[PATCH] arm64: zynqmp: Align #address/size-cells with node
zynqmp-mini-nand wasn't aligned with dt binding that's why fix it.
Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/arm/dts/zynqmp-mini-nand.dts | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/zynqmp-mini-nand.dts b/arch/arm/dts/zynqmp-mini-nand.dts index 5889d436edb8..e08a7840d8e1 100644 --- a/arch/arm/dts/zynqmp-mini-nand.dts +++ b/arch/arm/dts/zynqmp-mini-nand.dts @@ -46,8 +46,8 @@ status = "okay"; reg = <0x0 0xff100000 0x1000>; clock-names = "clk_sys", "clk_flash"; - #address-cells = <2>; - #size-cells = <1>; + #address-cells = <1>; + #size-cells = <0>; arasan,has-mdma; num-cs = <2>; nand@0 {
#size-cells = <1>;
Applied. M
Michal Simek
