[U-Boot] [PATCH v2] gpio: xilinx: Not read output values via regs
Reading registers for finding out output value is not working because input value is read instead in case of tristate.
Reported-by: Stefan Herbrechtsmeier stefan@herbrechtsmeier.net Signed-off-by: Michal Simek michal.simek@xilinx.com ---
Changes in v2: - Rebased on the top of reviewed patches - Change logic in xilinx_gpio_get_value()
drivers/gpio/xilinx_gpio.c | 36 ++++++++++++++++++++++++++++++++---- 1 file changed, 32 insertions(+), 4 deletions(-)
diff --git a/drivers/gpio/xilinx_gpio.c b/drivers/gpio/xilinx_gpio.c index da50d1634570..4b4bf651642c 100644 --- a/drivers/gpio/xilinx_gpio.c +++ b/drivers/gpio/xilinx_gpio.c @@ -25,6 +25,11 @@ struct xilinx_gpio_platdata { int bank_max[XILINX_GPIO_MAX_BANK]; int bank_input[XILINX_GPIO_MAX_BANK]; int bank_output[XILINX_GPIO_MAX_BANK]; + u32 dout_default[XILINX_GPIO_MAX_BANK]; +}; + +struct xilinx_gpio_privdata { + u32 output_val[XILINX_GPIO_MAX_BANK]; };
static int xilinx_gpio_get_bank_pin(unsigned offset, u32 *bank_num, @@ -54,6 +59,7 @@ static int xilinx_gpio_set_value(struct udevice *dev, unsigned offset, int value) { struct xilinx_gpio_platdata *platdata = dev_get_platdata(dev); + struct xilinx_gpio_privdata *priv = dev_get_priv(dev); int val, ret; u32 bank, pin;
@@ -61,10 +67,10 @@ static int xilinx_gpio_set_value(struct udevice *dev, unsigned offset, if (ret) return ret;
- val = readl(&platdata->regs->gpiodata + bank * 2); + val = priv->output_val[bank];
- debug("%s: regs: %lx, value: %x, gpio: %x, bank %x, pin %x\n", - __func__, (ulong)platdata->regs, value, offset, bank, pin); + debug("%s: regs: %lx, value: %x, gpio: %x, bank %x, pin %x, out %x\n", + __func__, (ulong)platdata->regs, value, offset, bank, pin, val);
if (value) val = val | (1 << pin); @@ -73,12 +79,15 @@ static int xilinx_gpio_set_value(struct udevice *dev, unsigned offset,
writel(val, &platdata->regs->gpiodata + bank * 2);
+ priv->output_val[bank] = val; + return val; };
static int xilinx_gpio_get_value(struct udevice *dev, unsigned offset) { struct xilinx_gpio_platdata *platdata = dev_get_platdata(dev); + struct xilinx_gpio_privdata *priv = dev_get_priv(dev); int val, ret; u32 bank, pin;
@@ -89,7 +98,14 @@ static int xilinx_gpio_get_value(struct udevice *dev, unsigned offset) debug("%s: regs: %lx, gpio: %x, bank %x, pin %x\n", __func__, (ulong)platdata->regs, offset, bank, pin);
- val = readl(&platdata->regs->gpiodata + bank * 2); + if (platdata->bank_output[bank]) { + debug("%s: Read saved output value\n", __func__); + val = priv->output_val[bank]; + } else { + debug("%s: Read input value from reg\n", __func__); + val = readl(&platdata->regs->gpiodata + bank * 2); + } + val = !!(val & (1 << pin));
return val; @@ -223,6 +239,7 @@ static const struct dm_gpio_ops xilinx_gpio_ops = { static int xilinx_gpio_probe(struct udevice *dev) { struct xilinx_gpio_platdata *platdata = dev_get_platdata(dev); + struct xilinx_gpio_privdata *priv = dev_get_priv(dev); struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); const void *label_ptr; void *label_c; @@ -239,6 +256,11 @@ static int xilinx_gpio_probe(struct udevice *dev)
uc_priv->gpio_count = platdata->bank_max[0] + platdata->bank_max[1];
+ priv->output_val[0] = platdata->dout_default[0]; + + if (platdata->bank_max[1]) + priv->output_val[1] = platdata->dout_default[1]; + return 0; }
@@ -255,6 +277,9 @@ static int xilinx_gpio_ofdata_to_platdata(struct udevice *dev) "xlnx,all-inputs", 0); platdata->bank_output[0] = dev_read_u32_default(dev, "xlnx,all-outputs", 0); + platdata->dout_default[0] = dev_read_u32_default(dev, + "xlnx,dout-default", + 0);
is_dual = dev_read_u32_default(dev, "xlnx,is-dual", 0); if (is_dual) { @@ -264,6 +289,8 @@ static int xilinx_gpio_ofdata_to_platdata(struct udevice *dev) "xlnx,all-inputs-2", 0); platdata->bank_output[1] = dev_read_u32_default(dev, "xlnx,all-outputs-2", 0); + platdata->dout_default[1] = dev_read_u32_default(dev, + "xlnx,dout-default-2", 0); }
return 0; @@ -282,4 +309,5 @@ U_BOOT_DRIVER(xilinx_gpio) = { .ofdata_to_platdata = xilinx_gpio_ofdata_to_platdata, .probe = xilinx_gpio_probe, .platdata_auto_alloc_size = sizeof(struct xilinx_gpio_platdata), + .priv_auto_alloc_size = sizeof(struct xilinx_gpio_privdata), };
Am 02.08.2018 um 14:54 schrieb Michal Simek:
Changes in v2:
- u32 dout_default[XILINX_GPIO_MAX_BANK];
- struct xilinx_gpio_privdata *priv = dev_get_priv(dev); int val, ret; u32 bank, pin;
- val = priv->output_val[bank];
- priv->output_val[bank] = val;
- return val;
The return value is wrong. But this isn't related to this patch.
} else {
return val;
- struct xilinx_gpio_privdata *priv = dev_get_priv(dev); struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); const void *label_ptr; void *label_c;
- priv->output_val[0] = platdata->dout_default[0];
- if (platdata->bank_max[1])
- return 0; }
0);
- .priv_auto_alloc_size = sizeof(struct xilinx_gpio_privdata), };
Reviewed-by: Stefan Herbrechtsmeier stefan@herbrechtsmeier.net
Michal Simek
