[U-Boot] [PATCH v3] x86: zImage: Pass working device tree data to the kernel
On x86 platforms, U-Boot does not pass Device Tree data to the kernel. This prevents the kernel from using FDT loaded by U-Boot.
Read the working FDT address from the "fdtaddr" environment variable and add a copy of the FDT data to the kernel setup_data list.
Signed-off-by: Ivan Gorinov ivan.gorinov@intel.com --- arch/x86/include/asm/bootparam.h | 7 +++++-- arch/x86/lib/zimage.c | 34 ++++++++++++++++++++++++++++++++++ 2 files changed, 39 insertions(+), 2 deletions(-)
diff --git a/arch/x86/include/asm/bootparam.h b/arch/x86/include/asm/bootparam.h index 90768a9..6aba614 100644 --- a/arch/x86/include/asm/bootparam.h +++ b/arch/x86/include/asm/bootparam.h @@ -10,8 +10,11 @@ #include <asm/video/edid.h>
/* setup data types */ -#define SETUP_NONE 0 -#define SETUP_E820_EXT 1 +enum { + SETUP_NONE = 0, + SETUP_E820_EXT, + SETUP_DTB, +};
/* extensible setup data list node */ struct setup_data { diff --git a/arch/x86/lib/zimage.c b/arch/x86/lib/zimage.c index 2a82bc8..1ff77e9 100644 --- a/arch/x86/lib/zimage.c +++ b/arch/x86/lib/zimage.c @@ -14,6 +14,7 @@ */
#include <common.h> +#include <malloc.h> #include <asm/acpi_table.h> #include <asm/io.h> #include <asm/ptrace.h> @@ -95,6 +96,38 @@ static int get_boot_protocol(struct setup_header *hdr) } }
+static int setup_device_tree(struct setup_header *hdr, const void *fdt_blob) +{ + int bootproto = get_boot_protocol(hdr); + struct setup_data *sd; + int size; + + if (bootproto < 0x0209) + return -ENOTSUPP; + + if (!fdt_blob) + return 0; + + size = fdt_totalsize(fdt_blob); + if (size < 0) + return -EINVAL; + + size += sizeof(struct setup_data); + sd = (struct setup_data *)malloc(size); + if (!sd) { + printf("Not enough memory for DTB setup data\n"); + return -ENOMEM; + } + + sd->next = hdr->setup_data; + sd->type = SETUP_DTB; + sd->len = fdt_totalsize(fdt_blob); + memcpy(sd->data, fdt_blob, sd->len); + hdr->setup_data = (unsigned long)sd; + + return 0; +} + struct boot_params *load_zimage(char *image, unsigned long kernel_size, ulong *load_addressp) { @@ -261,6 +294,7 @@ int setup_zimage(struct boot_params *setup_base, char *cmd_line, int auto_boot, hdr->acpi_rsdp_addr = acpi_get_rsdp_addr(); #endif
+ setup_device_tree(hdr, (const void *)env_get_hex("fdtaddr", 0)); setup_video(&setup_base->screen_info);
applied to u-boot-x86, thanks!
SETUP_NONE = 0,
SETUP_E820_EXT,
SETUP_DTB,
Sorry to mention that I added "#include <linux/libfdt.h>" here to fix build error seen on several x86 boards during a buildman testing. Changed applied to u-boot-x86.
Regards, Bin
Bin Meng
Ivan Gorinov
