[U-Boot] [PATCH 1/4] am43xx: Only read the MPU frequency bits of CTRL_DEV_ATTR
Signed-off-by: Tom Rini trini@ti.com --- board/ti/am43xx/board.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index d358ad8..e05a50b 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -464,7 +464,10 @@ static u32 get_sys_clk_index(void) static int get_opp_offset(int max_off, int min_off) { struct ctrl_stat *ctrl = (struct ctrl_stat *)CTRL_BASE; - int opp = readl(&ctrl->dev_attr), offset, i; + int opp, offset, i; + + /* Bits 0:11 are defined to be the MPU_MAX_FREQ */ + opp = readl(&ctrl->dev_attr) & ~0xFFFFF000;
for (i = max_off; i >= min_off; i--) { offset = opp & (1 << i);
Similar to OMAP4/5 we need to scale the voltage up prior to changing the clock frequencies up higher. Add a similar hook to start with.
Signed-off-by: Tom Rini trini@ti.com --- arch/arm/cpu/armv7/am33xx/clock.c | 11 +++++++++++ arch/arm/include/asm/arch-am33xx/clock.h | 1 + 2 files changed, 12 insertions(+)
diff --git a/arch/arm/cpu/armv7/am33xx/clock.c b/arch/arm/cpu/armv7/am33xx/clock.c index 0672798..ec7d468 100644 --- a/arch/arm/cpu/armv7/am33xx/clock.c +++ b/arch/arm/cpu/armv7/am33xx/clock.c @@ -170,8 +170,19 @@ void do_enable_clocks(u32 *const *clk_domains, }; }
+/* + * Before scaling up the clocks we need to have the PMIC scale up the + * voltages first. This will be dependent on which PMIC is in use + * and in some cases we may not be scaling things up at all and thus not + * need to do anything here. + */ +__weak void scale_vcores(void) +{ +} + void prcm_init() { enable_basic_clocks(); + scale_vcores(); setup_dplls(); } diff --git a/arch/arm/include/asm/arch-am33xx/clock.h b/arch/arm/include/asm/arch-am33xx/clock.h index f00fad3..4af6b57 100644 --- a/arch/arm/include/asm/arch-am33xx/clock.h +++ b/arch/arm/include/asm/arch-am33xx/clock.h @@ -107,6 +107,7 @@ const struct dpll_params *get_dpll_mpu_params(void); const struct dpll_params *get_dpll_core_params(void); const struct dpll_params *get_dpll_per_params(void); const struct dpll_params *get_dpll_ddr_params(void); +void scale_vcores(void); void do_setup_dpll(const struct dpll_regs *, const struct dpll_params *); void prcm_init(void); void enable_basic_clocks(void);
Applied to u-boot-ti/master, thanks!
Add a driver for the TPS65218 PMIC which is used by TI AM43xx SoCs and may be used by TI AM335x SoCs.
Signed-off-by: Tom Rini trini@ti.com --- drivers/power/pmic/Makefile | 1 + drivers/power/pmic/pmic_tps65218.c | 97 ++++++++++++++++++++++++++++++++++++ include/power/tps65218.h | 63 +++++++++++++++++++++++ 3 files changed, 161 insertions(+) create mode 100644 drivers/power/pmic/pmic_tps65218.c create mode 100644 include/power/tps65218.h
diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index 920bbdc..192df50 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -12,4 +12,5 @@ obj-$(CONFIG_POWER_MUIC_MAX8997) += muic_max8997.o obj-$(CONFIG_POWER_MAX77686) += pmic_max77686.o obj-$(CONFIG_POWER_PFUZE100) += pmic_pfuze100.o obj-$(CONFIG_POWER_TPS65217) += pmic_tps65217.o +obj-$(CONFIG_POWER_TPS65218) += pmic_tps65218.o obj-$(CONFIG_POWER_TPS65910) += pmic_tps65910.o diff --git a/drivers/power/pmic/pmic_tps65218.c b/drivers/power/pmic/pmic_tps65218.c new file mode 100644 index 0000000..0952456 --- /dev/null +++ b/drivers/power/pmic/pmic_tps65218.c @@ -0,0 +1,97 @@ +/* + * (C) Copyright 2011-2013 + * Texas Instruments, <www.ti.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <i2c.h> +#include <power/tps65218.h> + +/** + * tps65218_reg_write() - Generic function that can write a TPS65218 PMIC + * register or bit field regardless of protection + * level. + * + * @prot_level: Register password protection. Use + * TPS65218_PROT_LEVEL_NONE, + * TPS65218_PROT_LEVEL_1 or TPS65218_PROT_LEVEL_2 + * @dest_reg: Register address to write. + * @dest_val: Value to write. + * @mask: Bit mask (8 bits) to be applied. Function will only + * change bits that are set in the bit mask. + * + * @return: 0 for success, not 0 on failure, as per the i2c API + */ +int tps65218_reg_write(uchar prot_level, uchar dest_reg, uchar dest_val, + uchar mask) +{ + uchar read_val; + uchar xor_reg; + int ret; + + /* + * If we are affecting only a bit field, read dest_reg and apply the + * mask + */ + if (mask != TPS65218_MASK_ALL_BITS) { + ret = i2c_read(TPS65218_CHIP_PM, dest_reg, 1, &read_val, 1); + if (ret) + return ret; + read_val &= (~mask); + read_val |= (dest_val & mask); + dest_val = read_val; + } + + if (prot_level > 0) { + xor_reg = dest_reg ^ TPS65218_PASSWORD_UNLOCK; + ret = i2c_write(TPS65218_CHIP_PM, TPS65218_PASSWORD, 1, + &xor_reg, 1); + if (ret) + return ret; + } + + ret = i2c_write(TPS65218_CHIP_PM, dest_reg, 1, &dest_val, 1); + if (ret) + return ret; + + if (prot_level == TPS65218_PROT_LEVEL_2) { + ret = i2c_write(TPS65218_CHIP_PM, TPS65218_PASSWORD, 1, + &xor_reg, 1); + if (ret) + return ret; + + ret = i2c_write(TPS65218_CHIP_PM, dest_reg, 1, &dest_val, 1); + if (ret) + return ret; + } + + return 0; +} + +/** + * tps65218_voltage_update() - Function to change a voltage level, as this + * is a multi-step process. + * @dc_cntrl_reg: DC voltage control register to change. + * @volt_sel: New value for the voltage register + * @return: 0 for success, not 0 on failure. + */ +int tps65218_voltage_update(uchar dc_cntrl_reg, uchar volt_sel) +{ + if ((dc_cntrl_reg != TPS65218_DCDC1) && + (dc_cntrl_reg != TPS65218_DCDC2)) + return 1; + + /* set voltage level */ + if (tps65218_reg_write(TPS65218_PROT_LEVEL_2, dc_cntrl_reg, volt_sel, + TPS65218_MASK_ALL_BITS)) + return 1; + + /* set GO bit to initiate voltage transition */ + if (tps65218_reg_write(TPS65218_PROT_LEVEL_2, TPS65218_SLEW, + TPS65218_DCDC_GO, TPS65218_DCDC_GO)) + return 1; + + return 0; +} diff --git a/include/power/tps65218.h b/include/power/tps65218.h new file mode 100644 index 0000000..67aa2f8 --- /dev/null +++ b/include/power/tps65218.h @@ -0,0 +1,63 @@ +/* + * (C) Copyright 2014 + * Texas Instruments, <www.ti.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __POWER_TPS65218_H__ +#define __POWER_TPS65218_H__ + +/* I2C chip address */ +#define TPS65218_CHIP_PM 0x24 + +/* Registers */ +enum { + TPS65218_CHIPID = 0x00, + TPS65218_INT1, + TPS65218_INT2, + TPS65218_INT_MASK1, + TPS65218_INT_MASK2, + TPS65218_STATUS, + TPS65218_CONTROL, + TPS65218_FLAG, + TPS65218_PASSWORD = 0x10, + TPS65218_ENABLE1, + TPS65218_ENABLE2, + TPS65218_CONFIG1, + TPS65218_CONFIG2, + TPS65218_CONFIG3, + TPS65218_DCDC1, + TPS65218_DCDC2, + TPS65218_DCDC3, + TPS65218_DCDC4, + TPS65218_SLEW, + TPS65218_LDO1, + TPS65218_SEQ1 = 0x20, + TPS65218_SEQ2, + TPS65218_SEQ3, + TPS65218_SEQ4, + TPS65218_SEQ5, + TPS65218_SEQ6, + TPS65218_SEQ7, + TPS65218_PMIC_NUM_OF_REGS, +}; + +#define TPS65218_PROT_LEVEL_NONE 0x00 +#define TPS65218_PROT_LEVEL_1 0x01 +#define TPS65218_PROT_LEVEL_2 0x02 + +#define TPS65218_PASSWORD_LOCK_FOR_WRITE 0x00 +#define TPS65218_PASSWORD_UNLOCK 0x7D + +#define TPS65218_DCDC_GO 0x80 + +#define TPS65218_MASK_ALL_BITS 0xFF + +#define TPS65218_DCDC_VOLT_SEL_1100MV 0x19 +#define TPS65218_DCDC_VOLT_SEL_1330MV 0x30 + +int tps65218_reg_write(uchar prot_level, uchar dest_reg, uchar dest_val, + uchar mask); +int tps65218_voltage_update(uchar dc_cntrl_reg, uchar volt_sel); +#endif /* __POWER_TPS65218_H__ */
This family is supported by the TPS65218 PMIC. Implement a scale_vcores to set the MPU and CORE voltage correctly to the max frequency that is supported (and what we will be scaling them to in setup_dplls()).
Signed-off-by: Tom Rini trini@ti.com --- board/ti/am43xx/board.c | 48 ++++++++++++++++++++++++++++++++++++------ include/configs/am43xx_evm.h | 4 ++++ 2 files changed, 45 insertions(+), 7 deletions(-)
diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index e05a50b..7786903 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -19,6 +19,7 @@ #include <asm/arch/gpio.h> #include <asm/emif.h> #include "board.h" +#include <power/tps65218.h> #include <miiphy.h> #include <cpsw.h>
@@ -416,13 +417,6 @@ void emif_get_ext_phy_ctrl_const_regs(const u32 **regs, u32 *size)
const struct dpll_params *get_dpll_ddr_params(void) { - struct am43xx_board_id header; - - enable_i2c0_pin_mux(); - i2c_init(CONFIG_SYS_OMAP24_I2C_SPEED, CONFIG_SYS_OMAP24_I2C_SLAVE); - if (read_eeprom(&header) < 0) - puts("Could not get board ID.\n"); - if (board_is_eposevm()) return &epos_evm_dpll_ddr; else if (board_is_gpevm() || board_is_sk()) @@ -500,6 +494,46 @@ const struct dpll_params *get_dpll_per_params(void) return &dpll_per[ind]; }
+void scale_vcores(void) +{ + const struct dpll_params *mpu_params; + int mpu_vdd; + struct am43xx_board_id header; + + enable_i2c0_pin_mux(); + i2c_init(CONFIG_SYS_OMAP24_I2C_SPEED, CONFIG_SYS_OMAP24_I2C_SLAVE); + if (read_eeprom(&header) < 0) + puts("Could not get board ID.\n"); + + /* Get the frequency */ + mpu_params = get_dpll_mpu_params(); + + if (i2c_probe(TPS65218_CHIP_PM)) + return; + + if (mpu_params->m == 1000) { + mpu_vdd = TPS65218_DCDC_VOLT_SEL_1330MV; + } else if (mpu_params->m == 600) { + mpu_vdd = TPS65218_DCDC_VOLT_SEL_1100MV; + } else { + puts("Unknown MPU clock, not scaling\n"); + return; + } + + /* Set DCDC1 (CORE) voltage to 1.1V */ + if (tps65218_voltage_update(TPS65218_DCDC1, + TPS65218_DCDC_VOLT_SEL_1100MV)) { + puts("tps65218_voltage_update failure\n"); + return; + } + + /* Set DCDC2 (MPU) voltage */ + if (tps65218_voltage_update(TPS65218_DCDC2, mpu_vdd)) { + puts("tps65218_voltage_update failure\n"); + return; + } +} + void set_uart_mux_conf(void) { enable_uart0_pin_mux(); diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 470fa39..2e19c17 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -32,11 +32,15 @@ #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 #define CONFIG_SYS_I2C_MULTI_EEPROMS
+/* Power */ +#define CONFIG_POWER_TPS65218 + /* SPL defines. */ #define CONFIG_SPL_TEXT_BASE 0x40300350 #define CONFIG_SPL_MAX_SIZE (220 << 10) /* 220KB */ #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + \ (128 << 20)) +#define CONFIG_SPL_POWER_SUPPORT #define CONFIG_SPL_YMODEM_SUPPORT
/* Enabling L2 Cache */
