[U-Boot] [PATCH v4] SPL: Makefile: Build a separate autoconf.mk for SPL
SPL defines CONFIG_SPL_BUILD but this does not percolate to the autoconf.mk Makefile. As a result the build breaks when CONFIG_SPL_BUILD is used in the board-specific include header file. With this, there is a possibility of having a CONFIG option defined in the header file but not defined in the Makefile causing all kinds of build failure and problems.
It also messes things for up, for example, when one might want to undefine options to keep the SPL small and doesn't want to be stuck with the CONFIG options used for U-boot. Lastly, this also avoids defining special CONFIG_SPL_ variables for cases where some options are required in U-boot but not in SPL.
We add a spl-autoconf.mk rule that is generated for SPL with the CONFIG_SPL_BUILD flag and conditionally include it for SPL builds.
Signed-off-by: Ying Zhang b40530@freescale.com --- Change from v3: - No change. Change from v2: - Fixed the reported build breakage of am335x_evm_usbspl. Change from v1: - Fixed issue where builds in a different directory were failing.
Makefile | 19 +++++++++++++++++-- config.mk | 6 ++++++ spl/Makefile | 1 + 3 files changed, 24 insertions(+), 2 deletions(-)
diff --git a/Makefile b/Makefile index d545d30..75df06a 100644 --- a/Makefile +++ b/Makefile @@ -613,6 +613,7 @@ updater: # Explicitly make _depend in subdirs containing multiple targets to prevent # parallel sub-makes creating .depend files simultaneously. depend dep: $(TIMESTAMP_FILE) $(VERSION_FILE) \ + $(obj)include/spl-autoconf.mk \ $(obj)include/autoconf.mk \ $(obj)include/generated/generic-asm-offsets.h \ $(obj)include/generated/asm-offsets.h @@ -694,12 +695,23 @@ $(obj)include/autoconf.mk: $(obj)include/config.h sed -n -f tools/scripts/define2mk.sed > $@.tmp && \ mv $@.tmp $@
+# Auto-generate the spl-autoconf.mk file (which is included by all makefiles for SPL) +$(obj)include/spl-autoconf.mk: $(obj)include/config.h + @$(XECHO) Generating $@ ; \ + set -e ; \ + : Extract the config macros ; \ + $(CPP) $(CFLAGS) -DCONFIG_SPL_BUILD -DDO_DEPS_ONLY -dM include/common.h | \ + sed -n -f tools/scripts/define2mk.sed > $@.tmp && \ + mv $@.tmp $@ + $(obj)include/generated/generic-asm-offsets.h: $(obj)include/autoconf.mk.dep \ + $(obj)include/spl-autoconf.mk \ $(obj)lib/asm-offsets.s @$(XECHO) Generating $@ tools/scripts/make-asm-offsets $(obj)lib/asm-offsets.s $@
$(obj)lib/asm-offsets.s: $(obj)include/autoconf.mk.dep \ + $(obj)include/spl-autoconf.mk \ $(src)lib/asm-offsets.c @mkdir -p $(obj)lib $(CC) -DDO_DEPS_ONLY \ @@ -707,11 +719,13 @@ $(obj)lib/asm-offsets.s: $(obj)include/autoconf.mk.dep \ -o $@ $(src)lib/asm-offsets.c -c -S
$(obj)include/generated/asm-offsets.h: $(obj)include/autoconf.mk.dep \ + $(obj)include/spl-autoconf.mk \ $(obj)$(CPUDIR)/$(SOC)/asm-offsets.s @$(XECHO) Generating $@ tools/scripts/make-asm-offsets $(obj)$(CPUDIR)/$(SOC)/asm-offsets.s $@
-$(obj)$(CPUDIR)/$(SOC)/asm-offsets.s: $(obj)include/autoconf.mk.dep +$(obj)$(CPUDIR)/$(SOC)/asm-offsets.s: $(obj)include/autoconf.mk.dep \ + $(obj)include/spl-autoconf.mk @mkdir -p $(obj)$(CPUDIR)/$(SOC) if [ -f $(src)$(CPUDIR)/$(SOC)/asm-offsets.c ];then \ $(CC) -DDO_DEPS_ONLY \ @@ -783,7 +797,8 @@ include/license.h: tools/bin2header COPYING unconfig: @rm -f $(obj)include/config.h $(obj)include/config.mk \ $(obj)board/*/config.tmp $(obj)board/*/*/config.tmp \ - $(obj)include/autoconf.mk $(obj)include/autoconf.mk.dep + $(obj)include/autoconf.mk $(obj)include/autoconf.mk.dep \ + $(obj)include/spl-autoconf.mk
%_config:: unconfig @$(MKCONFIG) -A $(@:_config=) diff --git a/config.mk b/config.mk index 3e84f36..54e99f4 100644 --- a/config.mk +++ b/config.mk @@ -145,7 +145,13 @@ CHECK = sparse #########################################################################
# Load generated board configuration +ifeq ($(CONFIG_SPL_BUILD),y) +# Include SPL autoconf +sinclude $(OBJTREE)/include/spl-autoconf.mk +else +# Include normal autoconf sinclude $(OBJTREE)/include/autoconf.mk +endif sinclude $(OBJTREE)/include/config.mk
# Some architecture config.mk files need to know what CPUDIR is set to, diff --git a/spl/Makefile b/spl/Makefile index 6e5299b..43db01f 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -80,6 +80,7 @@ LIBS-$(CONFIG_SPL_POST_MEM_SUPPORT) += post/drivers/memory.o LIBS-$(CONFIG_SPL_NET_SUPPORT) += net/libnet.o LIBS-$(CONFIG_SPL_ETH_SUPPORT) += drivers/net/libnet.o LIBS-$(CONFIG_SPL_ETH_SUPPORT) += drivers/net/phy/libphy.o +LIBS-$(CONFIG_SPL_USBETH_SUPPORT) += drivers/net/phy/libphy.o LIBS-$(CONFIG_SPL_MUSB_NEW_SUPPORT) += drivers/usb/musb-new/libusb_musb-new.o LIBS-$(CONFIG_SPL_USBETH_SUPPORT) += drivers/usb/gadget/libusb_gadget.o
This patch changes Makefile and config.mk. I will need an ack from Tom before I can apply this patch to 85xx/master.
York
Change from v3:
- No change.
Change from v2:
Change from v1:
Uh, this is Joel's patch and you dropped his authorship when picking it up. I'm glad to see you picking it up and addressing the last of the issues I reported (right?), but you need to retain Joel's Author/SOB and add your own for any further changes you've made here. Thanks.
And please make sure a MAKEALL passes for both powerpc and arm.
York Sun
