[PATCH] net: macb: Add support for fixed link
From: BELOUARGA Mohamed m.belouarga@technologyandstrategy.com
The actual driver does not work when there is no linked PHY. These changes add support for fixed-link feature in the device tree.
Signed-off-by: BELOUARGA Mohamed m.belouarga@technologyandstrategy.com --- drivers/net/macb.c | 189 ++++++++++++++++++++++++++++----------------- 1 file changed, 117 insertions(+), 72 deletions(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index bfc48dac07..05d638cd77 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -128,6 +128,8 @@ struct macb_device { unsigned long dummy_desc_dma;
const struct device *dev; + unsigned int duplex; + unsigned int speed; unsigned short phy_addr; struct mii_dev *bus; #ifdef CONFIG_PHYLIB @@ -178,6 +180,12 @@ static int gem_is_gigabit_capable(struct macb_device *macb) return macb_is_gem(macb) && !cpu_is_sama5d2() && !cpu_is_sama5d4(); }
+/* Is the port a fixed link */ +static int macb_port_is_fixed_link(struct macb_device *macb) +{ + return macb->phy_addr > PHY_MAX_ADDR; +} + static void macb_mdio_write(struct macb_device *macb, u8 phy_adr, u8 reg, u16 value) { @@ -666,97 +674,110 @@ static int macb_phy_init(struct udevice *dev, const char *name) int i;
arch_get_mdio_control(name); - /* Auto-detect phy_addr */ - ret = macb_phy_find(macb, name); - if (ret) - return ret; + /* If port is not fixed -> setup PHY */ + if (!macb_port_is_fixed_link(macb)) { + /* Auto-detect phy_addr */ + ret = macb_phy_find(macb, name); + if (ret) + return ret;
- /* Check if the PHY is up to snuff... */ - phy_id = macb_mdio_read(macb, macb->phy_addr, MII_PHYSID1); - if (phy_id == 0xffff) { - printf("%s: No PHY present\n", name); - return -ENODEV; - } + /* Check if the PHY is up to snuff... */ + phy_id = macb_mdio_read(macb, macb->phy_addr, MII_PHYSID1); + if (phy_id == 0xffff) { + printf("%s: No PHY present\n", name); + return -ENODEV; + }
#ifdef CONFIG_PHYLIB - macb->phydev = phy_connect(macb->bus, macb->phy_addr, dev, - macb->phy_interface); - if (!macb->phydev) { - printf("phy_connect failed\n"); - return -ENODEV; - } + macb->phydev = phy_connect(macb->bus, macb->phy_addr, dev, + macb->phy_interface); + if (!macb->phydev) { + printf("phy_connect failed\n"); + return -ENODEV; + }
- phy_config(macb->phydev); + phy_config(macb->phydev); #endif
- status = macb_mdio_read(macb, macb->phy_addr, MII_BMSR); - if (!(status & BMSR_LSTATUS)) { - /* Try to re-negotiate if we don't have link already. */ - macb_phy_reset(macb, name); - - for (i = 0; i < MACB_AUTONEG_TIMEOUT / 100; i++) { - status = macb_mdio_read(macb, macb->phy_addr, MII_BMSR); - if (status & BMSR_LSTATUS) { - /* - * Delay a bit after the link is established, - * so that the next xfer does not fail - */ - mdelay(10); - break; + status = macb_mdio_read(macb, macb->phy_addr, MII_BMSR); + if (!(status & BMSR_LSTATUS)) { + /* Try to re-negotiate if we don't have link already. */ + macb_phy_reset(macb, name); + + for (i = 0; i < MACB_AUTONEG_TIMEOUT / 100; i++) { + status = macb_mdio_read(macb, macb->phy_addr, MII_BMSR); + if (status & BMSR_LSTATUS) { + /* + * Delay a bit after the link is established, + * so that the next xfer does not fail + */ + mdelay(10); + break; + } + udelay(100); } - udelay(100); } - }
- if (!(status & BMSR_LSTATUS)) { - printf("%s: link down (status: 0x%04x)\n", - name, status); - return -ENETDOWN; - } + if (!(status & BMSR_LSTATUS)) { + printf("%s: link down (status: 0x%04x)\n", + name, status); + return -ENETDOWN; + }
- /* First check for GMAC and that it is GiB capable */ - if (gem_is_gigabit_capable(macb)) { - lpa = macb_mdio_read(macb, macb->phy_addr, MII_STAT1000); + /* First check for GMAC and that it is GiB capable */ + if (gem_is_gigabit_capable(macb)) { + lpa = macb_mdio_read(macb, macb->phy_addr, MII_STAT1000);
- if (lpa & (LPA_1000FULL | LPA_1000HALF | LPA_1000XFULL | - LPA_1000XHALF)) { - duplex = ((lpa & (LPA_1000FULL | LPA_1000XFULL)) ? - 1 : 0); + if (lpa & (LPA_1000FULL | LPA_1000HALF | LPA_1000XFULL | + LPA_1000XHALF)) { + duplex = ((lpa & (LPA_1000FULL | LPA_1000XFULL)) ? + 1 : 0);
- printf("%s: link up, 1000Mbps %s-duplex (lpa: 0x%04x)\n", - name, - duplex ? "full" : "half", - lpa); + printf("%s: link up, 1000Mbps %s-duplex (lpa: 0x%04x)\n", + name, + duplex ? "full" : "half", + lpa);
- ncfgr = macb_readl(macb, NCFGR); - ncfgr &= ~(MACB_BIT(SPD) | MACB_BIT(FD)); - ncfgr |= GEM_BIT(GBE); + ncfgr = macb_readl(macb, NCFGR); + ncfgr &= ~(MACB_BIT(SPD) | MACB_BIT(FD)); + ncfgr |= GEM_BIT(GBE);
- if (duplex) - ncfgr |= MACB_BIT(FD); + if (duplex) + ncfgr |= MACB_BIT(FD);
- macb_writel(macb, NCFGR, ncfgr); + macb_writel(macb, NCFGR, ncfgr);
- ret = macb_linkspd_cb(dev, _1000BASET); - if (ret) - return ret; + ret = macb_linkspd_cb(dev, _1000BASET); + if (ret) + return ret;
- return 0; + return 0; + } } - }
- /* fall back for EMAC checking */ - adv = macb_mdio_read(macb, macb->phy_addr, MII_ADVERTISE); - lpa = macb_mdio_read(macb, macb->phy_addr, MII_LPA); - media = mii_nway_result(lpa & adv); - speed = (media & (ADVERTISE_100FULL | ADVERTISE_100HALF) - ? 1 : 0); - duplex = (media & ADVERTISE_FULL) ? 1 : 0; - printf("%s: link up, %sMbps %s-duplex (lpa: 0x%04x)\n", - name, - speed ? "100" : "10", - duplex ? "full" : "half", - lpa); + /* fall back for EMAC checking */ + adv = macb_mdio_read(macb, macb->phy_addr, MII_ADVERTISE); + lpa = macb_mdio_read(macb, macb->phy_addr, MII_LPA); + media = mii_nway_result(lpa & adv); + speed = (media & (ADVERTISE_100FULL | ADVERTISE_100HALF) + ? 1 : 0); + duplex = (media & ADVERTISE_FULL) ? 1 : 0; + printf("%s: link up, %sMbps %s-duplex (lpa: 0x%04x)\n", + name, + speed ? "100" : "10", + duplex ? "full" : "half", + lpa); + } + else { + /* if macb port is a fixed link */ + /* TODO : manage gigabit capable processors */ + speed = macb->speed; + duplex = macb->duplex; + printf("%s: link up, %sMbps %s-duplex\n", + name, + speed ? "100" : "10", + duplex ? "full" : "half"); + }
ncfgr = macb_readl(macb, NCFGR); ncfgr &= ~(MACB_BIT(SPD) | MACB_BIT(FD) | GEM_BIT(GBE)); @@ -1276,6 +1297,30 @@ int __weak macb_late_eth_of_to_plat(struct udevice *dev) static int macb_eth_of_to_plat(struct udevice *dev) { struct eth_pdata *pdata = dev_get_plat(dev); + struct macb_device *macb = dev_get_priv(dev); + void *blob = (void *)gd->fdt_blob; + int node = dev_of_offset(dev); + int fl_node, speed_fdt; + + /* fetch 'fixed-link' property */ + fl_node = fdt_subnode_offset(blob, node, "fixed-link"); + if (fl_node >= 0) { + /* set phy_addr to invalid value for fixed link */ + macb->phy_addr = PHY_MAX_ADDR + 1; + macb->duplex = fdtdec_get_bool(blob, fl_node, "full-duplex"); + speed_fdt = fdtdec_get_int(blob, fl_node, "speed", 0); + if (speed_fdt == 100) { + macb->speed = 1; + } + else if (speed_fdt == 10) { + macb->speed = 0; + } + else { + printf("%s: The given speed %d of ethernet in the DT is not supported\n", + __func__, speed_fdt); + return -EINVAL; + } + }
pdata->iobase = (uintptr_t)dev_remap_addr(dev); if (!pdata->iobase)
