[PATCH 1/1] efi_loader: improve documentation of enum efi_test_phase
* Avoid a warning warning: "Incorrect use of kernel-doc format". * Remove duplicate text. * Clarify usage of EFI_SETTING_VIRTUAL_ADDRESS_MAP.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- include/efi_selftest.h | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/include/efi_selftest.h b/include/efi_selftest.h index 07b619901c..94ceb14733 100644 --- a/include/efi_selftest.h +++ b/include/efi_selftest.h @@ -53,21 +53,25 @@ */ enum efi_test_phase { /** - * @EFI_EXECUTE_BEFORE_BOOTTIME_EXIT: - execute before ExitBootServices + * @EFI_EXECUTE_BEFORE_BOOTTIME_EXIT: * * Setup, execute, and teardown are executed before ExitBootServices(). */ EFI_EXECUTE_BEFORE_BOOTTIME_EXIT = 1, /** - * @EFI_SETUP_BEFORE_BOOTTIME_EXIT: - setup before ExitBootServices + * @EFI_SETUP_BEFORE_BOOTTIME_EXIT: * * Setup is executed before ExitBootServices() while execute, and * teardown are executed after ExitBootServices(). */ EFI_SETUP_BEFORE_BOOTTIME_EXIT, /** - * @EFI_SETTING_VIRTUAL_ADDRESS_MAP - calls SetVirtualAddressMap() - * Execute calls SetVirtualAddressMap(). + * @EFI_SETTING_VIRTUAL_ADDRESS_MAP: + * + * Execute calls SetVirtualAddressMap(). Setup is executed before + * ExitBootServices() while execute is executed after + * ExitBootServices(), and after the execute of tests marked as + * @EFI_SETUP_BEFORE_BOOTTIME_EXIT. Teardown is executed thereafter. */ EFI_SETTING_VIRTUAL_ADDRESS_MAP, }; -- 2.30.2
On 28.03.21 15:05, Alex Sadovsky wrote:
Dear Heinrich,
- Avoid a warning warning: "Incorrect use of kernel-doc format".
- Remove duplicate text.
- Clarify usage of EFI_SETTING_VIRTUAL_ADDRESS_MAP.
This is a duplicate text too: `a warning warning'.
Thanks for reviewing. I will correct the commit message before merging.
Best regards
Heinrich
Alex Sadovsky
