[U-Boot] [PATCH v5] Add "chip_config" command for PPC4xx bootstrap configuration
This patch adds a generic command for programming I2C bootstrap eeproms on PPC4xx. An implementation for Canyonlands board is included.
The command name is intentionally chosen not to be PPC4xx specific. This way other CPU's/SoC's can implement a similar command under the same name, perhaps with a different syntax.
Usage on Canyonlands:
=> chip_config Available configurations (I2C address 0x52): 600-nor - NOR CPU: 600 PLB: 200 OPB: 100 EBC: 100 600-nand - NAND CPU: 600 PLB: 200 OPB: 100 EBC: 100 800-nor - NOR CPU: 800 PLB: 200 OPB: 100 EBC: 100 800-nand - NAND CPU: 800 PLB: 200 OPB: 100 EBC: 100 1000-nor - NOR CPU:1000 PLB: 200 OPB: 100 EBC: 100 1000-nand - NAND CPU:1000 PLB: 200 OPB: 100 EBC: 100 1066-nor - NOR CPU:1066 PLB: 266 OPB: 88 EBC: 88 *** 1066-nand - NAND CPU:1066 PLB: 266 OPB: 88 EBC: 88 => chip_config 600-nor Using configuration: 600-nor - NOR CPU: 600 PLB: 200 OPB: 100 EBC: 100 done (dump via 'i2c md 52 0.1 10') Reset the board for the changes to take effect
Other 4xx boards will be migrated to use this command soon as well.
Signed-off-by: Stefan Roese sr@denx.de Signed-off-by: Dirk Eibach eibach@gdsys.de Cc: Matthias Fuchs matthias.fuchs@esd.eu --- v5: - Removed bogus lines from commit text
v4: - Command name changed from cpu_config to chip_config - Used eeprom_read/eeprom_write if available - Added CONFIG_4xx_CONFIG_I2C_EEPROM_OFFSET
v3: - Line length of one printf reduced
v2: - Patch authorship changes to Stefan - s-o-b from Dirk added - Added current configuration detection - Minor coding style cleanup
board/amcc/canyonlands/Makefile | 5 +- board/amcc/canyonlands/bootstrap.c | 195 ---------------------------------- board/amcc/canyonlands/chip_config.c | 55 ++++++++++ cpu/ppc4xx/Makefile | 3 + cpu/ppc4xx/cmd_chip_config.c | 142 ++++++++++++++++++++++++ include/asm-ppc/ppc4xx_config.h | 42 +++++++ include/configs/canyonlands.h | 6 + 7 files changed, 251 insertions(+), 197 deletions(-) delete mode 100644 board/amcc/canyonlands/bootstrap.c create mode 100644 board/amcc/canyonlands/chip_config.c create mode 100644 cpu/ppc4xx/cmd_chip_config.c create mode 100644 include/asm-ppc/ppc4xx_config.h
diff --git a/board/amcc/canyonlands/Makefile b/board/amcc/canyonlands/Makefile index 2aeead6..12f8a64 100644 --- a/board/amcc/canyonlands/Makefile +++ b/board/amcc/canyonlands/Makefile @@ -25,10 +25,11 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).a
-COBJS := $(BOARD).o -COBJS += bootstrap.o +COBJS-y := $(BOARD).o +COBJS-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o SOBJS := init.o
+COBJS := $(COBJS-y) SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) SOBJS := $(addprefix $(obj),$(SOBJS)) diff --git a/board/amcc/canyonlands/bootstrap.c b/board/amcc/canyonlands/bootstrap.c deleted file mode 100644 index 6dc2cca..0000000 --- a/board/amcc/canyonlands/bootstrap.c +++ /dev/null @@ -1,195 +0,0 @@ -/* - * (C) Copyright 2008 - * Stefan Roese, DENX Software Engineering, sr@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - * - */ - -#include <common.h> -#include <command.h> -#include <i2c.h> -#include <asm/io.h> - -/* - * NOR and NAND boot options change bytes 5, 6, 8, 9, 11. The - * values are independent of the rest of the clock settings. - */ - -#define NAND_COMPATIBLE 0x01 -#define NOR_COMPATIBLE 0x02 - -#define I2C_EEPROM_ADDR 0x52 - -static char *config_labels[] = { - "CPU: 600 PLB: 200 OPB: 100 EBC: 100", - "CPU: 800 PLB: 200 OPB: 100 EBC: 100", - "CPU:1000 PLB: 200 OPB: 100 EBC: 100", - "CPU:1066 PLB: 266 OPB: 88 EBC: 88", - NULL -}; - -static u8 boot_configs[][17] = { - { - (NAND_COMPATIBLE | NOR_COMPATIBLE), - 0x86, 0x80, 0xce, 0x1f, 0x79, 0x80, 0x00, 0xa0, 0x40, 0x08, - 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 - }, - { - (NAND_COMPATIBLE | NOR_COMPATIBLE), - 0x86, 0x80, 0xba, 0x14, 0x99, 0x80, 0x00, 0xa0, 0x40, 0x08, - 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 - }, - { - (NAND_COMPATIBLE | NOR_COMPATIBLE), - 0x86, 0x82, 0x96, 0x19, 0xb9, 0x80, 0x00, 0xa0, 0x40, 0x08, - 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 - }, - { - (NAND_COMPATIBLE | NOR_COMPATIBLE), - 0x86, 0x80, 0xb3, 0x01, 0x9d, 0x80, 0x00, 0xa0, 0x40, 0x08, - 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 - }, - { - 0, - 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 - } -}; - -/* - * Bytes 5,6,8,9,11 change for NAND boot - */ -#if 0 -/* - * Values for 512 page size NAND chips, not used anymore, just - * keep them here for reference - */ -static u8 nand_boot[] = { - 0x90, 0x01, 0xa0, 0x68, 0x58 -}; -#else -/* - * Values for 2k page size NAND chips - */ -static u8 nand_boot[] = { - 0x90, 0x01, 0xa0, 0xe8, 0x58 -}; -#endif - -static int do_bootstrap(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - u8 *buf, b_nand; - int x, y, nbytes, selcfg; - extern char console_buffer[]; - - if (argc < 2) { - cmd_usage(cmdtp); - return 1; - } - - if ((strcmp(argv[1], "nor") != 0) && - (strcmp(argv[1], "nand") != 0)) { - printf("Unsupported boot-device - only nor|nand support\n"); - return 1; - } - - /* set the nand flag based on provided input */ - if ((strcmp(argv[1], "nand") == 0)) - b_nand = 1; - else - b_nand = 0; - - printf("Available configurations: \n\n"); - - if (b_nand) { - for(x = 0, y = 0; boot_configs[x][0] != 0; x++) { - /* filter on nand compatible */ - if (boot_configs[x][0] & NAND_COMPATIBLE) { - printf(" %d - %s\n", (y+1), config_labels[x]); - y++; - } - } - } else { - for(x = 0, y = 0; boot_configs[x][0] != 0; x++) { - /* filter on nor compatible */ - if (boot_configs[x][0] & NOR_COMPATIBLE) { - printf(" %d - %s\n", (y+1), config_labels[x]); - y++; - } - } - } - - do { - nbytes = readline(" Selection [1-x / quit]: "); - - if (nbytes) { - if (strcmp(console_buffer, "quit") == 0) - return 0; - selcfg = simple_strtol(console_buffer, NULL, 10); - if ((selcfg < 1) || (selcfg > y)) - nbytes = 0; - } - } while (nbytes == 0); - - - y = (selcfg - 1); - - for (x = 0; boot_configs[x][0] != 0; x++) { - if (b_nand) { - if (boot_configs[x][0] & NAND_COMPATIBLE) { - if (y > 0) - y--; - else if (y < 1) - break; - } - } else { - if (boot_configs[x][0] & NOR_COMPATIBLE) { - if (y > 0) - y--; - else if (y < 1) - break; - } - } - } - - buf = &boot_configs[x][1]; - - if (b_nand) { - buf[5] = nand_boot[0]; - buf[6] = nand_boot[1]; - buf[8] = nand_boot[2]; - buf[9] = nand_boot[3]; - buf[11] = nand_boot[4]; - } - - if (i2c_write(I2C_EEPROM_ADDR, 0, 1, buf, 16) != 0) - printf("Error writing to EEPROM at address 0x%x\n", I2C_EEPROM_ADDR); - udelay(CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS * 1000); - - printf("Done\n"); - printf("Please power-cycle the board for the changes to take effect\n"); - - return 0; -} - -U_BOOT_CMD( - bootstrap, 2, 0, do_bootstrap, - "program the I2C bootstrap EEPROM", - "<nand|nor> - strap to boot from NAND or NOR flash" -); diff --git a/board/amcc/canyonlands/chip_config.c b/board/amcc/canyonlands/chip_config.c new file mode 100644 index 0000000..8504171 --- /dev/null +++ b/board/amcc/canyonlands/chip_config.c @@ -0,0 +1,55 @@ +/* + * (C) Copyright 2008-2009 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#include <common.h> +#include <asm/ppc4xx_config.h> + +struct ppc4xx_config ppc4xx_config_val[] = { + { "600-nor", "NOR CPU: 600 PLB: 200 OPB: 100 EBC: 100", + { 0x86, 0x80, 0xce, 0x1f, 0x79, 0x80, 0x00, 0xa0, + 0x40, 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 } }, + { "600-nand", "NAND CPU: 600 PLB: 200 OPB: 100 EBC: 100", + { 0x86, 0x80, 0xce, 0x1f, 0x79, 0x90, 0x01, 0xa0, + 0xa0, 0xe8, 0x23, 0x58, 0x0d, 0x05, 0x00, 0x00 } }, + { "800-nor", "NOR CPU: 800 PLB: 200 OPB: 100 EBC: 100", + { 0x86, 0x80, 0xba, 0x14, 0x99, 0x80, 0x00, 0xa0, + 0x40, 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 } }, + { "800-nand", "NAND CPU: 800 PLB: 200 OPB: 100 EBC: 100", + { 0x86, 0x80, 0xba, 0x14, 0x99, 0x90, 0x01, 0xa0, + 0xa0, 0xe8, 0x23, 0x58, 0x0d, 0x05, 0x00, 0x00 } }, + { "1000-nor", "NOR CPU:1000 PLB: 200 OPB: 100 EBC: 100", + { 0x86, 0x82, 0x96, 0x19, 0xb9, 0x80, 0x00, 0xa0, + 0x40, 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 } }, + { "1000-nand", "NAND CPU:1000 PLB: 200 OPB: 100 EBC: 100", + { 0x86, 0x82, 0x96, 0x19, 0xb9, 0x90, 0x01, 0xa0, + 0xa0, 0xe8, 0x23, 0x58, 0x0d, 0x05, 0x00, 0x00 } }, + { "1066-nor", "NOR CPU:1066 PLB: 266 OPB: 88 EBC: 88", + { 0x86, 0x80, 0xb3, 0x01, 0x9d, 0x80, 0x00, 0xa0, + 0x40, 0x08, 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 } }, + { "1066-nand", "NAND CPU:1066 PLB: 266 OPB: 88 EBC: 88", + { 0x86, 0x80, 0xb3, 0x01, 0x9d, 0x90, 0x01, 0xa0, + 0xa0, 0xe8, 0x23, 0x58, 0x0d, 0x05, 0x00, 0x00 } }, +}; + +int ppc4xx_config_count = ARRAY_SIZE(ppc4xx_config_val); diff --git a/cpu/ppc4xx/Makefile b/cpu/ppc4xx/Makefile index 6f52dfd..2050b17 100644 --- a/cpu/ppc4xx/Makefile +++ b/cpu/ppc4xx/Makefile @@ -41,6 +41,9 @@ endif COBJS += 4xx_pci.o COBJS += 4xx_pcie.o COBJS += bedbug_405.o +ifdef CONFIG_CMD_CHIP_CONFIG +COBJS += cmd_chip_config.o +endif COBJS += commproc.o COBJS += cpu.o COBJS += cpu_init.o diff --git a/cpu/ppc4xx/cmd_chip_config.c b/cpu/ppc4xx/cmd_chip_config.c new file mode 100644 index 0000000..d360d5b --- /dev/null +++ b/cpu/ppc4xx/cmd_chip_config.c @@ -0,0 +1,142 @@ +/* + * (C) Copyright 2008-2009 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * (C) Copyright 2009 + * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#include <common.h> +#include <command.h> +#include <i2c.h> +#include <asm/ppc4xx_config.h> +#include <asm/io.h> + +static void print_configs(int cur_config_nr) +{ + int i; + + for (i = 0; i < ppc4xx_config_count; i++) { + printf("%-16s - %s", ppc4xx_config_val[i].label, + ppc4xx_config_val[i].description); + if (i == cur_config_nr) + printf(" ***"); + printf("\n"); + } + +} + +static int do_chip_config(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + int i; + int ret; + int cur_config_nr = -1; + u8 cur_config[CONFIG_4xx_CONFIG_BLOCKSIZE]; + +#ifdef CONFIG_CMD_EEPROM + ret = eeprom_read(CONFIG_4xx_CONFIG_I2C_EEPROM_ADDR, + CONFIG_4xx_CONFIG_I2C_EEPROM_OFFSET, + cur_config, CONFIG_4xx_CONFIG_BLOCKSIZE); +#else + ret = i2c_read(CONFIG_4xx_CONFIG_I2C_EEPROM_ADDR, + CONFIG_4xx_CONFIG_I2C_EEPROM_OFFSET, + 1, cur_config, CONFIG_4xx_CONFIG_BLOCKSIZE); +#endif + if (ret) { + printf("Error reading EEPROM at addr 0x%x\n", + CONFIG_4xx_CONFIG_I2C_EEPROM_ADDR); + return -1; + } + + /* + * Search the current configuration + */ + for (i = 0; i < ppc4xx_config_count; i++) { + if (memcmp(cur_config, ppc4xx_config_val[i].val, + CONFIG_4xx_CONFIG_BLOCKSIZE) == 0) + cur_config_nr = i; + } + + if (cur_config_nr == -1) { + printf("Warning: The I2C bootstrap values don't match any" + " of the available options!\n"); + printf("I2C bootstrap EEPROM values are (I2C address 0x%02x):\n", + CONFIG_4xx_CONFIG_I2C_EEPROM_ADDR); + for (i = 0; i < CONFIG_4xx_CONFIG_BLOCKSIZE; i++) { + printf("%02x ", cur_config[i]); + } + printf("\n"); + } + + if (argc < 2) { + printf("Available configurations (I2C address 0x%02x):\n", + CONFIG_4xx_CONFIG_I2C_EEPROM_ADDR); + print_configs(cur_config_nr); + return 0; + } + + for (i = 0; i < ppc4xx_config_count; i++) { + /* + * Search for configuration name/label + */ + if (strcmp(argv[1], ppc4xx_config_val[i].label) == 0) { + printf("Using configuration:\n%-16s - %s\n", + ppc4xx_config_val[i].label, + ppc4xx_config_val[i].description); + +#ifdef CONFIG_CMD_EEPROM + ret = eeprom_write(CONFIG_4xx_CONFIG_I2C_EEPROM_ADDR, + CONFIG_4xx_CONFIG_I2C_EEPROM_OFFSET, + ppc4xx_config_val[i].val, + CONFIG_4xx_CONFIG_BLOCKSIZE); +#else + ret = i2c_write(CONFIG_4xx_CONFIG_I2C_EEPROM_ADDR, + CONFIG_4xx_CONFIG_I2C_EEPROM_OFFSET, + 1, ppc4xx_config_val[i].val, + CONFIG_4xx_CONFIG_BLOCKSIZE); +#endif + udelay(CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS * 1000); + if (ret) { + printf("Error updating EEPROM at addr 0x%x\n", + CONFIG_4xx_CONFIG_I2C_EEPROM_ADDR); + return -1; + } + + printf("done (dump via 'i2c md %x 0.1 %x')\n", + CONFIG_4xx_CONFIG_I2C_EEPROM_ADDR, + CONFIG_4xx_CONFIG_BLOCKSIZE); + printf("Reset the board for the changes to" + " take effect\n"); + return 0; + } + } + + printf("Configuration %s not found!\n", argv[1]); + print_configs(cur_config_nr); + return -1; +} + +U_BOOT_CMD( + chip_config, 2, 0, do_chip_config, + "program the I2C bootstrap EEPROM", + "[config-label]" +); diff --git a/include/asm-ppc/ppc4xx_config.h b/include/asm-ppc/ppc4xx_config.h new file mode 100644 index 0000000..49acb60 --- /dev/null +++ b/include/asm-ppc/ppc4xx_config.h @@ -0,0 +1,42 @@ +/* + * (C) Copyright 2008-2009 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * (C) Copyright 2009 + * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#ifndef __PPC4xx_CONFIG_H +#define __PPC4xx_CONFIG_H + +#include <common.h> + +struct ppc4xx_config { + char label[16]; + char description[64]; + u8 val[CONFIG_4xx_CONFIG_BLOCKSIZE]; +}; + +extern struct ppc4xx_config ppc4xx_config_val[]; +extern int ppc4xx_config_count; + +#endif /* __PPC4xx_CONFIG_H */ diff --git a/include/configs/canyonlands.h b/include/configs/canyonlands.h index d22d411..217a8ee 100644 --- a/include/configs/canyonlands.h +++ b/include/configs/canyonlands.h @@ -330,6 +330,11 @@ #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10
+/* I2C bootstrap EEPROM */ +#define CONFIG_4xx_CONFIG_I2C_EEPROM_ADDR 0x52 +#define CONFIG_4xx_CONFIG_I2C_EEPROM_OFFSET 0 +#define CONFIG_4xx_CONFIG_BLOCKSIZE 16 + /* I2C SYSMON (LM75, AD7414 is almost compatible) */ #define CONFIG_DTT_LM75 1 /* ON Semi's LM75 */ #define CONFIG_DTT_AD7414 1 /* use AD7414 */ @@ -442,6 +447,7 @@ /* * Commands additional to the ones defined in amcc-common.h */ +#define CONFIG_CMD_CHIP_CONFIG #if defined(CONFIG_ARCHES) #define CONFIG_CMD_DTT #define CONFIG_CMD_PCI
Works fine! Thanks.
Acked-by: Matthias Fuchs matthias.fuchs@esd.eu
v5:
v4:
v3:
v2:
- (C) Copyright 2008
- Stefan Roese, DENX Software Engineering, sr@denx.de.
- project.
- MA 02111-1307 USA
- NOR and NAND boot options change bytes 5, 6, 8, 9, 11. The
- values are independent of the rest of the clock settings.
- NULL
0,
- Bytes 5,6,8,9,11 change for NAND boot
-#if 0 -/*
- Values for 512 page size NAND chips, not used anymore, just
- keep them here for reference
-}; -#else -/*
- Values for 2k page size NAND chips
-}; -#endif
- u8 *buf, b_nand;
- if (argc < 2) {
cmd_usage(cmdtp);
return 1;
return 1;
b_nand = 1;
- else
b_nand = 0;
- if (b_nand) {
y++;
- } else {
y++;
- do {
if (nbytes) {
nbytes = 0;
- y = (selcfg - 1);
if (b_nand) {
if (y > 0)
y--;
else if (y < 1)
break;
} else {
if (y > 0)
y--;
else if (y < 1)
break;
- if (b_nand) {
- printf("Done\n");
-U_BOOT_CMD(
- (C) Copyright 2008-2009
- project.
- MA 02111-1307 USA
- { "600-nor", "NOR CPU: 600 PLB: 200 OPB: 100 EBC: 100",
- { "600-nand", "NAND CPU: 600 PLB: 200 OPB: 100 EBC: 100",
- { "800-nor", "NOR CPU: 800 PLB: 200 OPB: 100 EBC: 100",
- { "800-nand", "NAND CPU: 800 PLB: 200 OPB: 100 EBC: 100",
- { "1000-nor", "NOR CPU:1000 PLB: 200 OPB: 100 EBC: 100",
- { "1000-nand", "NAND CPU:1000 PLB: 200 OPB: 100 EBC: 100",
- { "1066-nor", "NOR CPU:1066 PLB: 266 OPB: 88 EBC: 88",
- { "1066-nand", "NAND CPU:1066 PLB: 266 OPB: 88 EBC: 88",
- (C) Copyright 2009
- Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de
- project.
- MA 02111-1307 USA
- int i;
- for (i = 0; i < ppc4xx_config_count; i++) {
printf(" ***");
printf("\n");
- int i;
- int ret;
- int cur_config_nr = -1;
- u8 cur_config[CONFIG_4xx_CONFIG_BLOCKSIZE];
- ret = eeprom_read(CONFIG_4xx_CONFIG_I2C_EEPROM_ADDR,
+#else
- ret = i2c_read(CONFIG_4xx_CONFIG_I2C_EEPROM_ADDR,
- if (ret) {
return -1;
cur_config_nr = i;
- if (cur_config_nr == -1) {
printf("\n");
- if (argc < 2) {
+#else
if (ret) {
return -1;
" take effect\n");
- printf("Configuration %s not found!\n", argv[1]);
- print_configs(cur_config_nr);
- return -1;
+U_BOOT_CMD(
- chip_config, 2, 0, do_chip_config,
- "[config-label]"
- project.
- MA 02111-1307 USA
- char label[16];
- char description[64];
- u8 val[CONFIG_4xx_CONFIG_BLOCKSIZE];
- Commands additional to the ones defined in amcc-common.h
Matthias Fuchs
Stefan Roese
