[U-Boot] [PATCH] arm64: zynqmp: Remove power domain description
This part hasn't been pushed to mainline yet that's why remove it. The patch can be reverted in future when this is pushed there.
Reported-by: Alexander Graf agraf@suse.de Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/dts/zynqmp.dtsi | 194 ----------------------------------------------- 1 file changed, 194 deletions(-)
diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index ad4bbbf66750..80ac9a6ac7b0 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -102,155 +102,6 @@ u-boot,dm-pre-reloc; };
- power-domains { - compatible = "xlnx,zynqmp-genpd"; - - pd_usb0: pd-usb0 { - #power-domain-cells = <0x0>; - pd-id = <0x16>; - }; - - pd_usb1: pd-usb1 { - #power-domain-cells = <0x0>; - pd-id = <0x17>; - }; - - pd_sata: pd-sata { - #power-domain-cells = <0x0>; - pd-id = <0x1c>; - }; - - pd_spi0: pd-spi0 { - #power-domain-cells = <0x0>; - pd-id = <0x23>; - }; - - pd_spi1: pd-spi1 { - #power-domain-cells = <0x0>; - pd-id = <0x24>; - }; - - pd_uart0: pd-uart0 { - #power-domain-cells = <0x0>; - pd-id = <0x21>; - }; - - pd_uart1: pd-uart1 { - #power-domain-cells = <0x0>; - pd-id = <0x22>; - }; - - pd_eth0: pd-eth0 { - #power-domain-cells = <0x0>; - pd-id = <0x1d>; - }; - - pd_eth1: pd-eth1 { - #power-domain-cells = <0x0>; - pd-id = <0x1e>; - }; - - pd_eth2: pd-eth2 { - #power-domain-cells = <0x0>; - pd-id = <0x1f>; - }; - - pd_eth3: pd-eth3 { - #power-domain-cells = <0x0>; - pd-id = <0x20>; - }; - - pd_i2c0: pd-i2c0 { - #power-domain-cells = <0x0>; - pd-id = <0x25>; - }; - - pd_i2c1: pd-i2c1 { - #power-domain-cells = <0x0>; - pd-id = <0x26>; - }; - - pd_dp: pd-dp { - #power-domain-cells = <0x0>; - pd-id = <0x29>; - }; - - pd_gdma: pd-gdma { - #power-domain-cells = <0x0>; - pd-id = <0x2a>; - }; - - pd_adma: pd-adma { - #power-domain-cells = <0x0>; - pd-id = <0x2b>; - }; - - pd_ttc0: pd-ttc0 { - #power-domain-cells = <0x0>; - pd-id = <0x18>; - }; - - pd_ttc1: pd-ttc1 { - #power-domain-cells = <0x0>; - pd-id = <0x19>; - }; - - pd_ttc2: pd-ttc2 { - #power-domain-cells = <0x0>; - pd-id = <0x1a>; - }; - - pd_ttc3: pd-ttc3 { - #power-domain-cells = <0x0>; - pd-id = <0x1b>; - }; - - pd_sd0: pd-sd0 { - #power-domain-cells = <0x0>; - pd-id = <0x27>; - }; - - pd_sd1: pd-sd1 { - #power-domain-cells = <0x0>; - pd-id = <0x28>; - }; - - pd_nand: pd-nand { - #power-domain-cells = <0x0>; - pd-id = <0x2c>; - }; - - pd_qspi: pd-qspi { - #power-domain-cells = <0x0>; - pd-id = <0x2d>; - }; - - pd_gpio: pd-gpio { - #power-domain-cells = <0x0>; - pd-id = <0x2e>; - }; - - pd_can0: pd-can0 { - #power-domain-cells = <0x0>; - pd-id = <0x2f>; - }; - - pd_can1: pd-can1 { - #power-domain-cells = <0x0>; - pd-id = <0x30>; - }; - - pd_pcie: pd-pcie { - #power-domain-cells = <0x0>; - pd-id = <0x3b>; - }; - - pd_gpu: pd-gpu { - #power-domain-cells = <0x0>; - pd-id = <0x3a 0x14 0x15>; - }; - }; - pmu { compatible = "arm,armv8-pmuv3"; interrupt-parent = <&gic>; @@ -394,7 +245,6 @@ interrupt-parent = <&gic>; tx-fifo-depth = <0x40>; rx-fifo-depth = <0x40>; - power-domains = <&pd_can0>; };
can1: can@ff070000 { @@ -406,7 +256,6 @@ interrupt-parent = <&gic>; tx-fifo-depth = <0x40>; rx-fifo-depth = <0x40>; - power-domains = <&pd_can1>; };
cci: cci@fd6e0000 { @@ -439,7 +288,6 @@ xlnx,bus-width = <128>; #stream-id-cells = <1>; iommus = <&smmu 0x14e8>; - power-domains = <&pd_gdma>; };
fpd_dma_chan2: dma@fd510000 { @@ -452,7 +300,6 @@ xlnx,bus-width = <128>; #stream-id-cells = <1>; iommus = <&smmu 0x14e9>; - power-domains = <&pd_gdma>; };
fpd_dma_chan3: dma@fd520000 { @@ -465,7 +312,6 @@ xlnx,bus-width = <128>; #stream-id-cells = <1>; iommus = <&smmu 0x14ea>; - power-domains = <&pd_gdma>; };
fpd_dma_chan4: dma@fd530000 { @@ -478,7 +324,6 @@ xlnx,bus-width = <128>; #stream-id-cells = <1>; iommus = <&smmu 0x14eb>; - power-domains = <&pd_gdma>; };
fpd_dma_chan5: dma@fd540000 { @@ -491,7 +336,6 @@ xlnx,bus-width = <128>; #stream-id-cells = <1>; iommus = <&smmu 0x14ec>; - power-domains = <&pd_gdma>; };
fpd_dma_chan6: dma@fd550000 { @@ -504,7 +348,6 @@ xlnx,bus-width = <128>; #stream-id-cells = <1>; iommus = <&smmu 0x14ed>; - power-domains = <&pd_gdma>; };
fpd_dma_chan7: dma@fd560000 { @@ -517,7 +360,6 @@ xlnx,bus-width = <128>; #stream-id-cells = <1>; iommus = <&smmu 0x14ee>; - power-domains = <&pd_gdma>; };
fpd_dma_chan8: dma@fd570000 { @@ -530,7 +372,6 @@ xlnx,bus-width = <128>; #stream-id-cells = <1>; iommus = <&smmu 0x14ef>; - power-domains = <&pd_gdma>; };
gpu: gpu@fd4b0000 { @@ -541,7 +382,6 @@ interrupts = <0 132 4>, <0 132 4>, <0 132 4>, <0 132 4>, <0 132 4>, <0 132 4>; interrupt-names = "IRQGP", "IRQGPMMU", "IRQPP0", "IRQPPMMU0", "IRQPP1", "IRQPPMMU1"; clock-names = "gpu", "gpu_pp0", "gpu_pp1"; - power-domains = <&pd_gpu>; };
/* LPDDMA default allows only secured access. inorder to enable @@ -558,7 +398,6 @@ xlnx,bus-width = <64>; #stream-id-cells = <1>; iommus = <&smmu 0x868>; - power-domains = <&pd_adma>; };
lpd_dma_chan2: dma@ffa90000 { @@ -571,7 +410,6 @@ xlnx,bus-width = <64>; #stream-id-cells = <1>; iommus = <&smmu 0x869>; - power-domains = <&pd_adma>; };
lpd_dma_chan3: dma@ffaa0000 { @@ -584,7 +422,6 @@ xlnx,bus-width = <64>; #stream-id-cells = <1>; iommus = <&smmu 0x86a>; - power-domains = <&pd_adma>; };
lpd_dma_chan4: dma@ffab0000 { @@ -597,7 +434,6 @@ xlnx,bus-width = <64>; #stream-id-cells = <1>; iommus = <&smmu 0x86b>; - power-domains = <&pd_adma>; };
lpd_dma_chan5: dma@ffac0000 { @@ -610,7 +446,6 @@ xlnx,bus-width = <64>; #stream-id-cells = <1>; iommus = <&smmu 0x86c>; - power-domains = <&pd_adma>; };
lpd_dma_chan6: dma@ffad0000 { @@ -623,7 +458,6 @@ xlnx,bus-width = <64>; #stream-id-cells = <1>; iommus = <&smmu 0x86d>; - power-domains = <&pd_adma>; };
lpd_dma_chan7: dma@ffae0000 { @@ -636,7 +470,6 @@ xlnx,bus-width = <64>; #stream-id-cells = <1>; iommus = <&smmu 0x86e>; - power-domains = <&pd_adma>; };
lpd_dma_chan8: dma@ffaf0000 { @@ -649,7 +482,6 @@ xlnx,bus-width = <64>; #stream-id-cells = <1>; iommus = <&smmu 0x86f>; - power-domains = <&pd_adma>; };
mc: memory-controller@fd070000 { @@ -670,7 +502,6 @@ #size-cells = <1>; #stream-id-cells = <1>; iommus = <&smmu 0x872>; - power-domains = <&pd_nand>; };
gem0: ethernet@ff0b0000 { @@ -684,7 +515,6 @@ #size-cells = <0>; #stream-id-cells = <1>; iommus = <&smmu 0x874>; - power-domains = <&pd_eth0>; };
gem1: ethernet@ff0c0000 { @@ -698,7 +528,6 @@ #size-cells = <0>; #stream-id-cells = <1>; iommus = <&smmu 0x875>; - power-domains = <&pd_eth1>; };
gem2: ethernet@ff0d0000 { @@ -712,7 +541,6 @@ #size-cells = <0>; #stream-id-cells = <1>; iommus = <&smmu 0x876>; - power-domains = <&pd_eth2>; };
gem3: ethernet@ff0e0000 { @@ -726,7 +554,6 @@ #size-cells = <0>; #stream-id-cells = <1>; iommus = <&smmu 0x877>; - power-domains = <&pd_eth3>; };
gpio: gpio@ff0a0000 { @@ -739,7 +566,6 @@ #interrupt-cells = <2>; reg = <0x0 0xff0a0000 0x0 0x1000>; gpio-controller; - power-domains = <&pd_gpio>; };
i2c0: i2c@ff020000 { @@ -750,7 +576,6 @@ reg = <0x0 0xff020000 0x0 0x1000>; #address-cells = <1>; #size-cells = <0>; - power-domains = <&pd_i2c0>; };
i2c1: i2c@ff030000 { @@ -761,7 +586,6 @@ reg = <0x0 0xff030000 0x0 0x1000>; #address-cells = <1>; #size-cells = <0>; - power-domains = <&pd_i2c1>; };
ocm: memory-controller@ff960000 { @@ -800,7 +624,6 @@ <0x0 0x0 0x0 0x2 &pcie_intc 0x2>, <0x0 0x0 0x0 0x3 &pcie_intc 0x3>, <0x0 0x0 0x0 0x4 &pcie_intc 0x4>; - power-domains = <&pd_pcie>; pcie_intc: legacy-interrupt-controller { interrupt-controller; #address-cells = <0>; @@ -822,7 +645,6 @@ #size-cells = <0>; #stream-id-cells = <1>; iommus = <&smmu 0x873>; - power-domains = <&pd_qspi>; };
rtc: rtc@ffa60000 { @@ -872,7 +694,6 @@ reg = <0x0 0xfd0c0000 0x0 0x2000>; interrupt-parent = <&gic>; interrupts = <0 133 4>; - power-domains = <&pd_sata>; #stream-id-cells = <4>; iommus = <&smmu 0x4c0>, <&smmu 0x4c1>, <&smmu 0x4c2>, <&smmu 0x4c3>; @@ -890,7 +711,6 @@ xlnx,device_id = <0>; #stream-id-cells = <1>; iommus = <&smmu 0x870>; - power-domains = <&pd_sd0>; nvmem-cells = <&soc_revision>; nvmem-cell-names = "soc_revision"; }; @@ -906,7 +726,6 @@ xlnx,device_id = <1>; #stream-id-cells = <1>; iommus = <&smmu 0x871>; - power-domains = <&pd_sd1>; nvmem-cells = <&soc_revision>; nvmem-cell-names = "soc_revision"; }; @@ -940,7 +759,6 @@ clock-names = "ref_clk", "pclk"; #address-cells = <1>; #size-cells = <0>; - power-domains = <&pd_spi0>; };
spi1: spi@ff050000 { @@ -952,7 +770,6 @@ clock-names = "ref_clk", "pclk"; #address-cells = <1>; #size-cells = <0>; - power-domains = <&pd_spi1>; };
ttc0: timer@ff110000 { @@ -962,7 +779,6 @@ interrupts = <0 36 4>, <0 37 4>, <0 38 4>; reg = <0x0 0xff110000 0x0 0x1000>; timer-width = <32>; - power-domains = <&pd_ttc0>; };
ttc1: timer@ff120000 { @@ -972,7 +788,6 @@ interrupts = <0 39 4>, <0 40 4>, <0 41 4>; reg = <0x0 0xff120000 0x0 0x1000>; timer-width = <32>; - power-domains = <&pd_ttc1>; };
ttc2: timer@ff130000 { @@ -982,7 +797,6 @@ interrupts = <0 42 4>, <0 43 4>, <0 44 4>; reg = <0x0 0xff130000 0x0 0x1000>; timer-width = <32>; - power-domains = <&pd_ttc2>; };
ttc3: timer@ff140000 { @@ -992,7 +806,6 @@ interrupts = <0 45 4>, <0 46 4>, <0 47 4>; reg = <0x0 0xff140000 0x0 0x1000>; timer-width = <32>; - power-domains = <&pd_ttc3>; };
uart0: serial@ff000000 { @@ -1003,7 +816,6 @@ interrupts = <0 21 4>; reg = <0x0 0xff000000 0x0 0x1000>; clock-names = "uart_clk", "pclk"; - power-domains = <&pd_uart0>; };
uart1: serial@ff010000 { @@ -1014,7 +826,6 @@ interrupts = <0 22 4>; reg = <0x0 0xff010000 0x0 0x1000>; clock-names = "uart_clk", "pclk"; - power-domains = <&pd_uart1>; };
usb0: usb0@ff9d0000 { @@ -1024,7 +835,6 @@ compatible = "xlnx,zynqmp-dwc3"; reg = <0x0 0xff9d0000 0x0 0x100>; clock-names = "bus_clk", "ref_clk"; - power-domains = <&pd_usb0>; ranges; nvmem-cells = <&soc_revision>; nvmem-cell-names = "soc_revision"; @@ -1050,7 +860,6 @@ compatible = "xlnx,zynqmp-dwc3"; reg = <0x0 0xff9e0000 0x0 0x100>; clock-names = "bus_clk", "ref_clk"; - power-domains = <&pd_usb1>; ranges; nvmem-cells = <&soc_revision>; nvmem-cell-names = "soc_revision"; @@ -1111,7 +920,6 @@ interrupts = <0 119 4>; interrupt-parent = <&gic>; clock-names = "aclk", "aud_clk"; - power-domains = <&pd_dp>; xlnx,dp-version = "v1.2"; xlnx,max-lanes = <2>; xlnx,max-link-rate = <540000>; @@ -1134,7 +942,6 @@ xlnx,output-fmt = "rgb"; xlnx,vid-fmt = "yuyv"; xlnx,gfx-fmt = "rgb565"; - power-domains = <&pd_dp>; };
xlnx_dpdma: dma@fd4c0000 { @@ -1144,7 +951,6 @@ interrupts = <0 122 4>; interrupt-parent = <&gic>; clock-names = "axi_clk"; - power-domains = <&pd_dp>; dma-channels = <6>; #dma-cells = <1>; dma-video0channel {
Michal Simek
