[U-Boot] is it mandatory for SPL to support DM
SPL has a foot-print constraint, so fully switching a particular subsystem like SPI or SPI Flash to DM would increase the size of it.
Possible areas to look at are (assume SPL_DM supported) 1) platdata 2) implement board or platform specific spl device driver which bypassed the actual framework ex: spl_spi_sunxi.c
Do we have any other solutions? or any arguments on above step 2?
Jagan.
- platdata
- implement board or platform specific spl device driver which
SPL does not need to support DM until the size problem is solved.
- platdata
I don't think the problem will ever be 'solved'. It is an ongoing battle.
But as it happens I've just sent a proposal for tiny-dm that I think will help.
Jagan, which board are you trying to convert? If you are trying to convert SPI flash, I think we need to remove the legacy code first.
- platdata
If you want a board which boots from SPI NOR and has some 14k or so limit on SPL, any of the R-Car Gen2 boards fit the bill.
Hi Marek,
- platdata
Thanks...do you have a link to one?
Also was there a 64-bit board that had to run 64-bit SPL? I think I remember you mentioning it.
On 5/25/20 5:48 PM, Simon Glass wrote:
Hi Marek,
- platdata
https://elinux.org/R-Car/Boards/U-Boot-Gen2
You can build SPL for R-Car Gen3 boards.
Hi Marek,
Hi Marek,
- platdata
I mean a link to buy one...if not too expensive. The links on those pages all go nowhere. Digikey lists it as a 'non-stock' item.
On 5/25/20 6:59 PM, Simon Glass wrote:
Hi Marek,
Hi Marek,
On 5/25/20 10:44 AM, Jagan Teki wrote: > SPL has a foot-print constraint, so fully switching a particular > subsystem like SPI or SPI Flash to DM would increase the size of it. > > Possible areas to look at are (assume SPL_DM supported) > 1) platdata > 2) implement board or platform specific spl device driver which > bypassed the actual framework ex: spl_spi_sunxi.c > > Do we have any other solutions? or any arguments on above step 2?
Y-RCAR-E2-SILK-A is probably the one you want then. I got it from Mouser iirc.
Hi Marek,
Hi Marek,
Hi Marek,
On Mon, 25 May 2020 at 04:35, Marek Vasut marex@denx.de wrote: > > On 5/25/20 10:44 AM, Jagan Teki wrote: >> SPL has a foot-print constraint, so fully switching a particular >> subsystem like SPI or SPI Flash to DM would increase the size of it. >> >> Possible areas to look at are (assume SPL_DM supported) >> 1) platdata >> 2) implement board or platform specific spl device driver which >> bypassed the actual framework ex: spl_spi_sunxi.c >> >> Do we have any other solutions? or any arguments on above step 2? > > SPL does not need to support DM until the size problem is solved.
It looks like it is obsolete and out of stock. I think I'll try rock2 for now.
- platdata
These are the partially dm converted drivers, so boards which are using can eventually need a dm spi switch.
drivers/spi/fsl_dspi.c drivers/spi/kirkwood_spi.c drivers/spi/mxc_spi.c drivers/spi/mxs_spi.c drivers/spi/omap3_spi.c drivers/spi/sh_qspi.c
I'm looking for proper options along with removal of some legacy code, and tiny-dm.
Jagan.
- platdata
For the number of about to be year past published deadline (which has been extended at times to get to that point even) boards, I think we need to start by dropping boards. Then we can see what makes sense moving forward.
- platdata
At least mxc_spi and sh_qspi must stay, since those are heavily used in embedded/industrial/automotive.
- platdata
So, this brings us back to the main topic of this thread. Both of the drivers you mention ARE converted to DM, but cannot fit adding DM to SPL. Where do we put non-DM SPL code as we have real size constraints in SPL/TPL? I should bring this up in Simon's new thread too, but I wonder if we shouldn't just make drivers/spl/{mmc,spi,xxx}/ and have the non-DM-framework drivers for SPL reside somewhere and move on. The notions of "we have a nice abstract framework" and "we need to be as small as possible" can and do conflict.
But then how do you propose to keep sharing code between the two worlds?
Sharing defines is easy. Sharing information buried in the device tree requires some of the dtoc changes either in progress or variations on them. Sharing other functionality? Depends on what fits well (logically) in inline functions. But I don't see some duplication of either functional (i.e. read()/write()) nor initialization code as a hard blocker.
But the only choice that doesn't have some duplication of code would be "throw out current DM, replace with a new DM that's small enough in all cases". And we're at a few years now of "DM is too big and bloaty!" without "here are my patches to slim down DM for all cases".
On Mon, May 25, 2020 at 9:06 PM Simon Glass sjg@chromium.org wrote: > > Hi, > > On Mon, 25 May 2020 at 04:35, Marek Vasut marex@denx.de wrote: >> >> On 5/25/20 10:44 AM, Jagan Teki wrote: >>> SPL has a foot-print constraint, so fully switching a particular >>> subsystem like SPI or SPI Flash to DM would increase the size of it. >>> >>> Possible areas to look at are (assume SPL_DM supported) >>> 1) platdata >>> 2) implement board or platform specific spl device driver which >>> bypassed the actual framework ex: spl_spi_sunxi.c >>> >>> Do we have any other solutions? or any arguments on above step 2? >> >> SPL does not need to support DM until the size problem is solved. > > I don't think the problem will ever be 'solved'. It is an ongoing battle. > > But as it happens I've just sent a proposal for tiny-dm that I think will help. > > Jagan, which board are you trying to convert? If you are trying to > convert SPI flash, I think we need to remove the legacy code first.
Surely the functionality to control/access hardware can be shared ? See tiny-mmc for example.
On Mon, May 25, 2020 at 10:58:12PM +0530, Jagan Teki wrote: > On Mon, May 25, 2020 at 9:06 PM Simon Glass sjg@chromium.org wrote: >> >> Hi, >> >> On Mon, 25 May 2020 at 04:35, Marek Vasut marex@denx.de wrote: >>> >>> On 5/25/20 10:44 AM, Jagan Teki wrote: >>>> SPL has a foot-print constraint, so fully switching a particular >>>> subsystem like SPI or SPI Flash to DM would increase the size of it. >>>> >>>> Possible areas to look at are (assume SPL_DM supported) >>>> 1) platdata >>>> 2) implement board or platform specific spl device driver which >>>> bypassed the actual framework ex: spl_spi_sunxi.c >>>> >>>> Do we have any other solutions? or any arguments on above step 2? >>> >>> SPL does not need to support DM until the size problem is solved. >> >> I don't think the problem will ever be 'solved'. It is an ongoing battle. >> >> But as it happens I've just sent a proposal for tiny-dm that I think will help. >> >> Jagan, which board are you trying to convert? If you are trying to >> convert SPI flash, I think we need to remove the legacy code first. > > These are the partially dm converted drivers, so boards which are > using can eventually need a dm spi switch. > > drivers/spi/fsl_dspi.c > drivers/spi/kirkwood_spi.c > drivers/spi/mxc_spi.c > drivers/spi/mxs_spi.c > drivers/spi/omap3_spi.c > drivers/spi/sh_qspi.c > > I'm looking for proper options along with removal of some legacy code, > and tiny-dm.
Yes, it can. Lets move over to the other thread where I call that out as a good example.
Jagan Teki
