[U-Boot] [PATCH 0/4] cosmetic
Here are some minor changes I've been collecting. Most of it is purely cosmetic, but there are some printf and help output changes, too.
Michael Jones (4): cosmetic altera: fix printf typo cmd_mac: cleanup help cmd_mac: fix help for 'mac read'
README | 6 +++--- arch/arm/include/asm/global_data.h | 2 +- common/cmd_eeprom.c | 2 +- common/cmd_i2c.c | 4 ++-- common/cmd_mac.c | 4 ++-- drivers/fpga/altera.c | 2 +- drivers/i2c/omap24xx_i2c.c | 2 +- include/altera.h | 10 +++++----- 8 files changed, 16 insertions(+), 16 deletions(-)
Signed-off-by: Michael Jones michael.jones@matrix-vision.de --- README | 6 +++--- arch/arm/include/asm/global_data.h | 2 +- common/cmd_eeprom.c | 2 +- common/cmd_i2c.c | 4 ++-- drivers/i2c/omap24xx_i2c.c | 2 +- include/altera.h | 10 +++++----- 6 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/README b/README index 446966d..38428cc 100644 --- a/README +++ b/README @@ -1693,12 +1693,12 @@ The following options need to be configured: =>
If you now switch to the new I2C Bus 3 with "i2c dev 3" - u-boot sends First the Commando to the mux@70 to enable - channel 6, and then the Commando to the mux@71 to enable + u-boot first sends the command to the mux@70 to enable + channel 6, and then the command to the mux@71 to enable the channel 4.
After that, you can use the "normal" i2c commands as - usual, to communicate with your I2C devices behind + usual to communicate with your I2C devices behind the 2 muxes.
This option is actually implemented for the bitbanging diff --git a/arch/arm/include/asm/global_data.h b/arch/arm/include/asm/global_data.h index ef9959e..7439a88 100644 --- a/arch/arm/include/asm/global_data.h +++ b/arch/arm/include/asm/global_data.h @@ -24,7 +24,7 @@ #ifndef __ASM_GBL_DATA_H #define __ASM_GBL_DATA_H /* - * The following data structure is placed in some memory wich is + * The following data structure is placed in some memory which is * available very early after boot (like DPRAM on MPC8xx/MPC82xx, or * some locked parts of the data cache) to allow for a minimum set of * global variables during system initialization (until we have set diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index 9f4b22c..e911377 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -250,7 +250,7 @@ int eeprom_write (unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cn
/* * For a FRAM device there is no limit on the number of the - * bytes that can be ccessed with the single read or write + * bytes that can be accessed with the single read or write * operation. */ #if !defined(CONFIG_SYS_I2C_FRAM) diff --git a/common/cmd_i2c.c b/common/cmd_i2c.c index d913e13..3ea75f7 100644 --- a/common/cmd_i2c.c +++ b/common/cmd_i2c.c @@ -1397,8 +1397,8 @@ static int i2c_mux_get_busid (void) return tmp; }
-/* Analyses a Muxstring and sends immediately the - Commands to the Muxes. Runs from Flash. +/* Analyses a Muxstring and immediately sends the + commands to the muxes. Runs from flash. */ int i2c_mux_ident_muxstring_f (uchar *buf) { diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index 71251d8..966ffc4 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -399,7 +399,7 @@ static void wait_for_bb (void) int timeout = I2C_TIMEOUT; u16 stat;
- writew(0xFFFF, &i2c_base->stat); /* clear current interruts...*/ + writew(0xFFFF, &i2c_base->stat); /* clear current interrupts...*/ while ((stat = readw (&i2c_base->stat) & I2C_STAT_BB) && timeout--) { writew (stat, &i2c_base->stat); udelay(1000); diff --git a/include/altera.h b/include/altera.h index bc21ddf..f28a6a8 100644 --- a/include/altera.h +++ b/include/altera.h @@ -51,18 +51,18 @@ typedef enum { /* typedef Altera_iface */ passive_parallel_asynchronous, /* parallel data */ passive_serial_asynchronous, /* serial data w/ internal clock (not used) */ altera_jtag_mode, /* jtag/tap serial (not used ) */ - fast_passive_parallel, /* fast passive parallel (FPP) */ + fast_passive_parallel, /* fast passive parallel (FPP) */ fast_passive_parallel_security, /* fast passive parallel with security (FPPS) */ max_altera_iface_type /* insert all new types before this */ } Altera_iface; /* end, typedef Altera_iface */
typedef enum { /* typedef Altera_Family */ - min_altera_type, /* insert all new types after this */ - Altera_ACEX1K, /* ACEX1K Family */ - Altera_CYC2, /* CYCLONII Family */ + min_altera_type, /* insert all new types after this */ + Altera_ACEX1K, /* ACEX1K Family */ + Altera_CYC2, /* CYCLONII Family */ Altera_StratixII, /* StratixII Familiy */ /* Add new models here */ - max_altera_type /* insert all new types before this */ + max_altera_type /* insert all new types before this */ } Altera_Family; /* end, typedef Altera_Family */
typedef struct { /* typedef Altera_desc */
Hi Michael,
Acked-by: Detlev Zundel dzu@denx.de
Cheers Detlev
Signed-off-by: Michael Jones michael.jones@matrix-vision.de --- drivers/fpga/altera.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/fpga/altera.c b/drivers/fpga/altera.c index 650f2ec..103d81c 100644 --- a/drivers/fpga/altera.c +++ b/drivers/fpga/altera.c @@ -60,7 +60,7 @@ int altera_load( Altera_desc *desc, void *buf, size_t bsize ) __FUNCTION__); ret_val = ACEX1K_load (desc, buf, bsize); #elif defined(CONFIG_FPGA_CYCLON2) - PRINTF ("%s: Launching the CYCLON II Loader...\n", + PRINTF ("%s: Launching the CYCLONE II Loader...\n", __FUNCTION__); ret_val = CYC2_load (desc, buf, bsize); #else
Michael Jones michael.jones@matrix-vision.de writes:
Dear Michael Jones,
In message 1310717371-1677-3-git-send-email-michael.jones@matrix-vision.de you wrote:
Applied, thanks.
Signed-off-by: Michael Jones michael.jones@matrix-vision.de --- common/cmd_mac.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/common/cmd_mac.c b/common/cmd_mac.c index 1884c2a..0f924b7 100644 --- a/common/cmd_mac.c +++ b/common/cmd_mac.c @@ -30,7 +30,7 @@ U_BOOT_CMD( mac, 3, 1, do_mac, "display and program the system ID and MAC addresses in EEPROM", "[read|save|id|num|errata|date|ports|0|1|2|3|4|5|6|7]\n" - "read\n" + "mac read\n" " - show content of EEPROM\n" "mac save\n" " - save to the EEPROM\n"
Dear Michael Jones,
In message 1310717371-1677-4-git-send-email-michael.jones@matrix-vision.de you wrote:
Applied, thanks.
In the only implementation of 'mac read', it doesn't display the contents of the eeprom as the help indicated unless compiled with DEBUG. It only re-reads the contents of the EEPROM into memory. Displaying the contents of the EEPROM is done by passing no arguments to 'mac'.
diff --git a/common/cmd_mac.c b/common/cmd_mac.c index 0f924b7..fcc2867 100644 --- a/common/cmd_mac.c +++ b/common/cmd_mac.c @@ -31,7 +31,7 @@ U_BOOT_CMD( "display and program the system ID and MAC addresses in EEPROM", "[read|save|id|num|errata|date|ports|0|1|2|3|4|5|6|7]\n" "mac read\n" - " - show content of EEPROM\n" + " - read EEPROM content into memory\n" "mac save\n" " - save to the EEPROM\n" "mac id\n"
Hi Detlev,
Thanks for the ack. Do you know when I can expect these to get merged in?
MATRIX VISION GmbH, Talstrasse 16, DE-71570 Oppenweiler Registergericht: Amtsgericht Stuttgart, HRB 271090 Geschaeftsfuehrer: Gerhard Thullner, Werner Armingeon, Uwe Furtner, Erhard Meier
Hi Michael,
Hi Detlev,
As we currently lack a network maintainer, these patches fall into the "and all the rest category" picked up sequentially by Wolfgang. I expect that to happen Real Soon (tm) now.
On the other hand, please do not forget that we _intentionally_ allow for some time to pass before the patches are merged in order to allow for review on the mailing list and to prevent potentially merge/revert/change/merge cycles.
Cheers Detlev
Hi Detlev,
Thanks for the reply.
On 07/27/2011 03:54 PM, Detlev Zundel wrote:
Hi Michael,
Hi Detlev,
That's exactly what I wanted to know- it seemed there wasn't a custodian whom I needed to cc:, and I didn't know who would end up merging them.
Sure, and that makes sense. I just wanted to get a feel for what kind of time scale that was in general. Obviously these are not important patches.
Cheers Detlev
thanks, Michael
Dear Michael Jones,
In message 1310717371-1677-5-git-send-email-michael.jones@matrix-vision.de you wrote:
Applied, thanks.
Detlev Zundel
Michael Jones
