[U-Boot] [PATCH 1/1] add u-boot/types to simplify HOST support
add fix MacOS HOST support
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- include/elf.h | 15 +------------ include/environment.h | 6 +---- include/image.h | 1 + include/libfdt_env.h | 3 +- include/u-boot/md5.h | 2 +- include/u-boot/types.h | 53 ++++++++++++++++++++++++++++++++++++++++++++++++ 6 files changed, 58 insertions(+), 22 deletions(-) create mode 100644 include/u-boot/types.h
diff --git a/include/elf.h b/include/elf.h index a9839df..88d76bd 100644 --- a/include/elf.h +++ b/include/elf.h @@ -33,20 +33,7 @@ #ifndef _ELF_H #define _ELF_H
-#if defined(__BEOS__) || \ - defined(__NetBSD__) || \ - defined(__FreeBSD__) || \ - defined(__sun__) || \ - defined(__APPLE__) -#include <inttypes.h> -#elif defined(__linux__) && defined(USE_HOSTCC) -#include <stdint.h> -#elif defined(__WIN32__) -#include <unistd.h> -typedef unsigned char uint8_t; -typedef unsigned short uint16_t; -typedef unsigned int uint32_t; -#endif +#include <u-boot/types.h>
/* * This version doesn't work for 64-bit ABIs - Erik. diff --git a/include/environment.h b/include/environment.h index 481ea73..d9d75cb 100644 --- a/include/environment.h +++ b/include/environment.h @@ -84,11 +84,7 @@ # endif #endif /* CFG_ENV_IS_IN_NAND */
-#ifdef USE_HOSTCC -# include <stdint.h> -#else -# include <linux/types.h> -#endif +#include <u-boot/types.h>
#ifdef CFG_REDUNDAND_ENVIRONMENT # define ENV_HEADER_SIZE (sizeof(uint32_t) + 1) diff --git a/include/image.h b/include/image.h index 4b9c582..0f1a5f4 100644 --- a/include/image.h +++ b/include/image.h @@ -35,6 +35,7 @@
#include <asm/byteorder.h> #include <command.h> +#include <u-boot/types.h>
#ifndef USE_HOSTCC #include <lmb.h> diff --git a/include/libfdt_env.h b/include/libfdt_env.h index a7fd2f8..d5b1c12 100644 --- a/include/libfdt_env.h +++ b/include/libfdt_env.h @@ -21,12 +21,11 @@ #ifndef _LIBFDT_ENV_H #define _LIBFDT_ENV_H
+#include <u-boot/types.h> #ifdef USE_HOSTCC -#include <stdint.h> #include <string.h> #else #include <linux/string.h> -#include <linux/types.h> #endif /* USE_HOSTCC */
#include <stddef.h> diff --git a/include/u-boot/md5.h b/include/u-boot/md5.h index 8b44a7f..0e3f3bc 100644 --- a/include/u-boot/md5.h +++ b/include/u-boot/md5.h @@ -6,7 +6,7 @@ #ifndef _MD5_H #define _MD5_H
-#include <linux/types.h> +#include <u-boot/types.h>
struct MD5Context { __u32 buf[4]; diff --git a/include/u-boot/types.h b/include/u-boot/types.h new file mode 100644 index 0000000..e4afa98 --- /dev/null +++ b/include/u-boot/types.h @@ -0,0 +1,53 @@ +/* + * (C) Copyright 2008 Jean-Christophe PLAGNIOL-VILLARD + * plagnioj@jcrosft.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __U_BOOT_TYPES_H__ +#define __U_BOOT_TYPES_H__ + +#ifndef USE_HOSTCC +#include <linux/types.h> +#else + +#if defined(__BEOS__) || \ + defined(__NetBSD__) || \ + defined(__FreeBSD__) || \ + defined(__sun__) || \ + defined(__APPLE__) +#include <inttypes.h> +/* sysv */ +typedef unsigned char unchar; +typedef unsigned short ushort; +typedef unsigned int uint; +typedef unsigned long ulong; + +#elif defined(__linux__) +#include <stdint.h> +#elif defined(__WIN32__) +#include <unistd.h> +typedef unsigned char uint8_t; +typedef unsigned short uint16_t; +typedef unsigned int uint32_t; +#endif +#endif /* USE_HOSTCC */ + +#endif /* __U_BOOT_TYPES_H__ */
Dear Jean-Christophe PLAGNIOL-VILLARD,
- (C) Copyright 2008 Jean-Christophe PLAGNIOL-VILLARD
- project.
- MA 02111-1307 USA
My initial reaction was "what a good idea", bt after looking at the resulting code I find that it bocmes even less readable. With this patch applied, I lost the last bit of track I had which define was coming where from.
For example, include/environment.h used to have this code:
So it would include <linux/types.h> for <stdint.h> for native builds.
With your change, we have added complexity of selecting from <inttypes.h> or <stdint.h> or <unistd.h> or nothing.
Are you absolutely sure that this is 100% equivalent and working?
I have to admit that I don't like this change.
we can modify it as
#ifdef USE_HOSTCC #include <linux/types.h> #else #if defined(__BEOS__) || \ defined(__NetBSD__) || \ defined(__FreeBSD__) || \ defined(__sun__) || \ defined(__APPLE__) #include <inttypes.h> /* sysv */ typedef unsigned char unchar; typedef unsigned short ushort; typedef unsigned int uint; typedef unsigned long ulong;
#elif defined(__WIN32__) #include <unistd.h> typedef unsigned char uint8_t; typedef unsigned short uint16_t; typedef unsigned int uint32_t; #else /* __linux__ & default */ #include <stdint.h> #endif #endif /* USE_HOSTCC */
I've test it on MacOs and Linux.
Best Regards, J.
Dear Jean-Christophe,
we can modify it as
Of course we can modify it - but that doesn't make it less cluttered.
That's just two systems out of N...
