[U-Boot-Users] problem with net?
My board use RTL8019,when i use tftp ,there are some problems. when start tftp,my hyperterminal always display "Loading: T T T T T T T T T T T T T T T T T T T T" the whole information as follows:
U-Boot 1.1.4_XT (Jun 6 2006 - 17:36:18) U-Boot code: 0C300000 -> 0C31AD70 BSS: -> 0C31EF98 RAM Configuration: Bank #0: 0c000000 8 MB Bank #1: 0c800000 8 MB Flash: 2 MB *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Hit any key to stop autoboot: 0 XT=> help tftp tftpboot [loadAddress] [bootfilename] XT=> tftpboot 0x0c700000 image.bin TFTP from server 192.168.0.23; our IP address is 192.168.0.70 Filename 'image.bin'. Load address: 0xc700000 Loading: T T T T T T T T T T T T T T T T T T T T Retry count exceeded; starting again TFTP from server 192.168.0.23; our IP address is 192.168.0.70
would someone give me some suggestions?
thank u !
xt
060607
您 想 拥 有 abc@188.com 邮 箱 吗 ? 创 纪 录 16G 超 大 容 量(送 6G 免 费 网 盘),最 高 性 价 比 的 电 子 邮 件 解 决 之 道
Problem is still same. You must change one parameter in /net/tftp.c Broadcast is defined with MAC address ff:ff:ff:ff:ff:ff, but now is defined as 00:00:00:00:00:00. Change one line (at the end of file). old: memset(NetServerEther, 0x0, 6); new: memset(NetServerEther, 0xff, 6);
And send me echo.
Michal Simek Czech Technical University
thank u !
xt
060607
Michel,
in message 1485.131-1515-35152903-1149704429@seznam.cz you wrote:
UHJvYmxlbSBpcyBzdGlsbCBzYW1lLiBZb3UgbXVzdCBjaGFuZ2Ugb25lIHBhcmFtZXRlciBpbiAg L25ldC90ZnRwLmMgCkJyb2FkY2FzdCBpcyBkZWZpbmVkIHdpdGggTUFDIGFkZHJlc3MgZmY6ZmY6 ZmY6ZmY6ZmY6ZmYsIGJ1dCBub3cgaXMgZGVmaW5lZCBhcyAwMDowMDowMDowMDowMDowMC4KQ2hh bmdlIG9uZSBsaW5lIChhdCB0aGUgZW5kIG9mIGZpbGUpLgpvbGQ6CW1lbXNldChOZXRTZXJ2ZXJF dGhlciwgMHgwLCA2KTsgCm5ldzoJbWVtc2V0KE5ldFNlcnZlckV0aGVyLCAweGZmLCA2KTsgCgpB bmQgc2VuZCBtZSBlY2hvLgoKTWljaGFsIFNpbWVrCkN6ZWNoIFRlY2huaWNhbCBVbml2ZXJzaXR5 CgoKPiAgICBNeSBib2FyZCB1c2UgUlRMODAxOSx3aGVuIGkgdXNlIHRmdHAgLHRoZXJlIGFyZSBz b21lIHByb2JsZW1zLgo+ICAgIHdoZW4gc3RhcnQgdGZ0cO+8jG15IGh5cGVydGVybWluYWwgYWx3 YXlzIGRpc3BsYXkgIkxvYWRpbmc6IFQgVCBUIFQgVCBUIFQgVCBUIFQKPiAgVCBUIFQgVCBUIFQg VCBUIFQgVCIKPiAgdGhlIHdob2xlIGluZm9ybWF0aW9uIGFzIGZvbGxvd3PvvJoKPiAgIAo+ICBV LUJvb3QgMS4xLjRfWFQgKEp1biAgNiAyMDA2IC0gMTc6MzY6MTgpCj4gIFUtQm9vdCBjb2RlOiAw QzMwMDAwMCAtPiAwQzMxQUQ3MCAgQlNTOiAtPiAwQzMxRUY5OAo+ICBSQU0gQ29uZmlndXJhdGlv bjoKPiAgQmFuayAjMDogMGMwMDAwMDAgIDggTUIKPiAgQmFuayAjMTogMGM4MDAwMDAgIDggTUIK PiAgRmxhc2g6ICAyIE1CCj4gICoqKiBXYXJuaW5nIC0gYmFkIENSQywgdXNpbmcgZGVmYXVsdCBl bnZpcm9ubWVudAo+ICBJbjogICAgc2VyaWFsCj4gIE91dDogICBzZXJpYWwKPiAgRXJyOiAgIHNl cmlhbAo+ICBIaXQgYW55IGtleSB0byBzdG9wIGF1dG9ib290OiAgMAo+ICBYVD0+ICBoZWxwIHRm dHAKPiAgdGZ0cGJvb3QgW2xvYWRBZGRyZXNzXSBbYm9vdGZpbGVuYW1lXQo+ICBYVD0+ICB0ZnRw Ym9vdCAweDBjNzAwMDAwIGltYWdlLmJpbgo+ICBURlRQIGZyb20gc2VydmVyIDE5Mi4xNjguMC4y Mzsgb3VyIElQIGFkZHJlc3MgaXMgMTkyLjE2OC4wLjcwCj4gIEZpbGVuYW1lICdpbWFnZS5iaW4n Lgo+ICBMb2FkIGFkZHJlc3M6IDB4YzcwMDAwMAo+ICBMb2FkaW5nOiBUIFQgVCBUIFQgVCBUIFQg VCBUIFQgVCBUIFQgVCBUIFQgVCBUIFQKPiAgUmV0cnkgY291bnQgZXhjZWVkZWQ7IHN0YXJ0aW5n IGFnYWluCj4gIFRGVFAgZnJvbSBzZXJ2ZXIgMTkyLjE2OC4wLjIzOyBvdXIgSVAgYWRkcmVzcyBp cyAxOTIuMTY4LjAuNzAKPiAgIAo+ICB3b3VsZCBzb21lb25lIGdpdmUgbWUgc29tZSBzdWdnZXN0 aW9ucz8KPiAgIAo+ICB0aGFuayB1ICEKPiAgIAo+ICB4dAo+ICAgCj4gICAKPiAgMDYwNjA3Cj4g ICAKPiAgIAo+ICAgCj4gIAo+ICAKPiAgCj4gIAo+ICAKPiAgCj4gIAo+ICDmgqgg5oOzIOaLpSDm nIkgYWJjQDE4OC5jb20g6YKuIOeusSDlkJcg77yfIAo+ICDliJsg57qqIOW9lSAxNkcg6LaFIOWk pyDlrrkg6YeP77yI6YCBIDZHIOWFjSDotLkg572RIOebmO+8ie+8jOacgCDpq5gg5oCnIOS7tyDm r5Qg55qEIOeUtSDlrZAg6YKuIOS7tiDop6Mg5YazIOS5iyDpgZMgCj4gIAo+ICAKCgpfX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXwpVLUJvb3QtVXNlcnMgbWFp bGluZyBsaXN0ClUtQm9vdC1Vc2Vyc0BsaXN0cy5zb3VyY2Vmb3JnZS5uZXQKaHR0cHM6Ly9saXN0 cy5zb3VyY2Vmb3JnZS5uZXQvbGlzdHMvbGlzdGluZm8vdS1ib290LXVzZXJzCg==
You really should fix your mailer.
You claimed this before. Can you pelase point out which official standard says that 00:00:00:00:00:00 should be used as broadcast ethernet address? All information available to me says that the boradcast MAC address is all bit ones; see for example http://en.wikipedia.org/wiki/MAC_address :
The broadcast address, all one bits, is received by all stations on a local area network. In hexadecimal this would be "FF:FF:FF:FF:FF:FF".
You are using default environment. I doubt you have a default MAC address in default environment. You must setup your board specific MAC address in environment for network to work on most boards.
Check your MAC address. You might want to sniff some network traffic to see if your board is using correct MAC address as well.
Best regards, Tolunay
mONStR
Tolunay Orkun
yadog
