[U-Boot-Users] clarifications u-boot for arm
Hi, I am using a omap5912osk board which uses arm926-ejs CPU.
I am trying to understand the flow of u-boot - what really happens when the board is powered on till i get the u-boot prompt which accepts commands from the user.
I started with the file u-boot-1.1.4/cpu/arm926ejs/start.S
Is this the place where u-boot actually starts?.
It tries switch the cpu mode to SVC32 mode and relocates u-boot to RAM, disables MMU and does so many things which i dont really understand.
Could anyone explain it to me what really is happening out there and why?.
Then i figured out that a function start_armboot() is called. This function is present in lib_arm/board.c is this function called by start.S?
Where exactly it is called from?.
There is a reference to start_armboot in start.S not sure if it is the one?.
ldr pc, _start_armboot
_start_armboot: .word start_armboot
Does this actually invoke start_armboot?.
I have got so far. could you please tell me am i right in my understarting?.
I understand that start_armboot initialises the the cpu, board, dram....
Once this is done - we can say that the board has been initialised.
Now start_armboot provides a prompt to accept and download the kernel.
Am i right in assuming this?.
Any other information and pointers u provide will be helpful
I am trying to understand u-boot sources and any help will be highly appreciated.
I just wanted to clarify my understanding.
Thanks and Regards, sriram
In message 8bf247760607140029l62f6c124idee300237361518f@mail.gmail.com you wrote:
You've posted the same question before.
I started with the file u-boot-1.1.4/cpu/arm926ejs/start.S Is this the place where u-boot actually starts?.
Yes.
I recommend toi follow the flow step by step. Most functions have pretty descriptive names.
We initialize the system step by step as needed to get a running system capable of booting Linux.
Use grep to find the call.
Why not?
Guess what happens when you load a new address into the rpgram counter?
Yes.
I understand that start_armboot initialises the the cpu, board, dram.... Once this is done - we can say that the board has been initialised.
More or less.
Read the README, the manual, and the sources.
Hi, Thanks for your response. I have gone much further and would like to know If
ldr pc, _start_armboot _start_armboot: .word start_armboot
Does this really invoke start_armboot?. This is because _start_armboot is what is stored in pc and not start_armboot and there is also a branch point _start_armboot (underscore start_armboot) Please see above.
Actually the above declares a variable start_armboot and does not invoke the function start_armboot. If this is true, then who calls start_armboot?
According to me start_armboot ( ) which is present in lib_arm/board.c never returns until u reset the board and probably should be one of the last functions that needs to be called.
Correct?.
Rest agreed, What i have understood is First, reset is called which set the cpu to SVC32 mode and calls cpu_init_crit which inturn calls lowlevel_init to setup memory and board specific register values.
Then stack is setup and start_amboot is called.
start_armboot is the point of entry where code is C. ie (Assembly to C) begins from start_armboot.
am i Correct?.
This is the function which does some remaining initialisation and then starts initialising the for pheripherals.
am i Correct?
I didnt understand the things relating interrupt and thier processing though.
Hello,
The answer to your question "who calls start_armboot?" is answered by you ASM code below. Hint... take a close look at the regsiter you are loading.
Regards,
Russell
Correct?.
Then stack is setup and start_amboot is called. start_armboot is the point of entry where code is C. ie
am i Correct?. This is the function which does some remaining initialisation
am i Correct?
Using Tomcat but need to do more? Need to support web services, security? Get stuff done quickly with pre-integrated technology to make your job easier Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&da... _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
See bottom posted reply.
Russell Peterson wrote:
Hello,
Regards,
Russell
On 7/14/06, *Ram* <vshrirama@gmail.com mailto:vshrirama@gmail.com> wrote:
Hi, Thanks for your response. I have gone much further and would like to know If ldr pc, _start_armboot _start_armboot: .word start_armboot Does this really invoke start_armboot?. This is because _start_armboot is what is stored in pc and not start_armboot and there is also a branch point _start_armboot (underscore start_armboot) Please see above. Actually the above declares a variable start_armboot and does not invoke the function start_armboot. If this is true, then who calls start_armboot?
[snip - I believe your observations are correct, but am not an expert]
Sriram:
C compiler naming convention prepends an underscore to the C function name so the C function start_armboot() can be referenced from assembly as a branch (call) to the label _start_armboot.
gvb
Dear Ram!
And why don't you learn the syntax and semantics of ARM assembler before you send messages to this list?
In order to understand the interrupt related things I recommend reading some documents about ARM architecture, your processor datasheet(s) AND U-BOOT DOCUMENTATION. Then you will find out by yourself why it is so difficult to understand interrupt handling on most platforms... :-) And why don't you just hook your JTAG debugger on the interrupt entry point and try to follow the execution flow? Then you will also notice something very important in U-Boot...
Andreas Schweigstill
participants (5)
Jerry Van Baren
Ram
Russell Peterson
