[U-Boot] [PATCH] a320evb: fix udelay / __udelay confusion
Fix the following compiler problems:
arch/arm/cpu/arm920t/a320/liba320.a(timer.o): In function `udelay': /home/wd/git/u-boot/work/arch/arm/cpu/arm920t/a320/timer.c:160: multiple definition of `udelay' lib/libgeneric.a(time.o):/home/wd/git/u-boot/work/lib/time.c:34: first defined here lib/libgeneric.a(time.o): In function `udelay': time.c:(.text+0x1c): undefined reference to `__udelay'
Signed-off-by: Wolfgang Denk wd@denx.de --- arch/arm/cpu/arm920t/a320/timer.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/arm920t/a320/timer.c b/arch/arm/cpu/arm920t/a320/timer.c index d69dbff..d2e316f 100644 --- a/arch/arm/cpu/arm920t/a320/timer.c +++ b/arch/arm/cpu/arm920t/a320/timer.c @@ -156,7 +156,7 @@ void set_timer(ulong t) }
/* delay x useconds AND preserve advance timestamp value */ -void udelay(unsigned long usec) +void __udelay(unsigned long usec) { long tmo = usec * (TIMER_CLOCK / 1000) / 1000; unsigned long now, last = readl(&tmr->timer3_counter);
