[U-Boot] [PATCH v7] spi: Add Faraday SPI controller support
The Faraday FTSSP010 is a multi-function controller which supports I2S/SPI/SSP/AC97/SPDIF. However This patch implements only the SPI mode.
NOTE: The DMA and CS/Clock control logic has been altered since hardware revision 1.19.0. So this patch would first detects the revision id of the underlying chip, and then switch to the corresponding software control routines.
Signed-off-by: Kuo-Jung Su dantesu@faraday-tech.com Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com CC: Tom Rini trini@ti.com --- Changes for v7: - Fixed some checkpatch warnings - Removed unneeded "inline" in few lenghty defination funcs. Changes for v6: - Drop SPI_LSB_FIRST support, because this driver supports only 8-bit mode access. - Bug fix: Move chip enable from ftssp010_cs_set() to spi_cs_activate(), because ftssp010_cs_set() is supposed to update only the cs signal.
Changes for v5: - Use SPDX-License-Identifier - Add SPI mode checking & setup - Coding Style cleanup
Changes for v4: - Coding Style cleanup. - Make it a separate patch, rather then a part of Faraday A36x patch series - Use macro constants for timeout control
Changes for v3: - Coding Style cleanup. - Drop macros for wirtel()/readl(), call them directly. - Always insert a blank line between declarations and code. - Replace all the infinite wait loop with a timeout. - Add '__iomem' to all the declaration of HW register pointers.
Changes for v2: - Coding Style cleanup. - Use readl(), writel(), clrsetbits_le32() to replace REG() macros. - Use structure based hardware registers to replace the macro constants. - Replace BIT() with BIT_MASK().
drivers/spi/Makefile | 1 + drivers/spi/ftssp010_spi.c | 508 +++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 509 insertions(+) create mode 100644 drivers/spi/ftssp010_spi.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index d5a7143..81b6af6 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -19,6 +19,7 @@ obj-$(CONFIG_CF_SPI) += cf_spi.o obj-$(CONFIG_CF_QSPI) += cf_qspi.o obj-$(CONFIG_DAVINCI_SPI) += davinci_spi.o obj-$(CONFIG_EXYNOS_SPI) += exynos_spi.o +obj-$(CONFIG_FTSSP010_SPI) += ftssp010_spi.o obj-$(CONFIG_ICH_SPI) += ich.o obj-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o obj-$(CONFIG_MPC52XX_SPI) += mpc52xx_spi.o diff --git a/drivers/spi/ftssp010_spi.c b/drivers/spi/ftssp010_spi.c new file mode 100644 index 0000000..aa3b5a0 --- /dev/null +++ b/drivers/spi/ftssp010_spi.c @@ -0,0 +1,508 @@ +/* + * (C) Copyright 2013 + * Faraday Technology Corporation. http://www.faraday-tech.com/tw/ + * Kuo-Jung Su dantesu@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <linux/compat.h> +#include <asm/io.h> +#include <malloc.h> +#include <spi.h> + +#ifndef CONFIG_FTSSP010_BASE_LIST +#define CONFIG_FTSSP010_BASE_LIST { CONFIG_FTSSP010_BASE } +#endif + +#ifndef CONFIG_FTSSP010_GPIO_BASE +#define CONFIG_FTSSP010_GPIO_BASE 0 +#endif + +#ifndef CONFIG_FTSSP010_GPIO_LIST +#define CONFIG_FTSSP010_GPIO_LIST { CONFIG_FTSSP010_GPIO_BASE } +#endif + +#ifndef CONFIG_FTSSP010_CLOCK +#define CONFIG_FTSSP010_CLOCK clk_get_rate("SSP"); +#endif + +#ifndef CONFIG_FTSSP010_TIMEOUT +#define CONFIG_FTSSP010_TIMEOUT 100 +#endif + +/* FTSSP010 chip registers */ +struct ftssp010_regs { + uint32_t cr[3];/* control register */ + uint32_t sr; /* status register */ + uint32_t icr; /* interrupt control register */ + uint32_t isr; /* interrupt status register */ + uint32_t dr; /* data register */ + uint32_t rsvd[17]; + uint32_t revr; /* revision register */ + uint32_t fear; /* feature register */ +}; + +/* Control Register 0 */ +#define CR0_FFMT_MASK (7 << 12) +#define CR0_FFMT_SSP (0 << 12) +#define CR0_FFMT_SPI (1 << 12) +#define CR0_FFMT_MICROWIRE (2 << 12) +#define CR0_FFMT_I2S (3 << 12) +#define CR0_FFMT_AC97 (4 << 12) +#define CR0_FLASH (1 << 11) +#define CR0_FSDIST(x) (((x) & 0x03) << 8) +#define CR0_LOOP (1 << 7) /* loopback mode */ +#define CR0_LSB (1 << 6) /* LSB */ +#define CR0_FSPO (1 << 5) /* fs atcive low (I2S only) */ +#define CR0_FSJUSTIFY (1 << 4) +#define CR0_OPM_SLAVE (0 << 2) +#define CR0_OPM_MASTER (3 << 2) +#define CR0_OPM_I2S_MSST (3 << 2) /* master stereo mode */ +#define CR0_OPM_I2S_MSMO (2 << 2) /* master mono mode */ +#define CR0_OPM_I2S_SLST (1 << 2) /* slave stereo mode */ +#define CR0_OPM_I2S_SLMO (0 << 2) /* slave mono mode */ +#define CR0_SCLKPO (1 << 1) /* clock polarity */ +#define CR0_SCLKPH (1 << 0) /* clock phase */ + +/* Control Register 1 */ +#define CR1_PDL(x) (((x) & 0xff) << 24) /* padding length */ +#define CR1_SDL(x) ((((x) - 1) & 0x1f) << 16) /* data length */ +#define CR1_DIV(x) (((x) - 1) & 0xffff) /* clock divider */ + +/* Control Register 2 */ +#define CR2_CS(x) (((x) & 3) << 10) /* CS/FS select */ +#define CR2_FS (1 << 9) /* CS/FS signal level */ +#define CR2_TXEN (1 << 8) /* tx enable */ +#define CR2_RXEN (1 << 7) /* rx enable */ +#define CR2_RESET (1 << 6) /* chip reset */ +#define CR2_TXFC (1 << 3) /* tx fifo Clear */ +#define CR2_RXFC (1 << 2) /* rx fifo Clear */ +#define CR2_TXDOE (1 << 1) /* tx data output enable */ +#define CR2_EN (1 << 0) /* chip enable */ + +/* Status Register */ +#define SR_RFF (1 << 0) /* rx fifo full */ +#define SR_TFNF (1 << 1) /* tx fifo not full */ +#define SR_BUSY (1 << 2) /* chip busy */ +#define SR_RFVE(reg) (((reg) >> 4) & 0x1f) /* rx fifo valid entries */ +#define SR_TFVE(reg) (((reg) >> 12) & 0x1f) /* tx fifo valid entries */ + +/* Feature Register */ +#define FEAR_BITS(reg) ((((reg) >> 0) & 0xff) + 1) /* data width */ +#define FEAR_RFSZ(reg) ((((reg) >> 8) & 0xff) + 1) /* rx fifo size */ +#define FEAR_TFSZ(reg) ((((reg) >> 16) & 0xff) + 1) /* tx fifo size */ +#define FEAR_AC97 (1 << 24) +#define FEAR_I2S (1 << 25) +#define FEAR_SPI_MWR (1 << 26) +#define FEAR_SSP (1 << 27) +#define FEAR_SPDIF (1 << 28) + +/* FTGPIO010 chip registers */ +struct ftgpio010_regs { + uint32_t out; /* 0x00: Data Output */ + uint32_t in; /* 0x04: Data Input */ + uint32_t dir; /* 0x08: Direction */ + uint32_t bypass; /* 0x0c: Bypass */ + uint32_t set; /* 0x10: Data Set */ + uint32_t clr; /* 0x14: Data Clear */ + uint32_t pull_up; /* 0x18: Pull-Up Enabled */ + uint32_t pull_st; /* 0x1c: Pull State (0=pull-down, 1=pull-up) */ +}; + +struct ftssp010_gpio { + struct ftgpio010_regs *regs; + uint32_t pin; +}; + +struct ftssp010_spi { + struct spi_slave slave; + struct ftssp010_gpio gpio; + struct ftssp010_regs *regs; + uint32_t fifo; + uint32_t mode; + uint32_t div; + uint32_t clk; + uint32_t speed; + uint32_t revision; +}; + +static inline struct ftssp010_spi *to_ftssp010_spi(struct spi_slave *slave) +{ + return container_of(slave, struct ftssp010_spi, slave); +} + +static int get_spi_chip(int bus, struct ftssp010_spi *chip) +{ + uint32_t fear, base[] = CONFIG_FTSSP010_BASE_LIST; + + if (bus >= ARRAY_SIZE(base) || !base[bus]) + return -1; + + chip->regs = (struct ftssp010_regs *)base[bus]; + + chip->revision = readl(&chip->regs->revr); + + fear = readl(&chip->regs->fear); + chip->fifo = min_t(uint32_t, FEAR_TFSZ(fear), FEAR_RFSZ(fear)); + + return 0; +} + +static int get_spi_gpio(int bus, struct ftssp010_gpio *chip) +{ + uint32_t base[] = CONFIG_FTSSP010_GPIO_LIST; + + if (bus >= ARRAY_SIZE(base) || !base[bus]) + return -1; + + chip->regs = (struct ftgpio010_regs *)(base[bus] & 0xfff00000); + chip->pin = base[bus] & 0x1f; + + /* make it an output pin */ + setbits_le32(&chip->regs->dir, 1 << chip->pin); + + return 0; +} + +static int ftssp010_wait(struct ftssp010_spi *chip) +{ + struct ftssp010_regs *regs = chip->regs; + int ret = -1; + ulong t; + + /* wait until device idle */ + for (t = get_timer(0); get_timer(t) < CONFIG_FTSSP010_TIMEOUT; ) { + if (readl(®s->sr) & SR_BUSY) + continue; + ret = 0; + break; + } + + if (ret) + puts("ftspi010: busy timeout\n"); + + return ret; +} + +static int ftssp010_wait_tx(struct ftssp010_spi *chip) +{ + struct ftssp010_regs *regs = chip->regs; + int ret = -1; + ulong t; + + /* wait until tx fifo not full */ + for (t = get_timer(0); get_timer(t) < CONFIG_FTSSP010_TIMEOUT; ) { + if (!(readl(®s->sr) & SR_TFNF)) + continue; + ret = 0; + break; + } + + if (ret) + puts("ftssp010: tx timeout\n"); + + return ret; +} + +static int ftssp010_wait_rx(struct ftssp010_spi *chip) +{ + struct ftssp010_regs *regs = chip->regs; + int ret = -1; + ulong t; + + /* wait until rx fifo not empty */ + for (t = get_timer(0); get_timer(t) < CONFIG_FTSSP010_TIMEOUT; ) { + if (!SR_RFVE(readl(®s->sr))) + continue; + ret = 0; + break; + } + + if (ret) + puts("ftssp010: rx timeout\n"); + + return ret; +} + +static int ftssp010_spi_work_transfer_v2(struct ftssp010_spi *chip, + const void *tx_buf, void *rx_buf, int len, uint flags) +{ + struct ftssp010_regs *regs = chip->regs; + const uint8_t *txb = tx_buf; + uint8_t *rxb = rx_buf; + + while (len > 0) { + int i, depth = min(chip->fifo >> 2, len); + uint32_t xmsk = 0; + + if (tx_buf) { + for (i = 0; i < depth; ++i) { + ftssp010_wait_tx(chip); + writel(*txb++, ®s->dr); + } + xmsk |= CR2_TXEN | CR2_TXDOE; + if ((readl(®s->cr[2]) & xmsk) != xmsk) + setbits_le32(®s->cr[2], xmsk); + } + if (rx_buf) { + xmsk |= CR2_RXEN; + if ((readl(®s->cr[2]) & xmsk) != xmsk) + setbits_le32(®s->cr[2], xmsk); + for (i = 0; i < depth; ++i) { + ftssp010_wait_rx(chip); + *rxb++ = (uint8_t)readl(®s->dr); + } + } + + len -= depth; + } + + return 0; +} + +static int ftssp010_spi_work_transfer_v1(struct ftssp010_spi *chip, + const void *tx_buf, void *rx_buf, int len, uint flags) +{ + struct ftssp010_regs *regs = chip->regs; + const uint8_t *txb = tx_buf; + uint8_t *rxb = rx_buf; + + while (len > 0) { + int i, depth = min(chip->fifo >> 2, len); + uint32_t tmp; + + for (i = 0; i < depth; ++i) { + ftssp010_wait_tx(chip); + writel(txb ? (*txb++) : 0, ®s->dr); + } + for (i = 0; i < depth; ++i) { + ftssp010_wait_rx(chip); + tmp = readl(®s->dr); + if (rxb) + *rxb++ = (uint8_t)tmp; + } + + len -= depth; + } + + return 0; +} + +static void ftssp010_cs_set(struct ftssp010_spi *chip, int high) +{ + struct ftssp010_regs *regs = chip->regs; + struct ftssp010_gpio *gpio = &chip->gpio; + uint32_t mask; + + /* cs pull high/low */ + if (chip->revision >= 0x11900) { + mask = CR2_CS(chip->slave.cs) | (high ? CR2_FS : 0); + writel(mask, ®s->cr[2]); + } else if (gpio->regs) { + mask = 1 << gpio->pin; + if (high) + writel(mask, &gpio->regs->set); + else + writel(mask, &gpio->regs->clr); + } + + /* extra delay for signal propagation */ + udelay_masked(1); +} + +/* + * Determine if a SPI chipselect is valid. + * This function is provided by the board if the low-level SPI driver + * needs it to determine if a given chipselect is actually valid. + * + * Returns: 1 if bus:cs identifies a valid chip on this board, 0 + * otherwise. + */ +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + struct ftssp010_spi chip; + + if (get_spi_chip(bus, &chip)) + return 0; + + if (!cs) + return 1; + else if ((cs < 4) && (chip.revision >= 0x11900)) + return 1; + + return 0; +} + +/* + * Activate a SPI chipselect. + * This function is provided by the board code when using a driver + * that can't control its chipselects automatically (e.g. + * common/soft_spi.c). When called, it should activate the chip select + * to the device identified by "slave". + */ +void spi_cs_activate(struct spi_slave *slave) +{ + struct ftssp010_spi *chip = to_ftssp010_spi(slave); + struct ftssp010_regs *regs = chip->regs; + + /* cs pull */ + if (chip->mode & SPI_CS_HIGH) + ftssp010_cs_set(chip, 1); + else + ftssp010_cs_set(chip, 0); + + /* chip enable + fifo clear */ + setbits_le32(®s->cr[2], CR2_EN | CR2_TXFC | CR2_RXFC); +} + +/* + * Deactivate a SPI chipselect. + * This function is provided by the board code when using a driver + * that can't control its chipselects automatically (e.g. + * common/soft_spi.c). When called, it should deactivate the chip + * select to the device identified by "slave". + */ +void spi_cs_deactivate(struct spi_slave *slave) +{ + struct ftssp010_spi *chip = to_ftssp010_spi(slave); + + /* wait until chip idle */ + ftssp010_wait(chip); + + /* cs pull */ + if (chip->mode & SPI_CS_HIGH) + ftssp010_cs_set(chip, 0); + else + ftssp010_cs_set(chip, 1); +} + +void spi_init(void) +{ + /* nothing to do */ +} + +struct spi_slave *spi_setup_slave(uint bus, uint cs, uint max_hz, uint mode) +{ + struct ftssp010_spi *chip; + + if (mode & SPI_3WIRE) { + puts("ftssp010: can't do 3-wire\n"); + return NULL; + } + + if (mode & SPI_SLAVE) { + puts("ftssp010: can't do slave mode\n"); + return NULL; + } + + if (mode & SPI_PREAMBLE) { + puts("ftssp010: can't skip preamble bytes\n"); + return NULL; + } + + if (!spi_cs_is_valid(bus, cs)) { + puts("ftssp010: invalid (bus, cs)\n"); + return NULL; + } + + chip = spi_alloc_slave(struct ftssp010_spi, bus, cs); + if (!chip) + return NULL; + + if (get_spi_chip(bus, chip)) + goto free_out; + + if (chip->revision < 0x11900 && get_spi_gpio(bus, &chip->gpio)) { + puts("ftssp010: Before revision 1.19.0, its clock & cs are\n" + "controlled by tx engine which is not synced with rx engine,\n" + "so the clock & cs might be shutdown before rx engine\n" + "finishs its jobs.\n" + "If possible, please add a dedicated gpio for it.\n"); + } + + chip->mode = mode; + chip->clk = CONFIG_FTSSP010_CLOCK; + chip->div = 2; + if (max_hz) { + while (chip->div < 0xffff) { + if ((chip->clk / (2 * chip->div)) <= max_hz) + break; + chip->div += 1; + } + } + chip->speed = chip->clk / (2 * chip->div); + + return &chip->slave; + +free_out: + free(chip); + return NULL; +} + +void spi_free_slave(struct spi_slave *slave) +{ + free(slave); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + struct ftssp010_spi *chip = to_ftssp010_spi(slave); + struct ftssp010_regs *regs = chip->regs; + + writel(CR1_SDL(8) | CR1_DIV(chip->div), ®s->cr[1]); + + if (chip->revision >= 0x11900) { + writel(CR0_OPM_MASTER | CR0_FFMT_SPI | CR0_FSPO | CR0_FLASH, + ®s->cr[0]); + writel(CR2_TXFC | CR2_RXFC, + ®s->cr[2]); + } else { + writel(CR0_OPM_MASTER | CR0_FFMT_SPI | CR0_FSPO, + ®s->cr[0]); + writel(CR2_TXFC | CR2_RXFC | CR2_EN | CR2_TXDOE, + ®s->cr[2]); + } + + if (chip->mode & SPI_LOOP) + setbits_le32(®s->cr[0], CR0_LOOP); + + if (chip->mode & SPI_CPOL) + setbits_le32(®s->cr[0], CR0_SCLKPO); + + if (chip->mode & SPI_CPHA) + setbits_le32(®s->cr[0], CR0_SCLKPH); + + spi_cs_deactivate(slave); + + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ + struct ftssp010_spi *chip = to_ftssp010_spi(slave); + struct ftssp010_regs *regs = chip->regs; + + writel(0, ®s->cr[2]); +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct ftssp010_spi *chip = to_ftssp010_spi(slave); + uint32_t len = bitlen >> 3; + + if (flags & SPI_XFER_BEGIN) + spi_cs_activate(slave); + + if (chip->revision >= 0x11900) + ftssp010_spi_work_transfer_v2(chip, dout, din, len, flags); + else + ftssp010_spi_work_transfer_v1(chip, dout, din, len, flags); + + if (flags & SPI_XFER_END) + spi_cs_deactivate(slave); + + return 0; +}
Hi Kuo-Jung Su,
Please check this v7 and try to add the test log if you have.
On Fri, Dec 20, 2013 at 12:34 AM, Jagannadha Sutradharudu Teki jagannadha.sutradharudu-teki@xilinx.com wrote:
Changes for v5:
Changes for v4:
Changes for v3:
Changes for v2:
- (C) Copyright 2013
- Faraday Technology Corporation. http://www.faraday-tech.com/tw/
- Kuo-Jung Su dantesu@gmail.com
uint32_t rsvd[17];
uint32_t pin;
uint32_t fifo;
uint32_t mode;
uint32_t div;
uint32_t clk;
uint32_t speed;
uint32_t revision;
return -1;
return -1;
int ret = -1;
ulong t;
continue;
ret = 0;
break;
if (ret)
return ret;
int ret = -1;
ulong t;
continue;
ret = 0;
break;
if (ret)
return ret;
int ret = -1;
ulong t;
continue;
ret = 0;
break;
if (ret)
return ret;
while (len > 0) {
uint32_t xmsk = 0;
if (tx_buf) {
if (rx_buf) {
xmsk |= CR2_RXEN;
len -= depth;
while (len > 0) {
uint32_t tmp;
if (rxb)
len -= depth;
uint32_t mask;
if (high)
else
udelay_masked(1);
- Determine if a SPI chipselect is valid.
- This function is provided by the board if the low-level SPI driver
- needs it to determine if a given chipselect is actually valid.
- Returns: 1 if bus:cs identifies a valid chip on this board, 0
- otherwise.
if (!cs)
return 1;
return 1;
- Activate a SPI chipselect.
- This function is provided by the board code when using a driver
- that can't control its chipselects automatically (e.g.
- common/soft_spi.c). When called, it should activate the chip select
- to the device identified by "slave".
/* cs pull */
else
- Deactivate a SPI chipselect.
- common/soft_spi.c). When called, it should deactivate the chip
- select to the device identified by "slave".
/* cs pull */
else
/* nothing to do */
return NULL;
return NULL;
return NULL;
return NULL;
if (!chip)
return NULL;
goto free_out;
chip->mode = mode;
chip->div = 2;
if (max_hz) {
break;
chip->div += 1;
+free_out:
free(chip);
return NULL;
free(slave);
®s->cr[0]);
®s->cr[2]);
} else {
®s->cr[0]);
®s->cr[2]);
else
2013/12/20 Jagan Teki jagannadh.teki@gmail.com:
Hi Kuo-Jung Su,
Hi Jagan:
Thanks for the v7 patch, it works flawlessly.
Here is the test log on Faraday A369 EVB:
U-Boot 2014.01-rc2-g3444b6f (Dec 20 2013 - 10:58:40)
CPU: FA626TE 528 MHz AHB: 132 MHz APB: 66 MHz I2C: ready DRAM: 256 MiB MMU: on NAND: 512 MiB MMC: ftsdc010: 0 *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial Net: FTGMAC100#0 Hit any key to stop autoboot: 0 => sf probe 0:0 SF: Detected MX25L1605D with page size 256 Bytes, erase size 64 KiB, total 2 MiB => sf read 0x10800000 0 0x400 SF: 1024 bytes @ 0x0 Read: OK => md 0x10800000 10800000: ea000013 e59ff014 e59ff014 e59ff014 ................ 10800010: e59ff014 e59ff014 e59ff014 e59ff014 ................ 10800020: 1ff7b0c0 1ff7b120 1ff7b180 1ff7b1e0 .... ........... 10800030: 1ff7b240 1ff7b2a0 1ff7b300 deadbeef @............... 10800040: 10800000 0002c1f0 0007409c 00032048 .........@..H .. 10800050: 1fd6af40 e10f0000 e3c0001f e38000d3 @............... 10800060: e129f000 eb000001 eb000223 e12fff1e ..).....#...../. 10800070: e3a00000 ee070f1e ee080f17 ee070f15 ................ 10800080: ee070f9a ee110f10 e3c00c03 e3c00087 ................ 10800090: e3c00a02 e3800002 e3800a01 ee010f10 ................ 108000a0: e1a0c00e eb007a68 e1a0e00c e1a0f00e ....hz.......... 108000b0: e1a00000 e1a00000 e1a00000 e1a00000 ................ 108000c0: e51fd078 e58de000 e14fe000 e58de004 x.........O..... 108000d0: e3a0d013 e169f00d e1a0e00f e1b0f00e ......i......... 108000e0: e24dd048 e88d1fff e51f20a0 e892000c H.M...... ...... 108000f0: e28d0048 e28d5034 e1a0100e e885000f H...4P.......... =>
Jagan Teki
Kuo-Jung Su
