[PATCH] doc: usage: Group all shell command docs into cmd/ sub-direcotry
Currently all shell command docs are put in the doc/usage root. Let's group them into cmd/ sub-direcotry.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
doc/usage/{ => cmd}/acpi.rst | 0 doc/usage/{ => cmd}/addrmap.rst | 0 doc/usage/{ => cmd}/askenv.rst | 0 doc/usage/{ => cmd}/base.rst | 0 doc/usage/{ => cmd}/bootefi.rst | 0 doc/usage/{ => cmd}/booti.rst | 0 doc/usage/{ => cmd}/bootmenu.rst | 0 doc/usage/{ => cmd}/button.rst | 0 doc/usage/{x86 => cmd}/cbsysinfo.rst | 0 doc/usage/{ => cmd}/conitrace.rst | 0 doc/usage/{ => cmd}/echo.rst | 0 doc/usage/{ => cmd}/exception.rst | 0 doc/usage/{ => cmd}/exit.rst | 0 doc/usage/{ => cmd}/extension.rst | 0 doc/usage/{ => cmd}/false.rst | 0 doc/usage/{ => cmd}/fatinfo.rst | 0 doc/usage/{ => cmd}/fatload.rst | 0 doc/usage/{ => cmd}/for.rst | 0 doc/usage/{ => cmd}/load.rst | 0 doc/usage/{ => cmd}/loady.rst | 0 doc/usage/{ => cmd}/mbr.rst | 0 doc/usage/{ => cmd}/md.rst | 0 doc/usage/{ => cmd}/mmc.rst | 0 doc/usage/{ => cmd}/pinmux.rst | 0 doc/usage/{ => cmd}/pstore.rst | 0 doc/usage/{ => cmd}/qfw.rst | 0 doc/usage/{ => cmd}/reset.rst | 0 doc/usage/{ => cmd}/sbi.rst | 0 doc/usage/{ => cmd}/scp03.rst | 0 doc/usage/{ => cmd}/setexpr.rst | 0 doc/usage/{ => cmd}/sf.rst | 0 doc/usage/{ => cmd}/size.rst | 0 doc/usage/{ => cmd}/true.rst | 0 doc/usage/{ => cmd}/ums.rst | 0 doc/usage/index.rst | 68 ++++++++++++++-------------- 35 files changed, 34 insertions(+), 34 deletions(-) rename doc/usage/{ => cmd}/acpi.rst (100%) rename doc/usage/{ => cmd}/addrmap.rst (100%) rename doc/usage/{ => cmd}/askenv.rst (100%) rename doc/usage/{ => cmd}/base.rst (100%) rename doc/usage/{ => cmd}/bootefi.rst (100%) rename doc/usage/{ => cmd}/booti.rst (100%) rename doc/usage/{ => cmd}/bootmenu.rst (100%) rename doc/usage/{ => cmd}/button.rst (100%) rename doc/usage/{x86 => cmd}/cbsysinfo.rst (100%) rename doc/usage/{ => cmd}/conitrace.rst (100%) rename doc/usage/{ => cmd}/echo.rst (100%) rename doc/usage/{ => cmd}/exception.rst (100%) rename doc/usage/{ => cmd}/exit.rst (100%) rename doc/usage/{ => cmd}/extension.rst (100%) rename doc/usage/{ => cmd}/false.rst (100%) rename doc/usage/{ => cmd}/fatinfo.rst (100%) rename doc/usage/{ => cmd}/fatload.rst (100%) rename doc/usage/{ => cmd}/for.rst (100%) rename doc/usage/{ => cmd}/load.rst (100%) rename doc/usage/{ => cmd}/loady.rst (100%) rename doc/usage/{ => cmd}/mbr.rst (100%) rename doc/usage/{ => cmd}/md.rst (100%) rename doc/usage/{ => cmd}/mmc.rst (100%) rename doc/usage/{ => cmd}/pinmux.rst (100%) rename doc/usage/{ => cmd}/pstore.rst (100%) rename doc/usage/{ => cmd}/qfw.rst (100%) rename doc/usage/{ => cmd}/reset.rst (100%) rename doc/usage/{ => cmd}/sbi.rst (100%) rename doc/usage/{ => cmd}/scp03.rst (100%) rename doc/usage/{ => cmd}/setexpr.rst (100%) rename doc/usage/{ => cmd}/sf.rst (100%) rename doc/usage/{ => cmd}/size.rst (100%) rename doc/usage/{ => cmd}/true.rst (100%) rename doc/usage/{ => cmd}/ums.rst (100%)
diff --git a/doc/usage/acpi.rst b/doc/usage/cmd/acpi.rst similarity index 100% rename from doc/usage/acpi.rst rename to doc/usage/cmd/acpi.rst diff --git a/doc/usage/addrmap.rst b/doc/usage/cmd/addrmap.rst similarity index 100% rename from doc/usage/addrmap.rst rename to doc/usage/cmd/addrmap.rst diff --git a/doc/usage/askenv.rst b/doc/usage/cmd/askenv.rst similarity index 100% rename from doc/usage/askenv.rst rename to doc/usage/cmd/askenv.rst diff --git a/doc/usage/base.rst b/doc/usage/cmd/base.rst similarity index 100% rename from doc/usage/base.rst rename to doc/usage/cmd/base.rst diff --git a/doc/usage/bootefi.rst b/doc/usage/cmd/bootefi.rst similarity index 100% rename from doc/usage/bootefi.rst rename to doc/usage/cmd/bootefi.rst diff --git a/doc/usage/booti.rst b/doc/usage/cmd/booti.rst similarity index 100% rename from doc/usage/booti.rst rename to doc/usage/cmd/booti.rst diff --git a/doc/usage/bootmenu.rst b/doc/usage/cmd/bootmenu.rst similarity index 100% rename from doc/usage/bootmenu.rst rename to doc/usage/cmd/bootmenu.rst diff --git a/doc/usage/button.rst b/doc/usage/cmd/button.rst similarity index 100% rename from doc/usage/button.rst rename to doc/usage/cmd/button.rst diff --git a/doc/usage/x86/cbsysinfo.rst b/doc/usage/cmd/cbsysinfo.rst similarity index 100% rename from doc/usage/x86/cbsysinfo.rst rename to doc/usage/cmd/cbsysinfo.rst diff --git a/doc/usage/conitrace.rst b/doc/usage/cmd/conitrace.rst similarity index 100% rename from doc/usage/conitrace.rst rename to doc/usage/cmd/conitrace.rst diff --git a/doc/usage/echo.rst b/doc/usage/cmd/echo.rst similarity index 100% rename from doc/usage/echo.rst rename to doc/usage/cmd/echo.rst diff --git a/doc/usage/exception.rst b/doc/usage/cmd/exception.rst similarity index 100% rename from doc/usage/exception.rst rename to doc/usage/cmd/exception.rst diff --git a/doc/usage/exit.rst b/doc/usage/cmd/exit.rst similarity index 100% rename from doc/usage/exit.rst rename to doc/usage/cmd/exit.rst diff --git a/doc/usage/extension.rst b/doc/usage/cmd/extension.rst similarity index 100% rename from doc/usage/extension.rst rename to doc/usage/cmd/extension.rst diff --git a/doc/usage/false.rst b/doc/usage/cmd/false.rst similarity index 100% rename from doc/usage/false.rst rename to doc/usage/cmd/false.rst diff --git a/doc/usage/fatinfo.rst b/doc/usage/cmd/fatinfo.rst similarity index 100% rename from doc/usage/fatinfo.rst rename to doc/usage/cmd/fatinfo.rst diff --git a/doc/usage/fatload.rst b/doc/usage/cmd/fatload.rst similarity index 100% rename from doc/usage/fatload.rst rename to doc/usage/cmd/fatload.rst diff --git a/doc/usage/for.rst b/doc/usage/cmd/for.rst similarity index 100% rename from doc/usage/for.rst rename to doc/usage/cmd/for.rst diff --git a/doc/usage/load.rst b/doc/usage/cmd/load.rst similarity index 100% rename from doc/usage/load.rst rename to doc/usage/cmd/load.rst diff --git a/doc/usage/loady.rst b/doc/usage/cmd/loady.rst similarity index 100% rename from doc/usage/loady.rst rename to doc/usage/cmd/loady.rst diff --git a/doc/usage/mbr.rst b/doc/usage/cmd/mbr.rst similarity index 100% rename from doc/usage/mbr.rst rename to doc/usage/cmd/mbr.rst diff --git a/doc/usage/md.rst b/doc/usage/cmd/md.rst similarity index 100% rename from doc/usage/md.rst rename to doc/usage/cmd/md.rst diff --git a/doc/usage/mmc.rst b/doc/usage/cmd/mmc.rst similarity index 100% rename from doc/usage/mmc.rst rename to doc/usage/cmd/mmc.rst diff --git a/doc/usage/pinmux.rst b/doc/usage/cmd/pinmux.rst similarity index 100% rename from doc/usage/pinmux.rst rename to doc/usage/cmd/pinmux.rst diff --git a/doc/usage/pstore.rst b/doc/usage/cmd/pstore.rst similarity index 100% rename from doc/usage/pstore.rst rename to doc/usage/cmd/pstore.rst diff --git a/doc/usage/qfw.rst b/doc/usage/cmd/qfw.rst similarity index 100% rename from doc/usage/qfw.rst rename to doc/usage/cmd/qfw.rst diff --git a/doc/usage/reset.rst b/doc/usage/cmd/reset.rst similarity index 100% rename from doc/usage/reset.rst rename to doc/usage/cmd/reset.rst diff --git a/doc/usage/sbi.rst b/doc/usage/cmd/sbi.rst similarity index 100% rename from doc/usage/sbi.rst rename to doc/usage/cmd/sbi.rst diff --git a/doc/usage/scp03.rst b/doc/usage/cmd/scp03.rst similarity index 100% rename from doc/usage/scp03.rst rename to doc/usage/cmd/scp03.rst diff --git a/doc/usage/setexpr.rst b/doc/usage/cmd/setexpr.rst similarity index 100% rename from doc/usage/setexpr.rst rename to doc/usage/cmd/setexpr.rst diff --git a/doc/usage/sf.rst b/doc/usage/cmd/sf.rst similarity index 100% rename from doc/usage/sf.rst rename to doc/usage/cmd/sf.rst diff --git a/doc/usage/size.rst b/doc/usage/cmd/size.rst similarity index 100% rename from doc/usage/size.rst rename to doc/usage/cmd/size.rst diff --git a/doc/usage/true.rst b/doc/usage/cmd/true.rst similarity index 100% rename from doc/usage/true.rst rename to doc/usage/cmd/true.rst diff --git a/doc/usage/ums.rst b/doc/usage/cmd/ums.rst similarity index 100% rename from doc/usage/ums.rst rename to doc/usage/cmd/ums.rst diff --git a/doc/usage/index.rst b/doc/usage/index.rst index ecb4908fd1..5c5fbf51b8 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -18,40 +18,40 @@ Shell commands .. toctree:: :maxdepth: 1
- acpi - addrmap - askenv - base - bootefi - booti - bootmenu - button - x86/cbsysinfo - conitrace - echo - exception - extension - exit - false - fatinfo - fatload - for - load - loady - mbr - md - mmc - pinmux - pstore - qfw - reset - sbi - sf - scp03 - setexpr - size - true - ums + cmd/acpi + cmd/addrmap + cmd/askenv + cmd/base + cmd/bootefi + cmd/booti + cmd/bootmenu + cmd/button + cmd/cbsysinfo + cmd/conitrace + cmd/echo + cmd/exception + cmd/extension + cmd/exit + cmd/false + cmd/fatinfo + cmd/fatload + cmd/for + cmd/load + cmd/loady + cmd/mbr + cmd/md + cmd/mmc + cmd/pinmux + cmd/pstore + cmd/qfw + cmd/reset + cmd/sbi + cmd/sf + cmd/scp03 + cmd/setexpr + cmd/size + cmd/true + cmd/ums
Booting OS ----------
%s/direcotry/directory/
I will fix that.
wdt.rst was added recently.
I will fix that when merging.
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
- acpi
- addrmap
- askenv
- base
- bootefi
- booti
- bootmenu
- button
- x86/cbsysinfo
- conitrace
- echo
- exception
- extension
- exit
- false
- fatinfo
- fatload
- for
- load
- loady
- mbr
- md
- mmc
- pinmux
- pstore
- qfw
- reset
- sbi
- sf
- scp03
- setexpr
- size
- true
- ums
cmd/acpi
cmd/addrmap
cmd/askenv
cmd/base
cmd/bootefi
cmd/booti
cmd/bootmenu
cmd/button
cmd/cbsysinfo
cmd/conitrace
cmd/echo
cmd/exception
cmd/extension
cmd/exit
cmd/false
cmd/fatinfo
cmd/fatload
cmd/for
cmd/load
cmd/loady
cmd/mbr
cmd/md
cmd/mmc
cmd/pinmux
cmd/pstore
cmd/qfw
cmd/reset
cmd/sbi
cmd/sf
cmd/scp03
cmd/setexpr
cmd/size
cmd/true
cmd/ums
Booting OS
Bin Meng
