[U-Boot] [PATCH 0/1] sh/serial: coding style cleanup
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
diff --git a/drivers/serial/serial_sh.c b/drivers/serial/serial_sh.c index 1d76a19..0ba88ea 100644 --- a/drivers/serial/serial_sh.c +++ b/drivers/serial/serial_sh.c @@ -49,7 +49,7 @@ # define SCFRDR (vu_char *)(SCIF_BASE + 0x24) #else # define SCFTDR (vu_char *)(SCIF_BASE + 0xC) -# define SCFSR (vu_short *)(SCIF_BASE + 0x10) +# define SCFSR (vu_short *)(SCIF_BASE + 0x10) # define SCFRDR (vu_char *)(SCIF_BASE + 0x14) #endif
@@ -64,7 +64,7 @@ #elif defined(CONFIG_CPU_SH7763) # if defined(CONFIG_CONS_SCIF2) # define SCSPTR (vu_short *)(SCIF_BASE + 0x20) -# define SCLSR (vu_short *)(SCIF_BASE + 0x24) +# define SCLSR (vu_short *)(SCIF_BASE + 0x24) # define LSR_ORER 1 # define FIFOLEVEL_MASK 0x1F # else @@ -90,7 +90,7 @@ defined(CONFIG_CPU_SH7722) || \ defined(CONFIG_CPU_SH7203) # define SCSPTR (vu_short *)(SCIF_BASE + 0x20) -# define SCLSR (vu_short *)(SCIF_BASE + 0x24) +# define SCLSR (vu_short *)(SCIF_BASE + 0x24) # define LSR_ORER 1 # define FIFOLEVEL_MASK 0x1F #elif defined(CONFIG_CPU_SH7720) @@ -106,31 +106,32 @@
/* SCBRR register value setting */ #if defined(CONFIG_CPU_SH7720) -# define SCBRR_VALUE(bps, clk) (((clk*2)+16*bps)/(32*bps)-1) +# define SCBRR_VALUE(bps, clk) (((clk * 2) + 16 * bps) / (32 * bps) - 1) #elif defined(CONFIG_CPU_SH7723) && defined(CONFIG_SCIF_A) /* SH7723 SCIFA use bus clock. So clock *2 */ -# define SCBRR_VALUE(bps, clk) (((clk*2*2)+16*bps)/(32*bps)-1) +# define SCBRR_VALUE(bps, clk) (((clk * 2 * 2) + 16 * bps) / (32 * bps) - 1) #else /* Generic SuperH */ -# define SCBRR_VALUE(bps, clk) ((clk+16*bps)/(32*bps)-1) +# define SCBRR_VALUE(bps, clk) ((clk + 16 * bps) / (32 * bps) - 1) #endif
-#define SCR_RE (1 << 4) -#define SCR_TE (1 << 5) +#define SCR_RE (1 << 4) +#define SCR_TE (1 << 5) #define FCR_RFRST (1 << 1) /* RFCL */ #define FCR_TFRST (1 << 2) /* TFCL */ -#define FSR_DR (1 << 0) -#define FSR_RDF (1 << 1) -#define FSR_FER (1 << 3) -#define FSR_BRK (1 << 4) -#define FSR_FER (1 << 3) -#define FSR_TEND (1 << 6) -#define FSR_ER (1 << 7) +#define FSR_DR (1 << 0) +#define FSR_RDF (1 << 1) +#define FSR_FER (1 << 3) +#define FSR_BRK (1 << 4) +#define FSR_FER (1 << 3) +#define FSR_TEND (1 << 6) +#define FSR_ER (1 << 7)
void serial_setbrg(void) { DECLARE_GLOBAL_DATA_PTR; + *SCBRR = SCBRR_VALUE(gd->baudrate, CONFIG_SYS_CLK_FREQ); }
@@ -191,8 +192,8 @@ int serial_tstc(void) return serial_rx_fifo_level() ? 1 : 0; }
-#define FSR_ERR_CLEAR 0x0063 -#define RDRF_CLEAR 0x00fc +#define FSR_ERR_CLEAR 0x0063 +#define RDRF_CLEAR 0x00fc void handle_error(void) {
diff --git a/drivers/serial/serial_sh.c b/drivers/serial/serial_sh.c index 0ba88ea..36770bb 100644 --- a/drivers/serial/serial_sh.c +++ b/drivers/serial/serial_sh.c @@ -18,6 +18,7 @@ */
#include <common.h> +#include <asm/io.h> #include <asm/processor.h>
#if defined(CONFIG_CONS_SCIF0) @@ -132,17 +133,17 @@ void serial_setbrg(void) { DECLARE_GLOBAL_DATA_PTR;
- *SCBRR = SCBRR_VALUE(gd->baudrate, CONFIG_SYS_CLK_FREQ); + writeb(SCBRR_VALUE(gd->baudrate, CONFIG_SYS_CLK_FREQ), SCBRR); }
int serial_init(void) { - *SCSCR = (SCR_RE | SCR_TE); - *SCSMR = 0; - *SCSMR = 0; - *SCFCR = (FCR_RFRST | FCR_TFRST); - *SCFCR; - *SCFCR = 0; + writew((SCR_RE | SCR_TE), SCSCR); + writew(0, SCSMR); + writew(0, SCSMR); + writew((FCR_RFRST | FCR_TFRST), SCFCR); + readw(SCFCR); + writew(0, SCFCR);
serial_setbrg(); return 0; @@ -151,9 +152,9 @@ int serial_init(void) static int serial_rx_fifo_level(void) { #if defined(SCRFDR) - return (*SCRFDR >> 0) & FIFOLEVEL_MASK; + return (readw(SCRFDR) >> 0) & FIFOLEVEL_MASK; #else - return (*SCFDR >> 0) & FIFOLEVEL_MASK; + return (readw(SCFDR) >> 0) & FIFOLEVEL_MASK; #endif }
@@ -162,15 +163,15 @@ void serial_raw_putc(const char c) unsigned int fsr_bits_to_clear;
while (1) { - if (*SCFSR & FSR_TEND) { /* Tx fifo is empty */ + if (readw(SCFSR) & FSR_TEND) { /* Tx fifo is empty */ fsr_bits_to_clear = FSR_TEND; break; } }
- *SCFTDR = c; + writeb(c, SCFTDR); if (fsr_bits_to_clear != 0) - *SCFSR &= ~fsr_bits_to_clear; + writew(readw(SCFSR) & ~fsr_bits_to_clear, SCFSR); }
void serial_putc(const char c) @@ -197,21 +198,21 @@ int serial_tstc(void) void handle_error(void) {
- (void)*SCFSR; - *SCFSR = FSR_ERR_CLEAR; - (void)*SCLSR; - *SCLSR = 0x00; + readw(SCFSR); + writew(FSR_ERR_CLEAR, SCFSR); + readw(SCLSR); + writew(0x00, SCLSR); }
int serial_getc_check(void) { unsigned short status;
- status = *SCFSR; + status = readw(SCFSR);
if (status & (FSR_FER | FSR_ER | FSR_BRK)) handle_error(); - if (*SCLSR & LSR_ORER) + if (readw(SCLSR) & LSR_ORER) handle_error(); return status & (FSR_DR | FSR_RDF); } @@ -224,15 +225,15 @@ int serial_getc(void) while (!serial_getc_check()) ;
- ch = *SCFRDR; - status = *SCFSR; + ch = readb(SCFRDR); + status = readw(SCFSR);
- *SCFSR = RDRF_CLEAR; + writew(RDRF_CLEAR, SCFSR);
if (status & (FSR_FER | FSR_FER | FSR_ER | FSR_BRK)) handle_error();
return ch;
2009/1/12 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com:
Applied, thanks.
Best regards, Nobuhiro
Applied, thanks.
Nobuhiro Iwamatsu
