Re: [DNX#2006033142000703] [U-Boot-Users] [PATCH] Update board NetStar
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006033142000703] was created:
<snip>
Just to sync my local tree with public one. Generated against testing-NAND branch.
Signed-off-by: Ladislav Michl ladis@linux-mips.org
CHANGELOG:
- Update board NetStar Patch by Ladislav Michl, 3 Nov 2005
diff --git a/board/netstar/crcek.S b/board/netstar/crcek.S --- a/board/netstar/crcek.S +++ b/board/netstar/crcek.S @@ -13,6 +13,7 @@
- u32 - crc32
+#include <config.h> #include "crcek.h"
/** @@ -39,7 +40,7 @@ .macro crcuj, offset, size mov r0, #0 ldr r1, \offset
- ldr r2, [r1]
- ldr r2, [r1], #4 cmp r2, r0 @ no data, no problem beq 2f tst r2, #3 @ unaligned size
@@ -47,7 +48,6 @@ ldr r3, \size cmp r2, r3 @ bogus size bhi 2f
- add r1, r1, #4 do_crc32 ldr r1, [r1]
2: @@ -55,16 +55,71 @@ .endm
.macro wait, reg
- mov \reg, #0x1000
- mov \reg, #0x100000
3: subs \reg, \reg, #0x1 bne 3b
- .endm
.text .globl crcek crcek:
- b crc2_bad
- /* Enable I-cache */
- mrc p15, 0, r1, c0, c0, 0 @ read C15 ID register
- mrc p15, 0, r1, c0, c0, 1 @ read C15 Cache information register
- mrc p15, 0, r1, c1, c0, 0 @ read C15 Control register
- orr r1, r1, #0x1000 @ enable I-cache, map interrupt vector
0xffff0000
- mcr p15, 0, r1, c1, c0, 0 @ write C15 Control register
- mov r1, #0x00
- mcr p15, 0, r1, c7, c5, 0 @ Flush I-cache
- nop
- nop
- nop
- nop
- /* Setup clocking mode */
- ldr r0, MPU_CLKM_BASE @ base of CLOCK unit
- ldrh r1, [r0, #0x18] @ ARM_SYST - get reset status
- bic r1, r1, #(7 << 11) @ clear clock select
- orr r1, r1, #(2 << 11) @ set synchronous scalable
- mov r2, #0
+loop:
- cmp r2, #1 @ this loop will wait for at least 100 cycles
- streqh r1, [r0, #0x18] @ before issuing next request from MPU
- add r2, r2, #1 @ on the 1st run code is loaded into I-cache
- cmp r2, #16 @ and second run will set clocking mode
- bne loop
- nop
- /* Setup clock dividers */
- ldr r1, CKCTL_VAL
- orr r1, r1, #0x2000 @ enable DSP clock
- strh r1, [r0] @ setup clock divisors
- /* Setup DPLL to generate requested freq */
- ldr r0, DPLL1_BASE @ base of DPLL1 register
- mov r1, #0x0010 @ set PLL_ENABLE
- orr r1, r1, #0x2000 @ set IOB to new locking
- orr r1, r1, #(OMAP5910_DPLL_MUL << 7) @ setup multiplier CLKREF
- orr r1, r1, #(OMAP5910_DPLL_DIV << 5) @ setup divider CLKREF
- strh r1, [r0] @ write
+locking:
- ldrh r1, [r0] @ get DPLL value
- tst r1, #0x01
- beq locking @ while LOCK not set
</snip>
Your U-Boot support team
DENX Support System
