[U-Boot] [PATCH] Support sending DHCP client options
Signed-off-by: Gray Remlin g_remlin@rocketmail.com
--- common/cmd_nvedit.c | 3 ++ net/bootp.c | 52 +++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 55 insertions(+), 0 deletions(-)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 3d30c32..2094e8e 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -224,6 +224,9 @@ int _do_env_set (int flag, int argc, char * const argv[]) if (ep) { /* variable exists */ #ifndef CONFIG_ENV_OVERWRITE if ((strcmp (name, "serial#") == 0) || +#if defined(CONFIG_BOOTP_OPTIONS) + (strcmp(name, "dhcp_vendor-class-identifier") == 0) || +#endif /* CONFIG_BOOTP_OPTIONS */ ((strcmp (name, "ethaddr") == 0) #if defined(CONFIG_OVERWRITE_ETHADDR_ONCE) && defined(CONFIG_ETHADDR) && (strcmp (ep->data,MK_STR(CONFIG_ETHADDR)) != 0) diff --git a/net/bootp.c b/net/bootp.c index 1289e3b..9e687b0 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -68,6 +68,54 @@ extern u8 *dhcp_vendorex_prep (u8 *e); /*rtn new e after add own opts. */ extern u8 *dhcp_vendorex_proc (u8 *e); /*rtn next e if mine,else NULL */ #endif
+#if defined(CONFIG_BOOTP_OPTIONS) /* check environment for dhcp client options */ + +/* + * The vendor-specifiable options should not be changeable + * unless CONFIG_ENV_OVERWRITE has been defined, however + * user-specifiable options should be changeable regardless + */ +u8 dhcp_options_prep(u8 **ep) +{ + u8 *e = *ep; + char *ptr; + + debug("DHCP Client options start\n"); + + /* vendor-specifiable identification string */ + if ((ptr = getenv("dhcp_vendor-class-identifier"))) { + debug("dhcp_vendor-class-identifier=%s\n",ptr); + *e++ = 60; + *e++ = strlen(ptr); + while (*ptr) + *e++ = *ptr++; + } + + /* user-specifiable identification string */ + if ((ptr = getenv("dhcp_dhcp-client-identifier"))) { + debug("dhcp_dhcp-client-identifier=%s\n",ptr); + *e++ = 61; + *e++ = strlen(ptr); + while (*ptr) + *e++ = *ptr++; + } + + /* user-specifiable identification string */ + if ((ptr = getenv("dhcp_user-class"))) { + debug("dhcp_user-class=%s\n",ptr); + *e++ = 77; + *e++ = strlen(ptr); + while (*ptr) + *e++ = *ptr++; + } + + debug("DHCP Client options end\n"); + *ep = e; + return e; +} + +#endif /* CONFIG_BOOTP_OPTIONS */ + #endif
static int BootpCheckPkt(uchar *pkt, unsigned dest, unsigned src, unsigned len) @@ -412,6 +460,10 @@ static int DhcpExtended (u8 * e, int message_type, IPaddr_t ServerID, IPaddr_t R } #endif
+#if defined(CONFIG_BOOTP_OPTIONS) + dhcp_options_prep (&e); +#endif + #if defined(CONFIG_BOOTP_VENDOREX) if ((x = dhcp_vendorex_prep (e))) return x - start; --
Gray Remlin
