[U-Boot] [PATCH 6/6] x86: Convert to use driver model pci on queensbay/crownbay
Move to driver model pci for Intel queensbay/crownbay.
Signed-off-by: Bin Meng bmeng.cn@gmail.com
arch/x86/cpu/queensbay/Makefile | 1 - arch/x86/cpu/queensbay/tnc.c | 5 ----- arch/x86/cpu/queensbay/tnc_pci.c | 46 ---------------------------------------- arch/x86/dts/crownbay.dts | 6 +++++- configs/crownbay_defconfig | 1 + 5 files changed, 6 insertions(+), 53 deletions(-) delete mode 100644 arch/x86/cpu/queensbay/tnc_pci.c
diff --git a/arch/x86/cpu/queensbay/Makefile b/arch/x86/cpu/queensbay/Makefile index d8761fd..660f967 100644 --- a/arch/x86/cpu/queensbay/Makefile +++ b/arch/x86/cpu/queensbay/Makefile @@ -6,4 +6,3 @@
obj-y += fsp_configs.o obj-y += tnc.o topcliff.o -obj-$(CONFIG_PCI) += tnc_pci.o diff --git a/arch/x86/cpu/queensbay/tnc.c b/arch/x86/cpu/queensbay/tnc.c index d27b2d9..de50893 100644 --- a/arch/x86/cpu/queensbay/tnc.c +++ b/arch/x86/cpu/queensbay/tnc.c @@ -25,7 +25,6 @@ static void unprotect_spi_flash(void)
int arch_cpu_init(void) { - struct pci_controller *hose; int ret;
post_code(POST_CPU_INIT); @@ -37,10 +36,6 @@ int arch_cpu_init(void) if (ret) return ret;
- ret = pci_early_init_hose(&hose); - if (ret) - return ret; - unprotect_spi_flash();
return 0; diff --git a/arch/x86/cpu/queensbay/tnc_pci.c b/arch/x86/cpu/queensbay/tnc_pci.c deleted file mode 100644 index 6c291f9..0000000 --- a/arch/x86/cpu/queensbay/tnc_pci.c +++ /dev/null @@ -1,46 +0,0 @@ -/* - * Copyright (C) 2014, Bin Meng bmeng.cn@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <pci.h> -#include <asm/pci.h> -#include <asm/fsp/fsp_support.h> - -DECLARE_GLOBAL_DATA_PTR; - -void board_pci_setup_hose(struct pci_controller *hose) -{ - hose->first_busno = 0; - hose->last_busno = 0; - - /* PCI memory space */ - pci_set_region(hose->regions + 0, - CONFIG_PCI_MEM_BUS, - CONFIG_PCI_MEM_PHYS, - CONFIG_PCI_MEM_SIZE, - PCI_REGION_MEM); - - /* PCI IO space */ - pci_set_region(hose->regions + 1, - CONFIG_PCI_IO_BUS, - CONFIG_PCI_IO_PHYS, - CONFIG_PCI_IO_SIZE, - PCI_REGION_IO); - - pci_set_region(hose->regions + 2, - CONFIG_PCI_PREF_BUS, - CONFIG_PCI_PREF_PHYS, - CONFIG_PCI_PREF_SIZE, - PCI_REGION_PREFETCH); - - pci_set_region(hose->regions + 3, - 0, - 0, - gd->ram_size, - PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); - - hose->region_count = 4; -} diff --git a/arch/x86/dts/crownbay.dts b/arch/x86/dts/crownbay.dts index 60da1f5..3af9cc3 100644 --- a/arch/x86/dts/crownbay.dts +++ b/arch/x86/dts/crownbay.dts @@ -90,8 +90,12 @@ pci { #address-cells = <3>; #size-cells = <2>; - compatible = "intel,pci"; + compatible = "pci-x86"; device_type = "pci"; + u-boot,dm-pre-reloc; + ranges = <0x02000000 0x0 0x40000000 0x40000000 0 0x80000000 + 0x42000000 0x0 0xc0000000 0xc0000000 0 0x20000000 + 0x01000000 0x0 0x2000 0x2000 0 0xe000>;
pcie@17,0 { #address-cells = <3>; diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 17e6a72..aa1232d 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTSTAGE_REPORT=y CONFIG_CMD_BOOTSTAGE=y CONFIG_OF_CONTROL=y CONFIG_CPU=y +CONFIG_DM_PCI=y CONFIG_SPI_FLASH=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y
Acked-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org
Applied to u-boot-x86, thanks!
Bin Meng
