Re: [U-Boot] ?==?utf-8?q? ?==?utf-8?q? [PATCH 2/2]?==?utf-8?q? ARM:?==?utf-8?q? imx6q_logic: Enable I2C for PMIC functionality
Hi Adam
On Tuesday, October 08, 2019 15:31 -03, Adam Ford aford173@gmail.com wrote:
The pfuze100 is the PMIC connected to the I2C bus. Currently, the I2C driver is disabled which prevents the PMIC from operating.
This patch enables the I2C which also enables the PMIC in U-Boot. This also keeps the PMIC and I2C disabled in SPL due to size constraints of SPL.
I understand the constrain issue, but instead of disabling I2C support on SPL is it possible to enable SPL_OF_PLATDATA and save some space? I haven't test this feature on a real board, but it should reduce SPL size.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index ec14b8eaf6..22ecec3be3 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -22,7 +22,6 @@ CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_SEPARATE_BSS=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_DMA_SUPPORT=y -CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_PAYLOAD="u-boot.img" @@ -64,6 +63,7 @@ CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_PCF8575_GPIO=y +CONFIG_SYS_I2C_MXC=y CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_FSL_USDHC=y @@ -78,6 +78,7 @@ CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y +# CONFIG_SPL_PMIC_CHILDREN is not set CONFIG_DM_PMIC_PFUZE100=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_PFUZE100=y -- 2.17.1
_______________________________________________> U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
On Wed, Oct 9, 2019 at 10:23 AM Walter Lozano walter.lozano@collabora.com wrote:
Hi Adam
I haven't had good luck with OF_PLATDATA when I've tried in the past. Maybe the drivers are better now, but some of them didn't load and/or match the names correctly. The PMIC is pre-programmed to come up to the correct voltages, so it's not really needed because we're not going to change the voltages during SPL anyway.
Stefano's IMX branch has a patch to increase the OCRAM to 256K for the boards that support the i.MX6D/Q. I am going to push some changes to the imx6q_logic_defconfig to enable that feature. Once that's done, I plan to add some other stuff like pinmuxing to remove the board's C-code. My hope is to re-enable them in SPL once I get the pinmuxing stuff added in.
adam
Adam Ford
Walter Lozano
