[U-Boot] [PULL] [NEXT] u-boot-arm.git next
The following changes since commit 006915fbb0e3c1c9927fe32c4e92cb011f8499e7:
Merge branch 'master' of ../master into next (2010-12-16 23:00:53 +0100)
git://git.denx.de/u-boot-arm.git next
Prafulla Wadaskar (7): arm: Add Support for Marvell ARMADA 100 Familiy SoCs gpio: Add Multi-Function-Pin configuration driver for Marvell SoCs add Multi Function Pin configuration support for ARMADA100 Serial: ns16550: Add support for CONFIG_SYS_NS16550_IER macro Serial: Add UART support for Marvell ARMADA 100 SoCs. mv-common.h: Add support for ARMADA100 Platforms Armada100: Add Board Support for Marvell Aspenite-DB
Simon Kagstrom (1): MAINTAINERS: Transfer openrd_base maintainership to Prafulla Wadaskar
MAINTAINERS | 6 +- MAKEALL | 1 + arch/arm/cpu/arm926ejs/armada100/Makefile | 46 +++++ arch/arm/cpu/arm926ejs/armada100/cpu.c | 92 ++++++++++ arch/arm/cpu/arm926ejs/armada100/dram.c | 131 ++++++++++++++ arch/arm/cpu/arm926ejs/armada100/timer.c | 207 +++++++++++++++++++++++ arch/arm/include/asm/arch-armada100/armada100.h | 121 +++++++++++++ arch/arm/include/asm/arch-armada100/cpu.h | 53 ++++++ arch/arm/include/asm/arch-armada100/mfp.h | 67 ++++++++ board/Marvell/aspenite/Makefile | 52 ++++++ board/Marvell/aspenite/aspenite.c | 53 ++++++ boards.cfg | 1 + drivers/gpio/Makefile | 1 + drivers/gpio/mvmfp.c | 87 ++++++++++ drivers/serial/ns16550.c | 8 +- drivers/serial/serial.c | 5 +- include/configs/aspenite.h | 63 +++++++ include/configs/mv-common.h | 66 ++++++-- include/mvmfp.h | 100 +++++++++++ 19 files changed, 1136 insertions(+), 24 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/armada100/Makefile create mode 100644 arch/arm/cpu/arm926ejs/armada100/cpu.c create mode 100644 arch/arm/cpu/arm926ejs/armada100/dram.c create mode 100644 arch/arm/cpu/arm926ejs/armada100/timer.c create mode 100644 arch/arm/include/asm/arch-armada100/armada100.h create mode 100644 arch/arm/include/asm/arch-armada100/cpu.h create mode 100644 arch/arm/include/asm/arch-armada100/mfp.h create mode 100644 board/Marvell/aspenite/Makefile create mode 100644 board/Marvell/aspenite/aspenite.c create mode 100644 drivers/gpio/mvmfp.c create mode 100644 include/configs/aspenite.h create mode 100644 include/mvmfp.h
Applied.
