[PATCH] imx8mn-ddr4-evk: generate single bootable image
As suggested in commit 028abfd9b157 ("imx8mm-evk: Generate a single bootable flash.bin again") for imx8mm_evk, it is possible to produce single bootable image via binman. This restores the original behavior in distros, where only one boot container is used to create target image.
Perform similar adaptions in order to provide single bootable image for imx8mn-ddr4-evk derivate.
Update documentation to drop additional step of copying u-boot.itb
Fixes: 353dfe4b4359 ("imx8mn-ddr4-evk: switch to use binman") Signed-off-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com --- arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi | 19 ++++++++++++++++++- .../imx8mn_evk/imximage-8mn-ddr4.cfg | 2 +- doc/board/nxp/imx8mn_evk.rst | 1 - 3 files changed, 19 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi index 1d3844437d..2e39790766 100644 --- a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi @@ -157,7 +157,9 @@ };
- flash { + spl { + filename = "spl.bin"; + mkimage { args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x912000";
@@ -224,4 +226,19 @@ }; }; }; + + imx-boot { + filename = "flash.bin"; + pad-byte = <0x00>; + + spl: blob-ext@1 { + offset = <0x0>; + filename = "spl.bin"; + }; + + uboot: blob-ext@2 { + offset = <0x58000>; + filename = "u-boot.itb"; + }; + }; }; diff --git a/board/freescale/imx8mn_evk/imximage-8mn-ddr4.cfg b/board/freescale/imx8mn_evk/imximage-8mn-ddr4.cfg index 22aec26da7..7286b26494 100644 --- a/board/freescale/imx8mn_evk/imximage-8mn-ddr4.cfg +++ b/board/freescale/imx8mn_evk/imximage-8mn-ddr4.cfg @@ -7,4 +7,4 @@
ROM_VERSION v2 BOOT_FROM sd -LOADER mkimage.flash.mkimage 0x912000 +LOADER u-boot-spl-ddr.bin 0x912000 diff --git a/doc/board/nxp/imx8mn_evk.rst b/doc/board/nxp/imx8mn_evk.rst index 9fbb947032..711545af89 100644 --- a/doc/board/nxp/imx8mn_evk.rst +++ b/doc/board/nxp/imx8mn_evk.rst @@ -50,7 +50,6 @@ Burn the flash.bin to MicroSD card offset 32KB: .. code-block:: bash
$sudo dd if=flash.bin of=/dev/sd[x] bs=1024 seek=32 conv=notrunc - $sudo dd if=u-boot.itb of=/dev/sd[x] bs=1024 seek=384 conv=notrunc
Boot ----
base-commit: 4e81f3be340072ad2c0aac093677333702f14f22
On Mon, Jan 17, 2022 at 7:04 PM Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com wrote:
Reviewed-by: Fabio Estevam festevam@gmail.com
As suggested in commit 028abfd9b157 ("imx8mm-evk: Generate a single bootable flash.bin again") for imx8mm_evk, it is possible to produce single bootable image via binman. This restores the original behavior in distros, where only one boot container is used to create target image. Perform similar adaptions in order to provide single bootable image for imx8mn-ddr4-evk derivate. Update documentation to drop additional step of copying u-boot.itb Fixes: 353dfe4b4359 ("imx8mn-ddr4-evk: switch to use binman") Signed-off-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com Reviewed-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
Andrey Zhizhikin
Fabio Estevam
sbabic@denx.de
