[PATCH] xilinx: Remove unused ZYNQ_MAC_IN_EEPROM/ZYNQ_GEM_I2C_MAC_OFFSET entries
The commit ba74bcf3e07b ("xilinx: common: Remove zynq_board_read_rom_ethaddr()") removed zynq_board_read_rom_ethaddr() because xlnx,eeprom link via DT chosen node is no longer used. But forget to remove Kconfig entries which are used by this code only.
Signed-off-by: Michal Simek michal.simek@amd.com ---
board/xilinx/Kconfig | 17 ----------------- ...azedev_cc_v1_0_ultrazedev_som_v1_0_defconfig | 2 -- configs/syzygy_hub_defconfig | 2 -- configs/xilinx_zynqmp_virt_defconfig | 2 -- 4 files changed, 23 deletions(-)
diff --git a/board/xilinx/Kconfig b/board/xilinx/Kconfig index 746a2332ad5f..4ea78418780c 100644 --- a/board/xilinx/Kconfig +++ b/board/xilinx/Kconfig @@ -58,23 +58,6 @@ config BOOT_SCRIPT_OFFSET help Specifies distro boot script offset in NAND/QSPI/NOR flash.
-config ZYNQ_MAC_IN_EEPROM - bool "Reading MAC address from EEPROM" - help - Enable this option if your MAC address is saved in eeprom and - xlnx,eeprom DT property in chosen node points to it. - -if ZYNQ_MAC_IN_EEPROM - -config ZYNQ_GEM_I2C_MAC_OFFSET - hex "Set the I2C MAC offset" - default 0x0 - depends on DM_I2C - help - Set the MAC offset for i2C. - -endif - config CMD_FRU bool "FRU information for product" help diff --git a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig index 943b4da21d13..ce07f1633e04 100644 --- a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig +++ b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig @@ -8,8 +8,6 @@ CONFIG_DEFAULT_DEVICE_TREE="avnet-ultrazedev-cc-v1.0-ultrazedev-som-v1.0" CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y -CONFIG_ZYNQ_MAC_IN_EEPROM=y -CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0xfa CONFIG_ZYNQMP_PSU_INIT_ENABLED=y CONFIG_SYS_LOAD_ADDR=0x8000000 CONFIG_DEBUG_UART=y diff --git a/configs/syzygy_hub_defconfig b/configs/syzygy_hub_defconfig index acce95ec026c..179cb5221250 100644 --- a/configs/syzygy_hub_defconfig +++ b/configs/syzygy_hub_defconfig @@ -9,8 +9,6 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="zynq-syzygy-hub" CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y -CONFIG_ZYNQ_MAC_IN_EEPROM=y -CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0xFA CONFIG_SYS_LOAD_ADDR=0x0 CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 9696e418daf5..4732c39bdbe1 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -13,8 +13,6 @@ CONFIG_SPL=y CONFIG_ENV_OFFSET_REDUND=0x1E80000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y -CONFIG_ZYNQ_MAC_IN_EEPROM=y -CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0x20 CONFIG_CMD_FRU=y CONFIG_ZYNQMP_USB=y CONFIG_SYS_LOAD_ADDR=0x8000000
st 23. 11. 2022 v 9:27 odesÃlatel Michal Simek michal.simek@amd.com napsal:
help
default 0x0
depends on DM_I2C
help
-endif
config CMD_FRU bool "FRU information for product" help diff --git a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig index 943b4da21d13..ce07f1633e04 100644 --- a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig +++ b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig @@ -8,8 +8,6 @@ CONFIG_DEFAULT_DEVICE_TREE="avnet-ultrazedev-cc-v1.0-ultrazedev-som-v1.0" CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y -CONFIG_ZYNQ_MAC_IN_EEPROM=y -CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0xfa CONFIG_ZYNQMP_PSU_INIT_ENABLED=y CONFIG_SYS_LOAD_ADDR=0x8000000 CONFIG_DEBUG_UART=y diff --git a/configs/syzygy_hub_defconfig b/configs/syzygy_hub_defconfig index acce95ec026c..179cb5221250 100644 --- a/configs/syzygy_hub_defconfig +++ b/configs/syzygy_hub_defconfig @@ -9,8 +9,6 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="zynq-syzygy-hub" CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y -CONFIG_ZYNQ_MAC_IN_EEPROM=y -CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0xFA CONFIG_SYS_LOAD_ADDR=0x0 CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 9696e418daf5..4732c39bdbe1 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -13,8 +13,6 @@ CONFIG_SPL=y CONFIG_ENV_OFFSET_REDUND=0x1E80000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y -CONFIG_ZYNQ_MAC_IN_EEPROM=y -CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0x20 CONFIG_CMD_FRU=y CONFIG_ZYNQMP_USB=y CONFIG_SYS_LOAD_ADDR=0x8000000 -- 2.36.1
Applied. M
Michal Simek
Michal Simek
