[U-Boot] [PATCH 1/2] socfpga: add missing struct member fifo_triple_byte
socfpga_scan_manager structure was missing a data member.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com Cc: Vince Bridgers vbridger@opensource.altera.com Cc: Chin Liang See clsee@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de Cc: Wolfgang Denk wd@denx.de --- arch/arm/include/asm/arch-socfpga/scan_manager.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/include/asm/arch-socfpga/scan_manager.h b/arch/arm/include/asm/arch-socfpga/scan_manager.h index b2686d3..1155fd3 100644 --- a/arch/arm/include/asm/arch-socfpga/scan_manager.h +++ b/arch/arm/include/asm/arch-socfpga/scan_manager.h @@ -13,6 +13,7 @@ struct socfpga_scan_manager { u32 padding[2]; u32 fifo_single_byte; u32 fifo_double_byte; + u32 fifo_triple_byte; u32 fifo_quad_byte; };
Correctly increment the base address of the freeze controller. And since SYSMGR_FRZCTRL_VIOCTRL_SHIFT is not needed, remove it from the include file.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com Cc: Vince Bridgers vbridger@opensource.altera.com Cc: Chin Liang See clsee@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de Cc: Wolfgang Denk wd@denx.de --- arch/arm/cpu/armv7/socfpga/freeze_controller.c | 6 ++---- arch/arm/include/asm/arch-socfpga/freeze_controller.h | 1 - 2 files changed, 2 insertions(+), 5 deletions(-)
diff --git a/arch/arm/cpu/armv7/socfpga/freeze_controller.c b/arch/arm/cpu/armv7/socfpga/freeze_controller.c index b8c9bce..0be643c 100644 --- a/arch/arm/cpu/armv7/socfpga/freeze_controller.c +++ b/arch/arm/cpu/armv7/socfpga/freeze_controller.c @@ -38,8 +38,7 @@ void sys_mgr_frzctrl_freeze_req(void) /* Freeze channel 0 to 2 */ for (channel_id = 0; channel_id <= 2; channel_id++) { ioctrl_reg_offset = (u32)( - &freeze_controller_base->vioctrl + - (channel_id << SYSMGR_FRZCTRL_VIOCTRL_SHIFT)); + &freeze_controller_base->vioctrl + channel_id);
/* * Assert active low enrnsl, plniotri @@ -120,8 +119,7 @@ void sys_mgr_frzctrl_thaw_req(void) /* Thaw channel 0 to 2 */ for (channel_id = 0; channel_id <= 2; channel_id++) { ioctrl_reg_offset - = (u32)(&freeze_controller_base->vioctrl - + (channel_id << SYSMGR_FRZCTRL_VIOCTRL_SHIFT)); + = (u32)(&freeze_controller_base->vioctrl + channel_id);
/* * Assert active low bhniotri signal and diff --git a/arch/arm/include/asm/arch-socfpga/freeze_controller.h b/arch/arm/include/asm/arch-socfpga/freeze_controller.h index 120f20e..f19ad87 100644 --- a/arch/arm/include/asm/arch-socfpga/freeze_controller.h +++ b/arch/arm/include/asm/arch-socfpga/freeze_controller.h @@ -42,7 +42,6 @@ typedef enum { #define SYSMGR_FRZCTRL_HWCTRL_VIO1REQ_MASK 0x00000001 #define SYSMGR_FRZCTRL_HWCTRL_VIO1STATE_ENUM_FROZEN 0x2 #define SYSMGR_FRZCTRL_HWCTRL_VIO1STATE_ENUM_THAWED 0x1 -#define SYSMGR_FRZCTRL_VIOCTRL_SHIFT 0x2
void sys_mgr_frzctrl_freeze_req(void); void sys_mgr_frzctrl_thaw_req(void);
Acked-by: Pavel Machek pavel@denx.de
On Wednesday, November 26, 2014 at 07:14:33 PM, dinguyen@opensource.altera.com wrote:
Applied both. Thank you and sorry for the delay. I am now back and catching up.
Best regards, Marek Vasut
Pavel Machek
