Re: [U-Boot] [PATCH] drivers: net: phy: atheros: apply the previous register setting for AR8031 to fix the voltage peak issue
-----Original Message----- From: Sekhar Nori [mailto:nsekhar@ti.com] Sent: Monday, February 6, 2017 12:53 AM To: Ken.Lin; ken <Ken Lin>; sbabic@denx.de Cc: u-boot@lists.denx.de; martin.donnelly@ge.com; Peter.Chiang; Peter.Stretz; akshay.bhat@timesys.com; joe.hershberger@ni.com; albert.u.uboot@aribaud.net Subject: Re: [PATCH] drivers: net: phy: atheros: apply the previous register setting for AR8031 to fix the voltage peak issue
On Saturday 04 February 2017 12:26 AM, Ken.Lin wrote:
-----Original Message----- From: Sekhar Nori [mailto:nsekhar@ti.com] Sent: Thursday, February 2, 2017 9:44 PM To: ken <Ken Lin>; sbabic@denx.de Cc: u-boot@lists.denx.de; martin.donnelly@ge.com; Ken.Lin; Peter.Chiang; Peter.Stretz; akshay.bhat@timesys.com; joe.hershberger@ni.com; albert.u.uboot@aribaud.net Subject: Re: [PATCH] drivers: net: phy: atheros: apply the previous register setting for AR8031 to fix the voltage peak issue
On Friday 03 February 2017 02:53 AM, ken <Ken Lin> wrote:
Apply the previous setting for the reserved bits in SetDes Test and System Mode Control register to avoid the voltage peak issue while we do the IEEE PHY comformance test
Signed-off-by: ken Lin ken.lin@advantech.com Tested on Advantech DMS-BA16 board Tested-by: Ken Lin ken.lin@advantech.com
drivers/net/phy/atheros.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index b34cdd3d87..82fe228604 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -28,6 +28,8 @@ static int ar8021_config(struct phy_device *phydev)
static int ar8031_config(struct phy_device *phydev) {
- int regval;
- if (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID || phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) { phy_write(phydev, MDIO_DEVAD_NONE,
AR803x_PHY_DEBUG_ADDR_REG, @@
-44,6 +46,10 @@ static int ar8031_config(struct phy_device *phydev) AR803x_RGMII_RX_CLK_DLY); }
AR803x_PHY_DEBUG_ADDR_REG, AR803x_DEBUG_REG_5);
regval = phy_read(phydev, MDIO_DEVAD_NONE,
AR803x_PHY_DEBUG_DATA_REG);
AR803x_PHY_DEBUG_DATA_REG,
- regval | 0x3C47);
I thought I had responded to this, but probably the mail did not go through.
What you have defeats the purpose of reading back the register. The idea of reading back was to avoid using any hardcoded reset state of the
register.
Also, your patch does nothing to the existing code writing to AR803x_DEBUG_REG_5. So you have two unneeded writes now. Does the following work for you (not compiled or tested).
The register setting would turn out to be 0x3D47 on our project boards and
our signal measurement results show the patch (v2 version, https://patchwork.ozlabs.org/patch/723461/)) could fix the voltage peak issue.
The proposed solution is to follow the implementation in previous commits,
which include the reserved bits settings in SerDes Test and System Mode Control register.
So what does the register setting turn out to be with my patch below ?
What are the "previous commits" you refer to ?
When I dig around the commit history, I could find the related config change info for AR8031. The original setting for the reserved bits in SerDes Test and System Mode Control register are not 0 (0x3C47).
commit d584c68ce0f5bf2f430ccfb2ba00bd506206fb91 Author: Fabio Estevam fabio.estevam@nxp.com Date: Tue Jan 5 17:02:52 2016 -0200
phy: atheros: Use ar8035_config for AR8031
Commit 08ad9b068afb88 (" ar8031: modify the config func of ar8031 to ar8021_config") selected 'ar8021_config' as the configuration function for AR8031.
The correct would be to use 'ar8035_config' instead as AR8031/AR8035 have the same programming model and even share the same phy driver in the linux kernel: drivers/net/phy/at803x.c.
Tested on a mx6qsabresd and wandboard, which now can work without any PHY setup code in the board files.
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com Acked-by: Joe Hershberger joe.hershberger@ni.com
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index d509e30..ba57b1a 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -51,7 +51,7 @@ static struct phy_driver AR8031_driver = { .uid = 0x4dd074, .mask = 0xffffffef, .features = PHY_GBIT_FEATURES, - .config = ar8021_config, + .config = ar8035_config, .startup = genphy_startup, .shutdown = genphy_shutdown, };
commit ce412b79e72557702185443501478646a938b5fe Author: Mugunthan V N mugunthanvnm@ti.com Date: Thu Oct 13 19:33:36 2016 +0530
drivers: net: phy: atheros: add separate config for AR8031
In the current driver implementation, config() callback is common for AR8035 and AR8031 phy. In config() callback, driver tries to configure MMD Access Control Register and MMD Access Address Data Register unconditionally for both phy versions which leads to auto negotiation failure in AM335x EVMsk second port which uses AR8031 Giga bit RGMII phy. Fixing this by adding separate config for AR8031 phy.
Reviewed-by: Sekhar Nori nsekhar@ti.com Signed-off-by: Mugunthan V N mugunthanvnm@ti.com Acked-by: Joe Hershberger joe.hershberger@ni.com
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 694a338..b34cdd3 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c
@@ -8,6 +8,15 @@ */ #include <phy.h>
+#define AR803x_PHY_DEBUG_ADDR_REG 0x1d +#define AR803x_PHY_DEBUG_DATA_REG 0x1e + +#define AR803x_DEBUG_REG_5 0x5 +#define AR803x_RGMII_TX_CLK_DLY 0x100 + +#define AR803x_DEBUG_REG_0 0x0 +#define AR803x_RGMII_RX_CLK_DLY 0x8000 + static int ar8021_config(struct phy_device *phydev) { phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); @@ -17,6 +26,32 @@ static int ar8021_config(struct phy_device *phydev) return 0; }
+static int ar8031_config(struct phy_device *phydev) +{ + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID || + phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) { + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, + AR803x_DEBUG_REG_5); + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, + AR803x_RGMII_TX_CLK_DLY); + } + + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID || + phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) { + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, + AR803x_DEBUG_REG_0); + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, + AR803x_RGMII_RX_CLK_DLY); + } + + phydev->supported = phydev->drv->features; + + genphy_config_aneg(phydev); + genphy_restart_aneg(phydev); + + return 0; +} +
When I checked the NXP u-boot codebase (git://git.freescale.com/imx/uboot-imx.git, branch l5.1.1_2.1.0-ga), It seems NXP worked with the PHY vendors and set the reserved bits to 0x3D47.
commit 9082eeac5de1335d663016668c9b89c290f5c79b Author: Andy Fleming afleming@freescale.com Date: Thu Apr 7 21:56:05 2011 -0500 phylib: Add a bunch of PHY drivers from tsec The tsec driver had a bunch of PHY drivers already written. This converts them all into PHY Lib drivers, and serves as the first set of PHY drivers for PHY Lib. While doing that, cleaned up a number of magic numbers (though not all of them, as PHY vendors like to keep their numbers as magical as possible). Also, noticed that almost all of the vitesse/cicada PHYs had the same config/parse/startup functions, so those have been collapsed into one. Signed-off-by: Andy Fleming afleming@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org Acked-by: Detlev Zundel dzu@denx.de
+/* + * Atheros PHY drivers + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + * Copyright 2011 Freescale Semiconductor, Inc. + * author Andy Fleming + * + */ +#include <phy.h> + +static int ar8021_config(struct phy_device *phydev) +{ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x3D47); + + return 0; +} + +struct phy_driver AR8021_driver = { + .name = "AR8021", + .uid = 0x4dd040, + .mask = 0xfffff0, + .features = PHY_GBIT_FEATURES, + .config = ar8021_config, + .startup = genphy_startup, + .shutdown = genphy_shutdown, +}; + +int phy_atheros_init(void) +{ + phy_register(&AR8021_driver); + + return 0; +}
commit 626ee1e32eeb4fc89e0f406d6067ed6e71d8302f Author: Shengzhou Liu Shengzhou.Liu@freescale.com Date: Thu Aug 8 16:33:35 2013 +0800 phylib: update atheros ar803x phy As AR8031 and AR8033 have same PHY ID 0x4dd074, they use the common driver. Currently AR8031_driver didn't work for AR8033, hence updated it to have it work on AR8031/AR8033. Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 0f2dfd6..7a1453f 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -48,11 +48,11 @@ static struct phy_driver AR8021_driver = { }; static struct phy_driver AR8031_driver = { - .name = "AR8031", + .name = "AR8031/AR8033", .uid = 0x4dd074, .mask = 0xfffff0, .features = PHY_GBIT_FEATURES, - .config = genphy_config, + .config = ar8021_config, .startup = genphy_startup, .shutdown = genphy_shutdown, };
Thanks, Sekhar
---8<--- diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index b34cdd3d87dc..aff9eb3d18c6 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -28,12 +28,16 @@ static int ar8021_config(struct phy_device *phydev)
- int regval;
phy_write(phydev, MDIO_DEVAD_NONE,AR803x_PHY_DEBUG_DATA_REG);
regval | AR803x_RGMII_TX_CLK_DLY);
Thanks, Sekhar
-- This message has been scanned for viruses and dangerous content by MailScanner, and is believed to be clean.
Thanks for the references to the commits. You left out answering my question about what register settings you see with my patch.
I have included another patch now with some debug enabled. Can you apply this patch to latest u-boot master, run on your board and send me the log ? Here is what I see on AM335x EVM-SK:
U-Boot 2017.03-rc1-00058-g1216f9a0851f (Feb 07 2017 - 13:55:38 +0530)
CPU : AM335X-GP rev 1.0 Model: TI AM335x EVM-SK DRAM: 256 MiB NAND: 0 MiB MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 reading uboot.env ERROR: No USB device found
at ../drivers/usb/gadget/ether.c:2709/usb_ether_init() Net: ar8031_config: value read back 0x2c47, written: 0x2d47 eth0: ethernet@4a100000 Hit any key to stop autoboot: 0
Thanks, Sekhar
---8<--- diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index b34cdd3d87dc..5c0a36676ce9 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -28,12 +28,18 @@ static int ar8021_config(struct phy_device *phydev)
static int ar8031_config(struct phy_device *phydev) { + int regval; + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID || phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) { phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, AR803x_DEBUG_REG_5); + regval = phy_read(phydev, MDIO_DEVAD_NONE, + AR803x_PHY_DEBUG_DATA_REG); + printf("%s: value read back 0x%x, written: 0x%x\n", + __func__, regval, regval | AR803x_RGMII_TX_CLK_DLY); phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, - AR803x_RGMII_TX_CLK_DLY); + regval | AR803x_RGMII_TX_CLK_DLY); }
Thanks, Sekhar
int regval;
regval | AR803x_RGMII_TX_CLK_DLY); } if (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID ||
Hi ,
Your patch doesn't work for the issue case on our project board. I added more debug messages for your reference.
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 3304fddc69..e7a8680a7f 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -7,6 +7,7 @@ * * SPDX-License-Identifier: GPL-2.0+ */ +#define DEBUG
#include <common.h> #include <dm.h> diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index b34cdd3d87..0d9380f833 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -28,12 +28,22 @@ static int ar8021_config(struct phy_device *phydev)
static int ar8031_config(struct phy_device *phydev) { + int regval; + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID || phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) { phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, AR803x_DEBUG_REG_5); + + regval = phy_read(phydev, MDIO_DEVAD_NONE, + AR803x_PHY_DEBUG_DATA_REG); + + printf("%s: value read back 0x%x, written: 0x%x\n", + __func__, regval, regval | +AR803x_RGMII_TX_CLK_DLY); + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, - AR803x_RGMII_TX_CLK_DLY); + regval | AR803x_RGMII_TX_CLK_DLY); }
if (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID || @@ -44,6 +54,21 @@ static int ar8031_config(struct phy_device *phydev) AR803x_RGMII_RX_CLK_DLY); }
+ +#if 1 + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, + AR803x_DEBUG_REG_5); + + regval = phy_read(phydev, MDIO_DEVAD_NONE, + AR803x_PHY_DEBUG_DATA_REG); +
U-Boot 2017.03-rc1-00057-gc83a824e62-dirty (Feb 08 2017 - 02:54:43 +0800)
CPU: Freescale i.MX6D rev1.5 at 792 MHz Reset cause: POR BOARD: General Electric B850v3 I2C: ready DRAM: 2 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 SF: Detected n25q32 with page size 256 Bytes, erase size 4 KiB, total 4 MiB *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial Net: eth_init: fec_probe(bd, -1, 4) @ 02188000 fec_mii_setspeed: mii_speed 0000001a fec_mdio_read: phy: 04 reg:02 val:0x4d fec_mdio_read: phy: 04 reg:03 val:0xd074 fec_mii_setspeed: mii_speed 0000001a fec_mdio_write: phy: 04 reg:00 val:0x8000 fec_mdio_read: phy: 04 reg:00 val:0x0 fec_mdio_write: phy: 04 reg:0d val:0x7 fec_mdio_write: phy: 04 reg:0e val:0x8016 fec_mdio_write: phy: 04 reg:0d val:0x4007 fec_mdio_write: phy: 04 reg:0e val:0x18 fec_mdio_write: phy: 04 reg:1d val:0x5 fec_mdio_write: phy: 04 reg:1e val:0x100 fec_mdio_write: phy: 04 reg:1d val:0x5 fec_mdio_read: phy: 04 reg:1e val:0x100 ar8031_config check: value read back 0x100, written: 0x100 fec_mdio_read: phy: 04 reg:04 val:0x1de1 fec_mdio_write: phy: 04 reg:04 val:0x11e1 fec_mdio_read: phy: 04 reg:01 val:0x7949 fec_mdio_read: phy: 04 reg:09 val:0x200 fec_mdio_write: phy: 04 reg:09 val:0x300 fec_mdio_read: phy: 04 reg:00 val:0x0 fec_mdio_write: phy: 04 reg:00 val:0x1200 fec_mdio_read: phy: 04 reg:00 val:0x1000 fec_mdio_write: phy: 04 reg:00 val:0x1200 FEC [PRIME] Error: FEC address not set.
Hit any key to stop autoboot: 1 0 =>
Thanks, Sekhar
int regval;
Hi ,
Hmm, so in effect you are forced to use the magic value of 0x3c47 as the reset default when actually it is 0x100 on your board. And there is no backing public documentation on why the reset default should be 0x3c47. And whether it will work for all boards that use this PHY.
Thats pretty unmaintainable in my opinion. If this value does not work for the next person that comes along, we will be in trouble again.
I guess the best thing that can be done at this point is to use this magic reset default value in a board specific way. By specifying it using device-tree, perhaps. I would wait for some feedback from Joe Hershberger though.
BTW, do you have the same problem in kernel ? Because AFAICS, even drivers/net/phy/at803x.c in kernel does not have any such provision for magic reset default values.
Thanks, Sekhar
Thanks, Sekhar
int regval;
Hi ,
Well that's quite unfortunate.
I think we can wait until someone else says they have a problem with this value before making it a board option.
I'm interested to know this too. Is the kernel depending on the bootloader to set this and it just avoids changing it?
Thanks, Sekhar _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On Wed, Feb 8, 2017 at 10:47 AM, Joe Hershberger joe.hershberger@gmail.com wrote:
> The register setting would turn out to be 0x3D47 on our project boards and our signal measurement results show the patch (v2 version, https://patchwork.ozlabs.org/patch/723461/)) could fix the voltage peak issue. > The proposed solution is to follow the implementation in previous commits, which include the reserved bits settings in SerDes Test and System Mode Control register.
Thanks, Sekhar
int regval;
Hi ,
Yes, I think so.Here are the code snippets in drivers/net/phy/at803x.c. I found it wouldn't change the bootloader setting when I dumped the value in kernel.
static int at803x_debug_reg_mask(struct phy_device *phydev, u16 reg, u16 clear, u16 set) { u16 val; int ret;
ret = at803x_debug_reg_read(phydev, reg); if (ret < 0) return ret;
val = ret & 0xffff; val &= ~clear; val |= set;
return phy_write(phydev, AT803X_DEBUG_DATA, val); }
static inline int at803x_enable_tx_delay(struct phy_device *phydev) { return at803x_debug_reg_mask(phydev, AT803X_DEBUG_REG_5, 0, AT803X_DEBUG_TX_CLK_DLY_EN); }
On Wed, Feb 8, 2017 at 5:35 PM, Yung-Ching LIN yungching0725@gmail.com wrote:
>> The register setting would turn out to be 0x3D47 on our project boards and > our signal measurement results show the patch (v2 version, > https://patchwork.ozlabs.org/patch/723461/)) could fix the voltage peak issue. >> The proposed solution is to follow the implementation in previous commits, > which include the reserved bits settings in SerDes Test and System Mode Control > register.
> So what does the register setting turn out to be with my patch below ? > > What are the "previous commits" you refer to ?
Thanks, Sekhar
int regval;
Your read-modify-write patch makes sense to me at some point. I added some debug messages in the u-boot source. ar8031_config gets called after the board specific mx6_rgmii_rework callback In our board test case, the phydev interface uses PHY_INTERFACE_MODE_RGMII, so it won't hit the condition and run the code statements you implemented.
U-Boot 2016.11-g922cf19526-dirty (Mar 03 2017 - 07:13:39 +0800)
CPU: Freescale i.MX6D rev1.5 at 792 MHz Reset cause: POR BOARD: General Electric B850v3 I2C: ready DRAM: 2 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 SF: Detected N25Q32 with page size 256 Bytes, erase size 4 KiB, total 4 MiB *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial Net: eth_init: fec_probe(bd, -1, 4) @ 02188000 fec_mii_setspeed: mii_speed 0000001a fec_mdio_read: phy: 04 reg:02 val:0x4d fec_mdio_read: phy: 04 reg:03 val:0xd074 fec_mii_setspeed: mii_speed 0000001a fec_mdio_write: phy: 04 reg:00 val:0x8000 fec_mdio_read: phy: 04 reg:00 val:0x0 ++mx6_rgmii_rework fec_mdio_write: phy: 04 reg:0d val:0x7 fec_mdio_write: phy: 04 reg:0e val:0x8016 fec_mdio_write: phy: 04 reg:0d val:0x4007 fec_mdio_write: phy: 04 reg:0e val:0x18 fec_mdio_write: phy: 04 reg:1d val:0x5 fec_mdio_write: phy: 04 reg:1e val:0x3d47 --mx6_rgmii_rework ++ar8031_config fec_mdio_read: phy: 04 reg:04 val:0x1de1 fec_mdio_write: phy: 04 reg:04 val:0x11e1 fec_mdio_read: phy: 04 reg:01 val:0x7949 fec_mdio_read: phy: 04 reg:09 val:0x200 fec_mdio_write: phy: 04 reg:09 val:0x300 fec_mdio_read: phy: 04 reg:00 val:0x0 fec_mdio_write: phy: 04 reg:00 val:0x1200 fec_mdio_read: phy: 04 reg:00 val:0x1000 fec_mdio_write: phy: 04 reg:00 val:0x1200 --ar8031_config FEC [PRIME] Error: FEC address not set.
Sorry for causing the confusion. Our board specific requirement(issue) for setting proper register value could be done in the board file. I resubmitted the patch at https://lists.denx.de/pipermail/u-boot/2017-February/281894.html
ret = at803x_debug_reg_read(phydev, reg); if (ret < 0) return ret; val = ret & 0xffff; val &= ~clear; val |= set; return phy_write(phydev, AT803X_DEBUG_DATA, val);
Joe Hershberger
Ken.Lin
Sekhar Nori
Yung-Ching LIN
