[PATCH v1] arm: dts: imx8mn_var_som: Set atf-bl31 blob entry type
Configure binman ATF blob entry type to use the path from the BL31 environment variable, if defined.
Signed-off-by: Ariel D'Alessandro ariel.dalessandro@collabora.com --- arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi index ce475885df6..6e37622cca7 100644 --- a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi @@ -200,7 +200,7 @@
atf_blob { filename = "bl31.bin"; - type = "blob-ext"; + type = "atf-bl31"; }; };
Configure binman ATF blob entry type to use the path from the BL31 environment variable, if defined. Signed-off-by: Ariel D'Alessandro ariel.dalessandro@collabora.com
Best regards, Stefano Babic
Ariel D'Alessandro
sbabic@denx.de
