon Chung' jh80.chung@samsung.com Cc: Y.b. Lu yangbo.lu@nxp.com Subject: RE: [v2, 07/11] mmc: fsl_esdhc: support eMMC HS400 mode
- Set ESDHCCTL[FAF]
Changes for v2:
- None.
- u32 time_out;
- time_out = 20;
break;
time_out--;
mdelay(1);
bool en)
- if (en)
- else
- u32 time_out;
- time_out = 20;
break;
time_out--;
mdelay(1);
bool en)
- if (en)
- else
Do you have any suggestion if we don't use a flag to identify HS400 and HS200 tuning in common mmc structure? Thanks.
Regards, Peng.
-- 2.7.4
Fix mmc->clock with actual clock which is divided by the controller, and record it with priv->clock which was removed accidentally.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - Added this patch. --- drivers/mmc/fsl_esdhc.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index c1a127c..8999b74 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -523,6 +523,9 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) while (sdhc_clk / (div * pre_div) > clock && div < 16) div++;
+ mmc->clock = sdhc_clk / pre_div / div; + priv->clock = mmc->clock; + pre_div >>= 1; div -= 1;
There was a fix-up for eMMC HS400 stability issue in Linux.
Patch link: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/ commit/?id=58d0bf843b49fa99588ac9f85178bd8dfd651b53
Description: Currently only LX2160A eSDHC supports eMMC HS400. According to a large number of tests, eMMC HS400 failed to work at 150MHz, and for a few boards failed to work at 175MHz. But eMMC HS400 worked fine on 200MHz. We hadn't found the root cause but setting eSDHC_DLLCFG0[DLL_FREQ_SEL] = 0 using slow delay chain seemed to resovle this issue. Let's use this as fixup for now.
Introduce the fix-up in u-boot since the issue could be reproduced in u-boot too.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - Added this patch. --- drivers/mmc/fsl_esdhc.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 8999b74..0879739 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -622,7 +622,10 @@ static void esdhc_set_timing(struct fsl_esdhc_priv *priv, enum bus_mode mode) esdhc_setbits32(®s->sdclkctl, CMD_CLK_CTL); esdhc_clock_control(priv, true);
- esdhc_setbits32(®s->dllcfg0, DLL_ENABLE | DLL_FREQ_SEL); + if (priv->clock == 200000000) + esdhc_setbits32(®s->dllcfg0, DLL_FREQ_SEL); + + esdhc_setbits32(®s->dllcfg0, DLL_ENABLE); esdhc_setbits32(®s->tbctl, HS400_WNDW_ADJUST);
Add properties related to eMMC HS400 mode.
mmc-hs400-1_8v; bus-width = <8>;
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. --- arch/arm/dts/fsl-lx2160a-rdb.dts | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/fsl-lx2160a-rdb.dts b/arch/arm/dts/fsl-lx2160a-rdb.dts index d787778..5fbdd90 100644 --- a/arch/arm/dts/fsl-lx2160a-rdb.dts +++ b/arch/arm/dts/fsl-lx2160a-rdb.dts @@ -80,6 +80,8 @@ &esdhc1 { status = "okay"; mmc-hs200-1_8v; + mmc-hs400-1_8v; + bus-width = <8>; };
&fspi {
Subject: [v2, 10/11] arm: dts: lx2160ardb: support eMMC HS400 mode
Changes for v2:
- None.
- mmc-hs400-1_8v;
- bus-width = <8>;
If kernel already has this, please add kernel commit. If not, please use fsl-lx2160a-rdb-u-boot.dtsi to include.
Regards, Peng.
&fspi {
2.7.4
Hi Peng,
-----Original Message----- From: Peng Fan peng.fan@nxp.com Sent: Monday, July 20, 2020 9:45 AM To: Y.b. Lu yangbo.lu@nxp.com; u-boot@lists.denx.de; Priyanka Jain priyanka.jain@nxp.com; 'Jaehoon Chung' jh80.chung@samsung.com Cc: Y.b. Lu yangbo.lu@nxp.com Subject: RE: [v2, 10/11] arm: dts: lx2160ardb: support eMMC HS400 mode
Changes for v2:
- None.
- mmc-hs400-1_8v;
- bus-width = <8>;
Thanks! Kernel had already has this since the first board dts patch. b068890 arm64: dts: add LX2160ARDB board support
Do you want me to mention it in commit message?
Regards, Peng.
&fspi {
2.7.4
Hi Peng,
Changes for v2:
- None.
- mmc-hs400-1_8v;
- bus-width = <8>;
Yes, please.
Thanks, Peng.
Regards, Peng.
&fspi {
2.7.4
Enable eMMC HS400 mode support on LX2160ARDB.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- Changes for v2: - None. --- configs/lx2160ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2160ardb_tfa_defconfig | 1 + configs/lx2160ardb_tfa_stmm_defconfig | 1 + 3 files changed, 3 insertions(+)
diff --git a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig index 12e224f..6c65853 100644 --- a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig @@ -40,6 +40,7 @@ CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_I2C_DEFAULT_BUS_NUMBER=0 CONFIG_DM_MMC=y +CONFIG_MMC_HS400_SUPPORT=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/lx2160ardb_tfa_defconfig b/configs/lx2160ardb_tfa_defconfig index a5c78d2..a5c60c8 100644 --- a/configs/lx2160ardb_tfa_defconfig +++ b/configs/lx2160ardb_tfa_defconfig @@ -46,6 +46,7 @@ CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_I2C_DEFAULT_BUS_NUMBER=0 CONFIG_DM_MMC=y +CONFIG_MMC_HS400_SUPPORT=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/lx2160ardb_tfa_stmm_defconfig b/configs/lx2160ardb_tfa_stmm_defconfig index e97c9b0..869d4e2 100644 --- a/configs/lx2160ardb_tfa_stmm_defconfig +++ b/configs/lx2160ardb_tfa_stmm_defconfig @@ -48,6 +48,7 @@ CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_I2C_DEFAULT_BUS_NUMBER=0 CONFIG_DM_MMC=y +CONFIG_MMC_HS400_SUPPORT=y CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y
Peng Fan
Y.b. Lu
Yangbo Lu
