[U-Boot] [PATCH] powerpc/p1_p2_rdb_pc: print -PC suffix in board name
Currently the -PC variants of the P1/P2 RDB boards do not print it on boot -- e.g. a P2020RDB-PC will claim to be a plain P2020RDB. Besides being incorrect, this can confuse a user into building U-Boot for P2020RDB rather than P2020RDB-PC, resulting in a board that does not boot.
P1024RDB and P1025RDB are not included, as these boards apparently do not have -PC as part of their name, even though they are supported by p1_p2_rdb_pc.
Signed-off-by: Scott Wood scottwood@freescale.com --- include/configs/p1_p2_rdb_pc.h | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index a8882d4..58af3a5 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -31,7 +31,7 @@ #endif
#if defined(CONFIG_P1020MBG) -#define CONFIG_BOARDNAME "P1020MBG" +#define CONFIG_BOARDNAME "P1020MBG-PC" #define CONFIG_P1020 #define CONFIG_VSC7385_ENET #define CONFIG_SLIC @@ -41,7 +41,7 @@ #endif
#if defined(CONFIG_P1020UTM) -#define CONFIG_BOARDNAME "P1020UTM" +#define CONFIG_BOARDNAME "P1020UTM-PC" #define CONFIG_P1020 #define __SW_BOOT_MASK 0x03 #define __SW_BOOT_NOR 0xe0 @@ -49,7 +49,7 @@ #endif
#if defined(CONFIG_P1020RDB) -#define CONFIG_BOARDNAME "P1020RDB" +#define CONFIG_BOARDNAME "P1020RDB-PC" #define CONFIG_NAND_FSL_ELBC #define CONFIG_P1020 #define CONFIG_SPI_FLASH @@ -64,7 +64,7 @@ #endif
#if defined(CONFIG_P1021RDB) -#define CONFIG_BOARDNAME "P1021RDB" +#define CONFIG_BOARDNAME "P1021RDB-PC" #define CONFIG_NAND_FSL_ELBC #define CONFIG_P1021 #define CONFIG_QE @@ -111,7 +111,7 @@ #endif
#if defined(CONFIG_P2020RDB) -#define CONFIG_BOARDNAME "P2020RDB" +#define CONFIG_BOARDNAME "P2020RDB-PC" #define CONFIG_NAND_FSL_ELBC #define CONFIG_P2020 #define CONFIG_SPI_FLASH
Scott Wood
