[PATCH] arm: socfpga: n5x: Enable all features as in exisiting devices
Enable more configurations and features as in Agilex device since all these hardware peripherals no change in N5X compare with Agilex.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- configs/socfpga_n5x_atf_defconfig | 2 ++ configs/socfpga_n5x_defconfig | 7 +++++-- configs/socfpga_n5x_vab_defconfig | 4 +++- 3 files changed, 10 insertions(+), 3 deletions(-)
diff --git a/configs/socfpga_n5x_atf_defconfig b/configs/socfpga_n5x_atf_defconfig index 37c8436318..d2598b9fb3 100644 --- a/configs/socfpga_n5x_atf_defconfig +++ b/configs/socfpga_n5x_atf_defconfig @@ -55,6 +55,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_WDT=y +CONFIG_CMD_MTD=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y @@ -70,6 +71,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y +CONFIG_SPL_ALTERA_SDRAM=y CONFIG_MMC_DW=y CONFIG_MTD=y CONFIG_SF_DEFAULT_MODE=0x2003 diff --git a/configs/socfpga_n5x_defconfig b/configs/socfpga_n5x_defconfig index 5f415b7ad4..4971acab8c 100644 --- a/configs/socfpga_n5x_defconfig +++ b/configs/socfpga_n5x_defconfig @@ -20,7 +20,9 @@ CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon panic=-1 earlyprintk=ttyS0,115200" CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="run fatscript; run mmcload; run linux_qspi_enable; run mmcboot" +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="earlycon panic=-1 earlyprintk=ttyS0,115200" +CONFIG_BOOTCOMMAND="run fatscript;run mmcload;run linux_qspi_enable;run rsu_status;run mmcboot" CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x3ff00000 @@ -44,9 +46,9 @@ CONFIG_CMD_MEMTEST=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_WDT=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y @@ -79,6 +81,7 @@ CONFIG_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_DESIGNWARE_WATCHDOG=y +CONFIG_CMD_WDT=y CONFIG_WDT=y # CONFIG_SPL_USE_TINY_PRINTF is not set CONFIG_PANIC_HANG=y diff --git a/configs/socfpga_n5x_vab_defconfig b/configs/socfpga_n5x_vab_defconfig index a57d54a7f2..977a90d493 100644 --- a/configs/socfpga_n5x_vab_defconfig +++ b/configs/socfpga_n5x_vab_defconfig @@ -55,7 +55,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_WDT=y +CONFIG_CMD_MTD=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y @@ -71,6 +71,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y +CONFIG_SPL_ALTERA_SDRAM=y CONFIG_MMC_DW=y CONFIG_MTD=y CONFIG_SF_DEFAULT_MODE=0x2003 @@ -90,5 +91,6 @@ CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_DESIGNWARE_WATCHDOG=y CONFIG_WDT=y +CONFIG_CMD_WDT=y # CONFIG_SPL_USE_TINY_PRINTF is not set CONFIG_PANIC_HANG=y
Jit Loon Lim
