[U-Boot] [PULL] u-boot-socfpga/master
The following changes since commit 4832e17787acb29734d895751bc7a594908aecc6:
Merge branch 'master' of git://www.denx.de/git/u-boot-microblaze (2015-12-18 07:28:24 -0500)
git://git.denx.de/u-boot-socfpga.git master
for you to fetch changes up to 48275c96ff4deaeca10d9e18c78f6a1e3653efa2:
arm: socfpga: fix trivial header preprocessor for socfpga_common.h (2015-12-20 03:44:56 +0100)
---------------------------------------------------------------- Dinh Nguyen (5): arm: socfpga: remove note to add CONFIG_USB_DWC2_REG_ADDR arm: socfpga: introduce TARGET_SOCFPGA_GEN5 config property arm: socfpga: remove building scan manager arm: socfpga: fix up a questionable macro for SDMMC arm: socfpga: fix trivial header preprocessor for socfpga_common.h
Marek Vasut (20): net: phy: micrel: Configure KSZ9021/KSZ9031 skew from OF arm: socfpga: socrates: Add missing PHY skew config arm: socfpga: arria5-socdk: Remove Micrel PHY configuration arm: socfpga: cyclone5-socdk: Remove Micrel PHY configuration arm: socfpga: de0_nano: Remove Micrel PHY configuration arm: socfpga: sockit: Remove Micrel PHY configuration arm: socfpga: socrates: Remove Micrel PHY configuration arm: socfpga: Allow DWC2 UDC probing from OF arm: socfpga: arria5-socdk: Probe DWC2 UDC from OF instead of hard-coded data arm: socfpga: cyclone5-socdk: Probe DWC2 UDC from OF instead of hard-coded data arm: socfpga: de0_nano: Probe DWC2 UDC from OF instead of hard-coded data arm: socfpga: mcvevk: Probe DWC2 UDC from OF instead of hard-coded data arm: socfpga: sockit: Probe DWC2 UDC from OF instead of hard-coded data arm: socfpga: socrates: Probe DWC2 UDC from OF instead of hard-coded data arm: socfpga: de0_nano: Zap VIRTUAL_TARGET arm: socfpga: sockit: Zap VIRTUAL_TARGET arm: socfpga: Switch CONFIG_G_DNL_MANUFACTURER to CONFIG_SYS_VENDOR arm: socfpga: Switch CONFIG_HOSTNAME to CONFIG_SYS_BOARD arm: socfpga: Introduce common board code arm: socfpga: Drop the board boilerplate
arch/arm/dts/socfpga_arria5_socdk.dts | 1 + arch/arm/dts/socfpga_cyclone5_de0_nano_soc.dts | 5 +++ arch/arm/dts/socfpga_cyclone5_mcvevk.dts | 5 +++ arch/arm/dts/socfpga_cyclone5_socdk.dts | 9 +++--- arch/arm/dts/socfpga_cyclone5_sockit.dts | 9 ++++-- arch/arm/dts/socfpga_cyclone5_socrates.dts | 17 ++++++++++ arch/arm/mach-socfpga/Kconfig | 5 +++ arch/arm/mach-socfpga/Makefile | 5 +-- arch/arm/mach-socfpga/board.c | 64 ++++++++++++++++++++++++++++++++++++++ arch/arm/mach-socfpga/include/mach/system_manager.h | 10 ++++-- board/altera/arria5-socdk/socfpga.c | 79 ---------------------------------------------- board/altera/cyclone5-socdk/socfpga.c | 79 ---------------------------------------------- board/denx/mcvevk/socfpga.c | 39 ----------------------- board/ebv/socrates/socfpga.c | 79 ---------------------------------------------- board/sr1500/socfpga.c | 17 ---------- board/terasic/de0-nano-soc/socfpga.c | 66 --------------------------------------- board/terasic/sockit/socfpga.c | 79 ---------------------------------------------- configs/socfpga_arria5_defconfig | 2 ++ configs/socfpga_cyclone5_defconfig | 2 ++ configs/socfpga_de0_nano_soc_defconfig | 2 ++ configs/socfpga_mcvevk_defconfig | 2 ++ configs/socfpga_sockit_defconfig | 2 ++ configs/socfpga_socrates_defconfig | 2 ++ drivers/mmc/socfpga_dw_mmc.c | 5 +-- drivers/net/phy/micrel.c | 146 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++- include/configs/socfpga_arria5_socdk.h | 15 --------- include/configs/socfpga_common.h | 19 +++++------- include/configs/socfpga_cyclone5_socdk.h | 15 --------- include/configs/socfpga_de0_nano_soc.h | 15 --------- include/configs/socfpga_mcvevk.h | 8 ----- include/configs/socfpga_sockit.h | 19 ------------ include/configs/socfpga_socrates.h | 15 --------- include/configs/socfpga_sr1500.h | 3 -- include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 35 files changed, 289 insertions(+), 553 deletions(-) create mode 100644 arch/arm/mach-socfpga/board.c
