[U-Boot] [PATCH 1/2] clk: add static qualifier to local functions
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
drivers/clk/clk_rk3036.c | 2 +- drivers/clk/clk_rk3288.c | 2 +- drivers/clk/clk_sandbox.c | 5 +++-- 3 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/drivers/clk/clk_rk3036.c b/drivers/clk/clk_rk3036.c index 6c802b6..f650810 100644 --- a/drivers/clk/clk_rk3036.c +++ b/drivers/clk/clk_rk3036.c @@ -314,7 +314,7 @@ static ulong rk3036_clk_set_rate(struct udevice *dev, ulong rate) return 0; }
-ulong rk3036_set_periph_rate(struct udevice *dev, int periph, ulong rate) +static ulong rk3036_set_periph_rate(struct udevice *dev, int periph, ulong rate) { struct rk3036_clk_priv *priv = dev_get_priv(dev); ulong new_rate; diff --git a/drivers/clk/clk_rk3288.c b/drivers/clk/clk_rk3288.c index 54d4930..0172ad1 100644 --- a/drivers/clk/clk_rk3288.c +++ b/drivers/clk/clk_rk3288.c @@ -508,7 +508,7 @@ static ulong rockchip_spi_set_clk(struct rk3288_cru *cru, uint clk_general_rate, return rockchip_spi_get_clk(cru, clk_general_rate, periph); }
-ulong rk3288_set_periph_rate(struct udevice *dev, int periph, ulong rate) +static ulong rk3288_set_periph_rate(struct udevice *dev, int periph, ulong rate) { struct rk3288_clk_priv *priv = dev_get_priv(dev); ulong new_rate; diff --git a/drivers/clk/clk_sandbox.c b/drivers/clk/clk_sandbox.c index 058225a..367130f 100644 --- a/drivers/clk/clk_sandbox.c +++ b/drivers/clk/clk_sandbox.c @@ -32,7 +32,7 @@ static ulong sandbox_clk_set_rate(struct udevice *dev, ulong rate) return 0; }
-ulong sandbox_get_periph_rate(struct udevice *dev, int periph) +static ulong sandbox_get_periph_rate(struct udevice *dev, int periph) { struct sandbox_clk_priv *priv = dev_get_priv(dev);
@@ -41,7 +41,8 @@ ulong sandbox_get_periph_rate(struct udevice *dev, int periph) return priv->periph_rate[periph]; }
-ulong sandbox_set_periph_rate(struct udevice *dev, int periph, ulong rate) +static ulong sandbox_set_periph_rate(struct udevice *dev, int periph, + ulong rate) { struct sandbox_clk_priv *priv = dev_get_priv(dev); ulong old_rate;
The comments in include/clk.h state "or -ve error code" for these functions, and actually the functions return negative error code here and there. Returning unsigned value is not suitable.
drivers/clk/clk-uclass.c | 8 ++++---- drivers/clk/clk_rk3036.c | 6 +++--- drivers/clk/clk_rk3288.c | 6 +++--- drivers/clk/clk_sandbox.c | 9 ++++----- include/clk.h | 16 ++++++++-------- 5 files changed, 22 insertions(+), 23 deletions(-)
diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index 73dfd7d..a5bef59 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -12,7 +12,7 @@ #include <dm/lists.h> #include <dm/root.h>
-ulong clk_get_rate(struct udevice *dev) +long clk_get_rate(struct udevice *dev) { struct clk_ops *ops = clk_get_ops(dev);
@@ -22,7 +22,7 @@ ulong clk_get_rate(struct udevice *dev) return ops->get_rate(dev); }
-ulong clk_set_rate(struct udevice *dev, ulong rate) +long clk_set_rate(struct udevice *dev, ulong rate) { struct clk_ops *ops = clk_get_ops(dev);
@@ -32,7 +32,7 @@ ulong clk_set_rate(struct udevice *dev, ulong rate) return ops->set_rate(dev, rate); }
-ulong clk_get_periph_rate(struct udevice *dev, int periph) +long clk_get_periph_rate(struct udevice *dev, int periph) { struct clk_ops *ops = clk_get_ops(dev);
@@ -42,7 +42,7 @@ ulong clk_get_periph_rate(struct udevice *dev, int periph) return ops->get_periph_rate(dev, periph); }
-ulong clk_set_periph_rate(struct udevice *dev, int periph, ulong rate) +long clk_set_periph_rate(struct udevice *dev, int periph, ulong rate) { struct clk_ops *ops = clk_get_ops(dev);
diff --git a/drivers/clk/clk_rk3036.c b/drivers/clk/clk_rk3036.c index f650810..8613123 100644 --- a/drivers/clk/clk_rk3036.c +++ b/drivers/clk/clk_rk3036.c @@ -298,7 +298,7 @@ static ulong rockchip_mmc_set_clk(struct rk3036_cru *cru, uint clk_general_rate, return rockchip_mmc_get_clk(cru, clk_general_rate, periph); }
-static ulong rk3036_clk_get_rate(struct udevice *dev) +static long rk3036_clk_get_rate(struct udevice *dev) { struct rk3036_clk_plat *plat = dev_get_platdata(dev); struct rk3036_clk_priv *priv = dev_get_priv(dev); @@ -307,14 +307,14 @@ static ulong rk3036_clk_get_rate(struct udevice *dev) return rkclk_pll_get_rate(priv->cru, plat->clk_id); }
-static ulong rk3036_clk_set_rate(struct udevice *dev, ulong rate) +static long rk3036_clk_set_rate(struct udevice *dev, ulong rate) { debug("%s\n", dev->name);
return 0; }
-static ulong rk3036_set_periph_rate(struct udevice *dev, int periph, ulong rate) +static long rk3036_set_periph_rate(struct udevice *dev, int periph, ulong rate) { struct rk3036_clk_priv *priv = dev_get_priv(dev); ulong new_rate; diff --git a/drivers/clk/clk_rk3288.c b/drivers/clk/clk_rk3288.c index 0172ad1..8ed0bff 100644 --- a/drivers/clk/clk_rk3288.c +++ b/drivers/clk/clk_rk3288.c @@ -337,7 +337,7 @@ static uint32_t rkclk_pll_get_rate(struct rk3288_cru *cru, } }
-static ulong rk3288_clk_get_rate(struct udevice *dev) +static long rk3288_clk_get_rate(struct udevice *dev) { struct rk3288_clk_plat *plat = dev_get_platdata(dev); struct rk3288_clk_priv *priv = dev_get_priv(dev); @@ -346,7 +346,7 @@ static ulong rk3288_clk_get_rate(struct udevice *dev) return rkclk_pll_get_rate(priv->cru, plat->clk_id); }
-static ulong rk3288_clk_set_rate(struct udevice *dev, ulong rate) +static long rk3288_clk_set_rate(struct udevice *dev, ulong rate) { struct rk3288_clk_plat *plat = dev_get_platdata(dev); struct rk3288_clk_priv *priv = dev_get_priv(dev); @@ -508,7 +508,7 @@ static ulong rockchip_spi_set_clk(struct rk3288_cru *cru, uint clk_general_rate, return rockchip_spi_get_clk(cru, clk_general_rate, periph); }
-static ulong rk3288_set_periph_rate(struct udevice *dev, int periph, ulong rate) +static long rk3288_set_periph_rate(struct udevice *dev, int periph, ulong rate) { struct rk3288_clk_priv *priv = dev_get_priv(dev); ulong new_rate; diff --git a/drivers/clk/clk_sandbox.c b/drivers/clk/clk_sandbox.c index 367130f..0ff4605 100644 --- a/drivers/clk/clk_sandbox.c +++ b/drivers/clk/clk_sandbox.c @@ -15,14 +15,14 @@ struct sandbox_clk_priv { ulong periph_rate[PERIPH_ID_COUNT]; };
-static ulong sandbox_clk_get_rate(struct udevice *dev) +static long sandbox_clk_get_rate(struct udevice *dev) { struct sandbox_clk_priv *priv = dev_get_priv(dev);
return priv->rate; }
-static ulong sandbox_clk_set_rate(struct udevice *dev, ulong rate) +static long sandbox_clk_set_rate(struct udevice *dev, ulong rate) { struct sandbox_clk_priv *priv = dev_get_priv(dev);
-static ulong sandbox_get_periph_rate(struct udevice *dev, int periph) +static long sandbox_get_periph_rate(struct udevice *dev, int periph) { struct sandbox_clk_priv *priv = dev_get_priv(dev);
@@ -41,8 +41,7 @@ static ulong sandbox_get_periph_rate(struct udevice *dev, int periph) return priv->periph_rate[periph]; }
-static ulong sandbox_set_periph_rate(struct udevice *dev, int periph, - ulong rate) +static long sandbox_set_periph_rate(struct udevice *dev, int periph, ulong rate) { struct sandbox_clk_priv *priv = dev_get_priv(dev); ulong old_rate; diff --git a/include/clk.h b/include/clk.h index 371784a..61bb468 100644 --- a/include/clk.h +++ b/include/clk.h @@ -21,7 +21,7 @@ struct clk_ops { * @dev: Device to check (UCLASS_CLK) * @return clock rate in Hz, or -ve error code */ - ulong (*get_rate)(struct udevice *dev); + long (*get_rate)(struct udevice *dev);
/** * set_rate() - Set current clock rate @@ -30,7 +30,7 @@ struct clk_ops { * @rate: New clock rate in Hz * @return new rate, or -ve error code */ - ulong (*set_rate)(struct udevice *dev, ulong rate); + long (*set_rate)(struct udevice *dev, ulong rate);
/** * get_periph_rate() - Get clock rate for a peripheral @@ -39,7 +39,7 @@ struct clk_ops { * @periph: Peripheral ID to check * @return clock rate in Hz, or -ve error code */ - ulong (*get_periph_rate)(struct udevice *dev, int periph); + long (*get_periph_rate)(struct udevice *dev, int periph);
/** * set_periph_rate() - Set current clock rate for a peripheral @@ -48,7 +48,7 @@ struct clk_ops { * @periph: Peripheral ID to update * @return new clock rate in Hz, or -ve error code */ - ulong (*set_periph_rate)(struct udevice *dev, int periph, ulong rate); + long (*set_periph_rate)(struct udevice *dev, int periph, ulong rate); };
#define clk_get_ops(dev) ((struct clk_ops *)(dev)->driver->ops) @@ -59,7 +59,7 @@ struct clk_ops { * @dev: Device to check (UCLASS_CLK) * @return clock rate in Hz, or -ve error code */ -ulong clk_get_rate(struct udevice *dev); +long clk_get_rate(struct udevice *dev);
/** * clk_set_rate() - Set current clock rate @@ -68,7 +68,7 @@ ulong clk_get_rate(struct udevice *dev); * @rate: New clock rate in Hz * @return new rate, or -ve error code */ -ulong clk_set_rate(struct udevice *dev, ulong rate); +long clk_set_rate(struct udevice *dev, ulong rate);
/** * clk_get_periph_rate() - Get current clock rate for a peripheral @@ -76,7 +76,7 @@ ulong clk_set_rate(struct udevice *dev, ulong rate); * @dev: Device to check (UCLASS_CLK) * @return clock rate in Hz, -ve error code */ -ulong clk_get_periph_rate(struct udevice *dev, int periph); +long clk_get_periph_rate(struct udevice *dev, int periph);
/** * clk_set_periph_rate() - Set current clock rate for a peripheral @@ -85,6 +85,6 @@ ulong clk_get_periph_rate(struct udevice *dev, int periph); * @periph: Peripheral ID to update * @return new clock rate in Hz, or -ve error code */ -ulong clk_set_periph_rate(struct udevice *dev, int periph, ulong rate); +long clk_set_periph_rate(struct udevice *dev, int periph, ulong rate);
#endif /* _CLK_H_ */
Hi Masahiro,
On 12 January 2016 at 00:40, Masahiro Yamada yamada.masahiro@socionext.com wrote:
This limits us to about 2GHz which seems a bit dangerous. We are starting to see things around that level. We can use IS_ERR_VALUE().
2016-01-14 5:10 GMT+09:00 Simon Glass sjg@chromium.org:
Hi Masahiro,
OK, please disregard this patch.
Commit message?
Masahiro Yamada
