[U-Boot] [PATCH] Revert "ARM: davinci: da850: Manual pinmux only when PINCTRL not available"
This reverts commit 877ab2423bc257045a06bc23d4b9440b82bda6fb.
The above patch was designed to shrink code by only pin-muxing items needed for SPL in SPL and relying on driver model or SPL to mux other items. Unfortunately, da850evm_direct_nor doesn't use SPL so items that were only muxed during SPL are not muxed causing the board to no longer boot.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/board/davinci/da8xxevm/da850evm.c b/board/davinci/da8xxevm/da850evm.c index fcf9334ba9..849905cf8a 100644 --- a/board/davinci/da8xxevm/da850evm.c +++ b/board/davinci/da8xxevm/da850evm.c @@ -215,29 +215,21 @@ static const struct pinmux_config gpio_pins[] = { };
const struct pinmux_resource pinmuxes[] = { -#ifndef CONFIG_SPL_BUILD #ifdef CONFIG_DRIVER_TI_EMAC PINMUX_ITEM(emac_pins_mdio), #ifdef CONFIG_DRIVER_TI_EMAC_USE_RMII PINMUX_ITEM(emac_pins_rmii), #else PINMUX_ITEM(emac_pins_mii), -#endif /* CONFIG_DRIVER_TI_EMAC */ -#endif /* CONFIG_DRIVER_TI_EMAC_USE_RMII */ -#endif /* CONFIG_SPL_BUILD */ +#endif +#endif #ifdef CONFIG_SPI_FLASH -#if !CONFIG_IS_ENABLED(PINCTRL) PINMUX_ITEM(spi1_pins_base), PINMUX_ITEM(spi1_pins_scs0), #endif -#endif -#if !CONFIG_IS_ENABLED(PINCTRL) PINMUX_ITEM(uart2_pins_txrx), PINMUX_ITEM(uart2_pins_rtscts), -#endif -#if !CONFIG_IS_ENABLED(PINCTRL) PINMUX_ITEM(i2c0_pins), -#endif #ifdef CONFIG_NAND_DAVINCI PINMUX_ITEM(emifa_pins_cs3), PINMUX_ITEM(emifa_pins_cs4), @@ -248,10 +240,8 @@ const struct pinmux_resource pinmuxes[] = { #endif PINMUX_ITEM(gpio_pins), #ifdef CONFIG_MMC_DAVINCI -#if !CONFIG_IS_ENABLED(PINCTRL) PINMUX_ITEM(mmc0_pins), #endif -#endif };
const int pinmuxes_size = ARRAY_SIZE(pinmuxes);
Adam Ford
