[U-Boot] [PATCH] mvebu_mmc: Driver addition
In function mvebu_mmc_write notice command timeout. It is possible that a command is done, but a timeout occurred.
Enable timeout in set bus function.
Set window registers. Without that I could not use the driver on a Kirkwood 88F6282 SoC.
Set high capacity and 52MHz driver feature.
Signed-off-by: Mario Schuknecht mario.schuknecht@dresearch-fe.de --- drivers/mmc/mvebu_mmc.c | 59 ++++++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 58 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/mvebu_mmc.c b/drivers/mmc/mvebu_mmc.c index 9759198..53754aa 100644 --- a/drivers/mmc/mvebu_mmc.c +++ b/drivers/mmc/mvebu_mmc.c @@ -17,8 +17,12 @@ #include <asm/arch/kirkwood.h> #include <mvebu_mmc.h>
+DECLARE_GLOBAL_DATA_PTR; + #define DRIVER_NAME "MVEBU_MMC"
+#define MVEBU_TARGET_DRAM 0 + static void mvebu_mmc_write(u32 offs, u32 val) { writel(val, CONFIG_SYS_MMC_BASE + (offs)); @@ -164,6 +168,9 @@ static int mvebu_mmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, return TIMEOUT; } } + if (mvebu_mmc_read(SDIO_ERR_INTR_STATUS) & + (SDIO_ERR_CMD_TIMEOUT | SDIO_ERR_DATA_TIMEOUT)) + return TIMEOUT;
/* Handling response */ if (cmd->resp_type & MMC_RSP_136) { @@ -271,6 +278,7 @@ static void mvebu_mmc_set_bus(unsigned int bus)
/* default to maximum timeout */ ctrl_reg |= SDIO_HOST_CTRL_TMOUT(SDIO_HOST_CTRL_TMOUT_MAX); + ctrl_reg |= SDIO_HOST_CTRL_TMOUT_EN;
ctrl_reg |= SDIO_HOST_CTRL_PUSH_PULL_EN;
@@ -296,6 +304,53 @@ static void mvebu_mmc_set_ios(struct mmc *mmc) mvebu_mmc_set_clk(mmc->clock); }
+/* + * Set window register. + */ +static void mvebu_window_setup(void) +{ + int i; + + for (i = 0; i < 4; i++) { + mvebu_mmc_write(WINDOW_CTRL(i), 0); + mvebu_mmc_write(WINDOW_BASE(i), 0); + } + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + u32 size, base, attrib; + + /* Enable DRAM bank */ + switch (i) { + case 0: + attrib = KWCPU_ATTR_DRAM_CS0; + break; + case 1: + attrib = KWCPU_ATTR_DRAM_CS1; + break; + case 2: + attrib = KWCPU_ATTR_DRAM_CS2; + break; + case 3: + attrib = KWCPU_ATTR_DRAM_CS3; + break; + default: + /* invalide bank, disable access */ + attrib = 0; + break; + } + + size = gd->bd->bi_dram[i].size; + base = gd->bd->bi_dram[i].start; + if ((size) && (attrib)) + mvebu_mmc_write(WINDOW_CTRL(i), + MVCPU_WIN_CTRL_DATA(size, MVEBU_TARGET_DRAM, + attrib, MVCPU_WIN_ENABLE)); + else + mvebu_mmc_write(WINDOW_CTRL(i), MVCPU_WIN_DISABLE); + + mvebu_mmc_write(WINDOW_BASE(i), base); + } +} + static int mvebu_mmc_initialize(struct mmc *mmc) { debug("%s: mvebu_mmc_initialize", DRIVER_NAME); @@ -322,6 +377,8 @@ static int mvebu_mmc_initialize(struct mmc *mmc) mvebu_mmc_write(SDIO_NOR_INTR_EN, 0); mvebu_mmc_write(SDIO_ERR_INTR_EN, 0);
+ mvebu_window_setup(); + /* SW reset */ mvebu_mmc_write(SDIO_SW_RESET, SDIO_SW_RESET_NOW);
@@ -342,7 +399,7 @@ static struct mmc_config mvebu_mmc_cfg = { .f_min = MVEBU_MMC_BASE_FAST_CLOCK / MVEBU_MMC_BASE_DIV_MAX, .f_max = MVEBU_MMC_CLOCKRATE_MAX, .voltages = MMC_VDD_32_33 | MMC_VDD_33_34, - .host_caps = MMC_MODE_4BIT | MMC_MODE_HS, + .host_caps = MMC_MODE_4BIT | MMC_MODE_HS | MMC_MODE_HC | MMC_MODE_HS_52MHz, .part_type = PART_TYPE_DOS, .b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT, };
Thanks. A few review comments below.
- #define DRIVER_NAME "MVEBU_MMC"
- static void mvebu_mmc_write(u32 offs, u32 val) { writel(val, CONFIG_SYS_MMC_BASE + (offs));
return TIMEOUT;
- Set window register.
- int i;
Spaces instead of tabs for indentation. Please fix globally (checkpatch clean)
- for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) {
switch (i) {
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
default:
attrib = 0;
break;
size and attrib don't need parentheses here.
else
Please use correct coding style for multi-line statements. So this should look like this:
if (size && attrib) { mvebu_mmc_write(WINDOW_CTRL(i), MVCPU_WIN_CTRL_DATA(size, MVEBU_TARGET_DRAM, attrib, MVCPU_WIN_ENABLE)); } else { mvebu_mmc_write(WINDOW_CTRL(i), MVCPU_WIN_DISABLE); }
Thanks, Stefan
2014-08-25 11:55 GMT+02:00 Stefan Roese sr@denx.de:
drivers/mmc/mvebu_mmc.c | 59 ++++++++++++++++++++++++++++++ ++++++++++++++++++- 1 file changed, 58 insertions(+), 1 deletion(-)
return TIMEOUT; /* Handling response */ if (cmd->resp_type & MMC_RSP_136) {
ctrl_reg |= SDIO_HOST_CTRL_TMOUT_EN; ctrl_reg |= SDIO_HOST_CTRL_PUSH_PULL_EN;
int i;
A question. What is meant by "Spaces instead of tabs for indentation"?
In the whole file (and other files) tabs are used for indentation. Should I create two patches. The first corrects all indentations (spaces instead of tabs) and the second contains the actual patch?
switch (i) {
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
default:
attrib = 0;
break;
You're right.
MVEBU_TARGET_DRAM,
else
MVCPU_WIN_DISABLE);
Ok, I'll change that.
Regards,
Mario
Thanks, Stefan
On 25.08.2014 12:53, Mario Schuknecht wrote:
+/* + * Set window register. + */ +static void mvebu_window_setup(void) +{ + int i; + + for (i = 0; i < 4; i++) { + mvebu_mmc_write(WINDOW_CTRL(i)__, 0); + mvebu_mmc_write(WINDOW_BASE(i)__, 0); + } Spaces instead of tabs for indentation. Please fix globally (checkpatch clean)
A question. What is meant by "Spaces instead of tabs for indentation"? In the whole file (and other files) tabs are used for indentation.
No. I meant, use only tabs for indentation. In the line above you have used spaces instead of tabs. Checkpatch should warn about those issues. Its recommended to run it before sending patches to the list.
Thanks, Stefan
Mario Schuknecht
Stefan Roese
