[PATCH] pytest:Shutdown power-supply to board after the pytest execution
From: Adarsh Babu Kalepalli opensource.kab@gmail.com
After executing the test-cases from pytest ,the board is still powered.Shutting down the board power supply at this point ,would keep the board safe.
Signed-off-by: Adarsh Babu Kalepalli opensource.kab@gmail.com ---
test/py/conftest.py | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/test/py/conftest.py b/test/py/conftest.py index 11a3f307ea..077358a37f 100644 --- a/test/py/conftest.py +++ b/test/py/conftest.py @@ -406,6 +406,13 @@ def cleanup(): """
if console: + if ((console.config.board_type != "sandbox") and (console.config.board_type != "sandbox64")): + args = [console.config.board_type, console.config.board_identity] + console.log.action('Powering Down the board') + cmd = ['u-boot-test-power-off'] + args + runner = console.log.get_runner(cmd[0], sys.stdout) + runner.run(cmd) + runner.close() console.close() if log: with log.section('Status Report', 'status_report'):
FWIW, this violates the original design of the test system. Turning the board off at the end of the test is a policy decision that not all use-cases will want, and hence not something that the test system should mandate. Instead, the intention is for the user to invoke the test system using a script that does something like:
1) Power on board. 2) Run test. 3) Power off board.
See ./doc/develop/py_testing.rst in the U-Boot source for more background info, or the following URL for an example script:
https://github.com/swarren/u-boot-ci-scripts/blob/master/test.sh
Hi Stephen,
Wasn't aware that powering OFF the board would not be a preferred choice for certain test cases. Executing python test cases on sandbox or Beaglebone Black with this power-off feature, did not cause me any issues.So,thought this would be a 'good to use' feature in the python test framework.Hence,this patch.
As recommended , will use this power-off outside the pytest environment.
Thanks , Adarsh
- Power on board.
- Run test.
- Power off board.
Stephen Warren
