[U-Boot] [PATCH 0/6] Introducing the Broadcom bcm281xx Architecture
This patchset introduces the Broadcom bcm281xx family of mobile SoC chips. Broadcom kona hardware blocks are often found in Broadcom mobile SoC chips including the bcm281xx family, so support for some of these kona blocks is also provided here. These patches work on u-boot master as well as the u-boot-arm custodian tree.
Darwin Rambo (6): arch: kona: Initial commit of kona-common architecture code arch: bcm281xx: Initial commit of bcm281xx architecture code gpio: kona: Add Kona gpio driver i2c: kona: Add Kona I2C driver mmc: kona: Add Kona mmc driver board: bcm28155_ap: Add board files
arch/arm/cpu/armv7/Makefile | 1 + arch/arm/cpu/armv7/bcm281xx/Makefile | 11 + arch/arm/cpu/armv7/bcm281xx/clk-bcm281xx.c | 525 +++++++++++++++++ arch/arm/cpu/armv7/bcm281xx/clk-bsc.c | 54 ++ arch/arm/cpu/armv7/bcm281xx/clk-core.c | 536 +++++++++++++++++ arch/arm/cpu/armv7/bcm281xx/clk-core.h | 510 +++++++++++++++++ arch/arm/cpu/armv7/bcm281xx/clk-sdio.c | 75 +++ arch/arm/cpu/armv7/bcm281xx/reset.c | 29 + arch/arm/cpu/armv7/kona-common/Makefile | 10 + arch/arm/cpu/armv7/kona-common/clk-stubs.c | 22 + arch/arm/cpu/armv7/kona-common/hwinit-common.c | 18 + arch/arm/cpu/armv7/kona-common/lowlevel_init.S | 15 + arch/arm/cpu/armv7/kona-common/proc.c | 20 + arch/arm/include/asm/arch-bcm281xx/gpio.h | 17 + arch/arm/include/asm/arch-bcm281xx/sysmap.h | 27 + arch/arm/include/asm/kona-common/clk.h | 31 + arch/arm/include/asm/kona-common/misc.h | 20 + board/broadcom/bcm28155_ap/Makefile | 7 + board/broadcom/bcm28155_ap/bcm28155_ap.c | 99 ++++ boards.cfg | 1 + drivers/gpio/Makefile | 1 + drivers/gpio/kona_gpio.c | 143 +++++ drivers/i2c/Makefile | 1 + drivers/i2c/kona_i2c.c | 730 ++++++++++++++++++++++++ drivers/mmc/Makefile | 1 + drivers/mmc/kona_sdhci.c | 127 +++++ include/configs/bcm28155_ap.h | 148 +++++ 27 files changed, 3179 insertions(+) create mode 100644 arch/arm/cpu/armv7/bcm281xx/Makefile create mode 100644 arch/arm/cpu/armv7/bcm281xx/clk-bcm281xx.c create mode 100644 arch/arm/cpu/armv7/bcm281xx/clk-bsc.c create mode 100644 arch/arm/cpu/armv7/bcm281xx/clk-core.c create mode 100644 arch/arm/cpu/armv7/bcm281xx/clk-core.h create mode 100644 arch/arm/cpu/armv7/bcm281xx/clk-sdio.c create mode 100644 arch/arm/cpu/armv7/bcm281xx/reset.c create mode 100644 arch/arm/cpu/armv7/kona-common/Makefile create mode 100644 arch/arm/cpu/armv7/kona-common/clk-stubs.c create mode 100644 arch/arm/cpu/armv7/kona-common/hwinit-common.c create mode 100644 arch/arm/cpu/armv7/kona-common/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/kona-common/proc.c create mode 100644 arch/arm/include/asm/arch-bcm281xx/gpio.h create mode 100644 arch/arm/include/asm/arch-bcm281xx/sysmap.h create mode 100644 arch/arm/include/asm/kona-common/clk.h create mode 100644 arch/arm/include/asm/kona-common/misc.h create mode 100644 board/broadcom/bcm28155_ap/Makefile create mode 100644 board/broadcom/bcm28155_ap/bcm28155_ap.c create mode 100644 drivers/gpio/kona_gpio.c create mode 100644 drivers/i2c/kona_i2c.c create mode 100644 drivers/mmc/kona_sdhci.c create mode 100644 include/configs/bcm28155_ap.h
The Kona architecture is present on a number of Broadcom mobile SoCs including the bcm281xx family of chips.
Signed-off-by: Darwin Rambo drambo@broadcom.com Reviewed-by: Steve Rae srae@broadcom.com Reviewed-by: Tim Kryger tkryger@linaro.org --- arch/arm/cpu/armv7/Makefile | 1 + arch/arm/cpu/armv7/kona-common/Makefile | 10 ++++++++ arch/arm/cpu/armv7/kona-common/clk-stubs.c | 22 +++++++++++++++++ arch/arm/cpu/armv7/kona-common/hwinit-common.c | 18 ++++++++++++++ arch/arm/cpu/armv7/kona-common/lowlevel_init.S | 15 ++++++++++++ arch/arm/cpu/armv7/kona-common/proc.c | 20 +++++++++++++++ arch/arm/include/asm/kona-common/clk.h | 31 ++++++++++++++++++++++++ arch/arm/include/asm/kona-common/misc.h | 20 +++++++++++++++ 8 files changed, 137 insertions(+) create mode 100644 arch/arm/cpu/armv7/kona-common/Makefile create mode 100644 arch/arm/cpu/armv7/kona-common/clk-stubs.c create mode 100644 arch/arm/cpu/armv7/kona-common/hwinit-common.c create mode 100644 arch/arm/cpu/armv7/kona-common/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/kona-common/proc.c create mode 100644 arch/arm/include/asm/kona-common/clk.h create mode 100644 arch/arm/include/asm/kona-common/misc.h
diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index 0467d00..119ebb3 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -23,6 +23,7 @@ obj-y += nonsec_virt.o obj-y += virt-v7.o endif
+obj-$(CONFIG_KONA) += kona-common/ obj-$(CONFIG_OMAP_COMMON) += omap-common/ obj-$(CONFIG_TEGRA) += tegra-common/
diff --git a/arch/arm/cpu/armv7/kona-common/Makefile b/arch/arm/cpu/armv7/kona-common/Makefile new file mode 100644 index 0000000..9a7c167 --- /dev/null +++ b/arch/arm/cpu/armv7/kona-common/Makefile @@ -0,0 +1,10 @@ +# +# Copyright 2013 Broadcom Corporation. All rights reserved. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += clk-stubs.o +obj-y += hwinit-common.o +obj-y += proc.o +obj-y += lowlevel_init.o diff --git a/arch/arm/cpu/armv7/kona-common/clk-stubs.c b/arch/arm/cpu/armv7/kona-common/clk-stubs.c new file mode 100644 index 0000000..dd3ce34 --- /dev/null +++ b/arch/arm/cpu/armv7/kona-common/clk-stubs.c @@ -0,0 +1,22 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +#include <common.h> + +/* + * These weak functions are available to kona architectures that don't + * require clock enables from the driver code. + */ +int __weak clk_sdio_enable(void *base, u32 rate, u32 *actual_ratep) +{ + return 0; +} +int __weak clk_bsc_enable(void *base, u32 rate, u32 *actual_ratep) +{ + return 0; +} diff --git a/arch/arm/cpu/armv7/kona-common/hwinit-common.c b/arch/arm/cpu/armv7/kona-common/hwinit-common.c new file mode 100644 index 0000000..5d6b131 --- /dev/null +++ b/arch/arm/cpu/armv7/kona-common/hwinit-common.c @@ -0,0 +1,18 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +#include <common.h> +#include <asm/sizes.h> + +#ifndef CONFIG_SYS_DCACHE_OFF +void enable_caches(void) +{ + /* Enable D-cache. I-cache is already enabled in start.S */ + dcache_enable(); +} +#endif diff --git a/arch/arm/cpu/armv7/kona-common/lowlevel_init.S b/arch/arm/cpu/armv7/kona-common/lowlevel_init.S new file mode 100644 index 0000000..a03afcc --- /dev/null +++ b/arch/arm/cpu/armv7/kona-common/lowlevel_init.S @@ -0,0 +1,15 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +//#include <asm-offsets.h> +//#include <config.h> +//#include <linux/linkage.h> + +.globl lowlevel_init +lowlevel_init: + mov pc, lr diff --git a/arch/arm/cpu/armv7/kona-common/proc.c b/arch/arm/cpu/armv7/kona-common/proc.c new file mode 100644 index 0000000..92fb39b --- /dev/null +++ b/arch/arm/cpu/armv7/kona-common/proc.c @@ -0,0 +1,20 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +#include <common.h> +#include <asm/io.h> +#include <asm/kona-common/misc.h> +#include <asm/armv7.h> + +void do_proc_wfe(int forever) +{ + do { + asm volatile ("wfe @ wait for event\n"); + /*printf("wake up from wfe\n"); */ + } while (forever); +} diff --git a/arch/arm/include/asm/kona-common/clk.h b/arch/arm/include/asm/kona-common/clk.h new file mode 100644 index 0000000..c26c6a4 --- /dev/null +++ b/arch/arm/include/asm/kona-common/clk.h @@ -0,0 +1,31 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +/* This API file is loosely based on u-boot/drivers/video/ipu.h and linux */ + +#ifndef __KONA_COMMON_CLK_H +#define __KONA_COMMON_CLK_H + +#include <linux/types.h> + +struct clk; + +/* Only implement required functions for your specific architecture */ +int clk_init(void); +struct clk *clk_get(const char *id); +int clk_enable(struct clk *clk); +void clk_disable(struct clk *clk); +unsigned long clk_get_rate(struct clk *clk); +long clk_round_rate(struct clk *clk, unsigned long rate); +int clk_set_rate(struct clk *clk, unsigned long rate); +int clk_set_parent(struct clk *clk, struct clk *parent); +struct clk *clk_get_parent(struct clk *clk); +int clk_sdio_enable(void *base, u32 rate, u32 *actual_ratep); +int clk_bsc_enable(void *base); + +#endif diff --git a/arch/arm/include/asm/kona-common/misc.h b/arch/arm/include/asm/kona-common/misc.h new file mode 100644 index 0000000..8506bbc --- /dev/null +++ b/arch/arm/include/asm/kona-common/misc.h @@ -0,0 +1,20 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +#ifndef __KONA_COMMON_MISC_H +#define __KONA_COMMON_MISC_H + +#include <mmc.h> + +void hw_watchdog_disable(void); +int kona_sdhci_init(int dev_index, u32 min_clk, u32 quirks); +int kona_i2c_init(unsigned int dev_idx, unsigned long base_addr); + +void proc_on_wfi(void); + +#endif
[snip]
Blank lines between functions please.
- mov pc, lr
(a) no commented out include lines (b) This is empty, which seems wrong. I strongly suspect you want to make use of arch/arm/cpu/armv7/lowlevel_init.S and have an s_init function, ala omap*/tegra/rmobile/etc.
- do {
No commented out printf, thanks.
[snip]
OK
- mov pc, lr
OK
Will check this out. Thanks.
- do {
OK
Add bcm281xx architecture support code including a clock framework and chip reset. Define register block base addresses for the bcm281xx architecture and create an empty gpio header file required when CONFIG_CMD_GPIO is set.
Signed-off-by: Darwin Rambo drambo@broadcom.com Reviewed-by: Steve Rae srae@broadcom.com Reviewed-by: Tim Kryger tkryger@linaro.org --- arch/arm/cpu/armv7/bcm281xx/Makefile | 11 + arch/arm/cpu/armv7/bcm281xx/clk-bcm281xx.c | 525 ++++++++++++++++++++++++++ arch/arm/cpu/armv7/bcm281xx/clk-bsc.c | 54 +++ arch/arm/cpu/armv7/bcm281xx/clk-core.c | 536 +++++++++++++++++++++++++++ arch/arm/cpu/armv7/bcm281xx/clk-core.h | 510 +++++++++++++++++++++++++ arch/arm/cpu/armv7/bcm281xx/clk-sdio.c | 75 ++++ arch/arm/cpu/armv7/bcm281xx/reset.c | 29 ++ arch/arm/include/asm/arch-bcm281xx/gpio.h | 17 + arch/arm/include/asm/arch-bcm281xx/sysmap.h | 27 ++ 9 files changed, 1784 insertions(+) create mode 100644 arch/arm/cpu/armv7/bcm281xx/Makefile create mode 100644 arch/arm/cpu/armv7/bcm281xx/clk-bcm281xx.c create mode 100644 arch/arm/cpu/armv7/bcm281xx/clk-bsc.c create mode 100644 arch/arm/cpu/armv7/bcm281xx/clk-core.c create mode 100644 arch/arm/cpu/armv7/bcm281xx/clk-core.h create mode 100644 arch/arm/cpu/armv7/bcm281xx/clk-sdio.c create mode 100644 arch/arm/cpu/armv7/bcm281xx/reset.c create mode 100644 arch/arm/include/asm/arch-bcm281xx/gpio.h create mode 100644 arch/arm/include/asm/arch-bcm281xx/sysmap.h
diff --git a/arch/arm/cpu/armv7/bcm281xx/Makefile b/arch/arm/cpu/armv7/bcm281xx/Makefile new file mode 100644 index 0000000..46c4943 --- /dev/null +++ b/arch/arm/cpu/armv7/bcm281xx/Makefile @@ -0,0 +1,11 @@ +# +# Copyright 2013 Broadcom Corporation. All rights reserved. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += reset.o +obj-y += clk-core.o +obj-y += clk-bcm281xx.o +obj-y += clk-sdio.o +obj-y += clk-bsc.o diff --git a/arch/arm/cpu/armv7/bcm281xx/clk-bcm281xx.c b/arch/arm/cpu/armv7/bcm281xx/clk-bcm281xx.c new file mode 100644 index 0000000..2726cfb --- /dev/null +++ b/arch/arm/cpu/armv7/bcm281xx/clk-bcm281xx.c @@ -0,0 +1,525 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +/***************************************************************************** +* +* bcm281xx-specific clock tables +* +*****************************************************************************/ + +#include <common.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/sysmap.h> +#include <asm/kona-common/clk.h> +#include "clk-core.h" + +#define CLOCK_1K 1000 +#define CLOCK_1M (CLOCK_1K * 1000) + +/* declare a reference clock */ +#define DECLARE_REF_CLK(clk_name, clk_parent, clk_rate, clk_div) \ +static struct refclk clk_name = { \ + .clk = { \ + .name = #clk_name, \ + .parent = clk_parent, \ + .rate = clk_rate, \ + .div = clk_div, \ + .ops = &ref_clk_ops, \ + }, \ +} + +/***************************************************************************** + Reference clocks +*****************************************************************************/ +/* Declare a list of reference clocks */ +DECLARE_REF_CLK(ref_crystal, 0, 26 * CLOCK_1M, 1); +DECLARE_REF_CLK(var_96m, 0, 96 * CLOCK_1M, 1); +DECLARE_REF_CLK(ref_96m, 0, 96 * CLOCK_1M, 1); +DECLARE_REF_CLK(ref_312m, 0, 312 * CLOCK_1M, 0); +DECLARE_REF_CLK(ref_104m, &ref_312m.clk, 104 * CLOCK_1M, 3); +DECLARE_REF_CLK(ref_52m, &ref_104m.clk, 52 * CLOCK_1M, 2); +DECLARE_REF_CLK(ref_13m, &ref_52m.clk, 13 * CLOCK_1M, 4); +DECLARE_REF_CLK(var_312m, 0, 312 * CLOCK_1M, 0); +DECLARE_REF_CLK(var_104m, &var_312m.clk, 104 * CLOCK_1M, 3); +DECLARE_REF_CLK(var_52m, &var_104m.clk, 52 * CLOCK_1M, 2); +DECLARE_REF_CLK(var_13m, &var_52m.clk, 13 * CLOCK_1M, 4); + +struct refclk_lkup { + struct refclk *procclk; + const char *name; +}; + +/* Lookup table for string to clk tranlation */ +#define MKSTR(x) {&x, #x} +static struct refclk_lkup refclk_str_tbl[] = { + MKSTR(ref_crystal), MKSTR(var_96m), MKSTR(ref_96m), + MKSTR(ref_312m), MKSTR(ref_104m), MKSTR(ref_52m), + MKSTR(ref_13m), MKSTR(var_312m), MKSTR(var_104m), + MKSTR(var_52m), MKSTR(var_13m), +}; + +int refclk_entries = sizeof(refclk_str_tbl)/sizeof(refclk_str_tbl[0]); + +/* convert ref clock string to clock structure pointer */ +struct refclk *refclk_str_to_clk(const char *name) +{ + int i; + struct refclk_lkup *tblp = refclk_str_tbl; + for (i = 0; i < refclk_entries; i++, tblp++) { + if (!(strcmp(name, tblp->name))) + return tblp->procclk; + } + return NULL; +} + +/* frequency tables indexed by freq_id */ +unsigned long master_axi_freq_tbl[8] = { + 26 * CLOCK_1M, + 52 * CLOCK_1M, + 104 * CLOCK_1M, + 156 * CLOCK_1M, + 156 * CLOCK_1M, + 208 * CLOCK_1M, + 312 * CLOCK_1M, + 312 * CLOCK_1M +}; + +unsigned long master_ahb_freq_tbl[8] = { + 26 * CLOCK_1M, + 52 * CLOCK_1M, + 52 * CLOCK_1M, + 52 * CLOCK_1M, + 78 * CLOCK_1M, + 104 * CLOCK_1M, + 104 * CLOCK_1M, + 156 * CLOCK_1M +}; + +unsigned long slave_axi_freq_tbl[8] = { + 26 * CLOCK_1M, + 52 * CLOCK_1M, + 78 * CLOCK_1M, + 104 * CLOCK_1M, + 156 * CLOCK_1M, + 156 * CLOCK_1M +}; + +unsigned long slave_apb_freq_tbl[8] = { + 26 * CLOCK_1M, + 26 * CLOCK_1M, + 39 * CLOCK_1M, + 52 * CLOCK_1M, + 52 * CLOCK_1M, + 78 * CLOCK_1M +}; + +static struct bus_clk_data bsc1_apb_data = { + .gate = HW_SW_GATE_AUTO(0x0458, 16, 0, 1), +}; + +static struct bus_clk_data bsc2_apb_data = { + .gate = HW_SW_GATE_AUTO(0x045c, 16, 0, 1), +}; + +static struct bus_clk_data bsc3_apb_data = { + .gate = HW_SW_GATE_AUTO(0x0484, 16, 0, 1), +}; + +/* Master CCU clocks */ + +static struct peri_clk_data sdio1_data = { + .gate = HW_SW_GATE(0x0358, 18, 2, 3), + .clocks = CLOCKS("ref_crystal", + "var_52m", + "ref_52m", + "var_96m", + "ref_96m"), + .sel = SELECTOR(0x0a28, 0, 3), + .div = DIVIDER(0x0a28, 4, 14), + .trig = TRIGGER(0x0afc, 9), +}; + +static struct peri_clk_data sdio2_data = { + .gate = HW_SW_GATE(0x035c, 18, 2, 3), + .clocks = CLOCKS("ref_crystal", + "var_52m", + "ref_52m", + "var_96m", + "ref_96m"), + .sel = SELECTOR(0x0a2c, 0, 3), + .div = DIVIDER(0x0a2c, 4, 14), + .trig = TRIGGER(0x0afc, 10), +}; + +static struct peri_clk_data sdio3_data = { + .gate = HW_SW_GATE(0x0364, 18, 2, 3), + .clocks = CLOCKS("ref_crystal", + "var_52m", + "ref_52m", + "var_96m", + "ref_96m"), + .sel = SELECTOR(0x0a34, 0, 3), + .div = DIVIDER(0x0a34, 4, 14), + .trig = TRIGGER(0x0afc, 12), +}; + +static struct peri_clk_data sdio4_data = { + .gate = HW_SW_GATE(0x0360, 18, 2, 3), + .clocks = CLOCKS("ref_crystal", + "var_52m", + "ref_52m", + "var_96m", + "ref_96m"), + .sel = SELECTOR(0x0a30, 0, 3), + .div = DIVIDER(0x0a30, 4, 14), + .trig = TRIGGER(0x0afc, 11), +}; + +static struct peri_clk_data sdio1_sleep_data = { + .clocks = CLOCKS("ref_32k"), + .gate = SW_ONLY_GATE(0x0358, 20, 4), +}; + +static struct peri_clk_data sdio2_sleep_data = { + .clocks = CLOCKS("ref_32k"), + .gate = SW_ONLY_GATE(0x035c, 20, 4), +}; + +static struct peri_clk_data sdio3_sleep_data = { + .clocks = CLOCKS("ref_32k"), + .gate = SW_ONLY_GATE(0x0364, 20, 4), +}; + +static struct peri_clk_data sdio4_sleep_data = { + .clocks = CLOCKS("ref_32k"), + .gate = SW_ONLY_GATE(0x0360, 20, 4), +}; + +static struct bus_clk_data sdio1_ahb_data = { + .gate = HW_SW_GATE_AUTO(0x0358, 16, 0, 1), +}; + +static struct bus_clk_data sdio2_ahb_data = { + .gate = HW_SW_GATE_AUTO(0x035c, 16, 0, 1), +}; + +static struct bus_clk_data sdio3_ahb_data = { + .gate = HW_SW_GATE_AUTO(0x0364, 16, 0, 1), +}; + +static struct bus_clk_data sdio4_ahb_data = { + .gate = HW_SW_GATE_AUTO(0x0360, 16, 0, 1), +}; + +/* Slave CCU clocks */ + +static struct peri_clk_data bsc1_data = { + .gate = HW_SW_GATE(0x0458, 18, 2, 3), + .clocks = CLOCKS("ref_crystal", + "var_104m", + "ref_104m", + "var_13m", + "ref_13m"), + .sel = SELECTOR(0x0a64, 0, 3), + .trig = TRIGGER(0x0afc, 23), +}; + +static struct peri_clk_data bsc2_data = { + .gate = HW_SW_GATE(0x045c, 18, 2, 3), + .clocks = CLOCKS("ref_crystal", + "var_104m", + "ref_104m", + "var_13m", + "ref_13m"), + .sel = SELECTOR(0x0a68, 0, 3), + .trig = TRIGGER(0x0afc, 24), +}; + +static struct peri_clk_data bsc3_data = { + .gate = HW_SW_GATE(0x0484, 18, 2, 3), + .clocks = CLOCKS("ref_crystal", + "var_104m", + "ref_104m", + "var_13m", + "ref_13m"), + .sel = SELECTOR(0x0a84, 0, 3), + .trig = TRIGGER(0x0b00, 2), +}; + +/***************************************************************************** + CCU clocks +*****************************************************************************/ +static struct ccu_clock kpm_ccu_clk = { + .clk = { + .name = "kpm_ccu_clk", + .ops = &ccu_clk_ops, + .ccu_clk_mgr_base = KONA_MST_CLK_BASE_ADDR, + }, + .num_policy_masks = 1, + .policy_freq_offset = 0x00000008, + .freq_bit_shift = 8, + .policy_ctl_offset = 0x0000000c, + .policy0_mask_offset = 0x00000010, + .policy1_mask_offset = 0x00000014, + .policy2_mask_offset = 0x00000018, + .policy3_mask_offset = 0x0000001c, + .lvm_en_offset = 0x00000034, + .freq_id = 2, + .freq_tbl = master_axi_freq_tbl, +}; + +static struct ccu_clock kps_ccu_clk = { + .clk = { + .name = "kps_ccu_clk", + .ops = &ccu_clk_ops, + .ccu_clk_mgr_base = KONA_SLV_CLK_BASE_ADDR, + }, + .num_policy_masks = 2, + .policy_freq_offset = 0x00000008, + .freq_bit_shift = 8, + .policy_ctl_offset = 0x0000000c, + .policy0_mask_offset = 0x00000010, + .policy1_mask_offset = 0x00000014, + .policy2_mask_offset = 0x00000018, + .policy3_mask_offset = 0x0000001c, + .policy0_mask2_offset = 0x00000048, + .policy1_mask2_offset = 0x0000004c, + .policy2_mask2_offset = 0x00000050, + .policy3_mask2_offset = 0x00000054, + .lvm_en_offset = 0x00000034, + .freq_id = 2, + .freq_tbl = slave_axi_freq_tbl, +}; + +/***************************************************************************** + Bus clocks +*****************************************************************************/ +/* KPM bus clocks */ + +static struct bus_clock sdio1_ahb_clk = { + .clk = { + .name = "sdio1_ahb_clk", + .parent = &kpm_ccu_clk.clk, + .ops = &bus_clk_ops, + .ccu_clk_mgr_base = KONA_MST_CLK_BASE_ADDR, + }, + .freq_tbl = master_ahb_freq_tbl, + .data = &sdio1_ahb_data, +}; + +static struct bus_clock sdio2_ahb_clk = { + .clk = { + .name = "sdio2_ahb_clk", + .parent = &kpm_ccu_clk.clk, + .ops = &bus_clk_ops, + .ccu_clk_mgr_base = KONA_MST_CLK_BASE_ADDR, + }, + .freq_tbl = master_ahb_freq_tbl, + .data = &sdio2_ahb_data, +}; + +static struct bus_clock sdio3_ahb_clk = { + .clk = { + .name = "sdio3_ahb_clk", + .parent = &kpm_ccu_clk.clk, + .ops = &bus_clk_ops, + .ccu_clk_mgr_base = KONA_MST_CLK_BASE_ADDR, + }, + .freq_tbl = master_ahb_freq_tbl, + .data = &sdio3_ahb_data, +}; + +static struct bus_clock sdio4_ahb_clk = { + .clk = { + .name = "sdio4_ahb_clk", + .parent = &kpm_ccu_clk.clk, + .ops = &bus_clk_ops, + .ccu_clk_mgr_base = KONA_MST_CLK_BASE_ADDR, + }, + .freq_tbl = master_ahb_freq_tbl, + .data = &sdio4_ahb_data, +}; + +static struct bus_clock bsc1_apb_clk = { + .clk = { + .name = "bsc1_apb_clk", + .parent = &kps_ccu_clk.clk, + .ops = &bus_clk_ops, + .ccu_clk_mgr_base = KONA_SLV_CLK_BASE_ADDR, + }, + .freq_tbl = slave_apb_freq_tbl, + .data = &bsc1_apb_data, +}; + +static struct bus_clock bsc2_apb_clk = { + .clk = { + .name = "bsc2_apb_clk", + .parent = &kps_ccu_clk.clk, + .ops = &bus_clk_ops, + .ccu_clk_mgr_base = KONA_SLV_CLK_BASE_ADDR, + }, + .freq_tbl = slave_apb_freq_tbl, + .data = &bsc2_apb_data, +}; + +static struct bus_clock bsc3_apb_clk = { + .clk = { + .name = "bsc3_apb_clk", + .parent = &kps_ccu_clk.clk, + .ops = &bus_clk_ops, + .ccu_clk_mgr_base = KONA_SLV_CLK_BASE_ADDR, + }, + .freq_tbl = slave_apb_freq_tbl, + .data = &bsc3_apb_data, +}; + +/* KPM peripheral */ +static struct peri_clock sdio1_clk = { + .clk = { + .name = "sdio1_clk", + .parent = &ref_52m.clk, + .ops = &peri_clk_ops, + .ccu_clk_mgr_base = KONA_MST_CLK_BASE_ADDR, + }, + .data = &sdio1_data, +}; + +static struct peri_clock sdio2_clk = { + .clk = { + .name = "sdio2_clk", + .parent = &ref_52m.clk, + .ops = &peri_clk_ops, + .ccu_clk_mgr_base = KONA_MST_CLK_BASE_ADDR, + }, + .data = &sdio2_data, +}; + +static struct peri_clock sdio3_clk = { + .clk = { + .name = "sdio3_clk", + .parent = &ref_52m.clk, + .ops = &peri_clk_ops, + .ccu_clk_mgr_base = KONA_MST_CLK_BASE_ADDR, + }, + .data = &sdio3_data, +}; + +static struct peri_clock sdio4_clk = { + .clk = { + .name = "sdio4_clk", + .parent = &ref_52m.clk, + .ops = &peri_clk_ops, + .ccu_clk_mgr_base = KONA_MST_CLK_BASE_ADDR, + }, + .data = &sdio4_data, +}; + +static struct peri_clock sdio1_sleep_clk = { + .clk = { + .name = "sdio1_sleep_clk", + .parent = &kpm_ccu_clk.clk, + .ops = &bus_clk_ops, + .ccu_clk_mgr_base = KONA_MST_CLK_BASE_ADDR, + }, + .data = &sdio1_sleep_data, +}; + +static struct peri_clock sdio2_sleep_clk = { + .clk = { + .name = "sdio2_sleep_clk", + .parent = &kpm_ccu_clk.clk, + .ops = &bus_clk_ops, + .ccu_clk_mgr_base = KONA_MST_CLK_BASE_ADDR, + }, + .data = &sdio2_sleep_data, +}; + +static struct peri_clock sdio3_sleep_clk = { + .clk = { + .name = "sdio3_sleep_clk", + .parent = &kpm_ccu_clk.clk, + .ops = &bus_clk_ops, + .ccu_clk_mgr_base = KONA_MST_CLK_BASE_ADDR, + }, + .data = &sdio3_sleep_data, +}; + +static struct peri_clock sdio4_sleep_clk = { + .clk = { + .name = "sdio4_sleep_clk", + .parent = &kpm_ccu_clk.clk, + .ops = &bus_clk_ops, + .ccu_clk_mgr_base = KONA_MST_CLK_BASE_ADDR, + }, + .data = &sdio4_sleep_data, +}; + +/* KPS peripheral clock */ +static struct peri_clock bsc1_clk = { + .clk = { + .name = "bsc1_clk", + .parent = &ref_13m.clk, + .rate = 13 * CLOCK_1M, + .div = 1, + .ops = &peri_clk_ops, + .ccu_clk_mgr_base = KONA_SLV_CLK_BASE_ADDR, + }, + .data = &bsc1_data, +}; + +static struct peri_clock bsc2_clk = { + .clk = { + .name = "bsc2_clk", + .parent = &ref_13m.clk, + .rate = 13 * CLOCK_1M, + .div = 1, + .ops = &peri_clk_ops, + .ccu_clk_mgr_base = KONA_SLV_CLK_BASE_ADDR, + }, + .data = &bsc2_data, +}; + +static struct peri_clock bsc3_clk = { + .clk = { + .name = "bsc3_clk", + .parent = &ref_13m.clk, + .rate = 13 * CLOCK_1M, + .div = 1, + .ops = &peri_clk_ops, + .ccu_clk_mgr_base = KONA_SLV_CLK_BASE_ADDR, + }, + .data = &bsc3_data, +}; + +/* public table for registering clocks */ +struct clk_lookup arch_clk_tbl[] = { + /* Peripheral clocks */ + CLK_LK(sdio1), + CLK_LK(sdio2), + CLK_LK(sdio3), + CLK_LK(sdio4), + CLK_LK(sdio1_sleep), + CLK_LK(sdio2_sleep), + CLK_LK(sdio3_sleep), + CLK_LK(sdio4_sleep), + CLK_LK(bsc1), + CLK_LK(bsc2), + CLK_LK(bsc3), + /* Bus clocks */ + CLK_LK(sdio1_ahb), + CLK_LK(sdio2_ahb), + CLK_LK(sdio3_ahb), + CLK_LK(sdio4_ahb), + CLK_LK(bsc1_apb), + CLK_LK(bsc2_apb), + CLK_LK(bsc3_apb), +}; + +/* public array size */ +unsigned int arch_clk_tbl_array_size = ARRAY_SIZE(arch_clk_tbl); diff --git a/arch/arm/cpu/armv7/bcm281xx/clk-bsc.c b/arch/arm/cpu/armv7/bcm281xx/clk-bsc.c new file mode 100644 index 0000000..9acb7f0 --- /dev/null +++ b/arch/arm/cpu/armv7/bcm281xx/clk-bsc.c @@ -0,0 +1,54 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +#include <common.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/sysmap.h> +#include <asm/kona-common/clk.h> +#include "clk-core.h" + +/* Enable appropriate clocks for a BSC/I2C port */ +int clk_bsc_enable(void *base) +{ + int ret; + char *bscstr, *apbstr; + + switch ((u32) base) { + case PMU_BSC_BASE_ADDR: + /* PMU clock is always enabled */ + return 0; + case BSC1_BASE_ADDR: + bscstr = "bsc1_clk"; + apbstr = "bsc1_apb_clk"; + break; + case BSC2_BASE_ADDR: + bscstr = "bsc2_clk"; + apbstr = "bsc2_apb_clk"; + break; + case BSC3_BASE_ADDR: + bscstr = "bsc3_clk"; + apbstr = "bsc3_apb_clk"; + break; + default: + printf("%s: base 0x%p not found\n", __func__, base); + return -EINVAL; + } + + /* Note that the bus clock must be enabled first */ + + ret = clk_get_and_enable(apbstr); + if (ret) + return ret; + + ret = clk_get_and_enable(bscstr); + if (ret) + return ret; + + return 0; +} diff --git a/arch/arm/cpu/armv7/bcm281xx/clk-core.c b/arch/arm/cpu/armv7/bcm281xx/clk-core.c new file mode 100644 index 0000000..9a60778 --- /dev/null +++ b/arch/arm/cpu/armv7/bcm281xx/clk-core.c @@ -0,0 +1,536 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +/***************************************************************************** +* +* bcm281xx architecture clock framework +* +*****************************************************************************/ + +#include <common.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/sysmap.h> +#include <asm/kona-common/clk.h> +#include "clk-core.h" + +#define CLK_WR_ACCESS_PASSWORD 0x00a5a501 +#define WR_ACCESS_OFFSET 0 /* common to all clock blocks */ +#define POLICY_CTL_GO 1 /* Load and refresh policy masks */ +#define POLICY_CTL_GO_ATL 4 /* Active Load */ + +/* Helper function */ +int clk_get_and_enable(char *clkstr) +{ + int ret = 0; + struct clk *c; + + clk_dbg("%s: %s\n", __func__, clkstr); + + c = clk_get(clkstr); + if (c) { + ret = clk_enable(c); + if (ret) + return ret; + } else { + printf("%s: Couldn't find %s\n", __func__, clkstr); + return -EINVAL; + } + return ret; +} + +/* Bitfield operations */ + +/* Produces a mask of set bits covering a range of a 32-bit value */ +static inline u32 bitfield_mask(u32 shift, u32 width) +{ + return ((1 << width) - 1) << shift; +} + +/* Extract the value of a bitfield found within a given register value */ +static inline u32 bitfield_extract(u32 reg_val, u32 shift, u32 width) +{ + return (reg_val & bitfield_mask(shift, width)) >> shift; +} + +/* Replace the value of a bitfield found within a given register value */ +static inline u32 bitfield_replace(u32 reg_val, u32 shift, u32 width, u32 val) +{ + u32 mask = bitfield_mask(shift, width); + + return (reg_val & ~mask) | (val << shift); +} + +/* + * Poll a register in a CCU's address space, returning when the + * specified bit in that register's value is set (or clear). Delay + * a microsecond after each read of the register. Returns true if + * successful, or false if we gave up trying. + * + * Caller must ensure the CCU lock is held. + */ +#define CLK_GATE_DELAY_USEC 2000 +static inline int wait_bit(void *base, u32 offset, u32 bit, bool want) +{ + unsigned int tries; + u32 bit_mask = 1 << bit; + + for (tries = 0; tries < CLK_GATE_DELAY_USEC; tries++) { + u32 val; + bool bit_val; + + val = readl(base + offset); + bit_val = (val & bit_mask) ? 1 : 0; + if (bit_val == want) + return 0; /* success */ + udelay(1); + } + + clk_dbg("%s: timeout on addr 0x%p, waiting for bit %d to go to %d\n", + __func__, base + offset, bit, want); + + return -ETIMEDOUT; +} + +/* Enable a peripheral clock */ +static int peri_clk_enable(struct clk *c, int enable) +{ + int ret = 0; + u32 reg; + struct peri_clock *peri_clk = to_peri_clk(c); + struct peri_clk_data *cd = peri_clk->data; + struct bcm_clk_gate *gate = &cd->gate; + void *base = (void *)c->ccu_clk_mgr_base; + + + clk_dbg("%s: %s\n", __func__, c->name); + + clk_get_rate(c); /* Make sure rate and sel are filled in */ + + /* enable access */ + writel(CLK_WR_ACCESS_PASSWORD, base + WR_ACCESS_OFFSET); + + if (enable) { + clk_dbg("%s %s set rate %lu div %lu sel %d parent %lu\n", + __func__, c->name, c->rate, c->div, c->sel, + c->parent->rate); + + /* + * clkgate - only software controllable gates are + * supported by u-boot which includes all clocks + * that matter. This avoids bringing in a lot of extra + * complexity as done in the kernel framework. + */ + if (gate_exists(gate)) { + reg = readl(base + cd->gate.offset); + reg |= (1 << cd->gate.en_bit); + writel(reg, base + cd->gate.offset); + } + + /* div and pll select */ + if (divider_exists(&cd->div)) { + reg = readl(base + cd->div.offset); + bitfield_replace(reg, cd->div.shift, cd->div.width, + c->div - 1); + writel(reg, base + cd->div.offset); + } + + /* frequency selector */ + if (selector_exists(&cd->sel)) { + reg = readl(base + cd->sel.offset); + bitfield_replace(reg, cd->sel.shift, cd->sel.width, + c->sel); + writel(reg, base + cd->sel.offset); + } + + /* trigger */ + if (trigger_exists(&cd->trig)) { + writel((1 << cd->trig.bit), base + cd->trig.offset); + + /* wait for trigger status bit to go to 0 */ + ret = wait_bit(base, cd->trig.offset, cd->trig.bit, 0); + if (ret) + return ret; + } + + /* wait for running (status_bit = 1) */ + ret = wait_bit(base, cd->gate.offset, cd->gate.status_bit, 1); + if (ret) + return ret; + } else { + clk_dbg("%s disable clock %s\n", __func__, c->name); + + /* clkgate */ + reg = readl(base + cd->gate.offset); + reg &= ~(1 << cd->gate.en_bit); + writel(reg, base + cd->gate.offset); + + /* wait for stop (status_bit = 0) */ + ret = wait_bit(base, cd->gate.offset, cd->gate.status_bit, 0); + } + + /* disable access */ + writel(0, base + WR_ACCESS_OFFSET); + + return ret; +} + +/* Set the rate of a peripheral clock */ +static int peri_clk_set_rate(struct clk *c, unsigned long rate) +{ + int ret = 0; + int i; + unsigned long diff; + unsigned long new_rate = 0, div = 1; + struct peri_clock *peri_clk = to_peri_clk(c); + struct peri_clk_data *cd = peri_clk->data; + const char **clock; + + clk_dbg("%s: %s\n", __func__, c->name); + diff = rate; + + i = 0; + for (clock = cd->clocks; *clock; clock++, i++) { + struct refclk *ref = refclk_str_to_clk(*clock); + if (!ref) { + printf("%s: Lookup of %s failed\n", __func__, *clock); + return -EINVAL; + } + + /* round to the new rate */ + div = ref->clk.rate / rate; + if (div == 0) + div = 1; + + new_rate = ref->clk.rate / div; + + /* get the min diff */ + if (abs(new_rate - rate) < diff) { + diff = abs(new_rate - rate); + c->sel = i; + c->parent = &ref->clk; + c->rate = new_rate; + c->div = div; + } + } + + clk_dbg("%s %s set rate %lu div %lu sel %d parent %lu\n", __func__, + c->name, c->rate, c->div, c->sel, c->parent->rate); + return ret; +} + +/* Get the rate of a peripheral clock */ +static unsigned long peri_clk_get_rate(struct clk *c) +{ + struct peri_clock *peri_clk = to_peri_clk(c); + struct peri_clk_data *cd = peri_clk->data; + void *base = (void *)c->ccu_clk_mgr_base; + int div = 1; + const char **clock; + struct refclk *ref; + u32 reg; + + clk_dbg("%s: %s\n", __func__, c->name); + if (selector_exists(&cd->sel)) { + reg = readl(base + cd->sel.offset); + c->sel = bitfield_extract(reg, cd->sel.shift, cd->sel.width); + } else { + /* + * For peri clocks that don't have a selector, the single + * reference clock will always exist at index 0. + */ + c->sel = 0; + } + + if (divider_exists(&cd->div)) { + reg = readl(base + cd->div.offset); + div = bitfield_extract(reg, cd->div.shift, cd->div.width); + div += 1; + } + + clock = cd->clocks; + ref = refclk_str_to_clk(clock[c->sel]); + if (!ref) { + printf("%s: Can't lookup %s\n", __func__, clock[c->sel]); + return 0; + } + + c->parent = &ref->clk; + c->div = div; + c->rate = c->parent->rate / c->div; + clk_dbg("%s parent rate %lu div %d sel %d rate %lu\n", __func__, + c->parent->rate, div, c->sel, c->rate); + + return c->rate; +} + +/* Peripheral clock operations */ +struct clk_ops peri_clk_ops = { + .enable = peri_clk_enable, + .set_rate = peri_clk_set_rate, + .get_rate = peri_clk_get_rate, +}; + +/* Enable a CCU clock */ +static int ccu_clk_enable(struct clk *c, int enable) +{ + struct ccu_clock *ccu_clk = to_ccu_clk(c); + void *base = (void *)c->ccu_clk_mgr_base; + int ret = 0; + u32 reg; + + clk_dbg("%s: %s\n", __func__, c->name); + if (!enable) + return -EINVAL; /* CCU clock cannot shutdown */ + + /* enable access */ + writel(CLK_WR_ACCESS_PASSWORD, base + WR_ACCESS_OFFSET); + + /* config enable for policy engine */ + writel(1, base + ccu_clk->lvm_en_offset); + + /* wait for bit to go to 0 */ + ret = wait_bit(base, ccu_clk->lvm_en_offset, 0, 0); + if (ret) + return ret; + + /* freq ID */ + if (!ccu_clk->freq_bit_shift) + ccu_clk->freq_bit_shift = 8; + + /* Set frequency id for each of the 4 policies */ + reg = ccu_clk->freq_id | + (ccu_clk->freq_id << (ccu_clk->freq_bit_shift)) | + (ccu_clk->freq_id << (ccu_clk->freq_bit_shift * 2)) | + (ccu_clk->freq_id << (ccu_clk->freq_bit_shift * 3)); + writel(reg, base + ccu_clk->policy_freq_offset); + + /* enable all clock mask */ + writel(0x7fffffff, base + ccu_clk->policy0_mask_offset); + writel(0x7fffffff, base + ccu_clk->policy1_mask_offset); + writel(0x7fffffff, base + ccu_clk->policy2_mask_offset); + writel(0x7fffffff, base + ccu_clk->policy3_mask_offset); + + if (ccu_clk->num_policy_masks == 2) { + writel(0x7fffffff, base + ccu_clk->policy0_mask2_offset); + writel(0x7fffffff, base + ccu_clk->policy1_mask2_offset); + writel(0x7fffffff, base + ccu_clk->policy2_mask2_offset); + writel(0x7fffffff, base + ccu_clk->policy3_mask2_offset); + } + + /* start policy engine */ + reg = readl(base + ccu_clk->policy_ctl_offset); + reg |= (POLICY_CTL_GO + POLICY_CTL_GO_ATL); + writel(reg, base + ccu_clk->policy_ctl_offset); + + /* wait till started */ + ret = wait_bit(base, ccu_clk->policy_ctl_offset, 0, 0); + if (ret) + return ret; + + /* disable access */ + writel(0, base + WR_ACCESS_OFFSET); + + return ret; +} + +/* Get the CCU clock rate */ +static unsigned long ccu_clk_get_rate(struct clk *c) +{ + struct ccu_clock *ccu_clk = to_ccu_clk(c); + clk_dbg("%s: %s\n", __func__, c->name); + c->rate = ccu_clk->freq_tbl[ccu_clk->freq_id]; + return c->rate; +} + +/* CCU clock operations */ +struct clk_ops ccu_clk_ops = { + .enable = ccu_clk_enable, + .get_rate = ccu_clk_get_rate, +}; + +/* Enable a bus clock */ +static int bus_clk_enable(struct clk *c, int enable) +{ + struct bus_clock *bus_clk = to_bus_clk(c); + struct bus_clk_data *cd = bus_clk->data; + void *base = (void *)c->ccu_clk_mgr_base; + int ret = 0; + u32 reg; + + clk_dbg("%s: %s\n", __func__, c->name); + /* enable access */ + writel(CLK_WR_ACCESS_PASSWORD, base + WR_ACCESS_OFFSET); + + /* enable gating */ + reg = readl(base + cd->gate.offset); + if (!!(reg & (1 << cd->gate.status_bit)) == !!enable) + clk_dbg("%s already %s\n", c->name, + enable ? "enabled" : "disabled"); + else { + int want = (enable) ? 1 : 0; + reg |= (1 << cd->gate.hw_sw_sel_bit); + + if (enable) + reg |= (1 << cd->gate.en_bit); + else + reg &= ~(1 << cd->gate.en_bit); + + writel(reg, base + cd->gate.offset); + ret = wait_bit(base, cd->gate.offset, cd->gate.status_bit, + want); + if (ret) + return ret; + } + + /* disable access */ + writel(0, base + WR_ACCESS_OFFSET); + + return ret; +} + +/* Get the rate of a bus clock */ +static unsigned long bus_clk_get_rate(struct clk *c) +{ + struct bus_clock *bus_clk = to_bus_clk(c); + struct ccu_clock *ccu_clk; + + clk_dbg("%s: %s\n", __func__, c->name); + ccu_clk = to_ccu_clk(c->parent); + + c->rate = bus_clk->freq_tbl[ccu_clk->freq_id]; + c->div = ccu_clk->freq_tbl[ccu_clk->freq_id] / c->rate; + return c->rate; +} + +/* Bus clock operations */ +struct clk_ops bus_clk_ops = { + .enable = bus_clk_enable, + .get_rate = bus_clk_get_rate, +}; + +/* Enable a reference clock */ +static int ref_clk_enable(struct clk *c, int enable) +{ + clk_dbg("%s: %s\n", __func__, c->name); + return 0; +} + +/* Reference clock operations */ +struct clk_ops ref_clk_ops = { + .enable = ref_clk_enable, +}; + +/* + * clk.h implementation follows + */ + +/* Initialize the clock framework */ +int clk_init(void) +{ + clk_dbg("%s:\n", __func__); + return 0; +} + +/* Get a clock handle, give a name string */ +struct clk *clk_get(const char *con_id) +{ + int i; + struct clk_lookup *clk_tblp; + + clk_dbg("%s: %s\n", __func__, con_id); + + clk_tblp = arch_clk_tbl; + for (i = 0; i < arch_clk_tbl_array_size; i++, clk_tblp++) { + if (clk_tblp->con_id) { + if (!con_id || strcmp(clk_tblp->con_id, con_id)) + continue; + return clk_tblp->clk; + } + } + return NULL; +} + +/* Enable a clock */ +int clk_enable(struct clk *c) +{ + int ret = 0; + + clk_dbg("%s: %s\n", __func__, c->name); + if (!c->ops || !c->ops->enable) + return -1; + + /* enable parent clock first */ + if (c->parent) + ret = clk_enable(c->parent); + + if (ret) + return ret; + + if (!c->use_cnt) { + c->use_cnt++; + ret = c->ops->enable(c, 1); + } + + return ret; +} + +/* Disable a clock */ +void clk_disable(struct clk *c) +{ + clk_dbg("%s: %s\n", __func__, c->name); + if (!c->ops || !c->ops->enable) + return; + + if (c->use_cnt) { + c->use_cnt--; + c->ops->enable(c, 0); + } + + /* disable parent */ + if (c->parent) + clk_disable(c->parent); +} + +/* Get the clock rate */ +unsigned long clk_get_rate(struct clk *c) +{ + unsigned long rate; + + clk_dbg("%s: %s\n", __func__, c->name); + if (!c || !c->ops || !c->ops->get_rate) + return 0; + + rate = c->ops->get_rate(c); + clk_dbg("%s: rate = %ld\n", __func__, rate); + return rate; +} + +/* Set the clock rate */ +int clk_set_rate(struct clk *c, unsigned long rate) +{ + int ret; + + clk_dbg("%s: %s rate=%ld\n", __func__, c->name, rate); + if (!c || !c->ops || !c->ops->set_rate) + return -EINVAL; + + if (c->use_cnt) + return -EINVAL; + + ret = c->ops->set_rate(c, rate); + + return ret; +} + +/* Not required for this arch */ +/* +long clk_round_rate(struct clk *clk, unsigned long rate); +int clk_set_parent(struct clk *clk, struct clk *parent); +struct clk *clk_get_parent(struct clk *clk); +*/ diff --git a/arch/arm/cpu/armv7/bcm281xx/clk-core.h b/arch/arm/cpu/armv7/bcm281xx/clk-core.h new file mode 100644 index 0000000..2cface4 --- /dev/null +++ b/arch/arm/cpu/armv7/bcm281xx/clk-core.h @@ -0,0 +1,510 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +#include <linux/stddef.h> + +#ifdef CONFIG_CLK_DEBUG +#define clk_dbg printf +#undef writel +#undef readl +static inline void writel(u32 val, void *addr) +{ + printf("Write [0x%p] = 0x%08x\n", addr, val); + *(u32 *)addr = val; +} + +static inline u32 readl(void *addr) +{ + u32 val = *(u32 *)addr; + printf("Read [0x%p] = 0x%08x\n", addr, val); + return val; +} +#else +#define clk_dbg(...) +#endif + +#ifndef offsetof +#define offsetof(TYPE, MEMBER) ((size_t) &((TYPE *)0)->MEMBER) +#endif + +#ifndef container_of +#define container_of(ptr, type, member) ({ \ + const typeof(((type *)0)->member) * __mptr = (ptr); \ + (type *)((char *)__mptr - offsetof(type, member)); }) +#endif + +struct clk; + +struct clk_lookup { + const char *dev_id; + const char *con_id; + struct clk *clk; +}; + +extern struct clk_lookup arch_clk_tbl[]; +extern unsigned int arch_clk_tbl_array_size; + +/** + * struct clk_ops - standard clock operations + * @enable: enable/disable clock, see clk_enable() and clk_disable() + * @set_rate: set the clock rate, see clk_set_rate(). + * @get_rate: get the clock rate, see clk_get_rate(). + * @round_rate: round a given clock rate, see clk_round_rate(). + * @set_parent: set the clock's parent, see clk_set_parent(). + * + * Group the common clock implementations together so that we + * don't have to keep setting the same fiels again. We leave + * enable in struct clk. + * + */ +struct clk_ops { + int (*enable) (struct clk *c, int enable); + int (*set_rate) (struct clk *c, unsigned long rate); + unsigned long (*get_rate) (struct clk *c); + unsigned long (*round_rate) (struct clk *c, unsigned long rate); + int (*set_parent) (struct clk *c, struct clk *parent); +}; + +struct clk { + struct clk *parent; + const char *name; + int use_cnt; + unsigned long rate; /* in HZ */ + + /* programmable divider. 0 means fixed ratio to parent clock */ + unsigned long div; + + struct clk_src *src; + struct clk_ops *ops; + + unsigned long ccu_clk_mgr_base; + int sel; +}; + +struct refclk *refclk_str_to_clk(const char *name); + +#define U8_MAX ((u8)~0U) +#define U32_MAX ((u32)~0U) +#define U64_MAX ((u64)~0U) + +/* The common clock framework uses u8 to represent a parent index */ +#define PARENT_COUNT_MAX ((u32)U8_MAX) + +#define BAD_CLK_INDEX U8_MAX /* Can't ever be valid */ +#define BAD_CLK_NAME ((const char *)-1) + +#define BAD_SCALED_DIV_VALUE U64_MAX + +/* + * Utility macros for object flag management. If possible, flags + * should be defined such that 0 is the desired default value. + */ +#define FLAG(type, flag) BCM_CLK_ ## type ## _FLAGS_ ## flag +#define FLAG_SET(obj, type, flag) ((obj)->flags |= FLAG(type, flag)) +#define FLAG_CLEAR(obj, type, flag) ((obj)->flags &= ~(FLAG(type, flag))) +#define FLAG_FLIP(obj, type, flag) ((obj)->flags ^= FLAG(type, flag)) +#define FLAG_TEST(obj, type, flag) (!!((obj)->flags & FLAG(type, flag))) + +/* Clock field state tests */ + +#define gate_exists(gate) FLAG_TEST(gate, GATE, EXISTS) +#define gate_is_enabled(gate) FLAG_TEST(gate, GATE, ENABLED) +#define gate_is_hw_controllable(gate) FLAG_TEST(gate, GATE, HW) +#define gate_is_sw_controllable(gate) FLAG_TEST(gate, GATE, SW) +#define gate_is_sw_managed(gate) FLAG_TEST(gate, GATE, SW_MANAGED) +#define gate_is_no_disable(gate) FLAG_TEST(gate, GATE, NO_DISABLE) + +#define gate_flip_enabled(gate) FLAG_FLIP(gate, GATE, ENABLED) + +#define divider_exists(div) FLAG_TEST(div, DIV, EXISTS) +#define divider_is_fixed(div) FLAG_TEST(div, DIV, FIXED) +#define divider_has_fraction(div) (!divider_is_fixed(div) && \ + (div)->frac_width > 0) + +#define selector_exists(sel) ((sel)->width != 0) +#define trigger_exists(trig) FLAG_TEST(trig, TRIG, EXISTS) + +/* Clock type, used to tell common block what it's part of */ +enum bcm_clk_type { + bcm_clk_none, /* undefined clock type */ + bcm_clk_bus, + bcm_clk_core, + bcm_clk_peri +}; + +/* + * Gating control and status is managed by a 32-bit gate register. + * + * There are several types of gating available: + * - (no gate) + * A clock with no gate is assumed to be always enabled. + * - hardware-only gating (auto-gating) + * Enabling or disabling clocks with this type of gate is + * managed automatically by the hardware. Such clocks can be + * considered by the software to be enabled. The current status + * of auto-gated clocks can be read from the gate status bit. + * - software-only gating + * Auto-gating is not available for this type of clock. + * Instead, software manages whether it's enabled by setting or + * clearing the enable bit. The current gate status of a gate + * under software control can be read from the gate status bit. + * To ensure a change to the gating status is complete, the + * status bit can be polled to verify that the gate has entered + * the desired state. + * - selectable hardware or software gating + * Gating for this type of clock can be configured to be either + * under software or hardware control. Which type is in use is + * determined by the hw_sw_sel bit of the gate register. + */ +struct bcm_clk_gate { + u32 offset; /* gate register offset */ + u32 status_bit; /* 0: gate is disabled; 0: gatge is enabled */ + u32 en_bit; /* 0: disable; 1: enable */ + u32 hw_sw_sel_bit; /* 0: hardware gating; 1: software gating */ + u32 flags; /* BCM_CLK_GATE_FLAGS_* below */ +}; + +/* + * Gate flags: + * HW means this gate can be auto-gated + * SW means the state of this gate can be software controlled + * NO_DISABLE means this gate is (only) enabled if under software control + * SW_MANAGED means the status of this gate is under software control + * ENABLED means this software-managed gate is *supposed* to be enabled + */ +#define BCM_CLK_GATE_FLAGS_EXISTS ((u32)1 << 0) /* Gate is valid */ +#define BCM_CLK_GATE_FLAGS_HW ((u32)1 << 1) /* Can auto-gate */ +#define BCM_CLK_GATE_FLAGS_SW ((u32)1 << 2) /* Software control */ +#define BCM_CLK_GATE_FLAGS_NO_DISABLE ((u32)1 << 3) /* HW or enabled */ +#define BCM_CLK_GATE_FLAGS_SW_MANAGED ((u32)1 << 4) /* SW now in control */ +#define BCM_CLK_GATE_FLAGS_ENABLED ((u32)1 << 5) /* If SW_MANAGED */ + +/* + * Gate initialization macros. + * + * Any gate initially under software control will be enabled. + */ + +/* A hardware/software gate initially under software control */ +#define HW_SW_GATE(_offset, _status_bit, _en_bit, _hw_sw_sel_bit) \ + { \ + .offset = (_offset), \ + .status_bit = (_status_bit), \ + .en_bit = (_en_bit), \ + .hw_sw_sel_bit = (_hw_sw_sel_bit), \ + .flags = FLAG(GATE, HW)|FLAG(GATE, SW)| \ + FLAG(GATE, SW_MANAGED)|FLAG(GATE, ENABLED)| \ + FLAG(GATE, EXISTS), \ + } + +/* A hardware/software gate initially under hardware control */ +#define HW_SW_GATE_AUTO(_offset, _status_bit, _en_bit, _hw_sw_sel_bit) \ + { \ + .offset = (_offset), \ + .status_bit = (_status_bit), \ + .en_bit = (_en_bit), \ + .hw_sw_sel_bit = (_hw_sw_sel_bit), \ + .flags = FLAG(GATE, HW)|FLAG(GATE, SW)| \ + FLAG(GATE, EXISTS), \ + } + +/* A hardware-or-enabled gate (enabled if not under hardware control) */ +#define HW_ENABLE_GATE(_offset, _status_bit, _en_bit, _hw_sw_sel_bit) \ + { \ + .offset = (_offset), \ + .status_bit = (_status_bit), \ + .en_bit = (_en_bit), \ + .hw_sw_sel_bit = (_hw_sw_sel_bit), \ + .flags = FLAG(GATE, HW)|FLAG(GATE, SW)| \ + FLAG(GATE, NO_DISABLE)|FLAG(GATE, EXISTS), \ + } + +/* A software-only gate */ +#define SW_ONLY_GATE(_offset, _status_bit, _en_bit) \ + { \ + .offset = (_offset), \ + .status_bit = (_status_bit), \ + .en_bit = (_en_bit), \ + .flags = FLAG(GATE, SW)|FLAG(GATE, SW_MANAGED)| \ + FLAG(GATE, ENABLED)|FLAG(GATE, EXISTS), \ + } + +/* A hardware-only gate */ +#define HW_ONLY_GATE(_offset, _status_bit) \ + { \ + .offset = (_offset), \ + .status_bit = (_status_bit), \ + .flags = FLAG(GATE, HW)|FLAG(GATE, EXISTS), \ + } + +/* + * Each clock can have zero, one, or two dividers which change the + * output rate of the clock. Each divider can be either fixed or + * variable. If there are two dividers, they are the "pre-divider" + * and the "regular" or "downstream" divider. If there is only one, + * there is no pre-divider. + * + * A fixed divider is any non-zero (positive) value, and it + * indicates how the input rate is affected by the divider. + * + * The value of a variable divider is maintained in a sub-field of a + * 32-bit divider register. The position of the field in the + * register is defined by its offset and width. The value recorded + * in this field is always 1 less than the value it represents. + * + * In addition, a variable divider can indicate that some subset + * of its bits represent a "fractional" part of the divider. Such + * bits comprise the low-order portion of the divider field, and can + * be viewed as representing the portion of the divider that lies to + * the right of the decimal point. Most variable dividers have zero + * fractional bits. Variable dividers with non-zero fraction width + * still record a value 1 less than the value they represent; the + * added 1 does *not* affect the low-order bit in this case, it + * affects the bits above the fractional part only. (Often in this + * code a divider field value is distinguished from the value it + * represents by referring to the latter as a "divisor".) + * + * In order to avoid dealing with fractions, divider arithmetic is + * performed using "scaled" values. A scaled value is one that's + * been left-shifted by the fractional width of a divider. Dividing + * a scaled value by a scaled divisor produces the desired quotient + * without loss of precision and without any other special handling + * for fractions. + * + * The recorded value of a variable divider can be modified. To + * modify either divider (or both), a clock must be enabled (i.e., + * using its gate). In addition, a trigger register (described + * below) must be used to commit the change, and polled to verify + * the change is complete. + */ +struct bcm_clk_div { + union { + struct { /* variable divider */ + u32 offset; /* divider register offset */ + u32 shift; /* field shift */ + u32 width; /* field width */ + u32 frac_width; /* field fraction width */ + + u64 scaled_div; /* scaled divider value */ + }; + u32 fixed; /* non-zero fixed divider value */ + }; + u32 flags; /* BCM_CLK_DIV_FLAGS_* below */ +}; + +/* + * Divider flags: + * EXISTS means this divider exists + * FIXED means it is a fixed-rate divider + */ +#define BCM_CLK_DIV_FLAGS_EXISTS ((u32)1 << 0) /* Divider is valid */ +#define BCM_CLK_DIV_FLAGS_FIXED ((u32)1 << 1) /* Fixed-value */ + +/* Divider initialization macros */ + +/* A fixed (non-zero) divider */ +#define FIXED_DIVIDER(_value) \ + { \ + .fixed = (_value), \ + .flags = FLAG(DIV, EXISTS)|FLAG(DIV, FIXED), \ + } + +/* A divider with an integral divisor */ +#define DIVIDER(_offset, _shift, _width) \ + { \ + .offset = (_offset), \ + .shift = (_shift), \ + .width = (_width), \ + .scaled_div = BAD_SCALED_DIV_VALUE, \ + .flags = FLAG(DIV, EXISTS), \ + } + +/* A divider whose divisor has an integer and fractional part */ +#define FRAC_DIVIDER(_offset, _shift, _width, _frac_width) \ + { \ + .offset = (_offset), \ + .shift = (_shift), \ + .width = (_width), \ + .frac_width = (_frac_width), \ + .scaled_div = BAD_SCALED_DIV_VALUE, \ + .flags = FLAG(DIV, EXISTS), \ + } + +/* + * Clocks may have multiple "parent" clocks. If there is more than + * one, a selector must be specified to define which of the parent + * clocks is currently in use. The selected clock is indicated in a + * sub-field of a 32-bit selector register. The range of + * representable selector values typically exceeds the number of + * available parent clocks. Occasionally the reset value of a + * selector field is explicitly set to a (specific) value that does + * not correspond to a defined input clock. + * + * We register all known parent clocks with the common clock code + * using a packed array (i.e., no empty slots) of (parent) clock + * names, and refer to them later using indexes into that array. + * We maintain an array of selector values indexed by common clock + * index values in order to map between these common clock indexes + * and the selector values used by the hardware. + * + * Like dividers, a selector can be modified, but to do so a clock + * must be enabled, and a trigger must be used to commit the change. + */ +struct bcm_clk_sel { + u32 offset; /* selector register offset */ + u32 shift; /* field shift */ + u32 width; /* field width */ + + u32 parent_count; /* number of entries in parent_sel[] */ + u32 *parent_sel; /* array of parent selector values */ + u8 clk_index; /* current selected index in parent_sel[] */ +}; + +/* Selector initialization macro */ +#define SELECTOR(_offset, _shift, _width) \ + { \ + .offset = (_offset), \ + .shift = (_shift), \ + .width = (_width), \ + .clk_index = BAD_CLK_INDEX, \ + } + +/* + * Making changes to a variable divider or a selector for a clock + * requires the use of a trigger. A trigger is defined by a single + * bit within a register. To signal a change, a 1 is written into + * that bit. To determine when the change has been completed, that + * trigger bit is polled; the read value will be 1 while the change + * is in progress, and 0 when it is complete. + * + * Occasionally a clock will have more than one trigger. In this + * case, the "pre-trigger" will be used when changing a clock's + * selector and/or its pre-divider. + */ +struct bcm_clk_trig { + u32 offset; /* trigger register offset */ + u32 bit; /* trigger bit */ + u32 flags; /* BCM_CLK_TRIG_FLAGS_* below */ +}; + +/* + * Trigger flags: + * EXISTS means this trigger exists + */ +#define BCM_CLK_TRIG_FLAGS_EXISTS ((u32)1 << 0) /* Trigger is valid */ + +/* Trigger initialization macro */ +#define TRIGGER(_offset, _bit) \ + { \ + .offset = (_offset), \ + .bit = (_bit), \ + .flags = FLAG(TRIG, EXISTS), \ + } + +struct bus_clk_data { + struct bcm_clk_gate gate; +}; + +struct core_clk_data { + struct bcm_clk_gate gate; +}; + +struct peri_clk_data { + struct bcm_clk_gate gate; + struct bcm_clk_trig pre_trig; + struct bcm_clk_div pre_div; + struct bcm_clk_trig trig; + struct bcm_clk_div div; + struct bcm_clk_sel sel; + const char *clocks[]; /* must be last; use CLOCKS() to declare */ +}; +#define CLOCKS(...) { __VA_ARGS__, NULL, } +#define NO_CLOCKS { NULL, } /* Must use of no parent clocks */ + +struct refclk { + struct clk clk; +}; + +struct peri_clock { + struct clk clk; + struct peri_clk_data *data; +}; + +struct ccu_clock { + struct clk clk; + + int num_policy_masks; + unsigned long policy_freq_offset; + int freq_bit_shift; /* 8 for most CCUs */ + unsigned long policy_ctl_offset; + unsigned long policy0_mask_offset; + unsigned long policy1_mask_offset; + unsigned long policy2_mask_offset; + unsigned long policy3_mask_offset; + unsigned long policy0_mask2_offset; + unsigned long policy1_mask2_offset; + unsigned long policy2_mask2_offset; + unsigned long policy3_mask2_offset; + unsigned long lvm_en_offset; + + int freq_id; + unsigned long *freq_tbl; +}; + +struct bus_clock { + struct clk clk; + struct bus_clk_data *data; + unsigned long *freq_tbl; +}; + +struct ref_clock { + struct clk clk; +}; + +static inline int is_same_clock(struct clk *a, struct clk *b) +{ + return (a == b); +} + +#define to_clk(p) (&((p)->clk)) +#define name_to_clk(name) (&((name##_clk).clk)) +/* declare a struct clk_lookup */ +#define CLK_LK(name) \ +{.con_id = __stringify(name##_clk), .clk = name_to_clk(name),} + +static inline struct refclk *to_refclk(struct clk *clock) +{ + return container_of(clock, struct refclk, clk); +} + +static inline struct peri_clock *to_peri_clk(struct clk *clock) +{ + return container_of(clock, struct peri_clock, clk); +} + +static inline struct ccu_clock *to_ccu_clk(struct clk *clock) +{ + return container_of(clock, struct ccu_clock, clk); +} + +static inline struct bus_clock *to_bus_clk(struct clk *clock) +{ + return container_of(clock, struct bus_clock, clk); +} + +static inline struct ref_clock *to_ref_clk(struct clk *clock) +{ + return container_of(clock, struct ref_clock, clk); +} + +extern struct clk_ops peri_clk_ops; +extern struct clk_ops ccu_clk_ops; +extern struct clk_ops bus_clk_ops; +extern struct clk_ops ref_clk_ops; + +extern int clk_get_and_enable(char *clkstr); diff --git a/arch/arm/cpu/armv7/bcm281xx/clk-sdio.c b/arch/arm/cpu/armv7/bcm281xx/clk-sdio.c new file mode 100644 index 0000000..ec7ccc0 --- /dev/null +++ b/arch/arm/cpu/armv7/bcm281xx/clk-sdio.c @@ -0,0 +1,75 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +#include <common.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/sysmap.h> +#include <asm/kona-common/clk.h> +#include "clk-core.h" + +/* Enable appropriate clocks for an SDIO port */ +int clk_sdio_enable(void *base, u32 rate, u32 *actual_ratep) +{ + int ret; + struct clk *c; + + char *clkstr; + char *slpstr; + char *ahbstr; + + switch ((u32) base) { + case CONFIG_SYS_SDIO_BASE0: + clkstr = CONFIG_SYS_SDIO0 "_clk"; + ahbstr = CONFIG_SYS_SDIO0 "_ahb_clk"; + slpstr = CONFIG_SYS_SDIO0 "_sleep_clk"; + break; + case CONFIG_SYS_SDIO_BASE1: + clkstr = CONFIG_SYS_SDIO1 "_clk"; + ahbstr = CONFIG_SYS_SDIO1 "_ahb_clk"; + slpstr = CONFIG_SYS_SDIO1 "_sleep_clk"; + break; + case CONFIG_SYS_SDIO_BASE2: + clkstr = CONFIG_SYS_SDIO2 "_clk"; + ahbstr = CONFIG_SYS_SDIO2 "_ahb_clk"; + slpstr = CONFIG_SYS_SDIO2 "_sleep_clk"; + break; + case CONFIG_SYS_SDIO_BASE3: + clkstr = CONFIG_SYS_SDIO3 "_clk"; + ahbstr = CONFIG_SYS_SDIO3 "_ahb_clk"; + slpstr = CONFIG_SYS_SDIO3 "_sleep_clk"; + break; + default: + printf("%s: base 0x%p not found\n", __func__, base); + return -EINVAL; + } + + ret = clk_get_and_enable(ahbstr); + if (ret) + return ret; + + ret = clk_get_and_enable(slpstr); + if (ret) + return ret; + + c = clk_get(clkstr); + if (c) { + ret = clk_set_rate(c, rate); + if (ret) + return ret; + + ret = clk_enable(c); + if (ret) + return ret; + } else { + printf("%s: Couldn't find %s\n", __func__, clkstr); + return -EINVAL; + } + *actual_ratep = rate; + return 0; +} diff --git a/arch/arm/cpu/armv7/bcm281xx/reset.c b/arch/arm/cpu/armv7/bcm281xx/reset.c new file mode 100644 index 0000000..f66db5c --- /dev/null +++ b/arch/arm/cpu/armv7/bcm281xx/reset.c @@ -0,0 +1,29 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sysmap.h> + +#define EN_MASK 0x08000000 /* Enable timer */ +#define SRSTEN_MASK 0x04000000 /* Enable soft reset */ +#define CLKS_SHIFT 20 /* Clock period shift */ +#define LD_SHIFT 0 /* Reload value shift */ + +void reset_cpu(ulong ignored) +{ + /* + * Set WD enable, RST enable, + * 3.9 msec clock period (8), reload value (8*3.9ms) + */ + u32 reg = EN_MASK + SRSTEN_MASK + (8 << CLKS_SHIFT) + (8 << LD_SHIFT); + writel(reg, SECWD2_BASE_ADDR); + + while (1) + ; /* loop forever till reset */ +} diff --git a/arch/arm/include/asm/arch-bcm281xx/gpio.h b/arch/arm/include/asm/arch-bcm281xx/gpio.h new file mode 100644 index 0000000..b0e7b60 --- /dev/null +++ b/arch/arm/include/asm/arch-bcm281xx/gpio.h @@ -0,0 +1,17 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +#ifndef __ARCH_BCM281XX_GPIO_H +#define __ARCH_BCM281XX_GPIO_H + +/* + * Empty file - cmd_gpio.c requires this. The implementation + * is in drivers/gpio/kona_gpio.c instead of inlined here. + */ + +#endif diff --git a/arch/arm/include/asm/arch-bcm281xx/sysmap.h b/arch/arm/include/asm/arch-bcm281xx/sysmap.h new file mode 100644 index 0000000..20d391b --- /dev/null +++ b/arch/arm/include/asm/arch-bcm281xx/sysmap.h @@ -0,0 +1,27 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +#ifndef __ARCH_BCM281XX_SYSMAP_H + +#define BSC1_BASE_ADDR 0x3e016000 +#define BSC2_BASE_ADDR 0x3e017000 +#define BSC3_BASE_ADDR 0x3e018000 +#define GPIO2_BASE_ADDR 0x35003000 +#define KONA_MST_CLK_BASE_ADDR 0x3f001000 +#define KONA_SLV_CLK_BASE_ADDR 0x3e011000 +#define PMU_BSC_BASE_ADDR 0x3500d000 +#define PWRMGR_BASE_ADDR 0x35010000 +#define SDIO1_BASE_ADDR 0x3f180000 +#define SDIO2_BASE_ADDR 0x3f190000 +#define SDIO3_BASE_ADDR 0x3f1a0000 +#define SDIO4_BASE_ADDR 0x3f1b0000 +#define SECWD_BASE_ADDR 0x3500c000 +#define SECWD2_BASE_ADDR 0x35002f40 +#define TIMER_BASE_ADDR 0x3e00d000 + +#endif
[snip]
- return ((1 << width) - 1) << shift;
- return (reg_val & bitfield_mask(shift, width)) >> shift;
- u32 mask = bitfield_mask(shift, width);
- return (reg_val & ~mask) | (val << shift);
This all feels horribly generic, isn't there some linux header we've already got that I can't think off of the top of my head that gives us these kind of functions?
- clk_dbg("%s: %s\n", __func__, c->name);
Please juse use debug(...), here and elsewhere.
- const typeof(((type *)0)->member) * __mptr = (ptr); \
- (type *)((char *)__mptr - offsetof(type, member)); })
We already have these..
[snip]
Hi Tom,
I had a similar feeling. There are files such as include/linux/bitops.h and arch/arm/include/asm/bitops.h and a host of others, but these seem single bit oriented, and don't provide the functionality here. The bcm281xx clock registers are a myriad of bit fields of different widths and positions, and the driver code is simpler because it uses these generic bitfield functions and data tables to describe the bitfields. Perhaps the bcm281xx clock register hardware has revealed the need for more functions like this now. I've searched through the tree for equivalent functions and they don't seem to exist, but I could be wrong. We could create include/bitfield.h with functions specifically for bitfield operations if it were warranted. But if it only ever got used by one driver, it might be wrong to make it generic. But my gut feel is that if we did create include/bitfield.h it probably would be used by others who wanted to take a similar data-driven approach to register fields. We would also have to make it non-u32 specific I imagine, possibly just 'int' types. Thanks.
Darwin
<snip>
[snip]
Hi Tom,
With Matt chiming in on where this is within the kernel, lets go with creating a include/bitfield.h here. Thanks!
[snip]
Hi Tom,
Will implement this and will try to remove the u32's everywhere. Thanks.
[snip]
To add to what Darwin mentioned about bitops.h being insufficient...
The equivalent kernel implementations are wrapped up in the regmap/regmap-mmio helpers. That implementation is *very* heavyweight, and IMHO simply not appropriate for U-Boot (and often not useful in the kernel as well). A homegrown generic set of inline ops would seem to be ideal for U-Boot.
-Matt
Add support for the Kona GPIO controller found on Broadcom mobile SoCs.
Signed-off-by: Darwin Rambo drambo@broadcom.com Reviewed-by: Steve Rae srae@broadcom.com Reviewed-by: Markus Mayer markus.mayer@linaro.org Reviewed-by: Tim Kryger tkryger@linaro.org --- drivers/gpio/Makefile | 1 + drivers/gpio/kona_gpio.c | 143 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 144 insertions(+) create mode 100644 drivers/gpio/kona_gpio.c
diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index b903c45..ed2c0c7 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -8,6 +8,7 @@ obj-$(CONFIG_AT91_GPIO) += at91_gpio.o obj-$(CONFIG_INTEL_ICH6_GPIO) += intel_ich6_gpio.o obj-$(CONFIG_KIRKWOOD_GPIO) += kw_gpio.o +obj-$(CONFIG_KONA_GPIO) += kona_gpio.o obj-$(CONFIG_MARVELL_GPIO) += mvgpio.o obj-$(CONFIG_MARVELL_MFP) += mvmfp.o obj-$(CONFIG_MXC_GPIO) += mxc_gpio.o diff --git a/drivers/gpio/kona_gpio.c b/drivers/gpio/kona_gpio.c new file mode 100644 index 0000000..a5782cc --- /dev/null +++ b/drivers/gpio/kona_gpio.c @@ -0,0 +1,143 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sysmap.h> + +#define GPIO_BASE (void *)GPIO2_BASE_ADDR + +#define GPIO_PASSWD 0x00a5a501 +#define GPIO_PER_BANK 32 +#define GPIO_MAX_BANK_NUM 8 + +#define GPIO_BANK(gpio) ((gpio) >> 5) +#define GPIO_BITMASK(gpio) \ + (1UL << ((gpio) & (GPIO_PER_BANK - 1))) + +#define GPIO_OUT_STATUS(bank) (0x00000000 + ((bank) << 2)) +#define GPIO_IN_STATUS(bank) (0x00000020 + ((bank) << 2)) +#define GPIO_OUT_SET(bank) (0x00000040 + ((bank) << 2)) +#define GPIO_OUT_CLEAR(bank) (0x00000060 + ((bank) << 2)) +#define GPIO_INT_STATUS(bank) (0x00000080 + ((bank) << 2)) +#define GPIO_INT_MASK(bank) (0x000000a0 + ((bank) << 2)) +#define GPIO_INT_MSKCLR(bank) (0x000000c0 + ((bank) << 2)) +#define GPIO_CONTROL(bank) (0x00000100 + ((bank) << 2)) +#define GPIO_PWD_STATUS(bank) (0x00000500 + ((bank) << 2)) + +#define GPIO_GPPWR_OFFSET 0x00000520 + +#define GPIO_GPCTR0_DBR_SHIFT 5 +#define GPIO_GPCTR0_DBR_MASK 0x000001e0 + +#define GPIO_GPCTR0_ITR_SHIFT 3 +#define GPIO_GPCTR0_ITR_MASK 0x00000018 +#define GPIO_GPCTR0_ITR_CMD_RISING_EDGE 0x00000001 +#define GPIO_GPCTR0_ITR_CMD_FALLING_EDGE 0x00000002 +#define GPIO_GPCTR0_ITR_CMD_BOTH_EDGE 0x00000003 + +#define GPIO_GPCTR0_IOTR_MASK 0x00000001 +#define GPIO_GPCTR0_IOTR_CMD_0UTPUT 0x00000000 +#define GPIO_GPCTR0_IOTR_CMD_INPUT 0x00000001 + +int gpio_request(unsigned gpio, const char *label) +{ + unsigned int value, off; + + writel(GPIO_PASSWD, GPIO_BASE + GPIO_GPPWR_OFFSET); + off = GPIO_PWD_STATUS(GPIO_BANK(gpio)); + value = readl(GPIO_BASE + off) & ~GPIO_BITMASK(gpio); + writel(value, GPIO_BASE + off); + + return 0; +} + +int gpio_free(unsigned gpio) +{ + unsigned int value, off; + + writel(GPIO_PASSWD, GPIO_BASE + GPIO_GPPWR_OFFSET); + off = GPIO_PWD_STATUS(GPIO_BANK(gpio)); + value = readl(GPIO_BASE + off) | GPIO_BITMASK(gpio); + writel(value, GPIO_BASE + off); + + return 0; +} + +int gpio_direction_input(unsigned gpio) +{ + u32 val; + + val = readl(GPIO_BASE + GPIO_CONTROL(gpio)); + val &= ~GPIO_GPCTR0_IOTR_MASK; + val |= GPIO_GPCTR0_IOTR_CMD_INPUT; + writel(val, GPIO_BASE + GPIO_CONTROL(gpio)); + + return 0; +} + +int gpio_direction_output(unsigned gpio, int value) +{ + int bank_id = GPIO_BANK(gpio); + int bitmask = GPIO_BITMASK(gpio); + u32 val, off; + + val = readl(GPIO_BASE + GPIO_CONTROL(gpio)); + val &= ~GPIO_GPCTR0_IOTR_MASK; + val |= GPIO_GPCTR0_IOTR_CMD_0UTPUT; + writel(val, GPIO_BASE + GPIO_CONTROL(gpio)); + off = value ? GPIO_OUT_SET(bank_id) : GPIO_OUT_CLEAR(bank_id); + + val = readl(GPIO_BASE + off); + val |= bitmask; + writel(val, GPIO_BASE + off); + + return 0; +} + +int gpio_get_value(unsigned gpio) +{ + int bank_id = GPIO_BANK(gpio); + int bitmask = GPIO_BITMASK(gpio); + u32 val, off; + + /* determine the GPIO pin direction */ + val = readl(GPIO_BASE + GPIO_CONTROL(gpio)); + val &= GPIO_GPCTR0_IOTR_MASK; + + /* read the GPIO bank status */ + off = (GPIO_GPCTR0_IOTR_CMD_INPUT == val) ? + GPIO_IN_STATUS(bank_id) : GPIO_OUT_STATUS(bank_id); + val = readl(GPIO_BASE + off); + + /* return the specified bit status */ + return !!(val & bitmask); +} + +void gpio_set_value(unsigned gpio, int value) +{ + int bank_id = GPIO_BANK(gpio); + int bitmask = GPIO_BITMASK(gpio); + u32 val, off; + + /* determine the GPIO pin direction */ + val = readl(GPIO_BASE + GPIO_CONTROL(gpio)); + val &= GPIO_GPCTR0_IOTR_MASK; + + /* this function only applies to output pin */ + if (GPIO_GPCTR0_IOTR_CMD_INPUT == val) { + printf("%s: Cannot set an input pin %d\n", __func__, gpio); + return; + } + + off = value ? GPIO_OUT_SET(bank_id) : GPIO_OUT_CLEAR(bank_id); + + val = readl(GPIO_BASE + off); + val |= bitmask; + writel(val, GPIO_BASE + off); +}
Add support for the Kona I2C controller found on Broadcom mobile SoCs.
Signed-off-by: Darwin Rambo drambo@broadcom.com Reviewed-by: Steve Rae srae@broadcom.com Reviewed-by: Tim Kryger tkryger@linaro.org --- drivers/i2c/Makefile | 1 + drivers/i2c/kona_i2c.c | 730 ++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 731 insertions(+) create mode 100644 drivers/i2c/kona_i2c.c
diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index fa3a875..36d5e5f 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -18,6 +18,7 @@ obj-$(CONFIG_SH_SH7734_I2C) += sh_sh7734_i2c.o obj-$(CONFIG_SYS_I2C) += i2c_core.o obj-$(CONFIG_SYS_I2C_FSL) += fsl_i2c.o obj-$(CONFIG_SYS_I2C_FTI2C010) += fti2c010.o +obj-$(CONFIG_SYS_I2C_KONA) += kona_i2c.o obj-$(CONFIG_SYS_I2C_MXC) += mxc_i2c.o obj-$(CONFIG_SYS_I2C_OMAP24XX) += omap24xx_i2c.o obj-$(CONFIG_SYS_I2C_OMAP34XX) += omap24xx_i2c.o diff --git a/drivers/i2c/kona_i2c.c b/drivers/i2c/kona_i2c.c new file mode 100644 index 0000000..049457a --- /dev/null +++ b/drivers/i2c/kona_i2c.c @@ -0,0 +1,730 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +#include <common.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/sysmap.h> +#include <asm/kona-common/clk.h> +#include <i2c.h> + +/* Hardware register offsets and field defintions */ +#define CS_OFFSET 0x00000020 +#define CS_ACK_SHIFT 3 +#define CS_ACK_MASK 0x00000008 +#define CS_ACK_CMD_GEN_START 0x00000000 +#define CS_ACK_CMD_GEN_RESTART 0x00000001 +#define CS_CMD_SHIFT 1 +#define CS_CMD_CMD_NO_ACTION 0x00000000 +#define CS_CMD_CMD_START_RESTART 0x00000001 +#define CS_CMD_CMD_STOP 0x00000002 +#define CS_EN_SHIFT 0 +#define CS_EN_CMD_ENABLE_BSC 0x00000001 + +#define TIM_OFFSET 0x00000024 +#define TIM_PRESCALE_SHIFT 6 +#define TIM_P_SHIFT 3 +#define TIM_NO_DIV_SHIFT 2 +#define TIM_DIV_SHIFT 0 + +#define DAT_OFFSET 0x00000028 + +#define TOUT_OFFSET 0x0000002c + +#define TXFCR_OFFSET 0x0000003c +#define TXFCR_FIFO_FLUSH_MASK 0x00000080 +#define TXFCR_FIFO_EN_MASK 0x00000040 + +#define IER_OFFSET 0x00000044 +#define IER_READ_COMPLETE_INT_MASK 0x00000010 +#define IER_I2C_INT_EN_MASK 0x00000008 +#define IER_FIFO_INT_EN_MASK 0x00000002 +#define IER_NOACK_EN_MASK 0x00000001 + +#define ISR_OFFSET 0x00000048 +#define ISR_RESERVED_MASK 0xffffff60 +#define ISR_CMDBUSY_MASK 0x00000080 +#define ISR_READ_COMPLETE_MASK 0x00000010 +#define ISR_SES_DONE_MASK 0x00000008 +#define ISR_ERR_MASK 0x00000004 +#define ISR_TXFIFOEMPTY_MASK 0x00000002 +#define ISR_NOACK_MASK 0x00000001 + +#define CLKEN_OFFSET 0x0000004c +#define CLKEN_AUTOSENSE_OFF_MASK 0x00000080 +#define CLKEN_M_SHIFT 4 +#define CLKEN_N_SHIFT 1 +#define CLKEN_CLKEN_MASK 0x00000001 + +#define FIFO_STATUS_OFFSET 0x00000054 +#define FIFO_STATUS_RXFIFO_EMPTY_MASK 0x00000004 +#define FIFO_STATUS_TXFIFO_EMPTY_MASK 0x00000010 + +#define HSTIM_OFFSET 0x00000058 +#define HSTIM_HS_MODE_MASK 0x00008000 +#define HSTIM_HS_HOLD_SHIFT 10 +#define HSTIM_HS_HIGH_PHASE_SHIFT 5 +#define HSTIM_HS_SETUP_SHIFT 0 + +#define PADCTL_OFFSET 0x0000005c +#define PADCTL_PAD_OUT_EN_MASK 0x00000004 + +#define RXFCR_OFFSET 0x00000068 +#define RXFCR_NACK_EN_SHIFT 7 +#define RXFCR_READ_COUNT_SHIFT 0 +#define RXFIFORDOUT_OFFSET 0x0000006c + +/* Locally used constants */ +#define MAX_RX_FIFO_SIZE 64U /* bytes */ +#define MAX_TX_FIFO_SIZE 64U /* bytes */ + +#define I2C_TIMEOUT 100000 /* usecs */ + +#define WAIT_INT_CHK 100 /* usecs */ +#if I2C_TIMEOUT % WAIT_INT_CHK +#error I2C_TIMEOUT must be a multiple of WAIT_INT_CHK +#endif + +/* Operations that can be commanded to the controller */ +enum bcm_kona_cmd_t { + BCM_CMD_NOACTION = 0, + BCM_CMD_START, + BCM_CMD_RESTART, + BCM_CMD_STOP, +}; + +enum bus_speed_index { + BCM_SPD_100K = 0, + BCM_SPD_400K, + BCM_SPD_1MHZ, +}; + +/* Internal divider settings for standard mode, fast mode and fast mode plus */ +struct bus_speed_cfg { + uint8_t time_m; /* Number of cycles for setup time */ + uint8_t time_n; /* Number of cycles for hold time */ + uint8_t prescale; /* Prescale divider */ + uint8_t time_p; /* Timing coefficient */ + uint8_t no_div; /* Disable clock divider */ + uint8_t time_div; /* Post-prescale divider */ +}; + +static const struct bus_speed_cfg std_cfg_table[] = { + [BCM_SPD_100K] = {0x01, 0x01, 0x03, 0x06, 0x00, 0x02}, + [BCM_SPD_400K] = {0x05, 0x01, 0x03, 0x05, 0x01, 0x02}, + [BCM_SPD_1MHZ] = {0x01, 0x01, 0x03, 0x01, 0x01, 0x03}, +}; + +struct bcm_kona_i2c_dev { + void *base; + uint speed; + const struct bus_speed_cfg *std_cfg; +}; + +/* Keep these two defines in sync */ +#define DEF_SPD 100000 +#define DEF_SPD_ENUM BCM_SPD_100K + +#define DEF_DEVICE(num) \ +{(void *)CONFIG_SYS_I2C_BASE##num, DEF_SPD, &std_cfg_table[DEF_SPD_ENUM]} + +static struct bcm_kona_i2c_dev g_i2c_devs[CONFIG_SYS_MAX_I2C_BUS] = { +#ifdef CONFIG_SYS_I2C_BASE0 + DEF_DEVICE(0), +#endif +#ifdef CONFIG_SYS_I2C_BASE1 + DEF_DEVICE(1), +#endif +#ifdef CONFIG_SYS_I2C_BASE2 + DEF_DEVICE(2), +#endif +#ifdef CONFIG_SYS_I2C_BASE3 + DEF_DEVICE(3), +#endif +#ifdef CONFIG_SYS_I2C_BASE4 + DEF_DEVICE(4), +#endif +#ifdef CONFIG_SYS_I2C_BASE5 + DEF_DEVICE(5), +#endif +}; + +#define I2C_M_TEN 0x0010 /* ten bit address */ +#define I2C_M_RD 0x0001 /* read data */ +#define I2C_M_NOSTART 0x4000 /* no restart between msgs */ + +struct i2c_msg { + uint16_t addr; + uint16_t flags; + uint16_t len; + uint8_t *buf; +}; + +static void bcm_kona_i2c_send_cmd_to_ctrl(struct bcm_kona_i2c_dev *dev, + enum bcm_kona_cmd_t cmd) +{ + debug("%s, %d\n", __func__, cmd); + + switch (cmd) { + case BCM_CMD_NOACTION: + writel((CS_CMD_CMD_NO_ACTION << CS_CMD_SHIFT) | + (CS_EN_CMD_ENABLE_BSC << CS_EN_SHIFT), + dev->base + CS_OFFSET); + break; + + case BCM_CMD_START: + writel((CS_ACK_CMD_GEN_START << CS_ACK_SHIFT) | + (CS_CMD_CMD_START_RESTART << CS_CMD_SHIFT) | + (CS_EN_CMD_ENABLE_BSC << CS_EN_SHIFT), + dev->base + CS_OFFSET); + break; + + case BCM_CMD_RESTART: + writel((CS_ACK_CMD_GEN_RESTART << CS_ACK_SHIFT) | + (CS_CMD_CMD_START_RESTART << CS_CMD_SHIFT) | + (CS_EN_CMD_ENABLE_BSC << CS_EN_SHIFT), + dev->base + CS_OFFSET); + break; + + case BCM_CMD_STOP: + writel((CS_CMD_CMD_STOP << CS_CMD_SHIFT) | + (CS_EN_CMD_ENABLE_BSC << CS_EN_SHIFT), + dev->base + CS_OFFSET); + break; + + default: + printf("Unknown command %d\n", cmd); + } +} + +static void bcm_kona_i2c_enable_clock(struct bcm_kona_i2c_dev *dev) +{ + writel(readl(dev->base + CLKEN_OFFSET) | CLKEN_CLKEN_MASK, + dev->base + CLKEN_OFFSET); +} + +static void bcm_kona_i2c_disable_clock(struct bcm_kona_i2c_dev *dev) +{ + writel(readl(dev->base + CLKEN_OFFSET) & ~CLKEN_CLKEN_MASK, + dev->base + CLKEN_OFFSET); +} + +/* Wait until at least one of the mask bit(s) are set */ +static unsigned long wait_for_int_timeout(struct bcm_kona_i2c_dev *dev, + unsigned long time_left, + uint32_t mask) +{ + uint32_t status; + + while (time_left) { + status = readl(dev->base + ISR_OFFSET); + + if ((status & ~ISR_RESERVED_MASK) == 0) { + debug("Bogus I2C interrupt 0x%x\n", status); + continue; + } + + /* Must flush the TX FIFO when NAK detected */ + if (status & ISR_NOACK_MASK) + writel(TXFCR_FIFO_FLUSH_MASK | TXFCR_FIFO_EN_MASK, + dev->base + TXFCR_OFFSET); + + writel(status & ~ISR_RESERVED_MASK, dev->base + ISR_OFFSET); + + if (status & mask) { + /* We are done since one of the mask bits are set */ + return time_left; + } + udelay(WAIT_INT_CHK); + time_left -= WAIT_INT_CHK; + } + return 0; +} + +/* Send command to I2C bus */ +static int bcm_kona_send_i2c_cmd(struct bcm_kona_i2c_dev *dev, + enum bcm_kona_cmd_t cmd) +{ + int rc = 0; + unsigned long time_left = I2C_TIMEOUT; + + /* Send the command */ + bcm_kona_i2c_send_cmd_to_ctrl(dev, cmd); + + /* Wait for transaction to finish or timeout */ + time_left = wait_for_int_timeout(dev, time_left, IER_I2C_INT_EN_MASK); + + if (!time_left) { + printf("controller timed out\n"); + rc = -ETIMEDOUT; + } + + /* Clear command */ + bcm_kona_i2c_send_cmd_to_ctrl(dev, BCM_CMD_NOACTION); + + return rc; +} + +/* Read a single RX FIFO worth of data from the i2c bus */ +static int bcm_kona_i2c_read_fifo_single(struct bcm_kona_i2c_dev *dev, + uint8_t *buf, unsigned int len, + unsigned int last_byte_nak) +{ + unsigned long time_left = I2C_TIMEOUT; + + /* Start the RX FIFO */ + writel((last_byte_nak << RXFCR_NACK_EN_SHIFT) | + (len << RXFCR_READ_COUNT_SHIFT), dev->base + RXFCR_OFFSET); + + /* Wait for FIFO read to complete */ + time_left = + wait_for_int_timeout(dev, time_left, IER_READ_COMPLETE_INT_MASK); + + if (!time_left) { + printf("RX FIFO time out\n"); + return -EREMOTEIO; + } + + /* Read data from FIFO */ + for (; len > 0; len--, buf++) + *buf = readl(dev->base + RXFIFORDOUT_OFFSET); + + return 0; +} + +/* Read any amount of data using the RX FIFO from the i2c bus */ +static int bcm_kona_i2c_read_fifo(struct bcm_kona_i2c_dev *dev, + struct i2c_msg *msg) +{ + unsigned int bytes_to_read = MAX_RX_FIFO_SIZE; + unsigned int last_byte_nak = 0; + unsigned int bytes_read = 0; + int rc; + + uint8_t *tmp_buf = msg->buf; + + while (bytes_read < msg->len) { + if (msg->len - bytes_read <= MAX_RX_FIFO_SIZE) { + last_byte_nak = 1; /* NAK last byte of transfer */ + bytes_to_read = msg->len - bytes_read; + } + + rc = bcm_kona_i2c_read_fifo_single(dev, tmp_buf, bytes_to_read, + last_byte_nak); + if (rc < 0) + return -EREMOTEIO; + + bytes_read += bytes_to_read; + tmp_buf += bytes_to_read; + } + + return 0; +} + +/* Write a single byte of data to the i2c bus */ +static int bcm_kona_i2c_write_byte(struct bcm_kona_i2c_dev *dev, uint8_t data, + unsigned int nak_expected) +{ + unsigned long time_left = I2C_TIMEOUT; + unsigned int nak_received; + + /* Clear pending session done interrupt */ + writel(ISR_SES_DONE_MASK, dev->base + ISR_OFFSET); + + /* Send one byte of data */ + writel(data, dev->base + DAT_OFFSET); + + time_left = wait_for_int_timeout(dev, time_left, IER_I2C_INT_EN_MASK); + + if (!time_left) { + debug("controller timed out\n"); + return -ETIMEDOUT; + } + + nak_received = readl(dev->base + CS_OFFSET) & CS_ACK_MASK ? 1 : 0; + + if (nak_received ^ nak_expected) { + debug("unexpected NAK/ACK\n"); + return -EREMOTEIO; + } + + return 0; +} + +/* Write a single TX FIFO worth of data to the i2c bus */ +static int bcm_kona_i2c_write_fifo_single(struct bcm_kona_i2c_dev *dev, + uint8_t *buf, unsigned int len) +{ + int k; + unsigned long time_left = I2C_TIMEOUT; + unsigned int fifo_status; + + /* Write data into FIFO */ + for (k = 0; k < len; k++) + writel(buf[k], (dev->base + DAT_OFFSET)); + + /* Wait for FIFO to empty */ + do { + time_left = + wait_for_int_timeout(dev, time_left, + (IER_FIFO_INT_EN_MASK | + IER_NOACK_EN_MASK)); + fifo_status = readl(dev->base + FIFO_STATUS_OFFSET); + } while (time_left && !(fifo_status & FIFO_STATUS_TXFIFO_EMPTY_MASK)); + + /* Check if there was a NAK */ + if (readl(dev->base + CS_OFFSET) & CS_ACK_MASK) { + printf("unexpected NAK\n"); + return -EREMOTEIO; + } + + /* Check if a timeout occured */ + if (!time_left) { + printf("completion timed out\n"); + return -EREMOTEIO; + } + + return 0; +} + +/* Write any amount of data using TX FIFO to the i2c bus */ +static int bcm_kona_i2c_write_fifo(struct bcm_kona_i2c_dev *dev, + struct i2c_msg *msg) +{ + unsigned int bytes_to_write = MAX_TX_FIFO_SIZE; + unsigned int bytes_written = 0; + int rc; + + uint8_t *tmp_buf = msg->buf; + + while (bytes_written < msg->len) { + if (msg->len - bytes_written <= MAX_TX_FIFO_SIZE) + bytes_to_write = msg->len - bytes_written; + + rc = bcm_kona_i2c_write_fifo_single(dev, tmp_buf, + bytes_to_write); + if (rc < 0) + return -EREMOTEIO; + + bytes_written += bytes_to_write; + tmp_buf += bytes_to_write; + } + + return 0; +} + +/* Send i2c address */ +static int bcm_kona_i2c_do_addr(struct bcm_kona_i2c_dev *dev, + struct i2c_msg *msg) +{ + unsigned char addr; + + if (msg->flags & I2C_M_TEN) { + /* First byte is 11110XX0 where XX is upper 2 bits */ + addr = 0xf0 | ((msg->addr & 0x300) >> 7); + if (bcm_kona_i2c_write_byte(dev, addr, 0) < 0) + return -EREMOTEIO; + + /* Second byte is the remaining 8 bits */ + addr = msg->addr & 0xff; + if (bcm_kona_i2c_write_byte(dev, addr, 0) < 0) + return -EREMOTEIO; + + if (msg->flags & I2C_M_RD) { + /* For read, send restart command */ + if (bcm_kona_send_i2c_cmd(dev, BCM_CMD_RESTART) < 0) + return -EREMOTEIO; + + /* Then re-send the first byte with the read bit set */ + addr = 0xf0 | ((msg->addr & 0x300) >> 7) | 0x01; + if (bcm_kona_i2c_write_byte(dev, addr, 0) < 0) + return -EREMOTEIO; + } + } else { + addr = msg->addr << 1; + + if (msg->flags & I2C_M_RD) + addr |= 1; + + if (bcm_kona_i2c_write_byte(dev, addr, 0) < 0) + return -EREMOTEIO; + } + + return 0; +} + +static void bcm_kona_i2c_enable_autosense(struct bcm_kona_i2c_dev *dev) +{ + writel(readl(dev->base + CLKEN_OFFSET) & ~CLKEN_AUTOSENSE_OFF_MASK, + dev->base + CLKEN_OFFSET); +} + +static void bcm_kona_i2c_config_timing(struct bcm_kona_i2c_dev *dev) +{ + writel(readl(dev->base + HSTIM_OFFSET) & ~HSTIM_HS_MODE_MASK, + dev->base + HSTIM_OFFSET); + + writel((dev->std_cfg->prescale << TIM_PRESCALE_SHIFT) | + (dev->std_cfg->time_p << TIM_P_SHIFT) | + (dev->std_cfg->no_div << TIM_NO_DIV_SHIFT) | + (dev->std_cfg->time_div << TIM_DIV_SHIFT), + dev->base + TIM_OFFSET); + + writel((dev->std_cfg->time_m << CLKEN_M_SHIFT) | + (dev->std_cfg->time_n << CLKEN_N_SHIFT) | + CLKEN_CLKEN_MASK, dev->base + CLKEN_OFFSET); +} + +/* Master transfer function */ +static int bcm_kona_i2c_xfer(struct bcm_kona_i2c_dev *dev, + struct i2c_msg msgs[], int num) +{ + struct i2c_msg *pmsg; + int rc = 0; + int i; + + /* Enable pad output */ + writel(0, dev->base + PADCTL_OFFSET); + + /* Enable internal clocks */ + bcm_kona_i2c_enable_clock(dev); + + /* Send start command */ + rc = bcm_kona_send_i2c_cmd(dev, BCM_CMD_START); + if (rc < 0) { + printf("Start command failed rc = %d\n", rc); + goto xfer_disable_pad; + } + + /* Loop through all messages */ + for (i = 0; i < num; i++) { + pmsg = &msgs[i]; + + /* Send restart for subsequent messages */ + if ((i != 0) && ((pmsg->flags & I2C_M_NOSTART) == 0)) { + rc = bcm_kona_send_i2c_cmd(dev, BCM_CMD_RESTART); + if (rc < 0) { + printf("restart cmd failed rc = %d\n", rc); + goto xfer_send_stop; + } + } + + /* Send slave address */ + if (!(pmsg->flags & I2C_M_NOSTART)) { + rc = bcm_kona_i2c_do_addr(dev, pmsg); + if (rc < 0) { + debug("NAK from addr %2.2x msg#%d rc = %d\n", + pmsg->addr, i, rc); + goto xfer_send_stop; + } + } + + /* Perform data transfer */ + if (pmsg->flags & I2C_M_RD) { + rc = bcm_kona_i2c_read_fifo(dev, pmsg); + if (rc < 0) { + printf("read failure\n"); + goto xfer_send_stop; + } + } else { + rc = bcm_kona_i2c_write_fifo(dev, pmsg); + if (rc < 0) { + printf("write failure"); + goto xfer_send_stop; + } + } + } + + rc = num; + +xfer_send_stop: + /* Send a STOP command */ + bcm_kona_send_i2c_cmd(dev, BCM_CMD_STOP); + +xfer_disable_pad: + /* Disable pad output */ + writel(PADCTL_PAD_OUT_EN_MASK, dev->base + PADCTL_OFFSET); + + /* Stop internal clock */ + bcm_kona_i2c_disable_clock(dev); + + return rc; +} + +static uint bcm_kona_i2c_assign_bus_speed(struct bcm_kona_i2c_dev *dev, + uint speed) +{ + switch (speed) { + case 100000: + dev->std_cfg = &std_cfg_table[BCM_SPD_100K]; + break; + case 400000: + dev->std_cfg = &std_cfg_table[BCM_SPD_400K]; + break; + case 1000000: + dev->std_cfg = &std_cfg_table[BCM_SPD_1MHZ]; + break; + default: + printf("%d hz bus speed not supported\n", speed); + return -EINVAL; + } + dev->speed = speed; + return 0; +} + +static void bcm_kona_i2c_init(struct bcm_kona_i2c_dev *dev) +{ + /* Parse bus speed */ + bcm_kona_i2c_assign_bus_speed(dev, dev->speed); + + /* Enable internal clocks */ + bcm_kona_i2c_enable_clock(dev); + + /* Configure internal dividers */ + bcm_kona_i2c_config_timing(dev); + + /* Disable timeout */ + writel(0, dev->base + TOUT_OFFSET); + + /* Enable autosense */ + bcm_kona_i2c_enable_autosense(dev); + + /* Enable TX FIFO */ + writel(TXFCR_FIFO_FLUSH_MASK | TXFCR_FIFO_EN_MASK, + dev->base + TXFCR_OFFSET); + + /* Mask all interrupts */ + writel(0, dev->base + IER_OFFSET); + + /* Clear all pending interrupts */ + writel(ISR_CMDBUSY_MASK | + ISR_READ_COMPLETE_MASK | + ISR_SES_DONE_MASK | + ISR_ERR_MASK | + ISR_TXFIFOEMPTY_MASK | ISR_NOACK_MASK, dev->base + ISR_OFFSET); + + /* Enable the controller but leave it idle */ + bcm_kona_i2c_send_cmd_to_ctrl(dev, BCM_CMD_NOACTION); + + /* Disable pad output */ + writel(PADCTL_PAD_OUT_EN_MASK, dev->base + PADCTL_OFFSET); +} + +/**************** uboot layer ********************/ +struct bcm_kona_i2c_dev *kona_get_dev(struct i2c_adapter *adap) +{ + return &g_i2c_devs[adap->hwadapnr]; +} + +static void kona_i2c_init(struct i2c_adapter *adap, int speed, int slaveaddr) +{ + struct bcm_kona_i2c_dev *dev = kona_get_dev(adap); + + if (clk_bsc_enable(dev->base)) + return; + + bcm_kona_i2c_init(dev); +} + +static int kona_i2c_read(struct i2c_adapter *adap, uchar chip, uint addr, + int alen, uchar *buffer, int len) +{ + /* msg[0] writes the addr, msg[1] reads the data */ + struct i2c_msg msg[2]; + unsigned char msgbuf0[64]; + struct bcm_kona_i2c_dev *dev = kona_get_dev(adap); + + msg[0].addr = chip; + msg[0].flags = 0; + msg[0].len = 1; + msg[0].buf = msgbuf0; /* msgbuf0 contains incrementing reg addr */ + + msg[1].addr = chip; + msg[1].flags = I2C_M_RD; + /* msg[1].buf dest ptr increments each read */ + + msgbuf0[0] = (unsigned char)addr; + msg[1].buf = buffer; + msg[1].len = len; + if (bcm_kona_i2c_xfer(dev, msg, 2) < 0) { + /* Sending 2 i2c messages */ + kona_i2c_init(adap, adap->speed, adap->slaveaddr); + debug("I2C read: I/O error\n"); + return -EIO; + } + return 0; +} + +static int kona_i2c_write(struct i2c_adapter *adap, uchar chip, uint addr, + int alen, uchar *buffer, int len) +{ + struct i2c_msg msg[0]; + unsigned char msgbuf0[64]; + unsigned int i; + struct bcm_kona_i2c_dev *dev = kona_get_dev(adap); + + msg[0].addr = chip; + msg[0].flags = 0; + msg[0].len = 2; /* addr byte plus data */ + msg[0].buf = msgbuf0; + + for (i = 0; i < len; i++) { + msgbuf0[0] = addr++; + msgbuf0[1] = buffer[i]; + if (bcm_kona_i2c_xfer(dev, msg, 1) < 0) { + kona_i2c_init(adap, adap->speed, adap->slaveaddr); + debug("I2C write: I/O error\n"); + return -EIO; + } + } + return 0; +} + +static int kona_i2c_probe(struct i2c_adapter *adap, uchar chip) +{ + uchar tmp; + + /* + * read addr 0x0 of the given chip. + */ + return kona_i2c_read(adap, chip, 0x0, 1, &tmp, 1); +} + +static uint kona_i2c_set_bus_speed(struct i2c_adapter *adap, uint speed) +{ + struct bcm_kona_i2c_dev *dev = kona_get_dev(adap); + return bcm_kona_i2c_assign_bus_speed(dev, speed); +} + +/* + * Register kona i2c adapters. Keep the order below so + * that the bus number matches the adapter number. + */ +#define DEF_ADAPTER(num) \ +U_BOOT_I2C_ADAP_COMPLETE(kona##num, kona_i2c_init, kona_i2c_probe, \ + kona_i2c_read, kona_i2c_write, \ + kona_i2c_set_bus_speed, DEF_SPD, 0x00, num) + +#ifdef CONFIG_SYS_I2C_BASE0 + DEF_ADAPTER(0) +#endif +#ifdef CONFIG_SYS_I2C_BASE1 + DEF_ADAPTER(1) +#endif +#ifdef CONFIG_SYS_I2C_BASE2 + DEF_ADAPTER(2) +#endif +#ifdef CONFIG_SYS_I2C_BASE3 + DEF_ADAPTER(3) +#endif +#ifdef CONFIG_SYS_I2C_BASE4 + DEF_ADAPTER(4) +#endif +#ifdef CONFIG_SYS_I2C_BASE5 + DEF_ADAPTER(5) +#endif
Add support for the Kona SDHCI found on Broadcom mobile SoCs.
Signed-off-by: Darwin Rambo drambo@broadcom.com Reviewed-by: Steve Rae srae@broadcom.com Reviewed-by: Tim Kryger tkryger@linaro.org --- drivers/mmc/Makefile | 1 + drivers/mmc/kona_sdhci.c | 127 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 128 insertions(+) create mode 100644 drivers/mmc/kona_sdhci.c
diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index e793ed9..931922b 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -21,6 +21,7 @@ obj-$(CONFIG_OMAP_HSMMC) += omap_hsmmc.o obj-$(CONFIG_PXA_MMC_GENERIC) += pxa_mmc_gen.o obj-$(CONFIG_SDHCI) += sdhci.o obj-$(CONFIG_BCM2835_SDHCI) += bcm2835_sdhci.o +obj-$(CONFIG_KONA_SDHCI) += kona_sdhci.o obj-$(CONFIG_S5P_SDHCI) += s5p_sdhci.o obj-$(CONFIG_SH_MMCIF) += sh_mmcif.o obj-$(CONFIG_SPEAR_SDHCI) += spear_sdhci.o diff --git a/drivers/mmc/kona_sdhci.c b/drivers/mmc/kona_sdhci.c new file mode 100644 index 0000000..c38e18e --- /dev/null +++ b/drivers/mmc/kona_sdhci.c @@ -0,0 +1,127 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +#include <common.h> +#include <malloc.h> +#include <sdhci.h> +#include <asm/errno.h> +#include <asm/kona-common/clk.h> + +#define SDHCI_CORECTRL_OFFSET 0x00008000 +#define SDHCI_CORECTRL_EN 0x01 +#define SDHCI_CORECTRL_RESET 0x02 + +#define SDHCI_CORESTAT_OFFSET 0x00008004 +#define SDHCI_CORESTAT_CD_SW 0x01 + +#define SDHCI_COREIMR_OFFSET 0x00008008 +#define SDHCI_COREIMR_IP 0x01 + +static int init_mmc_core(struct sdhci_host *host) +{ + unsigned int mask; + unsigned int timeout; + + if (sdhci_readb(host, SDHCI_SOFTWARE_RESET) & SDHCI_RESET_ALL) { + printf("%s: sd host controller reset error\n", __func__); + return 1; + } + + /* For kona a hardware reset before anything else. */ + mask = sdhci_readl(host, SDHCI_CORECTRL_OFFSET) | SDHCI_CORECTRL_RESET; + sdhci_writel(host, mask, SDHCI_CORECTRL_OFFSET); + + /* Wait max 100 ms */ + timeout = 1000; + do { + if (timeout == 0) { + printf("%s: reset timeout error\n", __func__); + return 1; + } + timeout--; + udelay(100); + } while (0 == + (sdhci_readl(host, SDHCI_CORECTRL_OFFSET) & + SDHCI_CORECTRL_RESET)); + + /* Clear the reset bit. */ + mask = mask & ~SDHCI_CORECTRL_RESET; + sdhci_writel(host, mask, SDHCI_CORECTRL_OFFSET); + udelay(10); + + /* Enable AHB clock */ + mask = sdhci_readl(host, SDHCI_CORECTRL_OFFSET); + sdhci_writel(host, mask | SDHCI_CORECTRL_EN, SDHCI_CORECTRL_OFFSET); + + /* Enable interrupts */ + sdhci_writel(host, SDHCI_COREIMR_IP, SDHCI_COREIMR_OFFSET); + + /* Make sure Card is detected in controller */ + mask = sdhci_readl(host, SDHCI_CORESTAT_OFFSET); + sdhci_writel(host, mask | SDHCI_CORESTAT_CD_SW, SDHCI_CORESTAT_OFFSET); + + return 0; +} + +int kona_sdhci_init(int dev_index, u32 min_clk, u32 quirks) +{ + int ret = 0; + u32 max_clk; + void *reg_base; + struct sdhci_host *host = NULL; + + host = (struct sdhci_host *)malloc(sizeof(struct sdhci_host)); + if (!host) { + printf("%s: sdhci host malloc fail!\n", __func__); + return -ENOMEM; + } + switch (dev_index) { + case 0: + reg_base = (void *)CONFIG_SYS_SDIO_BASE0; + ret = clk_sdio_enable(reg_base, CONFIG_SYS_SDIO0_MAX_CLK, + &max_clk); + break; + case 1: + reg_base = (void *)CONFIG_SYS_SDIO_BASE1; + ret = clk_sdio_enable(reg_base, CONFIG_SYS_SDIO1_MAX_CLK, + &max_clk); + break; + case 2: + reg_base = (void *)CONFIG_SYS_SDIO_BASE2; + ret = clk_sdio_enable(reg_base, CONFIG_SYS_SDIO2_MAX_CLK, + &max_clk); + break; + case 3: + reg_base = (void *)CONFIG_SYS_SDIO_BASE3; + ret = clk_sdio_enable(reg_base, CONFIG_SYS_SDIO3_MAX_CLK, + &max_clk); + break; + default: + printf("%s: sdio dev index %d not supported\n", + __func__, dev_index); + ret = -EINVAL; + } + if (ret) + return ret; + + host->name = "kona-sdhci"; + host->ioaddr = reg_base; + host->quirks = quirks; + host->host_caps = MMC_MODE_HC; + + if (init_mmc_core(host)) + return -EINVAL; + + if (quirks & SDHCI_QUIRK_REG32_RW) + host->version = sdhci_readl(host, SDHCI_HOST_VERSION - 2) >> 16; + else + host->version = sdhci_readw(host, SDHCI_HOST_VERSION); + + add_sdhci(host, max_clk, min_clk); + return ret; +}
Add support for the bcm28155_ap reference board.
Signed-off-by: Darwin Rambo drambo@broadcom.com Reviewed-by: Steve Rae srae@broadcom.com Reviewed-by: Tim Kryger tkryger@linaro.org --- board/broadcom/bcm28155_ap/Makefile | 7 ++ board/broadcom/bcm28155_ap/bcm28155_ap.c | 99 ++++++++++++++++++++ boards.cfg | 1 + include/configs/bcm28155_ap.h | 148 ++++++++++++++++++++++++++++++ 4 files changed, 255 insertions(+) create mode 100644 board/broadcom/bcm28155_ap/Makefile create mode 100644 board/broadcom/bcm28155_ap/bcm28155_ap.c create mode 100644 include/configs/bcm28155_ap.h
diff --git a/board/broadcom/bcm28155_ap/Makefile b/board/broadcom/bcm28155_ap/Makefile new file mode 100644 index 0000000..b6159dc --- /dev/null +++ b/board/broadcom/bcm28155_ap/Makefile @@ -0,0 +1,7 @@ +# +# Copyright 2013 Broadcom Corporation. All rights reserved. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += $(BOARD).o diff --git a/board/broadcom/bcm28155_ap/bcm28155_ap.c b/board/broadcom/bcm28155_ap/bcm28155_ap.c new file mode 100644 index 0000000..b86dbda --- /dev/null +++ b/board/broadcom/bcm28155_ap/bcm28155_ap.c @@ -0,0 +1,99 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +#include <common.h> +#include <asm/io.h> +#include <asm/mach-types.h> +#include <mmc.h> +#include <asm/kona-common/misc.h> +#include <asm/kona-common/clk.h> +#include <asm/arch/sysmap.h> + +#define SECWATCHDOG_SDOGCR_OFFSET 0x00000000 +#define SECWATCHDOG_SDOGCR_EN_SHIFT 27 +#define SECWATCHDOG_SDOGCR_SRSTEN_SHIFT 26 +#define SECWATCHDOG_SDOGCR_CLKS_SHIFT 20 +#define SECWATCHDOG_SDOGCR_LD_SHIFT 0 + +DECLARE_GLOBAL_DATA_PTR; + +/***************************************** + * board_init - early hardware init + *****************************************/ +int board_init(void) +{ + printf("Relocation Offset is: %08lx\n", gd->reloc_off); + + /* adress of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + + clk_init(); + + return 0; +} + +/***************************************************************** + * misc_init_r - miscellaneous platform dependent initializations + ******************************************************************/ +int misc_init_r(void) +{ + /* Disable watchdog reset - watchdog unused */ + writel((0 << SECWATCHDOG_SDOGCR_EN_SHIFT) | + (0 << SECWATCHDOG_SDOGCR_SRSTEN_SHIFT) | + (4 << SECWATCHDOG_SDOGCR_CLKS_SHIFT) | + (0x5a0 << SECWATCHDOG_SDOGCR_LD_SHIFT), + (SECWD_BASE_ADDR + SECWATCHDOG_SDOGCR_OFFSET)); + + return 0; +} + +/********************************************** + * dram_init - sets uboots idea of sdram size + **********************************************/ +int dram_init(void) +{ + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + + return 0; +} + +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = CONFIG_SYS_SDRAM_SIZE; +} + +#ifdef CONFIG_KONA_SDHCI +/******************************************* + * mmc_init - Initializes mmc + *********************************************/ +int board_mmc_init(bd_t *bis) +{ + int ret = 0; + + /* Register eMMC - SDIO2 */ + ret = kona_sdhci_init(1, 400000, 0); + if (ret) + return ret; + + /* Register SD Card - SDIO4 kona_mmc_init assumes 0 based index */ + ret = kona_sdhci_init(3, 400000, 0); + return ret; +} +#endif + +/* + * The timer functionality is now in u-boot/lib/time.c, enabled with + * CONFIG_SYS_TIMER_COUNTER and CONFIG_SYS_TIMER_RATE + */ + +/* Replace by __weak timer_init() framework function later */ +int timer_init(void) +{ + return 0; +} diff --git a/boards.cfg b/boards.cfg index a8336cc..2105ecc 100644 --- a/boards.cfg +++ b/boards.cfg @@ -271,6 +271,7 @@ Active arm armv7 am33xx ti ti816x Active arm armv7 at91 atmel sama5d3xek sama5d3xek_mmc sama5d3xek:SAMA5D3,SYS_USE_MMC Bo Shen voice.shen@atmel.com Active arm armv7 at91 atmel sama5d3xek sama5d3xek_nandflash sama5d3xek:SAMA5D3,SYS_USE_NANDFLASH Bo Shen voice.shen@atmel.com Active arm armv7 at91 atmel sama5d3xek sama5d3xek_spiflash sama5d3xek:SAMA5D3,SYS_USE_SERIALFLASH Bo Shen voice.shen@atmel.com +Active arm armv7 bcm281xx broadcom bcm28155_ap bcm28155_ap bcm28155_ap Tim Kryger tim.kryger@linaro.org Active arm armv7 exynos samsung arndale arndale - Inderpal Singh inderpal.singh@linaro.org Active arm armv7 exynos samsung origen origen - Chander Kashyap k.chander@samsung.com Active arm armv7 exynos samsung smdk5250 smdk5250 - Chander Kashyap k.chander@samsung.com diff --git a/include/configs/bcm28155_ap.h b/include/configs/bcm28155_ap.h new file mode 100644 index 0000000..2df9390 --- /dev/null +++ b/include/configs/bcm28155_ap.h @@ -0,0 +1,148 @@ +/***************************************************************************** +* +* Copyright 2013 Broadcom Corporation. All rights reserved. +* +* SPDX-License-Identifier: GPL-2.0+ +* +*****************************************************************************/ + +#ifndef __BCM28155_AP_H +#define __BCM28155_AP_H + +#include <asm/sizes.h> +#include <asm/arch/sysmap.h> + +/* Architecture, CPU, chip, mach, etc */ +#define CONFIG_ARMV7 +#define CONFIG_KONA + +/* + * Memory configuration + */ +#define CONFIG_SYS_TEXT_BASE 0xae000000 + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_SDRAM_SIZE 0x80000000 +#define CONFIG_NR_DRAM_BANKS 1 + +#define CONFIG_SYS_MALLOC_LEN SZ_4M /* see armv7/start.S. */ +#define CONFIG_STACKSIZE SZ_256K + +/* GPIO Driver */ +#define CONFIG_KONA_GPIO + +/* MMC/SD Driver */ +#define CONFIG_SDHCI +#define CONFIG_MMC_SDMA +#define CONFIG_KONA_SDHCI +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC + +#define CONFIG_SYS_SDIO_BASE0 SDIO1_BASE_ADDR +#define CONFIG_SYS_SDIO_BASE1 SDIO2_BASE_ADDR +#define CONFIG_SYS_SDIO_BASE2 SDIO3_BASE_ADDR +#define CONFIG_SYS_SDIO_BASE3 SDIO4_BASE_ADDR +#define CONFIG_SYS_SDIO0_MAX_CLK 48000000 +#define CONFIG_SYS_SDIO1_MAX_CLK 48000000 +#define CONFIG_SYS_SDIO2_MAX_CLK 48000000 +#define CONFIG_SYS_SDIO3_MAX_CLK 48000000 +#define CONFIG_SYS_SDIO0 "sdio1" +#define CONFIG_SYS_SDIO1 "sdio2" +#define CONFIG_SYS_SDIO2 "sdio3" +#define CONFIG_SYS_SDIO3 "sdio4" + +/* I2C Driver */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_KONA +#define CONFIG_SYS_SPD_BUS_NUM 3 /* Start with PMU bus */ +#define CONFIG_SYS_MAX_I2C_BUS 4 +#define CONFIG_SYS_I2C_BASE0 BSC1_BASE_ADDR +#define CONFIG_SYS_I2C_BASE1 BSC2_BASE_ADDR +#define CONFIG_SYS_I2C_BASE2 BSC3_BASE_ADDR +#define CONFIG_SYS_I2C_BASE3 PMU_BSC_BASE_ADDR + +/* Timer Driver */ +#define CONFIG_SYS_TIMER_RATE 32000 +#define CONFIG_SYS_TIMER_COUNTER (TIMER_BASE_ADDR + 4) /* STCLO offset */ + +/* Init functions */ +#define CONFIG_MISC_INIT_R /* board's misc_init_r function */ + +/* Some commands use this as the default load address */ +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + +/* Memory testing range */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + SZ_1M) + +/* + * This is the initial SP which is used only briefly for relocating the u-boot + * image to the top of SDRAM. After relocation u-boot moves the stack to the + * proper place. + */ +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE + +/* Serial Info */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +/* Post pad 3 bytes after each reg addr */ +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK 13000000 +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550_COM1 0x3e000000 + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, \ + 115200, 230400, 460800, 921600} + +#define CONFIG_ENV_SIZE 0x10000 +#define CONFIG_ENV_IS_NOWHERE + +#define CONFIG_SYS_NO_FLASH /* Not using NAND/NOR unmanaged flash */ + +/* console configuration */ +#define CONFIG_SYS_CBSIZE 1024 /* Console buffer size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) /* Printbuffer size */ +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* + * One partition type must be defined for part.c + * This is necessary for the fatls command to work on an SD card + * for example. + */ +#define CONFIG_DOS_PARTITION + +/* version string, parser, etc */ +#define CONFIG_VERSION_VARIABLE +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_LONGHELP + +#define CONFIG_CRC32_VERIFY +#define CONFIG_MX_CYCLIC + +/* Initial upstream - boot to cmd prompt only */ +#define CONFIG_BOOTCOMMAND "" + +#define CONFIG_SYS_PROMPT "bcm28155_ap> " + +/* Commands */ +#include <config_cmd_default.h> +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_FAT +#define CONFIG_CMD_GPIO +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MEMTEST +#define CONFIG_CMD_MMC +#define CONFIG_CMD_BOOTZ +#define CONFIG_FAT_WRITE + +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS + +#endif /* __BCM28155_AP_H */
[snip]
- gd->ram_size = CONFIG_SYS_SDRAM_SIZE;
Please use get_ram_size(...);
Please see doc/README.memory-test
Unless you really use those higher values in U-Boot, please use the default table.
Unneeded now.
[snip]
We tried using this on our reference board and it hangs accessing memory regions that are not populated. Our memory controller doesn't appear to properly support accessing regions that are not backed by physical sdram. So I think it's best to keep this code as is and consider this approach for future designs.
OK. I think I'll disable CONFIG_CMD_MEMORY and remove this stuff.
OK
Unneeded now.
OK
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
[snip]
Wait, what did you do? get_ram_size(base, max) must work and return CONFIG_SYS_SDRAM_SIZE, or you haven't properly configured your controller (as get_ram_size just pokes parts of the specified range).
- -- Tom
Tom,
In my experience, there are three general ways memory controllers behave when an access is made to an address that could be backed by RAM but isn't on a particular board.
1. All reads return a fixed pattern and writes are ignored 2. A bus error is triggered that the CPU sees as a data abort 3. No response to the transaction so the bus and CPU lock up
I believe the Broadcom memory controller can only behave in the third, least desirable way.
Thanks, Tim Kryger
Tom,
- All reads return a fixed pattern and writes are ignored
- A bus error is triggered that the CPU sees as a data abort
- No response to the transaction so the bus and CPU lock up
That's fine. You should still use get_ram_size(base, CONFIG_SYS_SDRAM_SIZE) like other platforms use as this go above the max size it's given. If this hangs, you have a problem with your configuration of the memory controller. Make sense?
- -- Tom
Tom,
Yes. We have tested that this works and will implement this way. Thanks.
Tom -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.11 (GNU/Linux) Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQIcBAEBAgAGBQJS69oUAAoJENk4IS6UOR1Wf/AP/2ApLwjAffxJ7LmEFFEK7hlr +dq1FW9ZRppfLRbfUrZz8Q/muyrx1ZuF9pIjjrFxLkNSLS3t8LZrJmfeswePqGC+ dq6qLl+ovk0VNYsxEhS77j1QQ/LLri67QCiGEZuS8vDB7qxiyuuCXkzyyW8hRFZ7 yfKpbfdRYpzWTJhAYnB0b1OaBi1jamsnjhXNU5XNa/H3PfDDofNA2fFQQfKbleOH BVOka1LP/+28gqKksEziM9cbcjPYJdE/FfY75nkbqKl9PWl+qIUZli90QO3Qdbgy uJJB1d3v6amfHZYbJymR3r8FoRjjCKxnCza5rCLpwFLxAKCUIIGHBFUGpvdcFoVa YctuEu2Dx2SgQ9dEGbLT1d2bsbfxOATEr5CyCpD7vD/9e/Ze7XaXALVKocfQmDbs 77s0YvHuXLGQPudPzYrEqPvgxf/NlNjeLj5IWqF++AE3j5U1sE26x95qk8jobMSn KjYGwzsxnd/gErqiYBawkrHxS2f4beAucsoprCh0WmSXiqSh6Wzc/+XlAIVSV7vm UE969gAzP1F2j37QfWR2/B0ILP27Pk3Ano8Dj2MIVKCAVkkpSQ5SCqAA7wvMzHej 801O52kArhG3/G/WrAbeLoQxKsdUyNI92+T0UaquTI4hRZk5GSvHQNCaZAcx6fCa hZ1o6zG9nMsp/yzVe7VZ =0yIj -----END PGP SIGNATURE-----
On Mon, Jan 27, 2014 at 10:53:24AM -0800, Darwin Rambo wrote:
This patchset introduces the Broadcom bcm281xx family of mobile SoC chips. Broadcom kona hardware blocks are often found in Broadcom mobile SoC chips including the bcm281xx family, so support for some of these kona blocks is also provided here. These patches work on u-boot master as well as the u-boot-arm custodian tree.
Darwin Rambo (6): arch: kona: Initial commit of kona-common architecture code arch: bcm281xx: Initial commit of bcm281xx architecture code gpio: kona: Add Kona gpio driver i2c: kona: Add Kona I2C driver mmc: kona: Add Kona mmc driver board: bcm28155_ap: Add board files
Thanks for posting. Globally, please don't introduce another style for the file header, /* * This works * just fine. * * Including what the file is about */
And I also see the incorrect style sprinkled throughout.
I saw some '#define<tab>' mixed in with '#define<space>', and some other things I'd have sworn checkpatch complains about, so please make sure things are checkpatch clean (except for very long printed strings, which are an exception to line length rules).
Finally, please CC the custodians for i2c/mmc for those drivers as they may have further comments than the above list.
Thanks!
- This works
- just fine.
- Including what the file is about
OK - legacy stuff will be fixed.
Well, checkpatch was clean, so I think there's a problem with the tool. Another minor gripe is that checkpatch and "indent -linux" don't agree on everything, "int * foo" being one of them. :)
OK. There are mmc, i2c and gpio drivers. I assume each driver gets a different CC:?
Thanks!
Thanks to you too!
[snip]
Yes, see the Custodians wiki page.
- -- Tom
Darwin Rambo
Matt Porter
Tim Kryger
