Re: [U-Boot-Users] How to use u-boot to load kernel and file system to one partition in NAND
Charles,
I currently have the kernel in NAND flash, but my NAND has two separate partitions. One for Kernel and one for file system.
The problem I have is not really how to put the kernel in NAND, but how to upgrade it. I don't really want to overwrite what I have, instead I want to load another image and have u-boot be able to pick up one or the other. This way, I can have two copies and in case the new version is bad, I can always have one to fall back on. This is why, I was thinking that either having a soft link to a file in a single partition nand or have three separate partitions (two of them for kernel, one for file system).
________________________________
From: Charles Krinke [mailto:ckrinke@istor.com] Sent: Thursday, November 02, 2006 1:24 PM To: Nancy Isaac; u-boot-users@lists.sourceforge.net Subject: RE: [U-Boot-Users] How to use u-boot to load kernel and file system toone partition in NAND
Dear Nancy & "the list":
I have a similar problem to solve with a PPC8241 board which currently has 2Mbyte NOR flash and 128Mbyte of NAND flash. Let me tell you how far I have gotten and maybe someone else can offer some suggestions for both of us.
In looking at u-boot, I can see in some jffs2 support in common/cmd_jffs2.c and fs/jffs2 and it looks like u-boot can be configured to boot a kernel in cramfs or jffs2. So based on that, I am assuming that getting the kernel onto an mtdblock partition as jffs2 should allow u-boot to boot the kernel from NAND flash instead of its current NOR flash.
I am currently studying the code trying to figure out how to configure this scenario.
Perhaps someone else can come in with a few suggestions for both of us.
Charles
From: u-boot-users-bounces@lists.sourceforge.net [mailto:u-boot-users-bounces@lists.sourceforge.net] On Behalf Of Nancy Isaac Sent: Thursday, November 02, 2006 12:13 PM To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] How to use u-boot to load kernel and file system toone partition in NAND
I am trying to see if u-boot allows to have a single partition for both kernel and file system in NAND Flash.
Currently, we have one 4M partition for kernel and the rest of the NAND flash for file system.
But, I am looking for possible ways of upgrading the kernel in the field.
Currently, I am looking at two possible approaches:
1. add an extra partition in the NAND flash and keep the second kernel in there and have some way in u-boot to decide which one to load.
2. if u-boot allows, have one single partition for both kernel and file system and upload both kernel images and have a soft link to a kernel image.
I can't find a way to do the second option above, but that would be ideal for field upgrade. Has anyone tried either of these approaches or have any other idea of how to do this? I am new to using u-boot and linux.
Thanks
In message 9BB2AECBBDD3E6499663C42C1DFD40AAE49768@PETWM02.calix.local you wrote:
Why not simply using different names for both images, and switching the boot filename in U-Boot? Remember that U-Boot is scriptable, so this is a trivial thing to do.
Nancy Isaac
