[PATCH 1/1] efi_selftest: add tool to download dtb
For validating the fixed up device tree we need a tool to need to save it to a file.
dtbdump.efi copies the configuration table with the device tree to a file on the same partition from which dtbdump.efi was invoked. The file name can be entered on the console.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_selftest/Makefile | 5 + lib/efi_selftest/dtbdump.c | 215 +++++++++++++++++++++++++++++++++++++ 2 files changed, 220 insertions(+) create mode 100644 lib/efi_selftest/dtbdump.c
diff --git a/lib/efi_selftest/Makefile b/lib/efi_selftest/Makefile index 06d66cfdd1..aabb743ecb 100644 --- a/lib/efi_selftest/Makefile +++ b/lib/efi_selftest/Makefile @@ -8,6 +8,8 @@ asflags-y += -DHOST_ARCH="$(HOST_ARCH)" ccflags-y += -DHOST_ARCH="$(HOST_ARCH)"
+CFLAGS_dtbdump_exit.o := $(CFLAGS_EFI) -Os -ffreestanding +CFLAGS_REMOVE_dtbdump.o := $(CFLAGS_NON_EFI) CFLAGS_efi_selftest_miniapp_exit.o := $(CFLAGS_EFI) -Os -ffreestanding CFLAGS_REMOVE_efi_selftest_miniapp_exit.o := $(CFLAGS_NON_EFI) CFLAGS_efi_selftest_miniapp_return.o := $(CFLAGS_EFI) -Os -ffreestanding @@ -76,6 +78,9 @@ efi_selftest_miniapp_exception.efi \ efi_selftest_miniapp_exit.efi \ efi_selftest_miniapp_return.efi
+always += \ +dtbdump.efi + $(obj)/efi_miniapp_file_image_exception.h: $(obj)/efi_selftest_miniapp_exception.efi $(obj)/../../tools/file2include $(obj)/efi_selftest_miniapp_exception.efi > \ $(obj)/efi_miniapp_file_image_exception.h diff --git a/lib/efi_selftest/dtbdump.c b/lib/efi_selftest/dtbdump.c new file mode 100644 index 0000000000..d90e3eb768 --- /dev/null +++ b/lib/efi_selftest/dtbdump.c @@ -0,0 +1,215 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2020, Heinrich Schuchardt xypron.glpk@gmx.de + * + * dtbdump.efi saves the device tree provided as a configuration table + * to a file. + */ + +#include <common.h> +#include <efi_api.h> + +#define BUFFER_SIZE 64 +#define ESC 0x17 +#define DEFAULT_FILENAME L"dtb.dtb" + +static struct efi_simple_text_output_protocol *cerr; +static struct efi_simple_text_output_protocol *cout; +static struct efi_simple_text_input_protocol *cin; +static struct efi_boot_services *bs; +static const efi_guid_t fdt_guid = EFI_FDT_GUID; +static const efi_guid_t loaded_image_guid = EFI_LOADED_IMAGE_PROTOCOL_GUID; +static const efi_guid_t guid_simple_file_system_protocol = + EFI_SIMPLE_FILE_SYSTEM_PROTOCOL_GUID; + +/** + * input() - read string from console + * + * @buffer: input buffer + * @buffer_size: buffer size + * Return: status code + */ +static efi_status_t efi_input(u16 *buffer, efi_uintn_t buffer_size) +{ + struct efi_input_key key = {0}; + efi_uintn_t index; + efi_uintn_t pos = 0; + u16 outbuf[2] = L" "; + efi_status_t ret; + + /* Drain the console input */ + ret = cin->reset(cin, true); + for (;;) { + ret = bs->wait_for_event(1, &cin->wait_for_key, &index); + if (ret != EFI_SUCCESS) + continue; + ret = cin->read_key_stroke(cin, &key); + if (ret != EFI_SUCCESS) + continue; + switch (key.scan_code) { + case 0x17: /* Escape */ + cout->output_string(cout, L"\nAborted\n"); + return EFI_ABORTED; + default: + break; + } + switch (key.unicode_char) { + case 0x08: /* Backspace */ + if (pos) { + buffer[pos--] = 0; + cout->output_string(cout, L"\b \b"); + } + break; + case 0x0a: /* Linefeed */ + case 0x0d: /* Carriage return */ + return EFI_SUCCESS; + default: + break; + } + /* Ignore surrogate codes */ + if (key.unicode_char >= 0xD800 && key.unicode_char <= 0xDBFF) + continue; + if (key.unicode_char >= 0x20 && + pos < buffer_size - 1) { + *outbuf = key.unicode_char; + buffer[pos++] = key.unicode_char; + cout->output_string(cout, outbuf); + } + } +} + +/* + * Convert FDT value to host endianness. + * + * @val FDT value + * @return converted value + */ +static u32 f2h(fdt32_t val) +{ + char *buf = (char *)&val; + char i; + + /* Swap the bytes */ + i = buf[0]; buf[0] = buf[3]; buf[3] = i; + i = buf[1]; buf[1] = buf[2]; buf[2] = i; + return *(u32 *)buf; +} + +/** + * get_dtb() - get device tree + * + * @systable: system table + * Return: device tree or NULL + */ +void *get_dtb(struct efi_system_table *systable) +{ + void *dtb = NULL; + efi_uintn_t i; + + for (i = 0; i < systable->nr_tables; ++i) { + if (!memcmp(&systable->tables[i].guid, &fdt_guid, + sizeof(efi_guid_t))) { + dtb = systable->tables[i].table; + break; + } + } + return dtb; +} + +/** + * efi_main() - entry point of the EFI application. + * + * @handle: handle of the loaded image + * @systable: system table + * @return: status code + */ +efi_status_t EFIAPI efi_main(efi_handle_t handle, + struct efi_system_table *systable) +{ + efi_uintn_t ret; + u16 filename[BUFFER_SIZE] = {0}; + efi_uintn_t dtb_size; + struct efi_loaded_image *loaded_image; + struct efi_simple_file_system_protocol *file_system; + struct efi_file_handle *root, *file; + struct fdt_header *dtb; + + cerr = systable->std_err; + cout = systable->con_out; + cin = systable->con_in; + bs = systable->boottime; + + cout->set_attribute(cout, EFI_LIGHTGRAY | EFI_BACKGROUND_BLACK); + cout->clear_screen(cout); + cout->set_attribute(cout, EFI_YELLOW | EFI_BACKGROUND_BLACK); + cout->output_string(cout, L"DTB Dump\n\n"); + cout->set_attribute(cout, EFI_LIGHTGRAY | EFI_BACKGROUND_BLACK); + + dtb = get_dtb(systable); + if (!dtb) { + cerr->output_string(cout, L"DTB not found\n"); + return EFI_NOT_FOUND; + } + if (f2h(dtb->magic) != FDT_MAGIC) { + cerr->output_string(cout, L"Wrong device tree magic\n"); + return EFI_NOT_FOUND; + } + dtb_size = f2h(dtb->totalsize); + + cout->output_string(cout, L"Filename (" DEFAULT_FILENAME ")?\n"); + ret = efi_input(filename, sizeof(filename)); + if (ret != EFI_SUCCESS) + return ret; + if (!*filename) + memcpy(filename, DEFAULT_FILENAME, sizeof(DEFAULT_FILENAME)); + + cout->output_string(cout, L"\n"); + + ret = bs->open_protocol(handle, &loaded_image_guid, + (void **)&loaded_image, NULL, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) { + cerr->output_string(cout, + L"Loaded image protocol not found\n"); + return ret; + } + + /* Open the simple file system protocol */ + ret = bs->open_protocol(loaded_image->device_handle, + &guid_simple_file_system_protocol, + (void **)&file_system, NULL, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) { + cerr->output_string( + cout, L"Failed to open simple file system protocol\n"); + return ret; + } + + /* Open volume */ + ret = file_system->open_volume(file_system, &root); + if (ret != EFI_SUCCESS) { + cerr->output_string(cerr, L"Failed to open volume\n"); + return ret; + } + /* Create file */ + ret = root->open(root, &file, filename, + EFI_FILE_MODE_READ | EFI_FILE_MODE_WRITE | + EFI_FILE_MODE_CREATE, EFI_FILE_ARCHIVE); + if (ret == EFI_SUCCESS) { + /* Write file */ + ret = file->write(file, &dtb_size, dtb); + if (ret != EFI_SUCCESS) + cerr->output_string(cerr, L"Failed to write file\n"); + file->close(file); + } else { + cerr->output_string(cerr, L"Failed to open file\n"); + } + root->close(root); + + if (ret == EFI_SUCCESS) { + cout->output_string(cout, filename); + cout->output_string(cout, L" written\n"); + } + + return ret; +} -- 2.28.0
