[U-Boot] [PATCH 1/4] Make pixis_set_sgmii more general to support MPC85xx boards.
The pixis sgmii command depend on the FPGA support on the board, some 85xx boards support SGMII riser card but did not support this command, define CONFIG_PIXIS_SGMII_CMD for those boards which support the sgmii command.
Not like 8544, 8572 has 4 eTsec so that the other two's pixis bits are not supported by 8544. Therefor, define PIXIS_VSPEED2_MASK and PIXIS_VCFGEN1_MASK in header file for both boards.
Signed-off-by: Liu Yu yu.liu@freescale.com --- board/freescale/common/pixis.c | 22 +++++++++++++++++++--- include/configs/MPC8544DS.h | 3 +++ 2 files changed, 22 insertions(+), 3 deletions(-)
diff --git a/board/freescale/common/pixis.c b/board/freescale/common/pixis.c index b5a0e84..978a255 100644 --- a/board/freescale/common/pixis.c +++ b/board/freescale/common/pixis.c @@ -283,7 +283,7 @@ U_BOOT_CMD( "diswd - Disable watchdog timer \n", NULL);
-#ifdef CONFIG_FSL_SGMII_RISER +#ifdef CONFIG_PIXIS_SGMII_CMD int pixis_set_sgmii(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { int which_tsec = -1; @@ -295,17 +295,33 @@ int pixis_set_sgmii(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) which_tsec = simple_strtoul(argv[1], NULL, 0);
switch (which_tsec) { +#ifdef CONFIG_TSEC1 case 1: mask = PIXIS_VSPEED2_TSEC1SER; switch_mask = PIXIS_VCFGEN1_TSEC1SER; break; +#endif +#ifdef CONFIG_TSEC2 + case 2: + mask = PIXIS_VSPEED2_TSEC2SER; + switch_mask = PIXIS_VCFGEN1_TSEC2SER; + break; +#endif +#ifdef CONFIG_TSEC3 case 3: mask = PIXIS_VSPEED2_TSEC3SER; switch_mask = PIXIS_VCFGEN1_TSEC3SER; break; +#endif +#ifdef CONFIG_TSEC4 + case 4: + mask = PIXIS_VSPEED2_TSEC4SER; + switch_mask = PIXIS_VCFGEN1_TSEC4SER; + break; +#endif default: - mask = PIXIS_VSPEED2_TSEC1SER | PIXIS_VSPEED2_TSEC3SER; - switch_mask = PIXIS_VCFGEN1_TSEC1SER | PIXIS_VCFGEN1_TSEC3SER; + mask = PIXIS_VSPEED2_MASK; + switch_mask = PIXIS_VCFGEN1_MASK; break; }
diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index b650874..76e5fb4 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -202,6 +202,8 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define PIXIS_VSPEED2_TSEC3SER 0x1 #define PIXIS_VCFGEN1_TSEC1SER 0x20 #define PIXIS_VCFGEN1_TSEC3SER 0x40 +#define PIXIS_VSPEED2_MASK (PIXIS_VSPEED2_TSEC1SER|PIXIS_VSPEED2_TSEC3SER) +#define PIXIS_VCFGEN1_MASK (PIXIS_VCFGEN1_TSEC1SER|PIXIS_VCFGEN1_TSEC3SER)
/* define to use L1 as initial stack */ @@ -374,6 +376,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_TSEC3 1 #define CONFIG_TSEC3_NAME "eTSEC3"
+#define CONFIG_PIXIS_SGMII_CMD #define CONFIG_FSL_SGMII_RISER 1 #define SGMII_RISER_PHY_OFFSET 0x1c
This patch based on Andy's work. Including command 'pixis_set_sgmii' support.
Signed-off-by: Liu Yu yu.liu@freescale.com --- board/freescale/mpc8572ds/mpc8572ds.c | 48 +++++++++++++++++++++++++++++++++ include/configs/MPC8572DS.h | 24 ++++++++++++++++ 2 files changed, 72 insertions(+), 0 deletions(-)
diff --git a/board/freescale/mpc8572ds/mpc8572ds.c b/board/freescale/mpc8572ds/mpc8572ds.c index 70b548b..0520137 100644 --- a/board/freescale/mpc8572ds/mpc8572ds.c +++ b/board/freescale/mpc8572ds/mpc8572ds.c @@ -32,8 +32,10 @@ #include <miiphy.h> #include <libfdt.h> #include <fdt_support.h> +#include <tsec.h>
#include "../common/pixis.h" +#include "../common/sgmii_riser.h"
#if defined(CONFIG_DDR_ECC) && !defined(CONFIG_ECC_INIT_VIA_DDRCONTROLLER) extern void ddr_enable_ecc(unsigned int dram_size); @@ -521,6 +523,52 @@ unsigned long get_board_ddr_clk(ulong dummy) } #endif
+#ifdef CONFIG_TSEC_ENET +int board_eth_init(bd_t *bis) +{ + struct tsec_info_struct tsec_info[4]; + volatile ccsr_gur_t *gur = (void *)(CFG_MPC85xx_GUTS_ADDR); + int num = 0; + +#ifdef CONFIG_TSEC1 + SET_STD_TSEC_INFO(tsec_info[num], 1); + if (!(gur->pordevsr & MPC85xx_PORDEVSR_SGMII1_DIS)) + tsec_info[num].flags |= TSEC_SGMII; + num++; +#endif +#ifdef CONFIG_TSEC2 + SET_STD_TSEC_INFO(tsec_info[num], 2); + if (!(gur->pordevsr & MPC85xx_PORDEVSR_SGMII2_DIS)) + tsec_info[num].flags |= TSEC_SGMII; + num++; +#endif +#ifdef CONFIG_TSEC3 + SET_STD_TSEC_INFO(tsec_info[num], 3); + if (!(gur->pordevsr & MPC85xx_PORDEVSR_SGMII3_DIS)) + tsec_info[num].flags |= TSEC_SGMII; + num++; +#endif +#ifdef CONFIG_TSEC4 + SET_STD_TSEC_INFO(tsec_info[num], 4); + if (!(gur->pordevsr & MPC85xx_PORDEVSR_SGMII4_DIS)) + tsec_info[num].flags |= TSEC_SGMII; + num++; +#endif + + if (!num) { + printf("No TSECs initialized\n"); + + return 0; + } + + fsl_sgmii_riser_init(tsec_info, num); + + tsec_eth_init(bis, tsec_info, num); + + return 0; +} +#endif + #if defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) { diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index d7e3a88..febc755 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -238,6 +238,22 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define PIXIS_VCLKH 0x19 /* VELA VCLKH register */ #define PIXIS_VCLKL 0x1A /* VELA VCLKL register */ #define CFG_PIXIS_VBOOT_MASK 0xc0 +#define PIXIS_VSPEED2_TSEC1SER 0x8 +#define PIXIS_VSPEED2_TSEC2SER 0x4 +#define PIXIS_VSPEED2_TSEC3SER 0x2 +#define PIXIS_VSPEED2_TSEC4SER 0x1 +#define PIXIS_VCFGEN1_TSEC1SER 0x20 +#define PIXIS_VCFGEN1_TSEC2SER 0x20 +#define PIXIS_VCFGEN1_TSEC3SER 0x20 +#define PIXIS_VCFGEN1_TSEC4SER 0x20 +#define PIXIS_VSPEED2_MASK (PIXIS_VSPEED2_TSEC1SER \ + | PIXIS_VSPEED2_TSEC2SER \ + | PIXIS_VSPEED2_TSEC3SER \ + | PIXIS_VSPEED2_TSEC4SER) +#define PIXIS_VCFGEN1_MASK (PIXIS_VCFGEN1_TSEC1SER \ + | PIXIS_VCFGEN1_TSEC2SER \ + | PIXIS_VCFGEN1_TSEC3SER \ + | PIXIS_VCFGEN1_TSEC4SER)
/* define to use L1 as initial stack */ #define CONFIG_L1_INIT_RAM @@ -403,6 +419,14 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_TSEC4 1 #define CONFIG_TSEC4_NAME "eTSEC4"
+#define CONFIG_PIXIS_SGMII_CMD +#define CONFIG_FSL_SGMII_RISER 1 +#define SGMII_RISER_PHY_OFFSET 0x1c + +#ifdef CONFIG_FSL_SGMII_RISER +#define CFG_TBIPA_VALUE 0x10 /* avoid conflict with eTSEC4 paddr */ +#endif + #define TSEC1_PHY_ADDR 0 #define TSEC2_PHY_ADDR 1 #define TSEC3_PHY_ADDR 2
Signed-off-by: Jason Jin Jason.jin@freescale.com --- board/freescale/mpc8536ds/mpc8536ds.c | 43 +++++++++++++++++++++++++++++++++ include/configs/MPC8536DS.h | 3 ++ 2 files changed, 46 insertions(+), 0 deletions(-)
diff --git a/board/freescale/mpc8536ds/mpc8536ds.c b/board/freescale/mpc8536ds/mpc8536ds.c index 8216c70..3401133 100644 --- a/board/freescale/mpc8536ds/mpc8536ds.c +++ b/board/freescale/mpc8536ds/mpc8536ds.c @@ -34,8 +34,11 @@ #include <libfdt.h> #include <spd_sdram.h> #include <fdt_support.h> +#include <tsec.h> +#include <netdev.h>
#if defined(CONFIG_DDR_ECC) && !defined(CONFIG_ECC_INIT_VIA_DDRCONTROLLER) extern void ddr_enable_ecc(unsigned int dram_size); @@ -608,6 +611,46 @@ get_board_ddr_clk(ulong dummy) } #endif
+int board_eth_init(bd_t *bis) +{ +#ifdef CONFIG_TSEC_ENET + struct tsec_info_struct tsec_info[2]; + volatile ccsr_gur_t *gur = (void *)(CFG_MPC85xx_GUTS_ADDR); + int num = 0; + uint devdisr = gur->devdisr; + uint sdrs2_io_sel = + (gur->pordevsr & MPC85xx_PORDEVSR_SRDS2_IO_SEL) >> 27; + +#ifdef CONFIG_TSEC1 + SET_STD_TSEC_INFO(tsec_info[num], 1); + if ((sdrs2_io_sel == 4) || (sdrs2_io_sel == 6)) { + tsec_info[num].phyaddr = 0; + tsec_info[num].flags |= TSEC_SGMII; + } + num++; +#endif +#ifdef CONFIG_TSEC3 + SET_STD_TSEC_INFO(tsec_info[num], 3); + if (sdrs2_io_sel == 4) { + tsec_info[num].phyaddr = 1; + tsec_info[num].flags |= TSEC_SGMII; + } + num++; +#endif + + if (!num) { + printf("No TSECs initialized\n"); + return 0; + } + + if ((sdrs2_io_sel == 4) || (sdrs2_io_sel == 6)) + fsl_sgmii_riser_init(tsec_info, num); + + tsec_eth_init(bis, tsec_info, num); +#endif + return pci_eth_init(bis); +} + #if defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 2578bef..365818c 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -428,6 +428,9 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_TSEC3 1 #define CONFIG_TSEC3_NAME "eTSEC3"
+#define CONFIG_FSL_SGMII_RISER 1 +#define SGMII_RISER_PHY_OFFSET 0x1c + #define TSEC1_PHY_ADDR 1 /* TSEC1 -> PHY1 */ #define TSEC3_PHY_ADDR 0 /* TSEC3 -> PHY0 */
SGMII and SATA share the serdes on MPC8536 CPU, When SATA disabled and the driver still try to access the SATA registers, the cpu will hangup. This patch try to fix this by reading the serdes status before the SATA initialize.
Signed-off-by: Jason Jin Jason.jin@freescale.com --- board/freescale/mpc8536ds/mpc8536ds.c | 12 ++++++++++++ lib_ppc/board.c | 16 ++++++++++++++-- 2 files changed, 26 insertions(+), 2 deletions(-)
diff --git a/board/freescale/mpc8536ds/mpc8536ds.c b/board/freescale/mpc8536ds/mpc8536ds.c index 3401133..37d4b61 100644 --- a/board/freescale/mpc8536ds/mpc8536ds.c +++ b/board/freescale/mpc8536ds/mpc8536ds.c @@ -651,6 +651,18 @@ int board_eth_init(bd_t *bis) return pci_eth_init(bis); }
+int is_sata_supported() +{ + volatile ccsr_gur_t *gur = (void *)(CFG_MPC85xx_GUTS_ADDR); + uint devdisr = gur->devdisr; + uint sdrs2_io_sel = + (gur->pordevsr & MPC85xx_PORDEVSR_SRDS2_IO_SEL) >> 27; + if (sdrs2_io_sel & 0x04) + return 0; + + return 1; +} + #if defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) diff --git a/lib_ppc/board.c b/lib_ppc/board.c index c02ac62..564faf2 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -635,6 +635,16 @@ void board_init_f (ulong bootflag) /* NOTREACHED - relocate_code() does not return */ }
+int __is_sata_supported() +{ + /* For some boards, when sata disabled by the switch, and the + * driver still access the sata registers, the cpu will hangup. + * please define platform specific is_sata_supported() if your + * board have such issue.*/ + return 1; +} +int is_sata_supported() __attribute__((weak, alias("__is_sata_supported"))); + /************************************************************************ * * This is the next part if the initialization sequence: we are now @@ -1105,8 +1115,10 @@ void board_init_r (gd_t *id, ulong dest_addr) #endif
#if defined(CONFIG_CMD_SATA) - puts ("SATA: "); - sata_initialize (); + if (is_sata_supported()) { + puts("SATA: "); + sata_initialize(); + } #endif
#ifdef CONFIG_LAST_STAGE_INIT
Wolfgang, I think this was a patch for v2008.10.. Andy was looking for you to ack or apply.
- k
Acked-by: Andy Fleming afleming@freescale.com
Wolfgang, if you want, I can apply this to my master branch, and push it out for 2008-10. Whichever is more convenient for you.
Andy
Dear Andy,
In message 2acbd3e40810131852p79033c20g92ba76742731f55e@mail.gmail.com you wrote:
I apply it directly, thanks.
Dear Kumar Gala,
In message 62E86B44-4E2A-4356-BD81-A0D014AB591E@kernel.crashing.org you wrote:
It was on my to-do list. Thanks for the reminder.
Dear Jason Jin,
In message 1223610061-5348-4-git-send-email-Jason.jin@freescale.com you wrote:
Applied, thanks.
Applied to 85xx-next
Andy
Andy Fleming
Jason Jin
Kumar Gala
