[PATCH v2] imx8mq: Generate a single bootable flash.bin again
All i.MX8MQ boards have been converted to binman, which makes it necessary to flash both flash.bin and u-boot.itb to get a bootable system. Prior to the conversion, only flash.bin was needed.
Such new requirement breaks existing distro mechanisms to generate the final binary because the extra u-boot.itb is now required.
Generate a final flash.bin that can be used again as a single bootable binary to keep the original behavior.
After this change the SPL binary is called spl.bin, which is a more descriptive name for its purpose, and can still be used standalone (for example, for secure boot purposes).
Also update imx8mq_evk.rst to remove the u-boot.itb copy step.
This is a cherry-pick of 028abfd9b157 ("imx8mm-evk: Generate a single bootable flash.bin again") adjusted to apply to i.MX8MQ.
Signed-off-by: Patrick Wildt patrick@blueri.se --- arch/arm/dts/imx8mq-u-boot.dtsi | 19 ++++++++++++++++++- arch/arm/mach-imx/imx8m/imximage.cfg | 2 +- doc/board/nxp/imx8mq_evk.rst | 1 - 3 files changed, 19 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/imx8mq-u-boot.dtsi b/arch/arm/dts/imx8mq-u-boot.dtsi index 2c10e9b645..8a6075c77b 100644 --- a/arch/arm/dts/imx8mq-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-u-boot.dtsi @@ -50,7 +50,9 @@ }; };
- flash { + spl { + filename = "spl.bin"; + mkimage { args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000";
@@ -119,4 +121,19 @@ }; }; }; + + imx-boot { + filename = "flash.bin"; + pad-byte = <0x00>; + + spl: blob-ext@1 { + offset = <0x0>; + filename = "spl.bin"; + }; + + uboot: blob-ext@2 { + offset = <0x57c00>; + filename = "u-boot.itb"; + }; + }; }; diff --git a/arch/arm/mach-imx/imx8m/imximage.cfg b/arch/arm/mach-imx/imx8m/imximage.cfg index 9c6eaf0a6d..2a3f959183 100644 --- a/arch/arm/mach-imx/imx8m/imximage.cfg +++ b/arch/arm/mach-imx/imx8m/imximage.cfg @@ -8,4 +8,4 @@ FIT BOOT_FROM sd SIGNED_HDMI signed_hdmi.bin -LOADER mkimage.flash.mkimage 0x7e1000 +LOADER u-boot-spl-ddr.bin 0x7e1000 diff --git a/doc/board/nxp/imx8mq_evk.rst b/doc/board/nxp/imx8mq_evk.rst index 92eeda79aa..aa1ecfb47a 100644 --- a/doc/board/nxp/imx8mq_evk.rst +++ b/doc/board/nxp/imx8mq_evk.rst @@ -50,7 +50,6 @@ Burn the flash.bin to MicroSD card offset 33KB: .. code-block:: bash
$sudo dd if=flash.bin of=/dev/sd[x] bs=1024 seek=33 conv=notrunc - $sudo dd if=u-boot.itb of=/dev/sd[x] bs=1024 seek=384 conv=notrunc
Boot ----
Thanks for the updated commit log:
Reviewed-by: Fabio Estevam festevam@denx.de
Fabio Estevam
Patrick Wildt
