[U-Boot] [PATCH v2] fsl-lsch3: Add FlexSPI address space in immap_lsch3
Signed-off-by: Priyanka Jain priyanka.jain@nxp.com Signed-off-by: Sriram Dash sriram.dash@nxp.com Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- v2: 1. Rename SYS_FSL_FSPI_ADDR SYS_NXP_FSPI_ADDR 2. Add mcaro for lutkey base addr and LUTa base addr
arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index b0cec74db0..a2aea18838 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -19,7 +19,13 @@ #define CONFIG_SYS_FSL_CH3_CLK_GRPA_ADDR (CONFIG_SYS_IMMR + 0x00300000) #define CONFIG_SYS_FSL_CH3_CLK_GRPB_ADDR (CONFIG_SYS_IMMR + 0x00310000) #define CONFIG_SYS_FSL_CH3_CLK_CTRL_ADDR (CONFIG_SYS_IMMR + 0x00370000) +#ifndef CONFIG_NXP_LSCH3_2 #define SYS_FSL_QSPI_ADDR (CONFIG_SYS_IMMR + 0x010c0000) +#else +#define SYS_NXP_FSPI_ADDR (CONFIG_SYS_IMMR + 0x010c0000) +#define SYS_NXP_FSPI_LUTKEY_BASE_ADDR 0x18 +#define SYS_NXP_FSPI_LUT_BASE_ADDR 0x200 +#endif #define CONFIG_SYS_FSL_ESDHC_ADDR (CONFIG_SYS_IMMR + 0x01140000) #define CONFIG_SYS_IFC_ADDR (CONFIG_SYS_IMMR + 0x01240000) #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x011C0500)
Enable AHB support for Flexspi controller interface meaning memory can be accessed via md command using absolute addresses
Signed-off-by: Yogesh Gaur yogeshnarayan.gaur@nxp.com Signed-off-by: Rajat Srivastava rajat.srivastava@nxp.com Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- v2: 1. Rename FSPI to FlexSPI in description and comments 2. s/cmd/command 3. Add macro and comments to improve readablity of code in soc.c 4. Add declaration in soc.h for fspi_ahb_init()
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 10 +++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 44 +++++++++++++++++++ .../arm/include/asm/arch-fsl-layerscape/soc.h | 7 +++ 3 files changed, 61 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 5280d33ec8..70f26973e9 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -327,6 +327,16 @@ config SYS_FSPI_AHB_INIT performed. Default LUT programmed in AHB mode is Fast Read command with 4-byte addressing enabled.
+config FSPI_AHB_EN_4BYTE + bool "Enable 4-byte Fast Read command for AHB mode" + depends on NXP_FSPI + default n + help + The default setting for FlexSPI AHB bus just supports 3-byte addressing. + But some FlexSPI flash sizes are up to 64MBytes. + This flag enables fast read command for AHB mode and modifies required + LUT to support full FlexSPI flash. + config SYS_CCI400_OFFSET hex "Offset for CCI400 base" depends on SYS_FSL_HAS_CCI400 diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 3f15cb08ff..0a0e112a88 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -640,6 +640,47 @@ void fsl_lsch2_early_init_f(void) } #endif
+#ifdef CONFIG_FSPI_AHB_EN_4BYTE +int fspi_ahb_init(void) +{ + /* Enable 4bytes address support and fast read */ + u32 *fspi_lut, lut_key, *fspi_key; + + fspi_key = (void *)SYS_NXP_FSPI_ADDR + SYS_NXP_FSPI_LUTKEY_BASE_ADDR; + fspi_lut = (void *)SYS_NXP_FSPI_ADDR + SYS_NXP_FSPI_LUT_BASE_ADDR; + + lut_key = in_be32(fspi_key); + + if (lut_key == SYS_NXP_FSPI_LUTKEY) { + /* That means the register is BE */ + out_be32(fspi_key, SYS_NXP_FSPI_LUTKEY); + /* Unlock the lut table */ + out_be32(fspi_key + 1, SYS_NXP_FSPI_LUTCR_UNLOCK); + /* Create READ LUT */ + out_be32(fspi_lut, 0x0820040c); + out_be32(fspi_lut + 1, 0x24003008); + out_be32(fspi_lut + 2, 0x00000000); + /* Lock the lut table */ + out_be32(fspi_key, SYS_NXP_FSPI_LUTKEY); + out_be32(fspi_key + 1, SYS_NXP_FSPI_LUTCR_LOCK); + } else { + /* That means the register is LE */ + out_le32(fspi_key, SYS_NXP_FSPI_LUTKEY); + /* Unlock the lut table */ + out_le32(fspi_key + 1, SYS_NXP_FSPI_LUTCR_UNLOCK); + /* Create READ LUT */ + out_le32(fspi_lut, 0x0820040c); + out_le32(fspi_lut + 1, 0x24003008); + out_le32(fspi_lut + 2, 0x00000000); + /* Lock the lut table */ + out_le32(fspi_key, SYS_NXP_FSPI_LUTKEY); + out_le32(fspi_key + 1, SYS_NXP_FSPI_LUTCR_LOCK); + } + + return 0; +} +#endif + #ifdef CONFIG_QSPI_AHB_INIT /* Enable 4bytes address support and fast read */ int qspi_ahb_init(void) @@ -688,6 +729,9 @@ int board_late_init(void) #ifdef CONFIG_QSPI_AHB_INIT qspi_ahb_init(); #endif +#ifdef CONFIG_FSPI_AHB_EN_4BYTE + fspi_ahb_init(); +#endif
return 0; } diff --git a/arch/arm/include/asm/arch-fsl-layerscape/soc.h b/arch/arm/include/asm/arch-fsl-layerscape/soc.h index 61b6e4bf07..84450c76ed 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/soc.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/soc.h @@ -102,6 +102,13 @@ void init_pfe_scfg_dcfg_regs(void); int qspi_ahb_init(void); #endif
+#ifdef CONFIG_FSPI_AHB_EN_4BYTE +#define SYS_NXP_FSPI_LUTCR_LOCK 0x00000001 +#define SYS_NXP_FSPI_LUTCR_UNLOCK 0x00000002 +#define SYS_NXP_FSPI_LUTKEY 0x5AF05AF0 +int fspi_ahb_init(void); +#endif + void cpu_name(char *name); #ifdef CONFIG_SYS_FSL_ERRATUM_A009635 void erratum_a009635(void);
v2:
- Rename FSPI to FlexSPI in description and comments
- s/cmd/command
- Add macro and comments to improve readablity of code in soc.c
- Add declaration in soc.h for fspi_ahb_init()
SYS_FSPI_AHB_INIT doesn't exist yet.
- bool "Enable 4-byte Fast Read command for AHB mode"
- depends on NXP_FSPI
- default n
- help
NXP_FSPI doesn't exist yet.
Do you have dependency I missed?
York
v2:
- s/cmd/command
- default n
- help
Please fix your patch asap.
York
-----Original Message----- From: York Sun Sent: Tuesday, November 13, 2018 3:34 AM To: Ashish Kumar ashish.kumar@nxp.com Cc: u-boot@lists.denx.de; Rajat Srivastava rajat.srivastava@nxp.com; Yogesh Narayan Gaur yogeshnarayan.gaur@nxp.com Subject: Re: [PATCH v2] fsl-lsch3: soc: Enable AHB read support for Flexspi controller
v2:
- Rename FSPI to FlexSPI in description and comments 2.
command
- default n
- help
addressing.
required
I have created v3[http://patchwork.ozlabs.org/patch/996846/] adding dependency patch information.
Regards Ashish
York
Ashish Kumar
Ashish Kumar
York Sun
