[PATCHv2 0/1] Makefile: pass external DTB provided by make variable EXT_DTB to binman
Changes in v2: - fix syntax errors in the description - impelement handling multiple DTB files in the EXT_DTB
Alexander Kochetkov (1): Makefile: pass external DTB provided by make variable EXT_DTB to binman
Makefile | 12 +++++++++++- 1 file changed, 11 insertions(+), 1 deletion(-)
Yocto build is using EXT_DTB to repack U-Boot during signed FIT kernel creation. First, it takes the DTB from U-Boot, then it creates signed FIT kernel image and places kernel key into the DTB. After that it executes: make EXT_DTB=/path/to/dtb/with/kernel/key
Despite the fact that in the documentation all examples with EXT_DTB use only single DTB, the patch allows pass many DTB files separated by spaces, e.g.: make EXT_DTB="/path1/to/1.dtb /path2/to/2.dtb"
The first DTB from the list become default configuration.
Signed-off-by: Alexander Kochetkov al.kochet@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- Makefile | 12 +++++++++++- 1 file changed, 11 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 1c754ceb595..6dea0345f50 100644 --- a/Makefile +++ b/Makefile @@ -1367,7 +1367,17 @@ u-boot.ldr: u-boot # --------------------------------------------------------------------------- # Use 'make BINMAN_DEBUG=1' to enable debugging # Use 'make BINMAN_VERBOSE=3' to set vebosity level + +ifneq ($(EXT_DTB),) +ext_dtb_list := $(basename $(notdir $(EXT_DTB))) +default_dt := $(firstword $(ext_dtb_list)) +of_list := "$(ext_dtb_list)" +of_list_dirs := $(dir $(EXT_DTB)) +else +of_list := $(CONFIG_OF_LIST) +of_list_dirs := $(dt_dir) default_dt := $(if $(DEVICE_TREE),$(DEVICE_TREE),$(CONFIG_DEFAULT_DEVICE_TREE)) +endif
quiet_cmd_binman = BINMAN $@ cmd_binman = $(srctree)/tools/binman/binman $(if $(BINMAN_DEBUG),-D) \ @@ -1377,7 +1387,7 @@ cmd_binman = $(srctree)/tools/binman/binman $(if $(BINMAN_DEBUG),-D) \ build -u -d u-boot.dtb -O . -m \ --allow-missing $(if $(BINMAN_ALLOW_MISSING),--ignore-missing) \ -I . -I $(srctree) -I $(srctree)/board/$(BOARDDIR) \ - -I $(dt_dir) -a of-list=$(CONFIG_OF_LIST) \ + $(foreach f,$(of_list_dirs),-I $(f)) -a of-list=$(of_list) \ $(foreach f,$(BINMAN_INDIRS),-I $(f)) \ -a atf-bl31-path=${BL31} \ -a tee-os-path=${TEE} \
On Thu, 19 Sep 2024 19:10:41 +0300, al.kochet@gmail.com wrote:
Changes in v2:
al.kochet@gmail.com
