[U-Boot-Users] [PATCH] Allow building mips versions with ELDK 3.1.1
.gpword works only with local symbols on certain binutils versions
Signed-off-by: Vlad Lungu vlad.lungu@windrvier.com --- cpu/mips/start.S | 9 ++++++--- 1 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/cpu/mips/start.S b/cpu/mips/start.S index 6e1a78c..947128d 100644 --- a/cpu/mips/start.S +++ b/cpu/mips/start.S @@ -345,7 +345,8 @@ relocate_code: jr t0 nop
- .gpword _GLOBAL_OFFSET_TABLE_ /* _GLOBAL_OFFSET_TABLE_ - _gp */ + .word _gp + .word _GLOBAL_OFFSET_TABLE_ .word uboot_end_data .word uboot_end .word num_got_entries @@ -358,8 +359,10 @@ in_ram: * generated by GNU ld. Skip these reserved entries from relocation. */ lw t3, -4(t0) /* t3 <-- num_got_entries */ - lw t4, -16(t0) /* t4 <-- (_GLOBAL_OFFSET_TABLE_ - _gp) */ - add t4, t4, gp /* t4 now holds _GLOBAL_OFFSET_TABLE_ */ + lw t4, -16(t0) /* t4 <-- _GLOBAL_OFFSET_TABLE_ */ + lw t5, -20(t0) /* t5 <-- _gp */ + sub t4, t5 /* compute offset*/ + add t4, t4, gp /* t4 now holds relocated _GLOBAL_OFFSET_TABLE_ */ addi t4, t4, 8 /* Skipping first two entries. */ li t2, 2 1:
Applied, thanks a lot.
This fixes the start.S erros/warnings.
So the only obvious problem remaining for MIPS are the cache.S warnings:
cache.S:243: Warning: Pretending global symbol used as branch target is local. cache.S:250: Warning: Pretending global symbol used as branch target is local.
This patch works with my two different CPUs. Thanks!
Assembler might be sensitive to global symbol references under PIC code because they should be processed through GOT in principle.
Therefore, we should have set up function entry point explicitly like:
diff --git a/cpu/mips/cache.S b/cpu/mips/cache.S index 8024a2e..7966079 100644 --- a/cpu/mips/cache.S +++ b/cpu/mips/cache.S @@ -239,14 +239,16 @@ NESTED(mips_cache_reset, 0, ra) */ move a1, t2 move a2, t4 - bal mips_init_icache + PTR_LA t7, mips_init_icache + jalr t7
/* * then initialize D-cache. */ move a1, t3 move a2, t5 - bal mips_init_dcache + PTR_LA t7, mips_init_dcache + jalr t7
jr RA END(mips_cache_reset)
I'll post the patch later.
thanks,
Shinya
Shinya Kuribayashi
Vlad Lungu
