[U-Boot] [PATCH 03/34] zynq: Cleanup on miscellaneous configs
Cleanup on miscellaneous configurable options: - Rename SYS_PROMPT as "zynq-uboot" - Add comment - Re-order configs
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- include/configs/zynq.h | 20 +++++++++++--------- 1 file changed, 11 insertions(+), 9 deletions(-)
diff --git a/include/configs/zynq.h b/include/configs/zynq.h index 6ac1350..f9a071d 100644 --- a/include/configs/zynq.h +++ b/include/configs/zynq.h @@ -111,19 +111,21 @@ CONFIG_SYS_INIT_RAM_SIZE - \ GENERATED_GBL_DATA_SIZE)
-#define CONFIG_SYS_PROMPT "U-Boot> " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ +/* Miscellaneous configurable options */ +#define CONFIG_SYS_PROMPT "zynq-uboot> " +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_MAXARGS 15 /* max number of command args */ +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16)
#define CONFIG_SYS_LOAD_ADDR 0 -#define CONFIG_SYS_MAXARGS 15 /* max number of command args */ -#define CONFIG_SYS_LONGHELP -#define CONFIG_AUTO_COMPLETE -#define CONFIG_CMDLINE_EDITING
-#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
/* OF */ #define CONFIG_FIT
On Tue, Nov 05, 2013 at 11:16:24PM +0530, Jagannadha Sutradharudu Teki wrote:
I'm not a fan of removing generic looking prompts, we should rely on other things to determine what we're on.
Not needed now, this is the default.
Isn't it this generic looking prompt?
include/config_fallbacks.h:56:#ifndef CONFIG_SYS_PROMPT include/config_fallbacks.h:57:#define CONFIG_SYS_PROMPT "=> "
yep.
Thanks, Michal
Michal Simek
