[U-Boot] [PATCHv2 0/2] omap3evm: Add support for EFI partitions
After enabling CONFIG_EFI_PARTITION, following errors were noticed.
part_efi.c: In function 'print_part_efi': part_efi.c:133:5: warning: passing argument 3 of 'is_gpt_valid' from incompatible pointer type part_efi.c:95:12: note: expected 'struct gpt_header *' but arg ument is of type 'struct gpt_header **' part_efi.c: In function 'get_partition_info_efi': part_efi.c:173:4: warning: passing argument 3 of 'is_gpt_valid ' from incompatible pointer type part_efi.c:95:12: note: expected 'struct gpt_header *' but arg ument is of type 'struct gpt_header **' part_efi.c: In function 'alloc_read_gpt_entries': part_efi.c:384:18: error: 'CONFIG_SYS_CACHELINE_SIZE' undeclar ed (first use in this function) part_efi.c:384:18: note: each undeclared identifier is reporte d only once for each function it appears in make[1]: *** [part_efi.o] Error 1 make[1]: Leaving directory `/home/premi/disk' make: *** [disk/libdisk.o] Error 2
Tested working via command "mmc part" on OMAP3EVM on MMC card with EFI partitions.
Changes since v1: * Use ARCH_DMA_MINALIGN instead of CONFIG_SYS_CACHELINE_SIZE in disk/part_efi.c. * Removed (now) redundant definition of CONFIG_SYS_CACHELINE_SIZE from /include/configs/omap3_evm_common.h
REF: http://lists.denx.de/pipermail/u-boot/2011-November/109895.html
Sanjeev Premi (2): part_efi: Fix compile errors omap3evm: Add support for EFI partitions
disk/part_efi.c | 6 +++--- include/configs/omap3_evm.h | 1 + 2 files changed, 4 insertions(+), 3 deletions(-)
Cc: Sandeep Paulraj s-paulraj@ti.com
Fix errors noticed after enabling CONFIG_EFI_PARTITION for the OMAP3 EVM board:
part_efi.c: In function 'print_part_efi': part_efi.c:133:5: warning: passing argument 3 of 'is_gpt_valid' from incompatible pointer type part_efi.c:95:12: note: expected 'struct gpt_header *' but arg ument is of type 'struct gpt_header **' part_efi.c: In function 'get_partition_info_efi': part_efi.c:173:4: warning: passing argument 3 of 'is_gpt_valid ' from incompatible pointer type part_efi.c:95:12: note: expected 'struct gpt_header *' but arg ument is of type 'struct gpt_header **' part_efi.c: In function 'alloc_read_gpt_entries': part_efi.c:384:18: error: 'CONFIG_SYS_CACHELINE_SIZE' undeclare d (first use in this function)
Signed-off-by: Sanjeev Premi premi@ti.com Cc: Tom Rini tom.rini@gmail.com Cc: Anton staaf robotboy@chromium.org ---
It is based on definition of ARCH_DMA_MINALIGN introduced in 44d6cbb6a77665caa14be2a561c4148446b3ba7e:
arm: cache: define ARCH_DMA_MINALIGN for DMA buffer alignment
disk/part_efi.c | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/disk/part_efi.c b/disk/part_efi.c index e7f2714..b6cda57 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -130,7 +130,7 @@ void print_part_efi(block_dev_desc_t * dev_desc) } /* This function validates AND fills in the GPT header and PTE */ if (is_gpt_valid(dev_desc, GPT_PRIMARY_PARTITION_TABLE_LBA, - &(gpt_head), &gpt_pte) != 1) { + gpt_head, &gpt_pte) != 1) { printf("%s: *** ERROR: Invalid GPT ***\n", __func__); return; } @@ -169,7 +169,7 @@ int get_partition_info_efi(block_dev_desc_t * dev_desc, int part,
/* This function validates AND fills in the GPT header and PTE */ if (is_gpt_valid(dev_desc, GPT_PRIMARY_PARTITION_TABLE_LBA, - &(gpt_head), &gpt_pte) != 1) { + gpt_head, &gpt_pte) != 1) { printf("%s: *** ERROR: Invalid GPT ***\n", __func__); return -1; } @@ -380,7 +380,7 @@ static gpt_entry *alloc_read_gpt_entries(block_dev_desc_t * dev_desc,
/* Allocate memory for PTE, remember to FREE */ if (count != 0) { - pte = memalign(CONFIG_SYS_CACHELINE_SIZE, count); + pte = memalign(ARCH_DMA_MINALIGN, count); }
if (count == 0 || pte == NULL) {
Defines CONFIG_EFI_PARTITION for OMAP3 EVM.
Signed-off-by: Sanjeev Premi premi@ti.com Cc: Sandeep Paulraj s-paulraj@ti.com Cc: Tom Rini tom.rini@gmail.com ---
Changes since v1: * Removed definition of CONFIG_SYS_CACHELINE_SIZE as it is no longer needed - since ARCH_DMA_MINALIGN is being used in previous patch.
include/configs/omap3_evm.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 47ec39f..9228ef1 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -84,6 +84,7 @@ #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC #define CONFIG_DOS_PARTITION +#define CONFIG_EFI_PARTITION
/* USB *
Sanjeev Premi
